[mapguide-commits] r5587 - in trunk/MgDev/Doc/samples/phpsamples: digitizing_features modifying_maps_and_layers
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Mar 3 09:32:22 EST 2011
Author: jng
Date: 2011-03-03 06:32:22 -0800 (Thu, 03 Mar 2011)
New Revision: 5587
   trunk/MgDev/Doc/samples/phpsamples/digitizing_features/draw_line.php
   trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/layer_functions.php
#1614: Fix redlining example due to out of date Layer Definition schema version
Modified: trunk/MgDev/Doc/samples/phpsamples/digitizing_features/draw_line.php
--- trunk/MgDev/Doc/samples/phpsamples/digitizing_features/draw_line.php	2011-03-03 14:27:19 UTC (rev 5586)
+++ trunk/MgDev/Doc/samples/phpsamples/digitizing_features/draw_line.php	2011-03-03 14:32:22 UTC (rev 5587)
@@ -69,8 +69,8 @@
     // Open the map
-    $map = new MgMap();
-    $map->Open($resourceService, $mapName);
+    $map = new MgMap($siteConnection);
+    $map->Open($mapName);
     $layerName = "Lines";
     $layerLegendLabel = "New Lines";
Modified: trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/layer_functions.php
--- trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/layer_functions.php	2011-03-03 14:27:19 UTC (rev 5586)
+++ trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/layer_functions.php	2011-03-03 14:32:22 UTC (rev 5587)
@@ -25,7 +25,7 @@
     // Validate the XML.
     $domDocument = new DOMDocument;
     $domDocument->loadXML($layerDefinition);
-  if (! $domDocument->schemaValidate($schemaDirectory . "LayerDefinition-1.1.0.xsd") ) // $schemaDirectory is defined in common.php
+  if (! $domDocument->schemaValidate($schemaDirectory . "LayerDefinition-1.3.0.xsd") ) // $schemaDirectory is defined in common.php
     echo "ERROR: The new XML document is invalid.<BR>\n.";
     return NULL;
More information about the mapguide-commits mailing list
