[mapguide-commits] r5577 - trunk/MgDev/Doc/devguide/source
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue Mar 1 08:56:51 EST 2011
Author: jng
Date: 2011-03-01 05:56:51 -0800 (Tue, 01 Mar 2011)
New Revision: 5577
Added:
   trunk/MgDev/Doc/devguide/source/revision_history.rst
   trunk/MgDev/Doc/devguide/source/index.rst
#1614: Add revision history section
Modified: trunk/MgDev/Doc/devguide/source/index.rst
--- trunk/MgDev/Doc/devguide/source/index.rst	2011-03-01 13:27:45 UTC (rev 5576)
+++ trunk/MgDev/Doc/devguide/source/index.rst	2011-03-01 13:56:51 UTC (rev 5577)
@@ -6,6 +6,7 @@
 MapGuide Developer's Guide
+*Version 2.0*
 Contents
@@ -13,6 +14,7 @@
 .. toctree::
    :maxdepth: 4
+   revision_history
    introduction
    mapguide_ajax_viewer
    interacting_with_layers
Added: trunk/MgDev/Doc/devguide/source/revision_history.rst
--- trunk/MgDev/Doc/devguide/source/revision_history.rst	                        (rev 0)
+++ trunk/MgDev/Doc/devguide/source/revision_history.rst	2011-03-01 13:56:51 UTC (rev 5577)
@@ -0,0 +1,30 @@
+.. index:
+Revision History
+This table provides a high level overview of changes between previous versions of this document
+For a more detailed list of changes, the entire subversion revision of log of this document can be found `here <http://trac.osgeo.org/mapguide/log/trunk/MgDev/Doc/devguide>`_
+| Version | Authors         | Date            | Summary of Changes                                           |
+| 2.0     | Jackie Ng       |                 | First version of developer's guide in source form            |
+|         |                 |                 | Added .net and Java code samples to match PHP examples       |
+|         |                 |                 | Removed references to the deprecated DWF viewer              |
+|         |                 |                 | Replaced defunct Web Studio references with MapGuide Maestro |
+|         |                 |                 | New Advanced MapGuide topics                                 |
+|         |                 |                 | New Topics on Fusion                                         |
+|         |                 |                 | New Topics on OpenLayers                                     |
+|         |                 |                 | New Topics on Maestro API                                    |
+| 1.0     | Autodesk        | Jan 2008        | Original version of the guide in PDF form (circa. MGOS 2.0)  |
\ No newline at end of file
More information about the mapguide-commits mailing list
