[mapguide-commits] r5664 - in trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource: . Validation
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Mar 28 08:23:13 EDT 2011
Author: jng
Date: 2011-03-28 05:23:13 -0700 (Mon, 28 Mar 2011)
New Revision: 5664
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/IResourceValidator.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/ApplicationDefinitionValidator.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/BaseLayerDefinitionValidator.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/BaseWebLayoutValidator.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/MapDefinitionValidator.cs
#1644: Cleanup recursive validation behaviour
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/IResourceValidator.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/IResourceValidator.cs	2011-03-28 10:56:52 UTC (rev 5663)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/IResourceValidator.cs	2011-03-28 12:23:13 UTC (rev 5664)
@@ -40,8 +40,8 @@
         /// resource type
         /// </summary>
         /// <param name="context"></param>
-        /// <param name="resource"></param>
-        /// <param name="recurse"></param>
+        /// <param name="resource">The resource to be validated</param>
+        /// <param name="recurse">Indicates whether to also validate resources this resource depends on</param>
         /// <returns></returns>
         ValidationIssue[] Validate(ResourceValidationContext context, IResource resource, bool recurse);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/ApplicationDefinitionValidator.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/ApplicationDefinitionValidator.cs	2011-03-28 10:56:52 UTC (rev 5663)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/ApplicationDefinitionValidator.cs	2011-03-28 12:23:13 UTC (rev 5664)
@@ -63,62 +63,61 @@
                 issues.Add(new ValidationIssue(fusionApp, ValidationStatus.Error, ValidationStatusCode.Error_Fusion_MissingMap, string.Format(Properties.Resources.ADF_MapMissingError)));
             else
-                if (recurse)
+                foreach (IMapGroup mapGroup in fusionApp.MapSet.MapGroups)
-                    foreach (IMapGroup mapGroup in fusionApp.MapSet.MapGroups)
+                    bool checkCmsProjection = false;
+                    List<IMapDefinition> mapDefsInGroup = new List<IMapDefinition>();
+                    foreach (IMap map in mapGroup.Map)
-                        bool checkCmsProjection = false;
-                        List<IMapDefinition> mapDefsInGroup = new List<IMapDefinition>();
-                        foreach (IMap map in mapGroup.Map)
+                        if (IsCommercialOverlay(map))
-                            if (IsCommercialOverlay(map))
+                            checkCmsProjection = true;
+                        try
+                            if (map.Type.ToLower() == "mapguide")
-                                checkCmsProjection = true;
-                            try
-                                if (map.Type.ToLower() == "mapguide")
+                                var mdfId = map.GetMapDefinition();
+                                if (string.IsNullOrEmpty(mdfId) || !resource.CurrentConnection.ResourceService.ResourceExists(mdfId))
-                                    var mdfId = map.GetMapDefinition();
-                                    if (string.IsNullOrEmpty(mdfId) || !resource.CurrentConnection.ResourceService.ResourceExists(mdfId))
+                                    issues.Add(new ValidationIssue(fusionApp, ValidationStatus.Error, ValidationStatusCode.Error_Fusion_InvalidMap, string.Format(Properties.Resources.ADF_MapInvalidError, mapGroup.id)));
+                                else
+                                    IMapDefinition mdef = (IMapDefinition)context.GetResource(mdfId);
+                                    mapDefsInGroup.Add(mdef);
+                                    IEnvelope mapEnv = ObjectFactory.CreateEnvelope(mdef.Extents.MinX, mdef.Extents.MaxX, mdef.Extents.MinY, mdef.Extents.MaxY);
+                                    if (mapGroup.InitialView != null)
-                                        issues.Add(new ValidationIssue(fusionApp, ValidationStatus.Error, ValidationStatusCode.Error_Fusion_InvalidMap, string.Format(Properties.Resources.ADF_MapInvalidError, mapGroup.id)));
