[mapguide-commits] r5632 - in trunk/Tools/Maestro/Maestro.Base: . Commands/SiteExplorer Properties UI
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Mar 16 07:04:41 EDT 2011
Author: jng
Date: 2011-03-16 04:04:41 -0700 (Wed, 16 Mar 2011)
New Revision: 5632
Added:
   trunk/Tools/Maestro/Maestro.Base/UI/NewFolderDialog.Designer.cs
   trunk/Tools/Maestro/Maestro.Base/UI/NewFolderDialog.cs
   trunk/Tools/Maestro/Maestro.Base/UI/NewFolderDialog.resx
   trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/NewFolderCommand.cs
   trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
   trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
   trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
Fix #1595: New folder improvement
Modified: trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/NewFolderCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/NewFolderCommand.cs	2011-03-16 10:47:26 UTC (rev 5631)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/NewFolderCommand.cs	2011-03-16 11:04:41 UTC (rev 5632)
@@ -22,6 +22,7 @@
 using System.Text;
 using ICSharpCode.Core;
 using Maestro.Base.Services;
+using Maestro.Base.UI;
 namespace Maestro.Base.Commands.SiteExplorer
@@ -46,14 +47,27 @@
                         counter++;
                         name = defaultName + counter;
-                    //conn.ResourceService.CreateFolder(item.ResourceId + name);
-                    conn.ResourceService.SetResourceXmlData(item.ResourceId + name + "/", null);
-                    var path = item.Model.GetPath(item);
-                    item.Model.RaiseStructureChanged(new Aga.Controls.Tree.TreeModelEventArgs(path, new object[0]));
-                    //Expand so user can see this new folder
-                    exp.ExpandNode(item.ResourceId);
-                    exp.SelectNode(item.ResourceId + name + "/");
+                    List<string> folderNames = new List<string>();
+                    foreach (var child in item.Children)
+                        if (child.IsFolder)
+                            folderNames.Add(child.Name);
+                    var diag = new NewFolderDialog(name, folderNames.ToArray());
+                    if (diag.ShowDialog() == System.Windows.Forms.DialogResult.OK)
+                        name = diag.FolderName;
+                        //conn.ResourceService.CreateFolder(item.ResourceId + name);
+                        conn.ResourceService.SetResourceXmlData(item.ResourceId + name + "/", null);
+                        var path = item.Model.GetPath(item);
+                        item.Model.RaiseStructureChanged(new Aga.Controls.Tree.TreeModelEventArgs(path, new object[0]));
+                        //Expand so user can see this new folder
+                        exp.ExpandNode(item.ResourceId);
+                        exp.SelectNode(item.ResourceId + name + "/");
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj	2011-03-16 10:47:26 UTC (rev 5631)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj	2011-03-16 11:04:41 UTC (rev 5632)
@@ -259,6 +259,12 @@
     <Compile Include="UI\MessageViewer.Designer.cs">
       <DependentUpon>MessageViewer.cs</DependentUpon>
     </Compile>
+    <Compile Include="UI\NewFolderDialog.cs">
+      <SubType>Form</SubType>
+    </Compile>
+    <Compile Include="UI\NewFolderDialog.Designer.cs">
+      <DependentUpon>NewFolderDialog.cs</DependentUpon>
+    </Compile>
     <Compile Include="UI\NewResourceDialog.cs">
     </Compile>
@@ -457,6 +463,9 @@
       <SubType>Designer</SubType>
     </EmbeddedResource>
+    <EmbeddedResource Include="UI\NewFolderDialog.resx">
+    </EmbeddedResource>
     <EmbeddedResource Include="UI\NewResourceDialog.resx">
       <DependentUpon>NewResourceDialog.cs</DependentUpon>
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs	2011-03-16 10:47:26 UTC (rev 5631)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs	2011-03-16 11:04:41 UTC (rev 5632)
@@ -663,6 +663,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to Folder name already exists.
+        /// </summary>
+        internal static string FolderNameExists {
+            get {
+                return ResourceManager.GetString("FolderNameExists", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to Error.
         /// </summary>
         internal static string Global_ErrorText {
@@ -1202,6 +1211,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to Required.
+        /// </summary>
+        internal static string Required {
+            get {
+                return ResourceManager.GetString("Required", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to This resource is already opened in another editor.
         /// </summary>
         internal static string ResourceAlreadyOpened {
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx	2011-03-16 10:47:26 UTC (rev 5631)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx	2011-03-16 11:04:41 UTC (rev 5632)
@@ -844,4 +844,10 @@
   <data name="DefaultSymbolName" xml:space="preserve">
     <value>MySymbol</value>
   </data>
+  <data name="Required" xml:space="preserve">
+    <value>Required</value>
+  </data>
+  <data name="FolderNameExists" xml:space="preserve">
+    <value>Folder name already exists</value>
+  </data>
 </root>
\ No newline at end of file
Added: trunk/Tools/Maestro/Maestro.Base/UI/NewFolderDialog.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/NewFolderDialog.Designer.cs	                        (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/UI/NewFolderDialog.Designer.cs	2011-03-16 11:04:41 UTC (rev 5632)
@@ -0,0 +1,116 @@
+namespace Maestro.Base.UI
+    partial class NewFolderDialog
+        /// <summary>
+        /// Required designer variable.
