[mapguide-commits] r5912 - in branches/2.2/MgDev/Web/src: mapviewerjava mapviewernet mapviewerphp
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri Jun 3 09:12:36 EDT 2011
Author: jng
Date: 2011-06-03 06:12:36 -0700 (Fri, 03 Jun 2011)
New Revision: 5912
   branches/2.2/MgDev/Web/src/mapviewerjava/mainframe.jsp
   branches/2.2/MgDev/Web/src/mapviewernet/mainframe.aspx
   branches/2.2/MgDev/Web/src/mapviewerphp/mainframe.php
#1712: Apply layer constraints to InvokeURL commands regardless of whether parameters are specified or not.
Modified: branches/2.2/MgDev/Web/src/mapviewerjava/mainframe.jsp
--- branches/2.2/MgDev/Web/src/mapviewerjava/mainframe.jsp	2011-06-03 12:40:53 UTC (rev 5911)
+++ branches/2.2/MgDev/Web/src/mapviewerjava/mainframe.jsp	2011-06-03 13:12:36 UTC (rev 5912)
@@ -238,13 +238,13 @@
                     String param = MessageFormat.format("navParams{0,number,integer}[{1,number,integer}] = new NavParam(\"{2}\", \"{3}\");\n", formatArgs);
                     paramObjs = paramObjs + param;
-                for( int j = 0;  j < invokeUrlCmd.GetLayerCount(); j++ )
-                    Object[] formatArgs = { new Integer(navCmdIndex), new Integer(j), invokeUrlCmd.GetLayerNameAt(j) };
-                    String layer = MessageFormat.format("layers{0,number,integer}[{1,number,integer}] = \"{2}\";\n", formatArgs);
-                    layers = layers + layer;
+            for( int j = 0;  j < invokeUrlCmd.GetLayerCount(); j++ )
+                Object[] formatArgs = { new Integer(navCmdIndex), new Integer(j), invokeUrlCmd.GetLayerNameAt(j) };
+                String layer = MessageFormat.format("layers{0,number,integer}[{1,number,integer}] = \"{2}\";\n", formatArgs);
+                layers = layers + layer;
             cmdObjects = cmdObjects + paramObjs + layers;
             if(invokeUrlCmd.DisabledIfSelectionEmpty() || invokeUrlCmd.GetLayerCount() > 0)
Modified: branches/2.2/MgDev/Web/src/mapviewernet/mainframe.aspx
--- branches/2.2/MgDev/Web/src/mapviewernet/mainframe.aspx	2011-06-03 12:40:53 UTC (rev 5911)
+++ branches/2.2/MgDev/Web/src/mapviewernet/mainframe.aspx	2011-06-03 13:12:36 UTC (rev 5912)
@@ -236,18 +236,17 @@
                 String layers = "var layers" + navCmdIndex + " = new Array();\n";
                 if (invokeUrlCmd.GetParameterCount() > 0)
-                    int j = 0;
-                    for (j = 0; j < invokeUrlCmd.GetParameterCount(); j++)
+                    for (int j = 0; j < invokeUrlCmd.GetParameterCount(); j++)
                         String param = String.Format("navParams{0}[{1}] = new NavParam(\"{2}\", \"{3}\");\n", navCmdIndex, j, invokeUrlCmd.GetParameterNameAt(j), invokeUrlCmd.GetParameterValueAt(j));
                         parameters = parameters + param;
-                    for (j = 0; j < invokeUrlCmd.GetLayerCount(); j++)
-                        String layer = String.Format("layers{0}[{1}] = \"{2}\";\n", navCmdIndex, j, invokeUrlCmd.GetLayerNameAt(j));
+                for (int j = 0; j < invokeUrlCmd.GetLayerCount(); j++)
+                    String layer = String.Format("layers{0}[{1}] = \"{2}\";\n", navCmdIndex, j, invokeUrlCmd.GetLayerNameAt(j));
                 cmdObjects = cmdObjects + parameters + layers;
                 if (invokeUrlCmd.DisabledIfSelectionEmpty() || invokeUrlCmd.GetLayerCount() > 0)
Modified: branches/2.2/MgDev/Web/src/mapviewerphp/mainframe.php
--- branches/2.2/MgDev/Web/src/mapviewerphp/mainframe.php	2011-06-03 12:40:53 UTC (rev 5911)
+++ branches/2.2/MgDev/Web/src/mapviewerphp/mainframe.php	2011-06-03 13:12:36 UTC (rev 5912)
@@ -251,12 +251,12 @@
                         $param = sprintf("navParams%d[%d] = new NavParam(\"%s\", \"%s\");\n", $navCmdIndex, $j, $cmd->GetParameterNameAt($j), $cmd->GetParameterValueAt($j));
                         $params = $params . $param;
-                    for($j = 0; $j < $cmd->GetLayerCount(); $j++)
-                        $layer = sprintf("layers%d[%d] = \"%s\";\n", $navCmdIndex, $j, $cmd->GetLayerNameAt($j));
-                        $layers = $layers . $layer;
+                for($j = 0; $j < $cmd->GetLayerCount(); $j++)
+                    $layer = sprintf("layers%d[%d] = \"%s\";\n", $navCmdIndex, $j, $cmd->GetLayerNameAt($j));
+                    $layers = $layers . $layer;
                 $cmdObjects = $cmdObjects . $params . $layers;
                 if($cmd->DisabledIfSelectionEmpty() || $cmd->GetLayerCount() > 0)
More information about the mapguide-commits mailing list
