[mapguide-commits] r5737 - in trunk/Tools/Maestro/SDK: . Samples
	Samples/DrawMap Samples/DrawMap/Properties
	Samples/QueryFeatureSource Samples/QueryFeatureSource/Properties
    svn_mapguide at osgeo.org
    Wed May  4 09:22:57 EDT 2011
Author: jng
Date: 2011-05-04 06:22:57 -0700 (Wed, 04 May 2011)
New Revision: 5737
Added:
   trunk/Tools/Maestro/SDK/Samples/
   trunk/Tools/Maestro/SDK/Samples/DrawMap/
   trunk/Tools/Maestro/SDK/Samples/DrawMap/DrawMap.csproj
   trunk/Tools/Maestro/SDK/Samples/DrawMap/Form1.Designer.cs
   trunk/Tools/Maestro/SDK/Samples/DrawMap/Form1.cs
   trunk/Tools/Maestro/SDK/Samples/DrawMap/Form1.resx
   trunk/Tools/Maestro/SDK/Samples/DrawMap/Program.cs
   trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/
   trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/AssemblyInfo.cs
   trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Resources.Designer.cs
   trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Resources.resx
   trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Settings.Designer.cs
   trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Settings.settings
   trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/
   trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Form1.Designer.cs
   trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Form1.cs
   trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Form1.resx
   trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Program.cs
   trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/
   trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/AssemblyInfo.cs
   trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Resources.Designer.cs
   trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Resources.resx
   trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Settings.Designer.cs
   trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Settings.settings
   trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/QueryFeatureSource.csproj
   trunk/Tools/Maestro/SDK/Samples/Samples.sln
#1676: Add two SDK samples. DrawMap and QueryFeatureSource. These are windows-based examples using the Maestro API to render a map definition and to query a feature source respectively
Added: trunk/Tools/Maestro/SDK/Samples/DrawMap/DrawMap.csproj
--- trunk/Tools/Maestro/SDK/Samples/DrawMap/DrawMap.csproj	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/DrawMap/DrawMap.csproj	2011-05-04 13:22:57 UTC (rev 5737)
@@ -0,0 +1,102 @@
+<?xml version="1.0" encoding="utf-8"?>
+<Project ToolsVersion="3.5" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+  <PropertyGroup>
+    <Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
+    <Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform>
+    <ProductVersion>9.0.30729</ProductVersion>
+    <SchemaVersion>2.0</SchemaVersion>
+    <ProjectGuid>{30EA9CAC-7DFA-4434-87F4-0AB226F2D305}</ProjectGuid>
+    <OutputType>WinExe</OutputType>
+    <AppDesignerFolder>Properties</AppDesignerFolder>
+    <RootNamespace>DrawMap</RootNamespace>
+    <AssemblyName>DrawMap</AssemblyName>
+    <TargetFrameworkVersion>v2.0</TargetFrameworkVersion>
+    <FileAlignment>512</FileAlignment>
+  </PropertyGroup>
+  <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|AnyCPU' ">
+    <DebugSymbols>true</DebugSymbols>
+    <DebugType>full</DebugType>
+    <Optimize>false</Optimize>
+    <OutputPath>bin\Debug\</OutputPath>
+    <DefineConstants>DEBUG;TRACE</DefineConstants>
+    <ErrorReport>prompt</ErrorReport>
+    <WarningLevel>4</WarningLevel>
+  </PropertyGroup>
+  <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Release|AnyCPU' ">
+    <DebugType>pdbonly</DebugType>
+    <Optimize>true</Optimize>
+    <OutputPath>bin\Release\</OutputPath>
+    <DefineConstants>TRACE</DefineConstants>