+                                        if (!mapEnv.Contains(mapGroup.InitialView.CenterX, mapGroup.InitialView.CenterY))
+                                            issues.Add(new ValidationIssue(mdef, ValidationStatus.Warning, ValidationStatusCode.Warning_Fusion_InitialViewOutsideMapExtents, string.Format(Properties.Resources.ADF_ViewOutsideMapExtents)));
-                                    else
-                                        IMapDefinition mdef = (IMapDefinition)context.GetResource(mdfId);
-                                        mapDefsInGroup.Add(mdef);
-                                        if (recurse)
-                                            issues.AddRange(ResourceValidatorSet.Validate(context, mdef, true));
-                                        IEnvelope mapEnv = ObjectFactory.CreateEnvelope(mdef.Extents.MinX, mdef.Extents.MaxX, mdef.Extents.MinY, mdef.Extents.MaxY);
-                                        if (mapGroup.InitialView != null)
-                                            if (!mapEnv.Contains(mapGroup.InitialView.CenterX, mapGroup.InitialView.CenterY))
-                                                issues.Add(new ValidationIssue(mdef, ValidationStatus.Warning, ValidationStatusCode.Warning_Fusion_InitialViewOutsideMapExtents, string.Format(Properties.Resources.ADF_ViewOutsideMapExtents)));
+                                    if (recurse)
+                                        issues.AddRange(ResourceValidatorSet.Validate(context, mdef, recurse));
-                            catch (Exception ex)
-                                string msg = NestedExceptionMessageProcessor.GetFullMessage(ex);
-                                issues.Add(new ValidationIssue(fusionApp, ValidationStatus.Error, ValidationStatusCode.Error_Fusion_MapValidationError, string.Format(Properties.Resources.ADF_MapValidationError, mapGroup.id, msg)));
+                        catch (Exception ex)
+                            string msg = NestedExceptionMessageProcessor.GetFullMessage(ex);
+                            issues.Add(new ValidationIssue(fusionApp, ValidationStatus.Error, ValidationStatusCode.Error_Fusion_MapValidationError, string.Format(Properties.Resources.ADF_MapValidationError, mapGroup.id, msg)));
-                        if (checkCmsProjection)
+                    if (checkCmsProjection)
+                        foreach (var mdf in mapDefsInGroup)
-                            foreach (var mdf in mapDefsInGroup)
+                            var wkt = mdf.CoordinateSystem;
+                            var csCode = resource.CurrentConnection.CoordinateSystemCatalog.ConvertWktToCoordinateSystemCode(wkt);
+                            if (csCode.ToUpper() != "WGS84.PSEUDOMERCATOR")
-                                var wkt = mdf.CoordinateSystem;
-                                var csCode = resource.CurrentConnection.CoordinateSystemCatalog.ConvertWktToCoordinateSystemCode(wkt);
-                                if (csCode.ToUpper() != "WGS84.PSEUDOMERCATOR")
-                                    issues.Add(new ValidationIssue(resource, ValidationStatus.Warning, ValidationStatusCode.Warning_Fusion_MapCoordSysIncompatibleWithCommericalLayers, string.Format(Properties.Resources.ADF_MapWithIncompatibleCommericalCs, mdf.ResourceID)));
+                                issues.Add(new ValidationIssue(resource, ValidationStatus.Warning, ValidationStatusCode.Warning_Fusion_MapCoordSysIncompatibleWithCommericalLayers, string.Format(Properties.Resources.ADF_MapWithIncompatibleCommericalCs, mdf.ResourceID)));
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/BaseLayerDefinitionValidator.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/BaseLayerDefinitionValidator.cs	2011-03-28 10:56:52 UTC (rev 5663)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/BaseLayerDefinitionValidator.cs	2011-03-28 12:23:13 UTC (rev 5664)
@@ -180,6 +180,11 @@
+                    if (recurse)
+                        issues.AddRange(ResourceValidatorSet.Validate(context, dws, recurse));
             else
@@ -187,85 +192,87 @@
                 issues.Add(new ValidationIssue(resource, ValidationStatus.Warning, ValidationStatusCode.Warning_LayerDefinition_UnsupportedLayerType, Properties.Resources.LDF_UnsupportedLayerTypeWarning));
-            if (recurse)
+            if (vldef != null || gldef != null)
-                if (vldef != null || gldef != null)
+                //Load referenced feature source
+                IFeatureSource fs = null;
