[mapguide-commits] r5551 - sandbox/adsk/2.3r/Common/CoordinateSystem
svn_mapguide at osgeo.org
Tue Feb 15 18:21:53 EST 2011
Author: brucedechant
Date: 2011-02-15 15:21:53 -0800 (Tue, 15 Feb 2011)
New Revision: 5551
sandbox/adsk/2.3r/Common/CoordinateSystem/CoordSysFormatConverter.cpp
Fix for trac ticket 1600 - Threading error with CodeToWkt() method
http://trac.osgeo.org/mapguide/ticket/1600
Notes:
- Added critical section around non-thread safe API
Modified: sandbox/adsk/2.3r/Common/CoordinateSystem/CoordSysFormatConverter.cpp
--- sandbox/adsk/2.3r/Common/CoordinateSystem/CoordSysFormatConverter.cpp 2011-02-15 20:17:07 UTC (rev 5550)
+++ sandbox/adsk/2.3r/Common/CoordinateSystem/CoordSysFormatConverter.cpp 2011-02-15 23:21:53 UTC (rev 5551)
@@ -438,7 +438,7 @@
throw new MgInvalidArgumentException(L"MgCoordinateSystemFormatConverter.CodeToWkt", __LINE__, __WFILE__, NULL, L"", NULL);
- const char* szMsiName=NULL;
+ std::string szMsiName;
std::string strName;
//if input is EPSG
@@ -467,8 +467,10 @@
//viewed from the outside of public API
//The mapping from Adsk name to Msi is done internally inside
//the method CSepsg2adskCS
+ CriticalClass.Enter();
szMsiName=CSepsg2adskCS(lEpsg);
- if (!szMsiName)
+ CriticalClass.Leave();
+ if (szMsiName.empty())
return L"";
@@ -484,8 +486,8 @@
strName=pszCsSource;
delete[] pszCsSource;
ReformatOldArbitraryName(strName);
- szMsiName=strName.c_str();
- if (!szMsiName)
+ szMsiName=strName;
return L"";
@@ -500,7 +502,7 @@
char csWktBufr [2048];
//is it an arbitrary system, one that uses NERTH projection?
- wchar_t* wszMsiName=Convert_Ascii_To_Wide(szMsiName);
+ wchar_t* wszMsiName=Convert_Ascii_To_Wide(szMsiName.c_str());
if (!wszMsiName)
throw new MgOutOfMemoryException(L"MgCoordinateSystemFormatConverter.CodeToWkt", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -523,7 +525,7 @@
else
SmartCriticalClass critical(true);
- if (0==CS_cs2Wkt(csWktBufr,sizeof(csWktBufr),szMsiName,GetWktFlavor(nWktFlavor)))
+ if (0==CS_cs2Wkt(csWktBufr,sizeof(csWktBufr),szMsiName.c_str(),GetWktFlavor(nWktFlavor)))
wchar_t* wszWkt=Convert_Ascii_To_Wide(csWktBufr);
if (!wszWkt)
More information about the mapguide-commits
