[mapguide-commits] r6014 - trunk/MgDev/Server/src/Services/Rendering
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Jul 28 03:51:19 EDT 2011
Author: hubu
Date: 2011-07-28 00:51:19 -0700 (Thu, 28 Jul 2011)
New Revision: 6014
   trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
Fix the ticket #1758
https://trac.osgeo.org/mapguide/ticket/1758
Set initial value to queryExtentPolygon, and change the coding style, the variable name should not start with a capital letter.
Modified: trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
--- trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp	2011-07-28 03:21:09 UTC (rev 6013)
+++ trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp	2011-07-28 07:51:19 UTC (rev 6014)
@@ -1645,13 +1645,13 @@
                             Ptr<MgLinearRing> extentRing = new MgLinearRing(extentCoords);
                             Ptr<MgPolygon> extentPolygon = new MgPolygon(extentRing, NULL);
-                            Ptr<MgGeometricEntity> QueryExtentPolygon;
+                            Ptr<MgGeometricEntity> queryExtentPolygon = extentPolygon;
                             if (trans)
                                 //get selection geometry in layer space
-                                QueryExtentPolygon = extentPolygon->Transform(trans);
+                                queryExtentPolygon = extentPolygon->Transform(trans);
-                            Ptr<MgGeometry> intersectPolygon = polygon->Intersection((MgPolygon *)QueryExtentPolygon.p);
+                            Ptr<MgGeometry> intersectPolygon = polygon->Intersection((MgPolygon *)queryExtentPolygon.p);
                             if (intersectPolygon != NULL)
More information about the mapguide-commits mailing list
