[mapguide-commits] r6012 - in sandbox/adsk/2.3r/Web/src: . mapviewerjava mapviewernet mapviewerphp
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Jul 27 22:13:43 EDT 2011
Author: liuar
Date: 2011-07-27 19:13:43 -0700 (Wed, 27 Jul 2011)
New Revision: 6012
   sandbox/adsk/2.3r/Web/src/
   sandbox/adsk/2.3r/Web/src/mapviewerjava/quickplotgeneratepicture.jsp
   sandbox/adsk/2.3r/Web/src/mapviewernet/quickplotgeneratepicture.aspx
   sandbox/adsk/2.3r/Web/src/mapviewerphp/quickplotgeneratepicture.php
On behalf of Mars Wu
For Ticket 1757: http://trac.osgeo.org/mapguide/ticket/1757
Property changes on: sandbox/adsk/2.3r/Web/src
___________________________________________________________________
Added: svn:mergeinfo
   + /Web/src:5504
/trunk/MgDev/Web/src:5504,5539,5561-5562,6010
Modified: sandbox/adsk/2.3r/Web/src/mapviewerjava/quickplotgeneratepicture.jsp
--- sandbox/adsk/2.3r/Web/src/mapviewerjava/quickplotgeneratepicture.jsp	2011-07-28 01:59:12 UTC (rev 6011)
+++ sandbox/adsk/2.3r/Web/src/mapviewerjava/quickplotgeneratepicture.jsp	2011-07-28 02:13:43 UTC (rev 6012)
@@ -46,24 +46,25 @@
     GetRequestParameters(request);
     response.setContentType("image/png");
     ImageIO.write(GenerateMap(printSize), "png", response.getOutputStream());
-void GetRequestParameters(HttpServletRequest request) throws MgException
+void GetRequestParameters(HttpServletRequest request) throws MgException, ParseException
+    NumberFormat numberFormat = NumberFormat.getInstance(Locale.ENGLISH);
     sessionId = ValidateSessionId(GetParameter(request, "session_id"));
     mapName   = ValidateMapName(GetParameter(request, "map_name"));
-    rotation  = GetDoubleParameter(request, "rotation");
+    rotation  = numberFormat.parse(request.getParameter("rotation")).doubleValue();
     printDpi  = GetIntParameter(request, "print_dpi");
     scaleDenominator = GetIntParameter(request, "scale_denominator");
     String[] a = GetParameter(request, "paper_size").split(",");
-    paperSize  = new Size<Double>(Double.parseDouble(a[0]), Double.parseDouble(a[1]));
+    paperSize  = new Size<Double>(numberFormat.parse(a[0]).doubleValue(), numberFormat.parse(a[1]).doubleValue());
     printSize  = new Size<Integer>((int) (paperSize.width / 25.4 * printDpi), (int) (paperSize.height / 25.4 * printDpi));
     a = GetParameter(request, "box").split(",");
@@ -76,17 +77,18 @@
     naPath = getServletContext().getRealPath("viewerfiles/quickplotnortharrow.png");
-MgPolygon CreatePolygon(String[] coordinates) throws MgException
+MgPolygon CreatePolygon(String[] coordinates) throws MgException, ParseException
     MgGeometryFactory geometryFactory = new MgGeometryFactory();
     MgCoordinateCollection coordinateCollection = new MgCoordinateCollection();
     for (int i = 0; i < coordinates.length; ++i)
-        coordinateCollection.Add(geometryFactory.CreateCoordinateXY(Double.parseDouble(coordinates[i]), Double.parseDouble(coordinates[++i])));
+        coordinateCollection.Add(geometryFactory.CreateCoordinateXY(numberFormat.parse(coordinates[i]).doubleValue(), numberFormat.parse(coordinates[++i]).doubleValue()));
-    coordinateCollection.Add(geometryFactory.CreateCoordinateXY(Double.parseDouble(coordinates[0]), Double.parseDouble(coordinates[1])));
+    coordinateCollection.Add(geometryFactory.CreateCoordinateXY(numberFormat.parse(coordinates[0]).doubleValue(), numberFormat.parse(coordinates[1]).doubleValue()));
     MgLinearRing linearRing = geometryFactory.CreateLinearRing(coordinateCollection);
     return geometryFactory.CreatePolygon(linearRing, null);
Modified: sandbox/adsk/2.3r/Web/src/mapviewernet/quickplotgeneratepicture.aspx
--- sandbox/adsk/2.3r/Web/src/mapviewernet/quickplotgeneratepicture.aspx	2011-07-28 01:59:12 UTC (rev 6011)
+++ sandbox/adsk/2.3r/Web/src/mapviewernet/quickplotgeneratepicture.aspx	2011-07-28 02:13:43 UTC (rev 6012)