+                try
-                    //Load referenced feature source
-                    IFeatureSource fs = null;
+                    fs = (IFeatureSource)context.GetResource(ldef.SubLayer.ResourceId);
+                    issues.AddRange(ResourceValidatorSet.Validate(context, fs, recurse));
+                catch (Exception)
+                    issues.Add(new ValidationIssue(resource, ValidationStatus.Error, ValidationStatusCode.Error_LayerDefinition_FeatureSourceLoadError, string.Format(Properties.Resources.LDF_FeatureSourceLoadError)));
+                if (fs != null)
+                    //Verify specified feature class and geometry check out
                     try
-                        fs = (IFeatureSource)context.GetResource(ldef.SubLayer.ResourceId);
-                        issues.AddRange(ResourceValidatorSet.Validate(context, fs, recurse));
-                    catch (Exception)
-                        issues.Add(new ValidationIssue(resource, ValidationStatus.Error, ValidationStatusCode.Error_LayerDefinition_FeatureSourceLoadError, string.Format(Properties.Resources.LDF_FeatureSourceLoadError)));
+                        string qualClassName = vldef == null ? gldef.FeatureName : vldef.FeatureName;
+                        string geometry = vldef == null ? gldef.Geometry : vldef.Geometry;
-                    if (fs != null)
-                        //Verify specified feature class and geometry check out
-                        try
+                        bool foundSchema = false;
+                        bool foundGeometry = false;
+                        FeatureSourceDescription desc = context.DescribeFeatureSource(ldef.SubLayer.ResourceId);
+                        foreach (FeatureSchema fsc in desc.Schemas)
-                            string qualClassName = vldef == null ? gldef.FeatureName : vldef.FeatureName;
-                            string geometry = vldef == null ? gldef.Geometry : vldef.Geometry;
-                            bool foundSchema = false;
-                            bool foundGeometry = false;
-                            FeatureSourceDescription desc = context.DescribeFeatureSource(ldef.SubLayer.ResourceId);
-                            foreach (FeatureSchema fsc in desc.Schemas)
+                            foreach (ClassDefinition scm in fsc.Classes)
-                                foreach (ClassDefinition scm in fsc.Classes)
+                                if (scm.QualifiedName == qualClassName)
-                                    if (scm.QualifiedName == qualClassName)
+                                    foundSchema = true;
+                                    foreach (PropertyDefinition col in scm.Properties)
-                                        foundSchema = true;
-                                        foreach (PropertyDefinition col in scm.Properties)
+                                        if (col.Name == geometry)
-                                            if (col.Name == geometry)
-                                                foundGeometry = true;
-                                                break;
+                                            foundGeometry = true;
+                                            break;
-                                        if (vldef != null && vldef.PropertyMapping != null)
+                                    if (vldef != null && vldef.PropertyMapping != null)
+                                        foreach (INameStringPair s in vldef.PropertyMapping)
-                                            foreach (INameStringPair s in vldef.PropertyMapping)
+                                            bool found = false;
-                                                bool found = false;
+                                                if (col.Name == s.Name)
-                                                    if (col.Name == s.Name)
-                                                        found = true;
-                                                        break;
+                                                    found = true;
+                                                    break;
-                                                if (!found)
-                                                    issues.Add(new ValidationIssue(resource, ValidationStatus.Error, ValidationStatusCode.Error_LayerDefinition_ClassNotFound, string.Format(Properties.Resources.LDF_SchemaMissingError, qualClassName, fs.ResourceID)));
