[mapguide-commits] r5661 - in trunk/Tools/Maestro/Maestro.Base: Services Templates UI
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Mar 28 06:29:00 EDT 2011
Author: jng
Date: 2011-03-28 03:29:00 -0700 (Mon, 28 Mar 2011)
New Revision: 5661
   trunk/Tools/Maestro/Maestro.Base/Services/NewItemTemplateService.cs
   trunk/Tools/Maestro/Maestro.Base/Templates/ItemTemplate.cs
   trunk/Tools/Maestro/Maestro.Base/UI/NewResourceDialog.Designer.cs
   trunk/Tools/Maestro/Maestro.Base/UI/NewResourceDialog.cs
   trunk/Tools/Maestro/Maestro.Base/UI/NewResourceDialog.resx
#1642: Change category view in New Resource Dialog to support multiple selection. The available templates view now shows all matching templates ordered by name and grouped by category.
Modified: trunk/Tools/Maestro/Maestro.Base/Services/NewItemTemplateService.cs
--- trunk/Tools/Maestro/Maestro.Base/Services/NewItemTemplateService.cs	2011-03-24 10:47:22 UTC (rev 5660)
+++ trunk/Tools/Maestro/Maestro.Base/Services/NewItemTemplateService.cs	2011-03-28 10:29:00 UTC (rev 5661)
@@ -92,20 +92,51 @@
             return values.ToArray();
-        public ItemTemplate[] GetItemTemplates(string category, Version siteVersion)
+        public class TemplateSet
-            if (_templates.ContainsKey(category))
+            private Dictionary<string, List<ItemTemplate>> _templates;
+            internal TemplateSet(IEnumerable<ItemTemplate> templates)
-                var templates = new List<ItemTemplate>();
-                foreach (var tpl in _templates[category])
+                _templates = new Dictionary<string,List<ItemTemplate>>();
+                foreach (var tpl in templates)
-                    if (siteVersion >= tpl.MinimumSiteVersion)
-                        templates.Add(tpl);
+                    if (!_templates.ContainsKey(tpl.Category))
+                        _templates[tpl.Category] = new List<ItemTemplate>();
+                    _templates[tpl.Category].Add(tpl);
-                return templates.ToArray();
+                foreach (var key in _templates.Keys)
+                    _templates[key].Sort();
-            return new ItemTemplate[0];
+            public IEnumerable<string> GetCategories() { return _templates.Keys; }
+            public IEnumerable<ItemTemplate> GetTemplatesForCategory(string category)
+                return _templates[category];
+        public TemplateSet GetItemTemplates(string[] categories, Version siteVersion)
+            List<ItemTemplate> templates = new List<ItemTemplate>();
+            foreach (var cat in categories)
+                if (_templates.ContainsKey(cat))
+                    var matches = new List<ItemTemplate>();
+                    foreach (var tpl in _templates[cat])
+                        if (siteVersion >= tpl.MinimumSiteVersion)
+                            matches.Add(tpl);
+                    templates.AddRange(matches);
+            return new TemplateSet(templates.ToArray());
Modified: trunk/Tools/Maestro/Maestro.Base/Templates/ItemTemplate.cs
--- trunk/Tools/Maestro/Maestro.Base/Templates/ItemTemplate.cs	2011-03-24 10:47:22 UTC (rev 5660)
+++ trunk/Tools/Maestro/Maestro.Base/Templates/ItemTemplate.cs	2011-03-28 10:29:00 UTC (rev 5661)
@@ -28,7 +28,7 @@
 namespace Maestro.Base.Templates
-    public abstract class ItemTemplate
+    public abstract class ItemTemplate : IComparable<ItemTemplate>
         public string Name { get; set; }
@@ -57,5 +57,10 @@
         /// <param name="conn">The server connection</param>
         /// <returns>a new resource, null if the user cancelled during this process</returns>
         public abstract IResource CreateItem(IServerConnection conn);
+        public int CompareTo(ItemTemplate other)
+            return this.Name.CompareTo(other.Name);
Modified: trunk/Tools/Maestro/Maestro.Base/UI/NewResourceDialog.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/NewResourceDialog.Designer.cs	2011-03-24 10:47:22 UTC (rev 5660)
+++ trunk/Tools/Maestro/Maestro.Base/UI/NewResourceDialog.Designer.cs	2011-03-28 10:29:00 UTC (rev 5661)
@@ -54,6 +54,7 @@
             resources.ApplyResources(this.lstCategories, "lstCategories");
             this.lstCategories.FormattingEnabled = true;
             this.lstCategories.Name = "lstCategories";
+            this.lstCategories.SelectionMode = System.Windows.Forms.SelectionMode.MultiSimple;
             this.lstCategories.SelectedIndexChanged += new System.EventHandler(this.lstCategories_SelectedIndexChanged);
             // label1
Modified: trunk/Tools/Maestro/Maestro.Base/UI/NewResourceDialog.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/NewResourceDialog.cs	2011-03-24 10:47:22 UTC (rev 5660)
+++ trunk/Tools/Maestro/Maestro.Base/UI/NewResourceDialog.cs	2011-03-28 10:29:00 UTC (rev 5661)
@@ -33,7 +33,7 @@
     public partial class NewResourceDialog : Form
-        private static string _lastSelectedCategory;
+        private static List<string> _lastSelectedCategoies = new List<string>();
         private NewResourceDialog()
@@ -56,11 +56,16 @@
             lstCategories.DataSource = _nits.GetCategories();
-            if (!string.IsNullOrEmpty(_lastSelectedCategory))
