[mapguide-commits] r5604 - in sandbox/maestro-3.0: Maestro.Base Maestro.Base/Commands Maestro.Base/Properties Maestro.Editors Maestro.Editors/Diagnostics OSGeo.MapGuide.MaestroAPI OSGeo.MapGuide.MaestroAPI/Commands OSGeo.MapGuide.MaestroAPI.Http OSGeo.MapGuide.MaestroAPI.Http/Commands
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue Mar 8 02:55:20 EST 2011
Author: jng
Date: 2011-03-07 23:55:20 -0800 (Mon, 07 Mar 2011)
New Revision: 5604
Added:
   sandbox/maestro-3.0/Maestro.Base/Commands/CacheViewerCommand.cs
   sandbox/maestro-3.0/Maestro.Editors/Diagnostics/FdoCacheViewer.Designer.cs
   sandbox/maestro-3.0/Maestro.Editors/Diagnostics/FdoCacheViewer.cs
   sandbox/maestro-3.0/Maestro.Editors/Diagnostics/FdoCacheViewer.resx
   sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/Commands/HttpGetFdoCacheInfo.cs
   sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Commands/IGetFdoCacheInfo.cs
   sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin
   sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj
   sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs
   sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx
   sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj
   sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpCapabilities.cs
   sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
   sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/OSGeo.MapGuide.MaestroAPI.Http.csproj
   sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/RequestBuilder.cs
   sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Commands/CommandType.cs
   sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
#1618: Implement FDO Connection cache viewer. Currently the output is the raw XML which is sufficient for now.
Added: sandbox/maestro-3.0/Maestro.Base/Commands/CacheViewerCommand.cs
--- sandbox/maestro-3.0/Maestro.Base/Commands/CacheViewerCommand.cs	                        (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/Commands/CacheViewerCommand.cs	2011-03-08 07:55:20 UTC (rev 5604)
@@ -0,0 +1,49 @@
+#region Disclaimer / License
+// Copyright (C) 2011, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+using ICSharpCode.Core;
+using Maestro.Base.Services;
+using Maestro.Editors.Diagnostics;
+using OSGeo.MapGuide.MaestroAPI.Commands;
+namespace Maestro.Base.Commands
+    public class CacheViewerCommand : AbstractMenuCommand
+        public override void Run()
+            try
+                var wb = Workbench.Instance;
+                var mgr = ServiceRegistry.GetService<ServerConnectionManager>();
+                var conn = mgr.GetConnection(wb.ActiveSiteExplorer.ConnectionName);
+                var diag = new FdoCacheViewer((IGetFdoCacheInfo)conn.CreateCommand((int)CommandType.GetFdoCacheInfo));
+                diag.Show();
+            catch (Exception ex)
+                MessageService.ShowError(ex.Message);
Modified: sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin
--- sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin	2011-03-07 13:47:28 UTC (rev 5603)
+++ sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin	2011-03-08 07:55:20 UTC (rev 5604)
@@ -190,6 +190,9 @@
             <MenuItem id="ServerMonitor"
                       label="${res:ServerMonitor}"
                       class="Maestro.Base.Commands.ServerMonitorCommand"/>
+            <MenuItem id="CacheView"
+                      label="${res:CacheView}"
+                      class="Maestro.Base.Commands.CacheViewerCommand"/>
             <MenuItem type="Separator" />
             <MenuItem id="Menu_Tools_Options"
                       label="${res:Menu_Tools_Options}"
Modified: sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj
--- sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj	2011-03-07 13:47:28 UTC (rev 5603)
+++ sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj	2011-03-08 07:55:20 UTC (rev 5604)
@@ -67,6 +67,7 @@
       <Link>GlobalAssemblyInfo.cs</Link>
     </Compile>
     <Compile Include="Commands\AboutCommand.cs" />
+    <Compile Include="Commands\CacheViewerCommand.cs" />
     <Compile Include="Commands\CloseActiveDocumentCommand.cs" />
     <Compile Include="Commands\CloseAllDocumentsCommand.cs" />
     <Compile Include="Commands\Conditions\ActiveEditorConditionEvaluator.cs" />
Modified: sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs	2011-03-07 13:47:28 UTC (rev 5603)
+++ sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs	2011-03-08 07:55:20 UTC (rev 5604)
@@ -259,6 +259,15 @@
+        /// <summary>
+        ///   Looks up a localized string similar to View Feature Source Cache.