+                                            if (!found)
+                                                issues.Add(new ValidationIssue(resource, ValidationStatus.Error, ValidationStatusCode.Error_LayerDefinition_ClassNotFound, string.Format(Properties.Resources.LDF_SchemaMissingError, qualClassName, fs.ResourceID)));
-                                        break;
+                                    break;
-                            if (!foundSchema)
-                            else if (!foundGeometry)
-                                issues.Add(new ValidationIssue(resource, ValidationStatus.Error, ValidationStatusCode.Error_LayerDefinition_GeometryNotFound, string.Format(Properties.Resources.LDF_GeometryMissingError, geometry, qualClassName, fs.ResourceID)));
-                        catch (Exception)
-                            issues.Add(new ValidationIssue(fs, ValidationStatus.Error, ValidationStatusCode.Error_LayerDefinition_Generic, string.Format(Properties.Resources.LDF_SchemaAndColumnReadFailedError)));
+                        if (!foundSchema)
+                        else if (!foundGeometry)
+                            issues.Add(new ValidationIssue(resource, ValidationStatus.Error, ValidationStatusCode.Error_LayerDefinition_GeometryNotFound, string.Format(Properties.Resources.LDF_GeometryMissingError, geometry, qualClassName, fs.ResourceID)));
+                    catch (Exception)
+                        issues.Add(new ValidationIssue(fs, ValidationStatus.Error, ValidationStatusCode.Error_LayerDefinition_Generic, string.Format(Properties.Resources.LDF_SchemaAndColumnReadFailedError)));
+                    if (recurse)
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/BaseWebLayoutValidator.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/BaseWebLayoutValidator.cs	2011-03-28 10:56:52 UTC (rev 5663)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/BaseWebLayoutValidator.cs	2011-03-28 12:23:13 UTC (rev 5664)
@@ -125,28 +125,26 @@
-                if (recurse)
+                try
-                    try
+                    IMapDefinition mdef = (IMapDefinition)context.GetResource(layout.Map.ResourceId);
+                    if (layout.Map.InitialView != null)
-                        IMapDefinition mdef = (IMapDefinition)context.GetResource(layout.Map.ResourceId);
+                        var mapEnv = ObjectFactory.CreateEnvelope(mdef.Extents.MinX, mdef.Extents.MaxX, mdef.Extents.MinY, mdef.Extents.MaxY);
+                        if (!mapEnv.Contains(layout.Map.InitialView.CenterX, layout.Map.InitialView.CenterY))
+                            issues.Add(new ValidationIssue(mdef, ValidationStatus.Warning, ValidationStatusCode.Warning_WebLayout_InitialViewOutsideMapExtents, string.Format(Properties.Resources.WL_StartViewOutsideExtentsWarning)));
+                    if (recurse)
-                        if (layout.Map.InitialView != null)
-                            var mapEnv = ObjectFactory.CreateEnvelope(mdef.Extents.MinX, mdef.Extents.MaxX, mdef.Extents.MinY, mdef.Extents.MaxY);
-                            if (!mapEnv.Contains(layout.Map.InitialView.CenterX, layout.Map.InitialView.CenterY))
-                                issues.Add(new ValidationIssue(mdef, ValidationStatus.Warning, ValidationStatusCode.Warning_WebLayout_InitialViewOutsideMapExtents, string.Format(Properties.Resources.WL_StartViewOutsideExtentsWarning)));
-                        issues.Add(new ValidationIssue(layout, ValidationStatus.Error, ValidationStatusCode.Error_WebLayout_Generic, string.Format(Properties.Resources.WL_MapValidationError, layout.Map.ResourceId, msg)));
+                    issues.Add(new ValidationIssue(layout, ValidationStatus.Error, ValidationStatusCode.Error_WebLayout_Generic, string.Format(Properties.Resources.WL_MapValidationError, layout.Map.ResourceId, msg)));
             context.MarkValidated(resource.ResourceID);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/MapDefinitionValidator.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/MapDefinitionValidator.cs	2011-03-28 10:56:52 UTC (rev 5663)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/MapDefinitionValidator.cs	2011-03-28 12:23:13 UTC (rev 5664)
@@ -91,89 +91,89 @@
                 if (l.ShowInLegend && (string.IsNullOrEmpty(l.LegendLabel) || l.LegendLabel.Trim().Length == 0))
