[mapguide-commits] r5538 - trunk/MgDev/Common/Foundation/Data
svn_mapguide at osgeo.org
Tue Feb 8 16:15:06 EST 2011
Author: brucedechant
Date: 2011-02-08 13:15:06 -0800 (Tue, 08 Feb 2011)
New Revision: 5538
trunk/MgDev/Common/Foundation/Data/Byte.cpp
trunk/MgDev/Common/Foundation/Data/Byte.h
trunk/MgDev/Common/Foundation/Data/ByteSink.cpp
Fix for trac ticket 1597 - Remove 16MB memory size restriction on MgByte
http://trac.osgeo.org/mapguide/ticket/1597
Notes:
- Removed the 16MB memory size restriction on MgByte
Modified: trunk/MgDev/Common/Foundation/Data/Byte.cpp
--- trunk/MgDev/Common/Foundation/Data/Byte.cpp 2011-02-06 06:11:01 UTC (rev 5537)
+++ trunk/MgDev/Common/Foundation/Data/Byte.cpp 2011-02-08 21:15:06 UTC (rev 5538)
@@ -29,7 +29,7 @@
MgByte::MgByte(BYTE_ARRAY_IN bytes, INT32 len, AllocatorType allocator)
: m_allocType(allocator)
- if (len > MgByte::MaxSize && allocator != MgByte::None)
+ if (allocator != MgByte::None)
throw new MgArgumentOutOfRangeException(L"MgByte.MgByte", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -99,11 +99,6 @@
throw new MgInvalidOperationException(L"MgByte.Append", __LINE__, __WFILE__, NULL, L"", NULL);
- if (len+m_len > MgByte::MaxSize)
- throw new MgArgumentOutOfRangeException(L"MgByte.Append", __LINE__, __WFILE__, NULL, L"", NULL);
if (len+m_len > m_allocLen)
// Use geometric allocation
Modified: trunk/MgDev/Common/Foundation/Data/Byte.h
--- trunk/MgDev/Common/Foundation/Data/Byte.h 2011-02-06 06:11:01 UTC (rev 5537)
+++ trunk/MgDev/Common/Foundation/Data/Byte.h 2011-02-08 21:15:06 UTC (rev 5538)
@@ -28,18 +28,15 @@
public:
/// \brief
- /// Maximum size of an MgByte array.
+ /// Maximum size of an MgByte array created by the MgStreamReader.
/// \remarks
- /// This is a hard limitation
- /// intended to stop any "piggy" algorithms that allocate too much data
- /// around in one chunk. If you need to allocate more than 16 megs
- /// of memory for a byte array then there is probably a better way to do
- /// what your are intending.
+ /// This value is only used by MgStreamReader to control when a
+ /// file based stream should be used instead of a memory based one.
/// \todo
/// This parameter should be tunable from the configuration file
- static const INT64 MaxSize = 16*1024*1024;
+ static const INT64 MaxSize = 64*1024*1024;
/// \brief
Modified: trunk/MgDev/Common/Foundation/Data/ByteSink.cpp
--- trunk/MgDev/Common/Foundation/Data/ByteSink.cpp 2011-02-06 06:11:01 UTC (rev 5537)
+++ trunk/MgDev/Common/Foundation/Data/ByteSink.cpp 2011-02-08 21:15:06 UTC (rev 5538)
@@ -148,12 +148,6 @@
- if (m_reader->GetLength() > MgByte::MaxSize)
- throw new MgArgumentOutOfRangeException(L"MgByteSink.ToBuffer",
- __LINE__, __WFILE__, NULL, L"", NULL);
Ptr<MgByte> bytes;
// See if we are sourced from an MgByte. If we are, just pass it back.
More information about the mapguide-commits