@@ -23,6 +23,7 @@
 <%@ Import Namespace="OSGeo.MapGuide" %>
 <%@ Import Namespace="System.Net" %>
 <%@ Import Namespace="System.Drawing.Drawing2D" %>
+<%@ Import Namespace="System.Globalization" %>
 <!-- #Include File="common.aspx -->
@@ -41,6 +42,7 @@
     Response.Charset = "utf-8";
     GetRequestParameters();
     GenerateMap(printSize);
@@ -65,7 +67,7 @@
     scaleDenominator = GetIntParameter(parameters, "scale_denominator");
     string[] a = parameters["paper_size"].Split(',');
-    paperSize  = new SizeF(float.Parse(a[0]), float.Parse(a[1]));
+    paperSize  = new SizeF(float.Parse(a[0], CultureInfo.InvariantCulture), float.Parse(a[1], CultureInfo.InvariantCulture));
     printSize  = new Size((int) (paperSize.Width / 25.4 * printDpi), (int) (paperSize.Height / 25.4 * printDpi));
     a = parameters["box"].Split(',');
@@ -82,10 +84,10 @@
     for (int i = 0; i < coordinates.Length; ++i)
-        coordinateCollection.Add(geometryFactory.CreateCoordinateXY(double.Parse(coordinates[i]), double.Parse(coordinates[++i])));
+        coordinateCollection.Add(geometryFactory.CreateCoordinateXY(double.Parse(coordinates[i], CultureInfo.InvariantCulture), double.Parse(coordinates[++i], CultureInfo.InvariantCulture)));
-    coordinateCollection.Add(geometryFactory.CreateCoordinateXY(double.Parse(coordinates[0]), double.Parse(coordinates[1])));
+    coordinateCollection.Add(geometryFactory.CreateCoordinateXY(double.Parse(coordinates[0], CultureInfo.InvariantCulture), double.Parse(coordinates[1], CultureInfo.InvariantCulture)));
Modified: sandbox/adsk/2.3r/Web/src/mapviewerphp/quickplotgeneratepicture.php
--- sandbox/adsk/2.3r/Web/src/mapviewerphp/quickplotgeneratepicture.php	2011-07-28 01:59:12 UTC (rev 6011)
+++ sandbox/adsk/2.3r/Web/src/mapviewerphp/quickplotgeneratepicture.php	2011-07-28 02:13:43 UTC (rev 6012)
@@ -30,13 +30,13 @@
         // Not necessary to validate the parameters
         $sessionID   = $args["session_id"];
         $mapName     = $args["map_name"];
-        $rotation    = floatval($args["rotation"]);
+        $rotation    = ParseLocaleDouble($args["rotation"]);
         $printDpi    = intval($args["print_dpi"]);
         $scaleDenominator = intval($args["scale_denominator"]);
         $array       = explode(",", $args["paper_size"]);
-        $paperSize   = new Size(floatval($array[0]), floatval($array[1]));
+        $paperSize   = new Size(ParseLocaleDouble($array[0]), ParseLocaleDouble($array[1]));
         $printSize   = new Size($paperSize->width / 25.4 * $printDpi, $paperSize->height / 25.4 * $printDpi);
         $array       = explode(",", $args["box"]);
@@ -54,11 +54,11 @@
         for ($index = 0; $index < count($coordinates); ++$index)
-            $coordinate = $geometryFactory->CreateCoordinateXY(floatval($coordinates[$index]), floatval($coordinates[++$index]));
+            $coordinate = $geometryFactory->CreateCoordinateXY(ParseLocaleDouble($coordinates[$index]), ParseLocaleDouble($coordinates[++$index]));
             $coordinateCollection->Add($coordinate);
-        $coordinateCollection->Add($geometryFactory->CreateCoordinateXY(floatval($coordinates[0]), floatval($coordinates[1])));
+        $coordinateCollection->Add($geometryFactory->CreateCoordinateXY(ParseLocaleDouble($coordinates[0]), ParseLocaleDouble($coordinates[1])));
         $linearRingCollection = $geometryFactory->CreateLinearRing($coordinateCollection);
         $captureBox           = $geometryFactory->CreatePolygon($linearRingCollection, null);
@@ -165,6 +165,12 @@
         imagedestroy($rotatedNa);
+    function ParseLocaleDouble($stringValue)
+        $lc = localeconv();
+        $result = str_replace(".", $lc["decimal_point"], $stringValue);
+        return doubleval($result);
 <?php
More information about the mapguide-commits mailing list