                     issues.Add(new ValidationIssue(mdef, ValidationStatus.Information, ValidationStatusCode.Warning_MapDefinition_LayerMissingLegendLabel, string.Format(Properties.Resources.MDF_LayerMissingLabelInformation, l.Name)));
-                if (recurse)
+                try
+                    ILayerDefinition layer = null;
+                    IResource res = context.GetResource(l.ResourceId);
+                    if (!ResourceValidatorSet.HasValidator(res.ResourceType, res.ResourceVersion))
+                        //Need to trap the no registered validator message
+                        issues.AddRange(ResourceValidatorSet.Validate(context, res, true));
+                        continue;
-                    try
+                    layer = (ILayerDefinition)res;
+                    if (recurse)
-                        ILayerDefinition layer = null;
-                        IResource res = context.GetResource(l.ResourceId);
-                        if (!ResourceValidatorSet.HasValidator(res.ResourceType, res.ResourceVersion))
-                            //Need to trap the no registered validator message
-                            issues.AddRange(ResourceValidatorSet.Validate(context, res, true));
-                            continue;
+                        issues.AddRange(ResourceValidatorSet.Validate(context, layer, recurse));
-                        layer = (ILayerDefinition)res;
-                        issues.AddRange(ResourceValidatorSet.Validate(context, layer, true));
+                    IVectorLayerDefinition vl = null;
+                    if (layer.SubLayer.LayerType == LayerType.Vector)
+                        vl = (IVectorLayerDefinition)layer.SubLayer;
-                        IVectorLayerDefinition vl = null;
-                        if (layer.SubLayer.LayerType == LayerType.Vector)
-                            vl = (IVectorLayerDefinition)layer.SubLayer;
+                    if (vl != null)
+                        try
+                            IFeatureSource fs = (IFeatureSource)context.GetResource(vl.ResourceId);
+                            //The layer recurses on the FeatureSource
+                            //issues.AddRange(Validation.Validate(fs, true));
-                        if (vl != null)
                             try
-                                IFeatureSource fs = (IFeatureSource)context.GetResource(vl.ResourceId);
-                                //The layer recurses on the FeatureSource
-                                //issues.AddRange(Validation.Validate(fs, true));
+                                FdoSpatialContextList scList = context.GetSpatialContexts(fs.ResourceID);
-                                try
+                                if (scList.SpatialContext == null || scList.SpatialContext.Count == 0)
+                                    issues.Add(new ValidationIssue(fs, ValidationStatus.Warning, ValidationStatusCode.Warning_MapDefinition_MissingSpatialContext, string.Format(Properties.Resources.MDF_MissingSpatialContextWarning, fs.ResourceID)));
+                                else
-                                    FdoSpatialContextList scList = context.GetSpatialContexts(fs.ResourceID);
+                                    if (scList.SpatialContext.Count > 1)
+                                        issues.Add(new ValidationIssue(fs, ValidationStatus.Information, ValidationStatusCode.Info_MapDefinition_MultipleSpatialContexts, string.Format(Properties.Resources.MDF_MultipleSpatialContextsInformation, fs.ResourceID)));
-                                    if (scList.SpatialContext == null || scList.SpatialContext.Count == 0)
-                                        issues.Add(new ValidationIssue(fs, ValidationStatus.Warning, ValidationStatusCode.Warning_MapDefinition_MissingSpatialContext, string.Format(Properties.Resources.MDF_MissingSpatialContextWarning, fs.ResourceID)));
-                                    else
-                                        if (scList.SpatialContext.Count > 1)
-                                            issues.Add(new ValidationIssue(fs, ValidationStatus.Information, ValidationStatusCode.Info_MapDefinition_MultipleSpatialContexts, string.Format(Properties.Resources.MDF_MultipleSpatialContextsInformation, fs.ResourceID)));
+                                    bool skipGeomCheck = false;
-                                        bool skipGeomCheck = false;
+                                    //TODO: Switch to the correct version (2.1), once released