+        /// </summary>
+        private System.ComponentModel.IContainer components = null;
+        /// <summary>
+        /// Clean up any resources being used.
+        /// </summary>
+        /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+        protected override void Dispose(bool disposing)
+            if (disposing && (components != null))
+                components.Dispose();
+            base.Dispose(disposing);
+        #region Windows Form Designer generated code
+        /// <summary>
+        /// Required method for Designer support - do not modify
+        /// the contents of this method with the code editor.
+        /// </summary>
+        private void InitializeComponent()
+            this.components = new System.ComponentModel.Container();
+            this.label1 = new System.Windows.Forms.Label();
+            this.txtName = new System.Windows.Forms.TextBox();
+            this.btnCreate = new System.Windows.Forms.Button();
+            this.btnCancel = new System.Windows.Forms.Button();
+            this.errorProvider = new System.Windows.Forms.ErrorProvider(this.components);
+            ((System.ComponentModel.ISupportInitialize)(this.errorProvider)).BeginInit();
+            this.SuspendLayout();
+            // label1
+            this.label1.AutoSize = true;
+            this.label1.Location = new System.Drawing.Point(13, 13);
+            this.label1.Name = "label1";
+            this.label1.Size = new System.Drawing.Size(67, 13);
+            this.label1.TabIndex = 0;
+            this.label1.Text = "Folder Name";
+            // txtName
+            this.txtName.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+                        | System.Windows.Forms.AnchorStyles.Right)));
+            this.txtName.Location = new System.Drawing.Point(16, 30);
+            this.txtName.Name = "txtName";
+            this.txtName.Size = new System.Drawing.Size(252, 20);
+            this.txtName.TabIndex = 1;
+            this.txtName.TextChanged += new System.EventHandler(this.txtName_TextChanged);
+            // btnCreate
+            this.btnCreate.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Bottom | System.Windows.Forms.AnchorStyles.Right)));
+            this.btnCreate.Enabled = false;
+            this.btnCreate.Location = new System.Drawing.Point(112, 56);
+            this.btnCreate.Name = "btnCreate";
+            this.btnCreate.Size = new System.Drawing.Size(75, 23);
+            this.btnCreate.TabIndex = 2;
+            this.btnCreate.Text = "Create";
+            this.btnCreate.UseVisualStyleBackColor = true;
+            this.btnCreate.Click += new System.EventHandler(this.btnCreate_Click);
+            // btnCancel
+            this.btnCancel.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Bottom | System.Windows.Forms.AnchorStyles.Right)));
+            this.btnCancel.DialogResult = System.Windows.Forms.DialogResult.Cancel;
+            this.btnCancel.Location = new System.Drawing.Point(193, 56);
+            this.btnCancel.Name = "btnCancel";
+            this.btnCancel.Size = new System.Drawing.Size(75, 23);
+            this.btnCancel.TabIndex = 3;
+            this.btnCancel.Text = "Cancel";
+            this.btnCancel.UseVisualStyleBackColor = true;
+            this.btnCancel.Click += new System.EventHandler(this.btnCancel_Click);
+            // errorProvider
+            this.errorProvider.ContainerControl = this;
+            // NewFolderDialog
+            this.AcceptButton = this.btnCreate;
+            this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
+            this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+            this.CancelButton = this.btnCancel;
+            this.ClientSize = new System.Drawing.Size(293, 88);
+            this.ControlBox = false;
+            this.Controls.Add(this.btnCancel);
+            this.Controls.Add(this.btnCreate);
+            this.Controls.Add(this.txtName);
+            this.Controls.Add(this.label1);
+            this.Name = "NewFolderDialog";
+            this.StartPosition = System.Windows.Forms.FormStartPosition.CenterParent;
+            this.Text = "Create New Folder";
+            ((System.ComponentModel.ISupportInitialize)(this.errorProvider)).EndInit();
+            this.ResumeLayout(false);
+            this.PerformLayout();
+        #endregion
+        private System.Windows.Forms.Label label1;
+        private System.Windows.Forms.TextBox txtName;
+        private System.Windows.Forms.Button btnCreate;
+        private System.Windows.Forms.Button btnCancel;
+        private System.Windows.Forms.ErrorProvider errorProvider;
Added: trunk/Tools/Maestro/Maestro.Base/UI/NewFolderDialog.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/NewFolderDialog.cs	                        (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/UI/NewFolderDialog.cs	2011-03-16 11:04:41 UTC (rev 5632)
@@ -0,0 +1,71 @@
+#region Disclaimer / License
+// Copyright (C) 2011, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Data;
+using System.Drawing;
+using System.Text;
+using System.Windows.Forms;
+    public partial class NewFolderDialog : Form
+        private List<string> _folderNames;
+        public NewFolderDialog(string name, string [] folderNames)
+            InitializeComponent();
+            _folderNames = new List<string>(folderNames);
+            txtName.Text = name;
+        public string FolderName { get { return txtName.Text; } }
