[mapguide-commits] r5973 - in
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition: Raster Vector
svn_mapguide at osgeo.org
Wed Jul 6 06:43:58 EDT 2011
Author: jng
Date: 2011-07-06 03:43:58 -0700 (Wed, 06 Jul 2011)
New Revision: 5973
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Raster/RasterLayerSettingsSectionCtrl.cs
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Raster/RasterLayerSettingsSectionCtrl.resx
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/VectorLayerSettingsSectionCtrl.cs
#1740: Auto-set feature class when creating new Vector/Raster layer definition.
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Raster/RasterLayerSettingsSectionCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Raster/RasterLayerSettingsSectionCtrl.cs 2011-07-06 02:16:58 UTC (rev 5972)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Raster/RasterLayerSettingsSectionCtrl.cs 2011-07-06 10:43:58 UTC (rev 5973)
@@ -93,6 +93,10 @@
_selectedClass = cls;
+ else
+ SetFeatureClass(_cachedDesc.Schemas[0].Classes[0]);
private void btnBrowseFeatureSource_Click(object sender, EventArgs e)
@@ -134,37 +138,42 @@
var item = GenericItemSelectionDialog.SelectItem(null, null, list.ToArray(), "QualifiedName", "QualifiedName");
if (item != null)
- txtFeatureClass.Text = item.QualifiedName;
- _selectedClass = item;
+ SetFeatureClass(item);
- //See if geometry needs invalidation
- bool invalidate = true;
- foreach (var col in item.Properties)
- if (col.Type == PropertyDefinitionType.Raster && col.Name.Equals(txtGeometry.Text))
- invalidate = false;
- break;
- if (invalidate)
- txtGeometry.Text = string.Empty;
+ private void SetFeatureClass(ClassDefinition item)
+ txtFeatureClass.Text = item.QualifiedName;
+ _selectedClass = item;
- //See if we can auto-assign geometry
- List<PropertyDefinition> geoms = new List<PropertyDefinition>();
- foreach (var col in _selectedClass.Properties)
+ //See if geometry needs invalidation
+ bool invalidate = true;
+ foreach (var col in item.Properties)
+ if (col.Type == PropertyDefinitionType.Raster && col.Name.Equals(txtGeometry.Text))
- if (col.Type == PropertyDefinitionType.Raster)
- geoms.Add(col);
+ invalidate = false;
+ break;
+ if (invalidate)
+ txtGeometry.Text = string.Empty;
- if (geoms.Count == 1)
- txtGeometry.Text = geoms[0].Name;
+ //See if we can auto-assign geometry
+ List<PropertyDefinition> geoms = new List<PropertyDefinition>();
+ foreach (var col in _selectedClass.Properties)
+ if (col.Type == PropertyDefinitionType.Raster)
+ geoms.Add(col);
- //OnFeatureClassChanged();
+ if (geoms.Count == 1)
+ txtGeometry.Text = geoms[0].Name;
+ //OnFeatureClassChanged();
private void btnBrowseGeometry_Click(object sender, EventArgs e)
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Raster/RasterLayerSettingsSectionCtrl.resx
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Raster/RasterLayerSettingsSectionCtrl.resx 2011-07-06 02:16:58 UTC (rev 5972)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Raster/RasterLayerSettingsSectionCtrl.resx 2011-07-06 10:43:58 UTC (rev 5973)
@@ -417,6 +417,9 @@
<metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
<value>True</value>
</metadata>
+ <data name="$this.HeaderText" xml:space="preserve">
+ <value>Feature Source Settings</value>
+ </data>
<data name="$this.Size" type="System.Drawing.Size, System.Drawing">
<value>449, 145</value>
</data>
@@ -424,6 +427,6 @@
<value>RasterLayerSettingsSectionCtrl</value>
</data>
<data name=">>$this.Type" xml:space="preserve">
- <value>Maestro.Editors.Common.EditorBindableCollapsiblePanel, Maestro.Editors, Version=3.0.0.5475, Culture=neutral, PublicKeyToken=null</value>
+ <value>Maestro.Editors.Common.EditorBindableCollapsiblePanel, Maestro.Editors, Version=3.1.0.5859, Culture=neutral, PublicKeyToken=null</value>
</data>
</root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/VectorLayerSettingsSectionCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/VectorLayerSettingsSectionCtrl.cs 2011-07-06 02:16:58 UTC (rev 5972)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/VectorLayerSettingsSectionCtrl.cs 2011-07-06 10:43:58 UTC (rev 5973)
@@ -110,6 +110,11 @@
private void txtFeatureSource_TextChanged(object sender, EventArgs e)
_cachedDesc = _edsvc.FeatureService.DescribeFeatureSource(txtFeatureSource.Text);
+ if (string.IsNullOrEmpty(txtFeatureClass.Text))
internal event EventHandler FeatureClassChanged;
@@ -202,37 +207,42 @@
var item = GenericItemSelectionDialog.SelectItem(null, null, list, "QualifiedName", "QualifiedName");
if (item != null)
- if (col.Type == PropertyDefinitionType.Geometry && col.Name.Equals(txtGeometry.Text))
- break;
- if (invalidate)
+ if (col.Type == PropertyDefinitionType.Geometry && col.Name.Equals(txtGeometry.Text))
- if (col.Type == PropertyDefinitionType.Geometry)
- geoms.Add(col);
+ break;
+ if (invalidate)
+ if (col.Type == PropertyDefinitionType.Geometry)
+ geoms.Add(col);
- OnFeatureClassChanged();
+ OnFeatureClassChanged();
More information about the mapguide-commits
