[mapguide-commits] r5646 - trunk/Tools/Maestro/Maestro.Editors/MapDefinition
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Mar 21 07:43:48 EDT 2011
Author: jng
Date: 2011-03-21 04:43:48 -0700 (Mon, 21 Mar 2011)
New Revision: 5646
   trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs
#1631: Hook up del keypress to delete current selected item
Modified: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs	2011-03-21 11:07:41 UTC (rev 5645)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs	2011-03-21 11:43:48 UTC (rev 5646)
@@ -46,8 +46,57 @@
         public MapLayersSectionCtrl()
             InitializeComponent();
+            trvBaseLayers.KeyUp += new KeyEventHandler(trvBaseLayers_KeyUp);
+            trvLayerDrawingOrder.KeyUp += new KeyEventHandler(trvLayerDrawingOrder_KeyUp);
+            trvLayersGroup.KeyUp += new KeyEventHandler(trvLayersGroup_KeyUp);
+        void trvLayersGroup_KeyUp(object sender, KeyEventArgs e)
+            if (e.KeyCode == Keys.Delete)
+                var group = GetSelectedLayerGroupItem() as GroupItem;
+                var layer = GetSelectedLayerGroupItem() as LayerItem;
+                if (layer != null)
+                    RemoveSelectedLayerGroupItem(layer);
+                else if (group != null)
+                    RemoveSelectedLayerGroupItem(group);
+        void trvLayerDrawingOrder_KeyUp(object sender, KeyEventArgs e)
+                var layer = GetSelectedDrawOrderItem() as LayerItem;
+                    RemoveSelectedDrawOrderLayerItem(layer);
+        void trvBaseLayers_KeyUp(object sender, KeyEventArgs e)
+                var group = GetSelectedTiledLayerItem() as BaseLayerGroupItem;
+                var layer = GetSelectedTiledLayerItem() as BaseLayerItem;
+                if (group != null)
+                    RemoveSelectedTiledLayerItem(group);
+                else if (layer != null)
+                    RemoveSelectedTiledLayerItem(layer);
         private IMapDefinition _map;
         private DrawOrderLayerModel _doLayerModel;
@@ -158,6 +207,11 @@
         private void btnRemoveGroup_Click(object sender, EventArgs e)
+        private void RemoveSelectedLayerGroupItem(GroupItem group)
             _map.RemoveGroup(group.Tag);
             propertiesPanel.Controls.Clear();
             _grpLayerModel.Invalidate();
@@ -183,12 +237,17 @@
             if (layer != null)
-                _map.RemoveLayer(layer.Tag);
-                propertiesPanel.Controls.Clear();
-                this.RefreshModels();
+        private void RemoveSelectedLayerGroupItem(LayerItem layer)
+            _map.RemoveLayer(layer.Tag);
+            propertiesPanel.Controls.Clear();
+            this.RefreshModels();
         private void btnConvertLayerGroupToBaseGroup_Click(object sender, EventArgs e)
@@ -218,12 +277,17 @@
             if (layer != null)
+        private void RemoveSelectedDrawOrderLayerItem(LayerItem layer)
         private void btnDLMoveLayerUp_Click(object sender, EventArgs e)
@@ -379,12 +443,17 @@
             if (group != null)
-                _map.BaseMap.RemoveBaseLayerGroup(group.Tag);
-                _tiledLayerModel.Invalidate();
+        private void RemoveSelectedTiledLayerItem(BaseLayerGroupItem group)
+            _map.BaseMap.RemoveBaseLayerGroup(group.Tag);
+            _tiledLayerModel.Invalidate();
         private void btnAddBaseLayer_Click(object sender, EventArgs e)
             using (var picker = new ResourcePicker(_edSvc.ResourceService, ResourceTypes.LayerDefinition, ResourcePickerMode.OpenResource))
@@ -478,13 +547,18 @@
             if (layer != null)
-                var grp = layer.Parent;
-                grp.RemoveBaseMapLayer(layer.Tag);
+        private void RemoveSelectedTiledLayerItem(BaseLayerItem layer)
+            var grp = layer.Parent;
+            grp.RemoveBaseMapLayer(layer.Tag);
         private void btnMoveBaseLayerUp_Click(object sender, EventArgs e)
More information about the mapguide-commits mailing list
