[mapguide-commits] r5617 - in trunk/Tools/Maestro: Maestro.Base Maestro.Base/UI Maestro.Editors/Generic OSGeo.MapGuide.MaestroAPI/ObjectModels
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sun Mar 13 11:44:22 EDT 2011
Author: jng
Date: 2011-03-13 08:44:22 -0700 (Sun, 13 Mar 2011)
New Revision: 5617
   trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin
   trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.Designer.cs
   trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.cs
   trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.resx
   trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditorCtrl.resx
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/SymbolDefinition.cs
Fix #1508: The Cut/Copy/Paste commands for the XML editor was being suppressed because the Ctrl+C/X/V keys were already assigned to the global Cut/Copy/Paste commands for the site explorer. This submission removes the keys assignment to the site explorer commands. Instead the SiteExplorer handles the keypress directly and invokes the appropriate command. This way the Ctrl+C/X/V handler for the XML editor does not conflict with the same handler for the Site Explorer.
Also in this submission, apply a whole series of [XmlIgnore] attributes to explicit interface properties which I'm sure Mono will attempt to serialize/deserialize
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin	2011-03-09 16:53:02 UTC (rev 5616)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin	2011-03-13 15:44:22 UTC (rev 5617)
@@ -125,12 +125,10 @@
                     <MenuItem id="CopyItem"
                               icon="document_copy"
                               label="${res:Menu_Edit_Copy}"
-                              shortcut="Control|C"
                               class="Maestro.Base.Commands.CopyCommand" />
                     <MenuItem id="CutItem"
                               label="${res:Menu_Edit_Cut}"
                               icon="scissors_blue"
-                              shortcut="Control|X"
                               class="Maestro.Base.Commands.CutCommand" />
                 </Condition>
             </Condition>
@@ -138,7 +136,6 @@
                 <MenuItem id="PasteItem"
                           label="${res:Menu_Edit_Paste}"
                           icon="clipboard_paste"
-                          shortcut="Control|V"
                           class="Maestro.Base.Commands.PasteCommand" />
             </Condition>
         </MenuItem>
@@ -409,10 +406,12 @@
                     <MenuItem id="Copy"
                               label="${res:SiteExplorer_SelectedItem_Copy}"
+                              shortcut="Control|C"
                     <MenuItem id="Cut"
                               label="${res:SiteExplorer_SelectedItem_Cut}"
+                              shortcut="Control|X"
                 </Condition>
             </Condition>
@@ -420,6 +419,7 @@
                 <MenuItem id="Paste"
                           label="${res:SiteExplorer_SelectedFolder_Paste}"
+                          shortcut="Control|V"
             </Condition>
             <MenuItem type="Separator" />
@@ -447,10 +447,12 @@
                 <MenuItem id="Copy"
                 <MenuItem id="Cut"
             </Condition>
             <MenuItem id="Validate"
@@ -487,10 +489,12 @@
                 <MenuItem id="Copy"
                 <MenuItem id="Cut"
             </Condition>
@@ -531,10 +535,12 @@
                 <MenuItem id="Copy"
                 <MenuItem id="Cut"
             </Condition>
@@ -564,10 +570,12 @@
                 <MenuItem id="Copy"
                 <MenuItem id="Cut"
             </Condition>
Modified: trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.Designer.cs	2011-03-09 16:53:02 UTC (rev 5616)
+++ trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.Designer.cs	2011-03-13 15:44:22 UTC (rev 5617)
@@ -65,6 +65,7 @@
             this.trvResources.Expanding += new System.EventHandler<Aga.Controls.Tree.TreeViewAdvEventArgs>(this.trvResources_Expanding);
             this.trvResources.DragEnter += new System.Windows.Forms.DragEventHandler(this.trvResources_DragEnter);
             this.trvResources.KeyUp += new System.Windows.Forms.KeyEventHandler(this.trvResources_KeyUp);
+            this.trvResources.KeyDown += new System.Windows.Forms.KeyEventHandler(this.trvResources_KeyDown);
             this.trvResources.Expanded += new System.EventHandler<Aga.Controls.Tree.TreeViewAdvEventArgs>(this.trvResources_Expanded);
             this.trvResources.ItemDrag += new System.Windows.Forms.ItemDragEventHandler(this.trvResources_ItemDrag);
Modified: trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.cs	2011-03-09 16:53:02 UTC (rev 5616)
+++ trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.cs	2011-03-13 15:44:22 UTC (rev 5617)
@@ -472,5 +472,32 @@
                 new DeleteSelectedItemsCommand().Run();
+        private void trvResources_KeyDown(object sender, KeyEventArgs e)
+            //Note: Even though the attached context menu has the shortcuts specified
+            //for Cut/Copy/Paste, I'm guessing the TreeViewAdv control is muffling the
+            //event. Nevertheless this handler's got it covered and keeping those
+            //shortcuts there is useful as a visual reference, even if they don't work
+            //the original way.