+                                    if (scList.SpatialContext[0].CoordinateSystemWkt != mdef.CoordinateSystem)
+                                        if (layer.SubLayer.LayerType == LayerType.Raster && mdef.CurrentConnection.SiteVersion <= SiteVersions.GetVersion(OSGeo.MapGuide.MaestroAPI.KnownSiteVersions.MapGuideOS2_0_2))
+                                            issues.Add(new ValidationIssue(fs, ValidationStatus.Error, ValidationStatusCode.Error_MapDefinition_RasterReprojection, string.Format(Properties.Resources.MDF_RasterReprojectionError, fs.ResourceID)));
+                                        else
+                                            issues.Add(new ValidationIssue(fs, ValidationStatus.Warning, ValidationStatusCode.Warning_MapDefinition_LayerReprojection, string.Format(Properties.Resources.MDF_DataReprojectionWarning, fs.ResourceID)));
-                                        //TODO: Switch to the correct version (2.1), once released
-                                        if (scList.SpatialContext[0].CoordinateSystemWkt != mdef.CoordinateSystem)
-                                            if (layer.SubLayer.LayerType == LayerType.Raster && mdef.CurrentConnection.SiteVersion <= SiteVersions.GetVersion(OSGeo.MapGuide.MaestroAPI.KnownSiteVersions.MapGuideOS2_0_2))
-                                                issues.Add(new ValidationIssue(fs, ValidationStatus.Error, ValidationStatusCode.Error_MapDefinition_RasterReprojection, string.Format(Properties.Resources.MDF_RasterReprojectionError, fs.ResourceID)));
-                                            else
-                                                issues.Add(new ValidationIssue(fs, ValidationStatus.Warning, ValidationStatusCode.Warning_MapDefinition_LayerReprojection, string.Format(Properties.Resources.MDF_DataReprojectionWarning, fs.ResourceID)));
+                                        skipGeomCheck = true;
-                                            skipGeomCheck = true;
-                                        if (vl.Geometry != null && !skipGeomCheck)
-                                            var env = fs.GetSpatialExtent(vl.FeatureName, vl.Geometry);
-                                            if (!env.Intersects(mapEnv))
-                                                issues.Add(new ValidationIssue(fs, ValidationStatus.Warning, ValidationStatusCode.Warning_MapDefinition_DataOutsideMapBounds, string.Format(Properties.Resources.MDF_DataOutsideMapWarning, fs.ResourceID)));
+                                    if (vl.Geometry != null && !skipGeomCheck)
+                                        var env = fs.GetSpatialExtent(vl.FeatureName, vl.Geometry);
+                                        if (!env.Intersects(mapEnv))
+                                            issues.Add(new ValidationIssue(fs, ValidationStatus.Warning, ValidationStatusCode.Warning_MapDefinition_DataOutsideMapBounds, string.Format(Properties.Resources.MDF_DataOutsideMapWarning, fs.ResourceID)));
-                                    issues.Add(new ValidationIssue(layer, ValidationStatus.Error, ValidationStatusCode.Error_MapDefinition_ResourceRead, string.Format(Properties.Resources.MDF_ResourceReadError, fs.ResourceID, msg)));
-                                issues.Add(new ValidationIssue(mdef, ValidationStatus.Error, ValidationStatusCode.Error_MapDefinition_FeatureSourceRead, string.Format(Properties.Resources.MDF_FeatureSourceReadError, l.ResourceId, msg)));
+                                issues.Add(new ValidationIssue(layer, ValidationStatus.Error, ValidationStatusCode.Error_MapDefinition_ResourceRead, string.Format(Properties.Resources.MDF_ResourceReadError, fs.ResourceID, msg)));
+                            issues.Add(new ValidationIssue(mdef, ValidationStatus.Error, ValidationStatusCode.Error_MapDefinition_FeatureSourceRead, string.Format(Properties.Resources.MDF_FeatureSourceReadError, l.ResourceId, msg)));
-                        issues.Add(new ValidationIssue(mdef, ValidationStatus.Error, ValidationStatusCode.Error_MapDefinition_LayerRead, string.Format(Properties.Resources.MDF_LayerReadError, l.ResourceId, msg)));
+                    issues.Add(new ValidationIssue(mdef, ValidationStatus.Error, ValidationStatusCode.Error_MapDefinition_LayerRead, string.Format(Properties.Resources.MDF_LayerReadError, l.ResourceId, msg)));
More information about the mapguide-commits mailing list
