[mapguide-commits] r5498 - in sandbox/adsk/2.3r: Server/src/Services/Kml Server/src/Services/Mapping Web/src/HttpHandler
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Jan 17 22:10:17 EST 2011
Author: liuar
Date: 2011-01-17 19:10:17 -0800 (Mon, 17 Jan 2011)
New Revision: 5498
   sandbox/adsk/2.3r/Server/src/Services/Kml/ServerKmlService.cpp
   sandbox/adsk/2.3r/Server/src/Services/Mapping/ServerMappingService.cpp
   sandbox/adsk/2.3r/Web/src/HttpHandler/WmsMapUtil.cpp
Port the fix of ticket #1586 (Incorrect LL84 wkt string existed in MapGuide code) to adsk branch.
Modified: sandbox/adsk/2.3r/Server/src/Services/Kml/ServerKmlService.cpp
--- sandbox/adsk/2.3r/Server/src/Services/Kml/ServerKmlService.cpp	2011-01-18 03:10:13 UTC (rev 5497)
+++ sandbox/adsk/2.3r/Server/src/Services/Kml/ServerKmlService.cpp	2011-01-18 03:10:17 UTC (rev 5498)
@@ -32,7 +32,7 @@
 //Zip support from DWF toolkit
 #include "dwfcore/ZipFileDescriptor.h"
-const STRING LL84_WKT = L"GEOGCS[\"LL84\",DATUM[\"WGS 84\",SPHEROID[\"WGS 84\",6378137,298.25722293287],TOWGS84[0,0,0,0,0,0,0]],PRIMEM[\"Greenwich\",0],UNIT[\"Degrees\",0.01745329252]]";
+const STRING LL84_WKT = L"GEOGCS[\"LL84\",DATUM[\"WGS84\",SPHEROID[\"WGS84\",6378137,298.25722293287],TOWGS84[0,0,0,0,0,0,0]],PRIMEM[\"Greenwich\",0],UNIT[\"Degrees\",0.01745329252]]";
 const STRING GOOGLE_EARTH_WKT = LL84_WKT;
 IMPLEMENT_CREATE_SERVICE(MgServerKmlService)
Modified: sandbox/adsk/2.3r/Server/src/Services/Mapping/ServerMappingService.cpp
--- sandbox/adsk/2.3r/Server/src/Services/Mapping/ServerMappingService.cpp	2011-01-18 03:10:13 UTC (rev 5497)
+++ sandbox/adsk/2.3r/Server/src/Services/Mapping/ServerMappingService.cpp	2011-01-18 03:10:17 UTC (rev 5498)
@@ -45,7 +45,7 @@
 //for use by observation mesh transformation
-const STRING SRS_LL84 = L"GEOGCS[\"LL84\",DATUM[\"WGS 84\",SPHEROID[\"WGS 84\",6378137,298.25722293287],TOWGS84[0,0,0,0,0,0,0]],PRIMEM[\"Greenwich\",0],UNIT[\"Degrees\",0.01745329252]]";
+const STRING SRS_LL84 = L"GEOGCS[\"LL84\",DATUM[\"WGS84\",SPHEROID[\"WGS84\",6378137,298.25722293287],TOWGS84[0,0,0,0,0,0,0]],PRIMEM[\"Greenwich\",0],UNIT[\"Degrees\",0.01745329252]]";
 IMPLEMENT_CREATE_SERVICE(MgServerMappingService)
Modified: sandbox/adsk/2.3r/Web/src/HttpHandler/WmsMapUtil.cpp
--- sandbox/adsk/2.3r/Web/src/HttpHandler/WmsMapUtil.cpp	2011-01-18 03:10:13 UTC (rev 5497)
+++ sandbox/adsk/2.3r/Web/src/HttpHandler/WmsMapUtil.cpp	2011-01-18 03:10:17 UTC (rev 5498)
@@ -31,8 +31,8 @@
     //Declare mappings between supported SRS strings and their WKT equivalents
     //WGS84
-    srsMappings[L"CRS:84"] = L"GEOGCS[\"LL84\",DATUM[\"WGS 84\",SPHEROID[\"WGS 84\",6378137,0],TOWGS84[0,0,0,0,0,0,0]],PRIMEM[\"Greenwich\",0],UNIT[\"Degrees\",0.01745329252]]";
-    srsMappings[L"EPSG:4326"] = L"GEOGCS[\"LL84\",DATUM[\"WGS 84\",SPHEROID[\"WGS 84\",6378137,0],TOWGS84[0,0,0,0,0,0,0]],PRIMEM[\"Greenwich\",0],UNIT[\"Degrees\",0.01745329252]]";
+    srsMappings[L"CRS:84"] = L"GEOGCS[\"LL84\",DATUM[\"WGS84\",SPHEROID[\"WGS84\",6378137,0],TOWGS84[0,0,0,0,0,0,0]],PRIMEM[\"Greenwich\",0],UNIT[\"Degrees\",0.01745329252]]";
+    srsMappings[L"EPSG:4326"] = L"GEOGCS[\"LL84\",DATUM[\"WGS84\",SPHEROID[\"WGS84\",6378137,0],TOWGS84[0,0,0,0,0,0,0]],PRIMEM[\"Greenwich\",0],UNIT[\"Degrees\",0.01745329252]]";
     //NAD83
     srsMappings[L"CRS:83"] = L"GEOGCS[\"LL83\",DATUM[\"NAD 83\",SPHEROID[\"GRS 80\",6378137,298.25722210089],TOWGS84[0,0,0,0,0,0,0]],PRIMEM[\"Greenwich\",0],UNIT[\"Degrees\",0.01745329252]]";
More information about the mapguide-commits mailing list