+        /// </summary>
+        internal static string CacheView {
+            get {
+                return ResourceManager.GetString("CacheView", resourceCulture);
         internal static System.Drawing.Bitmap clipboard_paste {
             get {
                 object obj = ResourceManager.GetObject("clipboard_paste", resourceCulture);
Modified: sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx
--- sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx	2011-03-07 13:47:28 UTC (rev 5603)
+++ sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx	2011-03-08 07:55:20 UTC (rev 5604)
@@ -832,4 +832,7 @@
   <data name="ConfirmBaseMapInvalidationLayerSave" xml:space="preserve">
     <value>This layer is used as a tiled layer in the following maps: {0} Saving this layer may reset the cached tiles of these maps. Continue with save?</value>
   </data>
+  <data name="CacheView" xml:space="preserve">
+    <value>View Feature Source Cache</value>
+  </data>
 </root>
\ No newline at end of file
Added: sandbox/maestro-3.0/Maestro.Editors/Diagnostics/FdoCacheViewer.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/Diagnostics/FdoCacheViewer.Designer.cs	                        (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/Diagnostics/FdoCacheViewer.Designer.cs	2011-03-08 07:55:20 UTC (rev 5604)
@@ -0,0 +1,85 @@
+namespace Maestro.Editors.Diagnostics
+    partial class FdoCacheViewer
+        /// <summary>
+        /// Required designer variable.
+        /// </summary>
+        private System.ComponentModel.IContainer components = null;
+        /// <summary>
+        /// Clean up any resources being used.
+        /// </summary>
+        /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+        protected override void Dispose(bool disposing)
+            if (disposing && (components != null))
+                components.Dispose();
+            base.Dispose(disposing);
+        #region Windows Form Designer generated code
+        /// <summary>
+        /// Required method for Designer support - do not modify
+        /// the contents of this method with the code editor.
+        /// </summary>
+        private void InitializeComponent()
+            this.components = new System.ComponentModel.Container();
+            System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(FdoCacheViewer));
+            this.btnClose = new System.Windows.Forms.Button();
+            this.chkAutoRefresh = new System.Windows.Forms.CheckBox();
+            this.tmRefresh = new System.Windows.Forms.Timer(this.components);
+            this.txtXml = new System.Windows.Forms.TextBox();
+            this.SuspendLayout();
+            // btnClose
+            resources.ApplyResources(this.btnClose, "btnClose");
+            this.btnClose.Name = "btnClose";
+            this.btnClose.UseVisualStyleBackColor = true;
+            this.btnClose.Click += new System.EventHandler(this.btnClose_Click);
+            // chkAutoRefresh
+            resources.ApplyResources(this.chkAutoRefresh, "chkAutoRefresh");
+            this.chkAutoRefresh.Name = "chkAutoRefresh";
+            this.chkAutoRefresh.UseVisualStyleBackColor = true;
+            this.chkAutoRefresh.CheckedChanged += new System.EventHandler(this.chkAutoRefresh_CheckedChanged);
+            // tmRefresh
+            this.tmRefresh.Interval = 5000;
+            this.tmRefresh.Tick += new System.EventHandler(this.tmRefresh_Tick);
+            // txtXml
+            resources.ApplyResources(this.txtXml, "txtXml");
+            this.txtXml.Name = "txtXml";
+            this.txtXml.ReadOnly = true;
+            // FdoCacheViewer
+            this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
+            resources.ApplyResources(this, "$this");
+            this.ControlBox = false;
+            this.Controls.Add(this.txtXml);
+            this.Controls.Add(this.chkAutoRefresh);
+            this.Controls.Add(this.btnClose);
+            this.Name = "FdoCacheViewer";
+            this.ResumeLayout(false);
+            this.PerformLayout();
+        #endregion
+        private System.Windows.Forms.Button btnClose;
+        private System.Windows.Forms.CheckBox chkAutoRefresh;
+        private System.Windows.Forms.Timer tmRefresh;
+        private System.Windows.Forms.TextBox txtXml;
Added: sandbox/maestro-3.0/Maestro.Editors/Diagnostics/FdoCacheViewer.cs
--- sandbox/maestro-3.0/Maestro.Editors/Diagnostics/FdoCacheViewer.cs	                        (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/Diagnostics/FdoCacheViewer.cs	2011-03-08 07:55:20 UTC (rev 5604)
@@ -0,0 +1,67 @@
+#endregion
+using System;
+using System.ComponentModel;
