[mapguide-commits] r5958 - trunk/Tools/Maestro/Maestro.Editors
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Jun 29 08:15:12 EDT 2011
Author: jng
Date: 2011-06-29 05:15:12 -0700 (Wed, 29 Jun 2011)
New Revision: 5958
Removed:
   trunk/Tools/Maestro/Maestro.Editors/AreaPatterns.Designer.cs
   trunk/Tools/Maestro/Maestro.Editors/AreaPatterns.resx
#1729: Remove empty resx file
Deleted: trunk/Tools/Maestro/Maestro.Editors/AreaPatterns.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/AreaPatterns.Designer.cs	2011-06-29 09:08:11 UTC (rev 5957)
+++ trunk/Tools/Maestro/Maestro.Editors/AreaPatterns.Designer.cs	2011-06-29 12:15:12 UTC (rev 5958)
@@ -1,63 +0,0 @@
-// <auto-generated>
-//     This code was generated by a tool.
-//     Runtime Version:2.0.50727.4952
-//     Changes to this file may cause incorrect behavior and will be lost if
-//     the code is regenerated.
-// </auto-generated>
-namespace Maestro.Editors {
-    using System;
-    /// <summary>
-    ///   A strongly-typed resource class, for looking up localized strings, etc.
-    /// </summary>
-    // This class was auto-generated by the StronglyTypedResourceBuilder
-    // class via a tool like ResGen or Visual Studio.
-    // To add or remove a member, edit your .ResX file then rerun ResGen
-    // with the /str option, or rebuild your VS project.
-    [global::System.CodeDom.Compiler.GeneratedCodeAttribute("System.Resources.Tools.StronglyTypedResourceBuilder", "2.0.0.0")]
-    [global::System.Diagnostics.DebuggerNonUserCodeAttribute()]
-    [global::System.Runtime.CompilerServices.CompilerGeneratedAttribute()]
-    internal class AreaPatterns {
-        private static global::System.Resources.ResourceManager resourceMan;
-        private static global::System.Globalization.CultureInfo resourceCulture;
-        [global::System.Diagnostics.CodeAnalysis.SuppressMessageAttribute("Microsoft.Performance", "CA1811:AvoidUncalledPrivateCode")]
-        internal AreaPatterns() {
-        /// <summary>
-        ///   Returns the cached ResourceManager instance used by this class.
-        /// </summary>
-        [global::System.ComponentModel.EditorBrowsableAttribute(global::System.ComponentModel.EditorBrowsableState.Advanced)]
-        internal static global::System.Resources.ResourceManager ResourceManager {
-            get {
-                if (object.ReferenceEquals(resourceMan, null)) {
-                    global::System.Resources.ResourceManager temp = new global::System.Resources.ResourceManager("Maestro.Editors.AreaPatterns", typeof(AreaPatterns).Assembly);
-                    resourceMan = temp;
-                return resourceMan;
-        /// <summary>
-        ///   Overrides the current thread's CurrentUICulture property for all
-        ///   resource lookups using this strongly typed resource class.
-        /// </summary>
-        internal static global::System.Globalization.CultureInfo Culture {
-            get {
-                return resourceCulture;
-            set {
-                resourceCulture = value;
Deleted: trunk/Tools/Maestro/Maestro.Editors/AreaPatterns.resx
--- trunk/Tools/Maestro/Maestro.Editors/AreaPatterns.resx	2011-06-29 09:08:11 UTC (rev 5957)
+++ trunk/Tools/Maestro/Maestro.Editors/AreaPatterns.resx	2011-06-29 12:15:12 UTC (rev 5958)
@@ -1,101 +0,0 @@
-<?xml version="1.0" encoding="utf-8"?>
-<root>
-		Microsoft ResX Schema
-		Version 1.3
-		The primary goals of this format is to allow a simple XML format
-		that is mostly human readable. The generation and parsing of the
-		various data types are done through the TypeConverter classes
-		associated with the data types.
-		Example:
-		... ado.net/XML headers & schema ...
-		<resheader name="resmimetype">text/microsoft-resx</resheader>
-		<resheader name="version">1.3</resheader>
-		<resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
-		<resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
-		<data name="Name1">this is my long string</data>
-		<data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
-		<data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
-			[base64 mime encoded serialized .NET Framework object]
-		</data>
-		<data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
-			[base64 mime encoded string representing a byte array form of the .NET Framework object]
-		</data>
-		There are any number of "resheader" rows that contain simple
-		name/value pairs.
-		Each data row contains a name, and value. The row also contains a
-		type or mimetype. Type corresponds to a .NET class that support
-		text/value conversion through the TypeConverter architecture.
-		Classes that don't support this are serialized and stored with the
-		mimetype set.
-		The mimetype is used for serialized objects, and tells the
-		ResXResourceReader how to depersist the object. This is currently not
-		extensible. For a given mimetype the value must be set accordingly:
-		Note - application/x-microsoft.net.object.binary.base64 is the format
-		that the ResXResourceWriter will generate, however the reader can
-		read any of the formats listed below.
-		mimetype: application/x-microsoft.net.object.binary.base64
-		value   : The object must be serialized with
-			: System.Serialization.Formatters.Binary.BinaryFormatter
-			: and then encoded with base64 encoding.
-		mimetype: application/x-microsoft.net.object.soap.base64
-			: System.Runtime.Serialization.Formatters.Soap.SoapFormatter
-		mimetype: application/x-microsoft.net.object.bytearray.base64
-		value   : The object must be serialized into a byte array
-			: using a System.ComponentModel.TypeConverter
-	<xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
-		<xsd:element name="root" msdata:IsDataSet="true">
-			<xsd:complexType>
-				<xsd:choice maxOccurs="unbounded">
-					<xsd:element name="data">
-						<xsd:complexType>
-							<xsd:sequence>
-								<xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
-								<xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
-							</xsd:sequence>
-							<xsd:attribute name="name" type="xsd:string" msdata:Ordinal="1" />
-							<xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
-							<xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
-						</xsd:complexType>
-					</xsd:element>
-					<xsd:element name="resheader">
-						<xsd:complexType>
-							<xsd:sequence>
-							</xsd:sequence>
-							<xsd:attribute name="name" type="xsd:string" use="required" />
-					</xsd:element>
-				</xsd:choice>
-		</xsd:element>
-	</xsd:schema>
-		<value>text/microsoft-resx</value>
-	</resheader>
-		<value>1.3</value>
-	</resheader>
-		<value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.3500.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
-	</resheader>
-		<value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.3500.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
-	</resheader>
-</root>
\ No newline at end of file
More information about the mapguide-commits mailing list