+            //Note: We handle keydown when intercepting pressing the Control+C/X/V
+            //because the keys are not actually released yet.
+            if (e.Control)
+                switch (e.KeyCode)
+                    case Keys.C:
+                        new CopyCommand().Run();
+                        break;
+                    case Keys.X:
+                        new CutCommand().Run();
+                        break;
+                    case Keys.V:
+                        new PasteCommand().Run();
+                        break;
Modified: trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.resx
--- trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.resx	2011-03-09 16:53:02 UTC (rev 5616)
+++ trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.resx	2011-03-13 15:44:22 UTC (rev 5617)
@@ -118,7 +118,7 @@
     <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </resheader>
   <metadata name="tsSiteExplorer.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>17, 17</value>
+    <value>0, 0</value>
   </metadata>
   <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
   <data name="tsSiteExplorer.Location" type="System.Drawing.Point, System.Drawing">
@@ -193,6 +193,6 @@
     <value>SiteExplorer</value>
   </data>
   <data name="&gt;&gt;$this.Type" xml:space="preserve">
-    <value>Maestro.Base.ViewContentBase, Maestro.Base, Version=3.0.0.5334, Culture=neutral, PublicKeyToken=null</value>
+    <value>Maestro.Base.ViewContentBase, Maestro.Base, Version=3.0.0.5610, Culture=neutral, PublicKeyToken=null</value>
   </data>
 </root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditorCtrl.resx
--- trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditorCtrl.resx	2011-03-09 16:53:02 UTC (rev 5616)
+++ trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditorCtrl.resx	2011-03-13 15:44:22 UTC (rev 5617)
@@ -330,7 +330,7 @@
     <value>resDataCtrl</value>
   </data>
   <data name="&gt;&gt;resDataCtrl.Type" xml:space="preserve">
-    <value>Maestro.Editors.Generic.ResourceDataPanel, Maestro.Editors, Version=3.0.0.5475, Culture=neutral, PublicKeyToken=null</value>
+    <value>Maestro.Editors.Generic.ResourceDataPanel, Maestro.Editors, Version=3.0.0.5610, Culture=neutral, PublicKeyToken=null</value>
   </data>
   <data name="&gt;&gt;resDataCtrl.Parent" xml:space="preserve">
     <value>$this</value>
@@ -450,6 +450,6 @@
     <value>XmlEditorCtrl</value>
   </data>
-    <value>Maestro.Editors.EditorBase, Maestro.Editors, Version=3.0.0.5475, Culture=neutral, PublicKeyToken=null</value>
+    <value>Maestro.Editors.EditorBase, Maestro.Editors, Version=3.0.0.5610, Culture=neutral, PublicKeyToken=null</value>
   </data>
 </root>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/SymbolDefinition.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/SymbolDefinition.cs	2011-03-09 16:53:02 UTC (rev 5616)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/SymbolDefinition.cs	2011-03-13 15:44:22 UTC (rev 5617)
@@ -120,6 +120,7 @@
             get { return true; }
+        [XmlIgnore]
         IEnumerable<IGraphicBase> ISimpleSymbolDefinition.Graphics
             get
@@ -149,6 +150,7 @@
+        [XmlIgnore]
         IResizeBox ISimpleSymbolDefinition.ResizeBox
             get
@@ -161,6 +163,7 @@
+        [XmlIgnore]
         IPointUsage ISimpleSymbolDefinition.PointUsage
             get
@@ -173,6 +176,7 @@
+        [XmlIgnore]
         ILineUsage ISimpleSymbolDefinition.LineUsage
             get
@@ -185,6 +189,7 @@
+        [XmlIgnore]
         IAreaUsage ISimpleSymbolDefinition.AreaUsage
             get
@@ -197,6 +202,7 @@
+        [XmlIgnore]
         IParameterDefinition ISimpleSymbolDefinition.ParameterDefinition
             get { return parameterDefinitionField; }
@@ -209,7 +215,7 @@
     partial class Text : IText
 #endif
+        [XmlIgnore]
         bool? IText.Bold
             get
@@ -228,6 +234,7 @@
+        [XmlIgnore]
         bool? IText.Italic
             get
@@ -246,6 +253,7 @@
+        [XmlIgnore]
         bool? IText.Underlined
             get
@@ -264,6 +272,7 @@
+        [XmlIgnore]
         double? IText.Height
             get
@@ -282,6 +291,7 @@
+        [XmlIgnore]
         bool? IText.HeightScalable
             get
@@ -300,6 +310,7 @@
+        [XmlIgnore]
         double? IText.Angle