+using System.Data;
+using System.Drawing;
+using System.Text;
+using System.Windows.Forms;
+using System.IO;
+    public partial class FdoCacheViewer : Form
+        private IGetFdoCacheInfo _cmd;
+        public FdoCacheViewer(IGetFdoCacheInfo cache)
+            InitializeComponent();
+            _cmd = cache;
+            txtXml.Text = ToXml(_cmd.Execute());
+        private string ToXml(FdoCacheInfo fdoCacheInfo)
+            using (var ms = new MemoryStream())
+                FdoCacheInfo.Serializer.Serialize(ms, fdoCacheInfo);
+                return Encoding.UTF8.GetString(ms.GetBuffer());
+        private void btnClose_Click(object sender, EventArgs e)
+            this.Close();
+        private void chkAutoRefresh_CheckedChanged(object sender, EventArgs e)
+            tmRefresh.Enabled = chkAutoRefresh.Checked;
+        private void tmRefresh_Tick(object sender, EventArgs e)
Added: sandbox/maestro-3.0/Maestro.Editors/Diagnostics/FdoCacheViewer.resx
--- sandbox/maestro-3.0/Maestro.Editors/Diagnostics/FdoCacheViewer.resx	                        (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/Diagnostics/FdoCacheViewer.resx	2011-03-08 07:55:20 UTC (rev 5604)
@@ -0,0 +1,237 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+    Microsoft ResX Schema
+    Version 2.0
+    The primary goals of this format is to allow a simple XML format
+    that is mostly human readable. The generation and parsing of the
+    various data types are done through the TypeConverter classes
+    associated with the data types.
+    Example:
+    ... ado.net/XML headers & schema ...
+    <resheader name="resmimetype">text/microsoft-resx</resheader>
+    <resheader name="version">2.0</resheader>
+    <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+    <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+    <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+    <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+    <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+        <value>[base64 mime encoded serialized .NET Framework object]</value>
+    </data>
+    <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+        <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+        <comment>This is a comment</comment>
+    </data>
+    There are any number of "resheader" rows that contain simple
+    name/value pairs.
+    Each data row contains a name, and value. The row also contains a
+    type or mimetype. Type corresponds to a .NET class that support
+    text/value conversion through the TypeConverter architecture.
+    Classes that don't support this are serialized and stored with the
+    mimetype set.
+    The mimetype is used for serialized objects, and tells the
+    ResXResourceReader how to depersist the object. This is currently not
+    extensible. For a given mimetype the value must be set accordingly:
+    Note - application/x-microsoft.net.object.binary.base64 is the format
+    that the ResXResourceWriter will generate, however the reader can
+    read any of the formats listed below.
+    mimetype: application/x-microsoft.net.object.binary.base64
+    value   : The object must be serialized with
+            : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+            : and then encoded with base64 encoding.
+    mimetype: application/x-microsoft.net.object.soap.base64
+            : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+    mimetype: application/x-microsoft.net.object.bytearray.base64
+    value   : The object must be serialized into a byte array
+            : using a System.ComponentModel.TypeConverter
+  <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+    <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+    <xsd:element name="root" msdata:IsDataSet="true">
+      <xsd:complexType>
+        <xsd:choice maxOccurs="unbounded">
+          <xsd:element name="metadata">
+            <xsd:complexType>
+              <xsd:sequence>
+                <xsd:element name="value" type="xsd:string" minOccurs="0" />
+              </xsd:sequence>
+              <xsd:attribute name="name" use="required" type="xsd:string" />
+              <xsd:attribute name="type" type="xsd:string" />
+              <xsd:attribute name="mimetype" type="xsd:string" />
+              <xsd:attribute ref="xml:space" />
+            </xsd:complexType>
+          </xsd:element>
+          <xsd:element name="assembly">
+            <xsd:complexType>
+              <xsd:attribute name="alias" type="xsd:string" />
+              <xsd:attribute name="name" type="xsd:string" />
+          </xsd:element>
+          <xsd:element name="data">
+            <xsd:complexType>