+            if (_lastSelectedCategoies.Count > 0)
-                var idx = lstCategories.Items.IndexOf(_lastSelectedCategory);
-                if (idx >= 0)
-                    lstCategories.SelectedIndex = idx;
+                foreach (var cat in _lastSelectedCategoies)
+                    var idx = lstCategories.Items.IndexOf(cat);
+                    if (idx >= 0)
+                        lstCategories.SetSelected(idx, true);
@@ -69,48 +74,81 @@
             this.DialogResult = DialogResult.Cancel;
+        private string[] GetSelectedCategories()
+            List<string> categories = new List<string>();
+            foreach (var item in lstCategories.SelectedItems)
+                categories.Add(item.ToString());
+            return categories.ToArray();
         private void lstCategories_SelectedIndexChanged(object sender, EventArgs e)
-            if (lstCategories.SelectedItem != null)
+            if (lstCategories.SelectedItems.Count > 0)
                 string cat = lstCategories.SelectedItem.ToString();
-                LoadTemplates(_nits.GetItemTemplates(cat, _siteVersion));
+                LoadTemplates(_nits.GetItemTemplates(GetSelectedCategories(), _siteVersion));
                 txtDescription.Text = string.Empty;
                 btnOK.Enabled = false;
+            else
+                lstTemplates.Clear();
+                lstTemplates.Groups.Clear();
+                tplImgList.Images.Clear();
         private ImageList tplImgList = new ImageList();
-        private void LoadTemplates(ItemTemplate[] templates)
+        private void LoadTemplates(Maestro.Base.Services.NewItemTemplateService.TemplateSet templSet)
-            tplImgList.Images.Add(Properties.Resources.document);
-            foreach (var tpl in templates)
+            Dictionary<string, ListViewGroup> groups = new Dictionary<string, ListViewGroup>();
+            foreach (var cat in templSet.GetCategories())
-                var li = new ListViewItem();
-                li.Name = tpl.Name;
-                li.Text = tpl.Name;
-                li.ToolTipText = tpl.Description;
+                var grp = new ListViewGroup();
+                grp.Name = cat;
+                grp.Header = cat;
-                if (tpl.Icon == null)
+                lstTemplates.Groups.Add(grp);
+                groups.Add(cat, grp);
+                tplImgList.Images.Add(Properties.Resources.document);
+                foreach (var tpl in templSet.GetTemplatesForCategory(cat))
-                    li.ImageIndex = 0;
-                else
-                    tplImgList.Images.Add(tpl.Icon);
-                    li.ImageIndex = tplImgList.Images.Count - 1;
+                    var li = new ListViewItem();
+                    li.Name = tpl.Name;
+                    li.Text = tpl.Name;
+                    li.ToolTipText = tpl.Description;
-                li.Tag = tpl;
+                    if (tpl.Icon == null)
+                        li.ImageIndex = 0;
+                    else
+                        tplImgList.Images.Add(tpl.Icon);
+                        li.ImageIndex = tplImgList.Images.Count - 1;
-                lstTemplates.Items.Add(li);
+                    li.Tag = tpl;
+                    li.Group = groups[cat];
+                    lstTemplates.Items.Add(li);
+                lstTemplates.SmallImageList = tplImgList;
+                lstTemplates.LargeImageList = tplImgList;
-            lstTemplates.SmallImageList = tplImgList;
-            lstTemplates.LargeImageList = tplImgList;
         private void lstTemplates_SelectedIndexChanged(object sender, EventArgs e)
@@ -143,7 +181,7 @@
         private void btnOK_Click(object sender, EventArgs e)
-            RememberSelectedCategory();
+            RememberSelectedCategories();
             this.DialogResult = DialogResult.OK;
@@ -162,9 +200,13 @@
-        private void RememberSelectedCategory()
+        private void RememberSelectedCategories()
-            _lastSelectedCategory = lstCategories.SelectedItem.ToString();
+            _lastSelectedCategoies.Clear();
+                _lastSelectedCategoies.Add(item.ToString());
         private void lstTemplates_MouseDoubleClick(object sender, MouseEventArgs e)
@@ -175,7 +217,7 @@
                 lstTemplates.SelectedItems.Clear();
                 item.Selected = true;
Modified: trunk/Tools/Maestro/Maestro.Base/UI/NewResourceDialog.resx
--- trunk/Tools/Maestro/Maestro.Base/UI/NewResourceDialog.resx	2011-03-24 10:47:22 UTC (rev 5660)
+++ trunk/Tools/Maestro/Maestro.Base/UI/NewResourceDialog.resx	2011-03-28 10:29:00 UTC (rev 5661)
@@ -178,13 +178,13 @@
     <value>15, 13</value>
   </data>
   <data name="label1.Size" type="System.Drawing.Size, System.Drawing">
-    <value>57, 13</value>
+    <value>159, 13</value>
   </data>
   <data name="label1.TabIndex" type="System.Int32, mscorlib">
     <value>2</value>
   </data>
   <data name="label1.Text" xml:space="preserve">
-    <value>Categories</value>
+    <value>Categories (Filtered by selection)</value>
   </data>
   <data name="&gt;&gt;label1.Name" xml:space="preserve">
     <value>label1</value>
More information about the mapguide-commits mailing list
