[mapguide-commits] r5592 - branches/2.2/MgDev/Doc/samples/phpsamples
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Mar 3 10:54:40 EST 2011
Author: jng
Date: 2011-03-03 07:54:40 -0800 (Thu, 03 Mar 2011)
New Revision: 5592
Added:
   branches/2.2/MgDev/Doc/samples/phpsamples/PHPSamples.mgp
   branches/2.2/MgDev/Doc/samples/phpsamples/readme.txt
#1614: Add readme and package that is required by the samples
Property changes on: branches/2.2/MgDev/Doc/samples/phpsamples
___________________________________________________________________
Modified: svn:mergeinfo
   - /trunk/MgDev/Doc/samples/phpsamples:5584-5588
   + /trunk/MgDev/Doc/samples/phpsamples:5584-5588,5591
Copied: branches/2.2/MgDev/Doc/samples/phpsamples/PHPSamples.mgp (from rev 5591, trunk/MgDev/Doc/samples/phpsamples/PHPSamples.mgp)
(Binary files differ)
Copied: branches/2.2/MgDev/Doc/samples/phpsamples/readme.txt (from rev 5591, trunk/MgDev/Doc/samples/phpsamples/readme.txt)
--- branches/2.2/MgDev/Doc/samples/phpsamples/readme.txt	                        (rev 0)
+++ branches/2.2/MgDev/Doc/samples/phpsamples/readme.txt	2011-03-03 15:54:40 UTC (rev 5592)
@@ -0,0 +1,16 @@
+MapGuide Developer's Guide PHP Samples README
+This is the complete set of PHP samples referenced in the MapGuide Developer's Guide
+Notes
+These samples assume that MapGuide Open Source is installed in the default location in
+C:\Program Files\OSGeo\MapGuide
+If this is not the case edit common/common.php and change the paths to match your install location
+These samples require a user named "Author" (pass: author) with authoring privileges. This is a default user in a standard MapGuide installation. If you have deleted or modified this user, edit main.php and update with a matching login
+These samples require the Sheboygan sample dataset. In addition it requires a web layout that is provided in the PHPSamples.mgp. Load this package first before running the samples.
\ No newline at end of file
More information about the mapguide-commits mailing list