+  </PropertyGroup>
+  <ItemGroup>
+    <Reference Include="Maestro.Editors, Version=3.0.0.5728, Culture=neutral, processorArchitecture=MSIL">
+      <SpecificVersion>False</SpecificVersion>
+      <HintPath>..\..\bin\Maestro.Editors.dll</HintPath>
+    </Reference>
+    <Reference Include="Maestro.Login, Version=3.0.0.5728, Culture=neutral, processorArchitecture=MSIL">
+      <HintPath>..\..\bin\Maestro.Login.dll</HintPath>
+    </Reference>
+    <Reference Include="OSGeo.MapGuide.MaestroAPI, Version=3.0.0.5728, Culture=neutral, PublicKeyToken=f526c48929fda856, processorArchitecture=MSIL">
+      <HintPath>..\..\bin\OSGeo.MapGuide.MaestroAPI.dll</HintPath>
+    </Reference>
+    <Reference Include="System" />
+    <Reference Include="System.Data" />
+    <Reference Include="System.Deployment" />
+    <Reference Include="System.Drawing" />
+    <Reference Include="System.Windows.Forms" />
+    <Reference Include="System.Xml" />
+  </ItemGroup>
+  <ItemGroup>
+    <Compile Include="Form1.cs">
+      <SubType>Form</SubType>
+    </Compile>
+    <Compile Include="Form1.Designer.cs">
+      <DependentUpon>Form1.cs</DependentUpon>
+    </Compile>
+    <Compile Include="Program.cs" />
+    <Compile Include="Properties\AssemblyInfo.cs" />
+    <EmbeddedResource Include="Form1.resx">
+    </EmbeddedResource>
+    <EmbeddedResource Include="Properties\Resources.resx">
+      <Generator>ResXFileCodeGenerator</Generator>
+      <LastGenOutput>Resources.Designer.cs</LastGenOutput>
+      <SubType>Designer</SubType>
+    <Compile Include="Properties\Resources.Designer.cs">
+      <AutoGen>True</AutoGen>
+      <DependentUpon>Resources.resx</DependentUpon>
+    </Compile>
+    <None Include="Properties\Settings.settings">
+      <Generator>SettingsSingleFileGenerator</Generator>
+      <LastGenOutput>Settings.Designer.cs</LastGenOutput>
+    </None>
+    <Compile Include="Properties\Settings.Designer.cs">
+      <DependentUpon>Settings.settings</DependentUpon>
+      <DesignTimeSharedInput>True</DesignTimeSharedInput>
+    </Compile>
+  </ItemGroup>
+  <ItemGroup>
+    <Content Include="..\..\bin\ConnectionProviders.xml">
+      <Link>ConnectionProviders.xml</Link>
+      <CopyToOutputDirectory>Always</CopyToOutputDirectory>
+    </Content>
+    <Content Include="..\..\bin\OSGeo.MapGuide.MaestroAPI.Http.dll">
+      <Link>OSGeo.MapGuide.MaestroAPI.Http.dll</Link>
+    </Content>
+  </ItemGroup>
+  <Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
+  <!-- To modify your build process, add your task inside one of the targets below and uncomment it.
+       Other similar extension points exist, see Microsoft.Common.targets.
+  <Target Name="BeforeBuild">
+  </Target>
+  <Target Name="AfterBuild">
+  </Target>
+</Project>
\ No newline at end of file
Added: trunk/Tools/Maestro/SDK/Samples/DrawMap/Form1.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/DrawMap/Form1.Designer.cs	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/DrawMap/Form1.Designer.cs	2011-05-04 13:22:57 UTC (rev 5737)
@@ -0,0 +1,91 @@
+namespace DrawMap
+    partial class Form1
+        /// <summary>
+        /// Required designer variable.
+        /// </summary>
+        private System.ComponentModel.IContainer components = null;
+        /// <summary>
+        /// Clean up any resources being used.
+        /// </summary>
+        /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+        protected override void Dispose(bool disposing)
+            if (disposing && (components != null))
+                components.Dispose();
+            base.Dispose(disposing);
+        #region Windows Form Designer generated code
+        /// <summary>
+        /// Required method for Designer support - do not modify
+        /// the contents of this method with the code editor.
