[mapguide-commits] r5540 - sandbox/adsk/2.3r/Web/src/mapadmin/HelpDocs
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Feb 9 01:44:24 EST 2011
Author: christinebao
Date: 2011-02-08 22:44:24 -0800 (Tue, 08 Feb 2011)
New Revision: 5540
   sandbox/adsk/2.3r/Web/src/mapadmin/HelpDocs/about_packages.htm
   sandbox/adsk/2.3r/Web/src/mapadmin/HelpDocs/about_users_groups_and_roles.htm
   sandbox/adsk/2.3r/Web/src/mapadmin/HelpDocs/managing_packages.htm
Fix ticket http://trac.osgeo.org/mapguide/ticket/1587
Update name for Studio
Modified: sandbox/adsk/2.3r/Web/src/mapadmin/HelpDocs/about_packages.htm
--- sandbox/adsk/2.3r/Web/src/mapadmin/HelpDocs/about_packages.htm	2011-02-09 06:33:58 UTC (rev 5539)
+++ sandbox/adsk/2.3r/Web/src/mapadmin/HelpDocs/about_packages.htm	2011-02-09 06:44:24 UTC (rev 5540)
@@ -149,7 +149,7 @@
       <div class="rule">
         <hr color="#464646" NOSHADE size="1" width="100%">
         <p>You can create data packages (.mgp files) here in the Site Administrator
-          or during the process of loading file-based data in MapGuide Studio.
+          or during the process of loading file-based data in Autodesk Infrastructure Studio.
           Large collections of source-data files can be zipped up in this file
           format and saved for easy transport. You can use packages to load data
           onto the site when a standard load procedure fails on very large files
Modified: sandbox/adsk/2.3r/Web/src/mapadmin/HelpDocs/about_users_groups_and_roles.htm
--- sandbox/adsk/2.3r/Web/src/mapadmin/HelpDocs/about_users_groups_and_roles.htm	2011-02-09 06:33:58 UTC (rev 5539)
+++ sandbox/adsk/2.3r/Web/src/mapadmin/HelpDocs/about_users_groups_and_roles.htm	2011-02-09 06:44:24 UTC (rev 5540)
@@ -152,7 +152,7 @@
       <br>
       <font size="2">Roles control what users can do. For example, only a user
       with the Administrator role can log into the Site Administrator program.
-      Only users with the Map Author role can access resources in Autodesk MapGuide
+      Only users with the Map Author role can access resources in Autodesk Infrastructure
       Studio. Everyone can use the MapGuide Viewer to view maps, but
       this is not considered a separate role.</font>
       <p class="paragraph">You might assign a small team of users to groups and
Modified: sandbox/adsk/2.3r/Web/src/mapadmin/HelpDocs/managing_packages.htm
--- sandbox/adsk/2.3r/Web/src/mapadmin/HelpDocs/managing_packages.htm	2011-02-09 06:33:58 UTC (rev 5539)
+++ sandbox/adsk/2.3r/Web/src/mapadmin/HelpDocs/managing_packages.htm	2011-02-09 06:44:24 UTC (rev 5540)
@@ -191,7 +191,7 @@
           <td class="paragraph" width="51%">
             <hr>
             You can load packages created in the Site Administrator or in Autodesk
-            MapGuide Studio.
+            Infrastructure Studio.
             <hr>
           </td>
         </tr>
More information about the mapguide-commits mailing list