+              <xsd:sequence>
+                <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+                <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+              <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+              <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+          </xsd:element>
+          <xsd:element name="resheader">
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" use="required" />
+          </xsd:element>
+        </xsd:choice>
+    </xsd:element>
+  </xsd:schema>
+    <value>text/microsoft-resx</value>
+  </resheader>
+    <value>2.0</value>
+  </resheader>
+    <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </resheader>
+    <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </resheader>
+  <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+  <data name="btnClose.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+    <value>Bottom, Right</value>
+  </data>
+  <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+  <data name="btnClose.Location" type="System.Drawing.Point, System.Drawing">
+    <value>581, 449</value>
+  </data>
+  <data name="btnClose.Size" type="System.Drawing.Size, System.Drawing">
+    <value>75, 23</value>
+  </data>
+  <assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+  <data name="btnClose.TabIndex" type="System.Int32, mscorlib">
+    <value>1</value>
+  </data>
+  <data name="btnClose.Text" xml:space="preserve">
+    <value>Close</value>
+  </data>
+  <data name="&gt;&gt;btnClose.Name" xml:space="preserve">
+    <value>btnClose</value>
+  </data>
+  <data name="&gt;&gt;btnClose.Type" xml:space="preserve">
+    <value>System.Windows.Forms.Button, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name="&gt;&gt;btnClose.Parent" xml:space="preserve">
+    <value>$this</value>
+  </data>
+  <data name="&gt;&gt;btnClose.ZOrder" xml:space="preserve">
+    <value>2</value>
+  </data>
+  <data name="chkAutoRefresh.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+    <value>Bottom, Left</value>
+  </data>
+  <data name="chkAutoRefresh.AutoSize" type="System.Boolean, mscorlib">
+    <value>True</value>
+  </data>
+  <data name="chkAutoRefresh.Location" type="System.Drawing.Point, System.Drawing">
+    <value>12, 453</value>
+  </data>
+  <data name="chkAutoRefresh.Size" type="System.Drawing.Size, System.Drawing">
+    <value>151, 17</value>
+  </data>
+  <data name="chkAutoRefresh.TabIndex" type="System.Int32, mscorlib">
+    <value>2</value>
+  </data>
+  <data name="chkAutoRefresh.Text" xml:space="preserve">
+    <value>Auto-Refresh every 5 secs</value>
+  </data>
+  <data name="&gt;&gt;chkAutoRefresh.Name" xml:space="preserve">
+    <value>chkAutoRefresh</value>
+  </data>
+  <data name="&gt;&gt;chkAutoRefresh.Type" xml:space="preserve">
+    <value>System.Windows.Forms.CheckBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name="&gt;&gt;chkAutoRefresh.Parent" xml:space="preserve">
+  </data>
+  <data name="&gt;&gt;chkAutoRefresh.ZOrder" xml:space="preserve">
+    <value>1</value>
+  </data>
+  <metadata name="tmRefresh.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>17, 17</value>
+  </metadata>
+  <data name="txtXml.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+    <value>Top, Bottom, Left, Right</value>
+  </data>
+  <data name="txtXml.Font" type="System.Drawing.Font, System.Drawing">
+    <value>Courier New, 9.75pt</value>
+  </data>
+  <data name="txtXml.Location" type="System.Drawing.Point, System.Drawing">
+    <value>13, 13</value>
+  </data>
+  <data name="txtXml.Multiline" type="System.Boolean, mscorlib">
+  </data>
+  <data name="txtXml.ScrollBars" type="System.Windows.Forms.ScrollBars, System.Windows.Forms">
+    <value>Vertical</value>
+  </data>
+  <data name="txtXml.Size" type="System.Drawing.Size, System.Drawing">
+    <value>643, 430</value>
+  </data>
+  <data name="txtXml.TabIndex" type="System.Int32, mscorlib">
+    <value>3</value>
+  </data>
+  <data name="&gt;&gt;txtXml.Name" xml:space="preserve">
+    <value>txtXml</value>
+  </data>
+  <data name="&gt;&gt;txtXml.Type" xml:space="preserve">
+    <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name="&gt;&gt;txtXml.Parent" xml:space="preserve">
+  </data>
+  <data name="&gt;&gt;txtXml.ZOrder" xml:space="preserve">
+    <value>0</value>
+  </data>
+  <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+  </metadata>
+  <data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
+    <value>668, 484</value>
+  </data>
+  <data name="$this.Text" xml:space="preserve">
+    <value>Feature Source Cache Information</value>
+  </data>
+  <data name="&gt;&gt;tmRefresh.Name" xml:space="preserve">