+        /// </summary>
+        private void InitializeComponent()
+            System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(Form1));
+            this.pictureBox1 = new System.Windows.Forms.PictureBox();
+            this.toolStrip1 = new System.Windows.Forms.ToolStrip();
+            this.toolStripButton1 = new System.Windows.Forms.ToolStripButton();
+            ((System.ComponentModel.ISupportInitialize)(this.pictureBox1)).BeginInit();
+            this.toolStrip1.SuspendLayout();
+            this.SuspendLayout();
+            // pictureBox1
+            this.pictureBox1.Dock = System.Windows.Forms.DockStyle.Fill;
+            this.pictureBox1.Location = new System.Drawing.Point(0, 25);
+            this.pictureBox1.Name = "pictureBox1";
+            this.pictureBox1.Size = new System.Drawing.Size(536, 374);
+            this.pictureBox1.TabIndex = 0;
+            this.pictureBox1.TabStop = false;
+            // toolStrip1
+            this.toolStrip1.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+            this.toolStripButton1});
+            this.toolStrip1.Location = new System.Drawing.Point(0, 0);
+            this.toolStrip1.Name = "toolStrip1";
+            this.toolStrip1.Size = new System.Drawing.Size(536, 25);
+            this.toolStrip1.TabIndex = 1;
+            this.toolStrip1.Text = "toolStrip1";
+            // toolStripButton1
+            this.toolStripButton1.Image = ((System.Drawing.Image)(resources.GetObject("toolStripButton1.Image")));
+            this.toolStripButton1.ImageTransparentColor = System.Drawing.Color.Magenta;
+            this.toolStripButton1.Name = "toolStripButton1";
+            this.toolStripButton1.Size = new System.Drawing.Size(138, 22);
+            this.toolStripButton1.Text = "Open Map Definition";
+            this.toolStripButton1.Click += new System.EventHandler(this.toolStripButton1_Click);
+            // Form1
+            this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
+            this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+            this.ClientSize = new System.Drawing.Size(536, 399);
+            this.Controls.Add(this.pictureBox1);
+            this.Controls.Add(this.toolStrip1);
+            this.Name = "Form1";
+            this.Text = "DrawMap example";
+            ((System.ComponentModel.ISupportInitialize)(this.pictureBox1)).EndInit();
+            this.toolStrip1.ResumeLayout(false);
+            this.toolStrip1.PerformLayout();
+            this.ResumeLayout(false);
+            this.PerformLayout();
+        #endregion
+        private System.Windows.Forms.PictureBox pictureBox1;
+        private System.Windows.Forms.ToolStrip toolStrip1;
+        private System.Windows.Forms.ToolStripButton toolStripButton1;
Added: trunk/Tools/Maestro/SDK/Samples/DrawMap/Form1.cs
--- trunk/Tools/Maestro/SDK/Samples/DrawMap/Form1.cs	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/DrawMap/Form1.cs	2011-05-04 13:22:57 UTC (rev 5737)
@@ -0,0 +1,120 @@
+#region Disclaimer / License
+// Copyright (C) 2011, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Data;
+using System.Drawing;
+using System.Text;
+using System.Windows.Forms;
+using Maestro.Editors.Generic;
+using OSGeo.MapGuide.MaestroAPI;
+using OSGeo.MapGuide.MaestroAPI.Services;
+using OSGeo.MapGuide.ObjectModels.MapDefinition;
+namespace DrawMap
+    public partial class Form1 : Form
+        public Form1()
+            InitializeComponent();
+        private IServerConnection _conn;
+        protected override void OnLoad(EventArgs e)
+            //Anytime we work with the Maestro API, we require an IServerConnection
+            //reference. The Maestro.Login.LoginDialog provides a UI to obtain such a
+            //reference.