+        private void btnCancel_Click(object sender, EventArgs e)
+            this.DialogResult = DialogResult.Cancel;
+        private void btnCreate_Click(object sender, EventArgs e)
+            this.DialogResult = DialogResult.OK;
+        private void txtName_TextChanged(object sender, EventArgs e)
+            errorProvider.Clear();
+            btnCreate.Enabled = false;
+            if (string.IsNullOrEmpty(txtName.Text))
+                errorProvider.SetError(txtName, Properties.Resources.Required);
+                return;
+            else if (_folderNames.Contains(txtName.Text))
+                errorProvider.SetError(txtName, Properties.Resources.FolderNameExists);
+                return;
+            btnCreate.Enabled = true;
Added: trunk/Tools/Maestro/Maestro.Base/UI/NewFolderDialog.resx
--- trunk/Tools/Maestro/Maestro.Base/UI/NewFolderDialog.resx	                        (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/UI/NewFolderDialog.resx	2011-03-16 11:04:41 UTC (rev 5632)
@@ -0,0 +1,123 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+    Microsoft ResX Schema
+    Version 2.0
+    The primary goals of this format is to allow a simple XML format
+    that is mostly human readable. The generation and parsing of the
+    various data types are done through the TypeConverter classes
+    associated with the data types.
+    Example:
+    ... ado.net/XML headers & schema ...
+    <resheader name="resmimetype">text/microsoft-resx</resheader>
+    <resheader name="version">2.0</resheader>
+    <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+    <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+    <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+    <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+    <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+        <value>[base64 mime encoded serialized .NET Framework object]</value>
+    </data>
+    <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+        <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+        <comment>This is a comment</comment>
+    </data>
+    There are any number of "resheader" rows that contain simple
+    name/value pairs.
+    Each data row contains a name, and value. The row also contains a
+    type or mimetype. Type corresponds to a .NET class that support
+    text/value conversion through the TypeConverter architecture.
+    Classes that don't support this are serialized and stored with the
+    mimetype set.
+    The mimetype is used for serialized objects, and tells the
+    ResXResourceReader how to depersist the object. This is currently not
+    extensible. For a given mimetype the value must be set accordingly:
+    Note - application/x-microsoft.net.object.binary.base64 is the format
+    that the ResXResourceWriter will generate, however the reader can
+    read any of the formats listed below.
+    mimetype: application/x-microsoft.net.object.binary.base64
+    value   : The object must be serialized with
+            : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+            : and then encoded with base64 encoding.
+    mimetype: application/x-microsoft.net.object.soap.base64
+            : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+    mimetype: application/x-microsoft.net.object.bytearray.base64
+    value   : The object must be serialized into a byte array
+            : using a System.ComponentModel.TypeConverter
+  <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+    <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+    <xsd:element name="root" msdata:IsDataSet="true">
+      <xsd:complexType>
+        <xsd:choice maxOccurs="unbounded">
+          <xsd:element name="metadata">
+            <xsd:complexType>
+              <xsd:sequence>
+                <xsd:element name="value" type="xsd:string" minOccurs="0" />
+              </xsd:sequence>
+              <xsd:attribute name="name" use="required" type="xsd:string" />
+              <xsd:attribute name="type" type="xsd:string" />
+              <xsd:attribute name="mimetype" type="xsd:string" />
+              <xsd:attribute ref="xml:space" />
+            </xsd:complexType>
+          </xsd:element>
+          <xsd:element name="assembly">
+            <xsd:complexType>
+              <xsd:attribute name="alias" type="xsd:string" />
+              <xsd:attribute name="name" type="xsd:string" />
+          </xsd:element>
+          <xsd:element name="data">
+            <xsd:complexType>
+              <xsd:sequence>
+                <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+                <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+              <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+              <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+          </xsd:element>
+          <xsd:element name="resheader">
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" use="required" />
+          </xsd:element>
+        </xsd:choice>
+    </xsd:element>
+  </xsd:schema>
+    <value>text/microsoft-resx</value>
+  </resheader>
+    <value>2.0</value>
+  </resheader>
+    <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </resheader>
+    <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </resheader>
+  <metadata name="errorProvider.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>17, 17</value>
+  </metadata>
+</root>
More information about the mapguide-commits mailing list