+    <value>tmRefresh</value>
+  </data>
+  <data name="&gt;&gt;tmRefresh.Type" xml:space="preserve">
+    <value>System.Windows.Forms.Timer, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name="&gt;&gt;$this.Name" xml:space="preserve">
+    <value>FdoCacheViewer</value>
+  </data>
+  <data name="&gt;&gt;$this.Type" xml:space="preserve">
+    <value>System.Windows.Forms.Form, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+</root>
Modified: sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj
--- sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj	2011-03-07 13:47:28 UTC (rev 5603)
+++ sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj	2011-03-08 07:55:20 UTC (rev 5604)
@@ -107,6 +107,12 @@
     <Compile Include="Common\UnmanagedFileBrowser.Designer.cs">
       <DependentUpon>UnmanagedFileBrowser.cs</DependentUpon>
     </Compile>
+    <Compile Include="Diagnostics\FdoCacheViewer.cs">
+      <SubType>Form</SubType>
+    </Compile>
+    <Compile Include="Diagnostics\FdoCacheViewer.Designer.cs">
+      <DependentUpon>FdoCacheViewer.cs</DependentUpon>
+    </Compile>
     <Compile Include="Diagnostics\ServerStatusMonitor.cs">
     </Compile>
@@ -931,6 +937,9 @@
       <SubType>Designer</SubType>
     </EmbeddedResource>
+    <EmbeddedResource Include="Diagnostics\FdoCacheViewer.resx">
+    </EmbeddedResource>
     <EmbeddedResource Include="Diagnostics\ServerStatusMonitor.resx">
       <DependentUpon>ServerStatusMonitor.cs</DependentUpon>
     </EmbeddedResource>
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Commands/CommandType.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Commands/CommandType.cs	2011-03-07 13:47:28 UTC (rev 5603)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Commands/CommandType.cs	2011-03-08 07:55:20 UTC (rev 5604)
@@ -52,5 +52,9 @@
         /// Creates a data store on a feature source
         /// </summary>
         CreateDataStore,
+        /// <summary>
+        /// Retrieves information about cached FDO connections
+        /// </summary>
+        GetFdoCacheInfo
Added: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Commands/IGetFdoCacheInfo.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Commands/IGetFdoCacheInfo.cs	                        (rev 0)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Commands/IGetFdoCacheInfo.cs	2011-03-08 07:55:20 UTC (rev 5604)
@@ -0,0 +1,151 @@
+#endregion
+using System;
+using System.Text;
+using System.Xml.Serialization;
+namespace OSGeo.MapGuide.MaestroAPI.Commands
+    public interface IGetFdoCacheInfo : ICommand
+        FdoCacheInfo Execute();
+    [XmlRoot(ElementName = "FdoCacheInformation")]
+    public class FdoCacheInfo
+        private static XmlSerializer smSerializer;
+        public static XmlSerializer Serializer
+            get
+                if (null == smSerializer)
+                    smSerializer = new XmlSerializer(typeof(FdoCacheInfo));
+                return smSerializer;
+        [XmlElement]
+        public DateTime TimeStamp { get; set; }
+        [XmlElement(ElementName = "ConfigurationSettings")]
+        [DisplayName("Configuration Settings")]
+        public ConfigurationSettings Configuration { get; set; }
+        [XmlElement(ElementName = "Provider")]
+        [DisplayName("Cached FDO Providers")]
+        public CachedProviderInfo[] Providers { get; set; }
+    [Serializable]
+    public class CachedFdoConnection
+        [XmlElement]
+        [DisplayName("Feature Source")]
+        public string Name { get; set; }
+        [XmlElement]
+        public string ConnectionState { get; set; }
+        [XmlElement]
+        public string InUse { get; set; }
+        [XmlElement]
+        public int UseCount { get; set; }
+        [XmlElement]
+        public string LongTransaction { get; set; }
+        [XmlElement]
+        public DateTime LastUsed { get; set; }
+        [XmlElement]
+        public string Valid { get; set; }
+    [Serializable]
+    public class CachedProviderInfo
+        [XmlElement(ElementName = "Name")]
+        public string FeatureSourceId { get; set; }
+        [XmlElement]
+        public int MaximumDataConnectionPoolSize { get; set; }
+        [XmlElement]
+        public int CurrentDataConnectionPoolSize { get; set; }
+        [XmlElement]
+        public int CurrentDataConnections { get; set; }
+        [XmlElement]
+        public string ThreadModel { get; set; }
+        [XmlElement]
+        public string KeepDataConnectionsCached { get; set; }
+        [XmlElement(ElementName = "CachedFdoConnection")]
+        [DisplayName("Cached Feature Sources")]
+        public CachedFdoConnection[] CachedFdoConnections { get; set; }