             get
@@ -318,6 +329,7 @@
+        [XmlIgnore]
         double? IText.PositionX
             get
@@ -336,6 +348,7 @@
+        [XmlIgnore]
         double? IText.PositionY
             get
@@ -354,6 +367,7 @@
+        [XmlIgnore]
         double? IText.LineSpacing
             get
@@ -372,6 +386,7 @@
+        [XmlIgnore]
         ITextFrame IText.Frame
             get
@@ -387,6 +402,7 @@
     partial class TextFrame : ITextFrame
+        [XmlIgnore]
         double? ITextFrame.OffsetX
             get
@@ -405,6 +421,7 @@
+        [XmlIgnore]
         double? ITextFrame.OffsetY
             get
@@ -426,6 +443,7 @@
     partial class ResizeBox : IResizeBox
+        [XmlIgnore]
         double? IResizeBox.SizeX
             get
@@ -444,6 +462,7 @@
+        [XmlIgnore]
         double? IResizeBox.SizeY
             get
@@ -462,6 +481,7 @@
+        [XmlIgnore]
         double? IResizeBox.PositionX
             get
@@ -480,6 +500,7 @@
+        [XmlIgnore]
         double? IResizeBox.PositionY
             get
@@ -501,6 +522,7 @@
     partial class Graphics : IGraphics
+        [XmlIgnore]
         public IEnumerable<IGraphicBase> Elements
             get
@@ -538,6 +560,7 @@
     partial class Parameter : IParameter
+        [XmlIgnore]
         string IParameter.DataType
             get
@@ -558,6 +581,7 @@
     partial class ParameterDefinition : IParameterDefinition
+        [XmlIgnore]
         IEnumerable<IParameter> IParameterDefinition.Parameter
             get
@@ -590,6 +614,7 @@
     partial class LineUsage : ILineUsage
+        [XmlIgnore]
         double? ILineUsage.StartOffset
             get
@@ -608,6 +633,7 @@
+        [XmlIgnore]
         double? ILineUsage.EndOffset
             get
@@ -626,6 +652,7 @@
+        [XmlIgnore]
         double? ILineUsage.Repeat
             get
@@ -644,6 +671,7 @@
+        [XmlIgnore]
         double? ILineUsage.VertexAngleLimit
             get
@@ -662,6 +690,7 @@
+        [XmlIgnore]
         IPath ILineUsage.DefaultPath
             get
@@ -674,7 +703,7 @@
+        [XmlIgnore]
         double? IUsageBase.Angle
             get
@@ -696,6 +725,7 @@
     partial class PointUsage : IPointUsage
+        [XmlIgnore]
         double? IPointUsage.OriginOffsetX
             get
@@ -714,6 +744,7 @@
+        [XmlIgnore]
         double? IPointUsage.OriginOffsetY
             get
@@ -732,6 +763,7 @@
+        [XmlIgnore]
         string IUsageBase.AngleControl
             get
@@ -744,6 +776,7 @@
+        [XmlIgnore]
             get
@@ -765,6 +798,7 @@
     partial class AreaUsage : IAreaUsage
+        [XmlIgnore]
         double? IAreaUsage.OriginX
             get
@@ -783,6 +817,7 @@
+        [XmlIgnore]
         double? IAreaUsage.OriginY
             get
@@ -801,6 +836,7 @@
+        [XmlIgnore]
         double? IAreaUsage.RepeatX
             get
@@ -819,6 +855,7 @@
+        [XmlIgnore]
         double? IAreaUsage.RepeatY
             get
@@ -837,6 +874,7 @@
+        [XmlIgnore]
         double? IAreaUsage.BufferWidth
             get
@@ -855,6 +893,7 @@
+        [XmlIgnore]
             get
@@ -876,6 +915,7 @@
     partial class Path : IPath
+        [XmlIgnore]
         double? IPath.LineWeight
             get
@@ -894,6 +934,7 @@
+        [XmlIgnore]
         bool? IPath.LineWeightScalable
             get
@@ -912,6 +953,7 @@
+        [XmlIgnore]
         double? IPath.LineMiterLimit
             get
@@ -1010,6 +1052,7 @@
+        [XmlIgnore]
         IEnumerable<ISimpleSymbolReferenceBase> ICompoundSymbolDefinition.SimpleSymbol
             get
@@ -1042,6 +1085,7 @@
     partial class SimpleSymbol : ISimpleSymbolInlineReference, ISimpleSymbolLibraryReference
+        [XmlIgnore]
         ISimpleSymbolDefinition ISimpleSymbolInlineReference.SimpleSymbolDefinition
             get
@@ -1054,6 +1098,7 @@
+        [XmlIgnore]
         public SimpleSymbolReferenceType Type
             get
@@ -1069,6 +1114,7 @@
+        [XmlIgnore]
         string ISimpleSymbolLibraryReference.ResourceId
             get
@@ -1092,6 +1138,7 @@
     partial class ImageReference : ISymbolLibraryReference
+        [XmlIgnore]
         SymbolInstanceType ISymbolInstanceReference.Type
             get { return SymbolInstanceType.Reference; }
More information about the mapguide-commits mailing list
