[mapguide-commits] r5572 -
sandbox/maestro-3.0/Maestro.Editors/Generic
svn_mapguide at osgeo.org
Mon Feb 28 10:41:59 EST 2011
Author: jng
Date: 2011-02-28 07:41:58 -0800 (Mon, 28 Feb 2011)
New Revision: 5572
sandbox/maestro-3.0/Maestro.Editors/Generic/XmlEditorCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Generic/XmlEditorCtrl.cs
sandbox/maestro-3.0/Maestro.Editors/Generic/XmlEditorCtrl.resx
Implement unimplemented cut/copy/paste/undo commands on the xml editor toolbar
Modified: sandbox/maestro-3.0/Maestro.Editors/Generic/XmlEditorCtrl.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/Generic/XmlEditorCtrl.Designer.cs 2011-02-28 15:17:24 UTC (rev 5571)
+++ sandbox/maestro-3.0/Maestro.Editors/Generic/XmlEditorCtrl.Designer.cs 2011-02-28 15:41:58 UTC (rev 5572)
@@ -94,6 +94,7 @@
this.btnCopy.Image = global::Maestro.Editors.Properties.Resources.document_copy;
resources.ApplyResources(this.btnCopy, "btnCopy");
this.btnCopy.Name = "btnCopy";
+ this.btnCopy.Click += new System.EventHandler(this.btnCopy_Click);
// btnCut
@@ -101,6 +102,7 @@
this.btnCut.Image = global::Maestro.Editors.Properties.Resources.scissors_blue;
resources.ApplyResources(this.btnCut, "btnCut");
this.btnCut.Name = "btnCut";
+ this.btnCut.Click += new System.EventHandler(this.btnCut_Click);
// btnPaste
@@ -108,6 +110,7 @@
this.btnPaste.Image = global::Maestro.Editors.Properties.Resources.clipboard_paste;
resources.ApplyResources(this.btnPaste, "btnPaste");
this.btnPaste.Name = "btnPaste";
+ this.btnPaste.Click += new System.EventHandler(this.btnPaste_Click);
// toolStripSeparator2
Modified: sandbox/maestro-3.0/Maestro.Editors/Generic/XmlEditorCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/Generic/XmlEditorCtrl.cs 2011-02-28 15:17:24 UTC (rev 5571)
+++ sandbox/maestro-3.0/Maestro.Editors/Generic/XmlEditorCtrl.cs 2011-02-28 15:41:58 UTC (rev 5572)
@@ -215,9 +215,32 @@
private void txtXmlContent_KeyUp(object sender, KeyEventArgs e)
- if (e.Control && e.KeyCode == Keys.A)
+ if (e.KeyData == (Keys.Control | Keys.A))
txtXmlContent.SelectAll();
+ e.SuppressKeyPress = true;
+ e.Handled = true;
+ else if (e.KeyData == (Keys.Control | Keys.C))
+ txtXmlContent.Copy();
+ e.Handled = true;
+ else if (e.KeyData == (Keys.Control | Keys.V))
+ txtXmlContent.Paste();
+ e.Handled = true;
+ else if (e.KeyData == (Keys.Control | Keys.X))
+ txtXmlContent.Cut();
+ e.Handled = true;
UpdateTextPosition();
EvaluateCommands();
@@ -315,5 +338,20 @@
if (_ready)
OnResourceChanged();
+ private void btnCut_Click(object sender, EventArgs e)
+ private void btnCopy_Click(object sender, EventArgs e)
+ private void btnPaste_Click(object sender, EventArgs e)
Modified: sandbox/maestro-3.0/Maestro.Editors/Generic/XmlEditorCtrl.resx
--- sandbox/maestro-3.0/Maestro.Editors/Generic/XmlEditorCtrl.resx 2011-02-28 15:17:24 UTC (rev 5571)
+++ sandbox/maestro-3.0/Maestro.Editors/Generic/XmlEditorCtrl.resx 2011-02-28 15:41:58 UTC (rev 5572)
@@ -118,7 +118,7 @@
<value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</resheader>
<metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>17, 17</value>
+ <value>0, 0</value>
</metadata>
<assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
<data name="btnUndo.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
@@ -330,7 +330,7 @@
<value>resDataCtrl</value>
</data>
<data name=">>resDataCtrl.Type" xml:space="preserve">
- <value>Maestro.Editors.Generic.ResourceDataPanel, Maestro.Editors, Version=3.0.0.5334, Culture=neutral, PublicKeyToken=null</value>
+ <value>Maestro.Editors.Generic.ResourceDataPanel, Maestro.Editors, Version=3.0.0.5475, Culture=neutral, PublicKeyToken=null</value>
</data>
<data name=">>resDataCtrl.Parent" xml:space="preserve">
<value>$this</value>
@@ -450,6 +450,6 @@
<value>XmlEditorCtrl</value>
</data>
<data name=">>$this.Type" xml:space="preserve">
- <value>Maestro.Editors.EditorBase, Maestro.Editors, Version=3.0.0.5334, Culture=neutral, PublicKeyToken=null</value>
+ <value>Maestro.Editors.EditorBase, Maestro.Editors, Version=3.0.0.5475, Culture=neutral, PublicKeyToken=null</value>
</data>
</root>
\ No newline at end of file
More information about the mapguide-commits