+    [Serializable]
+    public class ConfigurationSettings
+        [XmlElement]
+        public string DataConnectionPoolEnabled { get; set; }
+        [XmlElement]
+        public string DataConnectionPoolExcludedProviders { get; set; }
+        [XmlElement]
+        public int DataConnectionPoolSize { get; set; }
+        [XmlElement]
+        public string DataConnectionPoolSizeCustom { get; set; }
+        [XmlElement]
+        public int DataConnectionTimeout { get; set; }
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj	2011-03-07 13:47:28 UTC (rev 5603)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj	2011-03-08 07:55:20 UTC (rev 5604)
@@ -174,6 +174,7 @@
     </Compile>
     <Compile Include="ArgumentParser.cs" />
     <Compile Include="BindingListExtensions.cs" />
+    <Compile Include="Commands\IGetFdoCacheInfo.cs" />
     <Compile Include="Commands\IGetResourceContents.cs" />
     <Compile Include="Capability\ConnectionCapabilities.cs" />
     <Compile Include="Check.cs" />
Added: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/Commands/HttpGetFdoCacheInfo.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/Commands/HttpGetFdoCacheInfo.cs	                        (rev 0)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/Commands/HttpGetFdoCacheInfo.cs	2011-03-08 07:55:20 UTC (rev 5604)
@@ -0,0 +1,43 @@
+#endregion
+using System;
+using System.Text;
+namespace OSGeo.MapGuide.MaestroAPI.Http.Commands
+    public class HttpGetFdoCacheInfo : IGetFdoCacheInfo
+        private HttpServerConnection _conn;
+        internal HttpGetFdoCacheInfo(HttpServerConnection conn)
+            _conn = conn;
+        public IServerConnection Parent { get { return _conn; } }
+        public FdoCacheInfo Execute()
+            return _conn.GetFdoCacheInfo();
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpCapabilities.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpCapabilities.cs	2011-03-07 13:47:28 UTC (rev 5603)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpCapabilities.cs	2011-03-08 07:55:20 UTC (rev 5604)
@@ -38,7 +38,8 @@
                 //TODO: Work out what this can/can't do
                 return new int[]
-                    (int)CommandType.GetResourceContents
+                    (int)CommandType.GetResourceContents,
+                    (int)CommandType.GetFdoCacheInfo
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs	2011-03-07 13:47:28 UTC (rev 5603)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs	2011-03-08 07:55:20 UTC (rev 5604)
@@ -1732,7 +1732,20 @@
             CommandType ct = (CommandType)cmdType;
             if (ct == CommandType.GetResourceContents)
                 return new HttpGetResourceContents(this);
+            else if (ct == CommandType.GetFdoCacheInfo)
+                return new HttpGetFdoCacheInfo(this);
             return base.CreateCommand(cmdType);
+        internal FdoCacheInfo GetFdoCacheInfo()
+            var req = m_reqBuilder.GetFdoCacheInfo();
+            using (var s = this.OpenRead(req))
+                var info = this.DeserializeObject<FdoCacheInfo>(s);
+                return info;
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/OSGeo.MapGuide.MaestroAPI.Http.csproj
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/OSGeo.MapGuide.MaestroAPI.Http.csproj	2011-03-07 13:47:28 UTC (rev 5603)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/OSGeo.MapGuide.MaestroAPI.Http.csproj	2011-03-08 07:55:20 UTC (rev 5604)
@@ -51,6 +51,7 @@
     <Compile Include="..\Properties\SignedAssemblyInfo.cs">
       <Link>SignedAssemblyInfo.cs</Link>
     </Compile>
+    <Compile Include="Commands\HttpGetFdoCacheInfo.cs" />
     <Compile Include="HttpCapabilities.cs" />
     <Compile Include="HttpCoordinateSystem.cs" />
     <Compile Include="HttpCoordinateSystemCatalog.cs" />
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/RequestBuilder.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/RequestBuilder.cs	2011-03-07 13:47:28 UTC (rev 5603)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/RequestBuilder.cs	2011-03-08 07:55:20 UTC (rev 5604)
@@ -1539,5 +1539,17 @@
             return req;
+        internal string GetFdoCacheInfo()
+            NameValueCollection param = new NameValueCollection();
+            param.Add("OPERATION", "GETFDOCACHEINFO");
+            param.Add("VERSION", "1.0.0");
+            param.Add("SESSION", m_sessionID);
+            param.Add("FORMAT", "text/xml");
+            param.Add("CLIENTAGENT", m_userAgent);
+            return m_hosturi + "?" + EncodeParameters(param);
More information about the mapguide-commits mailing list