+            //If you need to obtain an IServerConnection reference programmatically and
+            //without user intervention, use the ConnectionProviderRegistry class
+            var login = new Maestro.Login.LoginDialog();
+            if (login.ShowDialog() == DialogResult.OK)
+                _conn = login.Connection;
+            else //This sample does not work without an IServerConnection
+                Application.Exit();
+        private void LoadMap(IServerConnection conn, string mapDefinitionId)
+            //To render a map, we need to create a runtime map instance. IMappingService gives us
+            //the required services. This is not a standard service, so you need to call GetService()
+            //with the correct ServiceType to get the IMappingService reference.
+            IMappingService mapSvc = (IMappingService)conn.GetService((int)ServiceType.Mapping);
+            //Get an IMapDefinition from the specified resource id. GetResource() returns an instance
+            //of IResource, which IMapDefinition extends. As long as you pass in a valid resource id
+            //of the right type, you can safely cast the returned object to the expected type.
+            IMapDefinition mapDef = (IMapDefinition)conn.ResourceService.GetResource(mapDefinitionId);
+            //Create a runtime map
+            var rtMap = mapSvc.CreateMap(mapDef);
+            //Set map display to match the size of our picture box
+            rtMap.InitialiseDisplayParameters(pictureBox1.Width, pictureBox1.Height);
+            //Note: Sometimes the meters-per-unit value may be inaccurate. This has ramifications on
+            //display and measuring. If you have access to the MgCoordinateSystem API, create an instance
+            //using the Map Definition's WKT and use the meters-per-unit value obtained like so:
+            // MgCoordinateSystemFactory csFactory = new MgCoordinateSystemFactory();
+            // MgCoordinateSystem cs = csFactory.Create(srs);
+            // double metersPerUnit = cs.ConvertCoordinateSystemUnitsToMeters(1.0);
+            //This result gives a more accurate MPU
+            //Before we can do anything with this map, it must first be saved.
+            //Anytime you manipulate this map, you need to save it for the changes to be
+            //applied back to the MapGuide Server
+            rtMap.Save();
+            //Render the map with its current display parameters in PNG format. A System.IO.Stream
+            //is returned.
+            using (var stream = rtMap.Render("PNG"))
+                //Create a System.Drawing.Image from the stream and load it into our picture box.
+                pictureBox1.Image = Image.FromStream(stream);
+        private void toolStripButton1_Click(object sender, EventArgs e)
+            //The ResourcePicker class, functions like a file dialog allowing the user
+            //to easily select a given resource. In our case, we want the user to select
+            //a Map Definition
+            using (var picker = new ResourcePicker(_conn.ResourceService,
+                                                   ResourceTypes.MapDefinition,
+                                                   ResourcePickerMode.OpenResource))
+                if (picker.ShowDialog() == DialogResult.OK)
+                    LoadMap(_conn, picker.ResourceID);
Added: trunk/Tools/Maestro/SDK/Samples/DrawMap/Form1.resx
--- trunk/Tools/Maestro/SDK/Samples/DrawMap/Form1.resx	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/DrawMap/Form1.resx	2011-05-04 13:22:57 UTC (rev 5737)
@@ -0,0 +1,139 @@
+<root>
+    Microsoft ResX Schema
+    Version 2.0
+    The primary goals of this format is to allow a simple XML format
+    that is mostly human readable. The generation and parsing of the
+    various data types are done through the TypeConverter classes
+    associated with the data types.
+    Example:
+    ... ado.net/XML headers & schema ...
+    <resheader name="resmimetype">text/microsoft-resx</resheader>
+    <resheader name="version">2.0</resheader>
+    <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+    <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+    <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+    <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+    <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+        <value>[base64 mime encoded serialized .NET Framework object]</value>
+    </data>
+    <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+        <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+        <comment>This is a comment</comment>
+    </data>
+    There are any number of "resheader" rows that contain simple
+    name/value pairs.
+    Each data row contains a name, and value. The row also contains a
+    type or mimetype. Type corresponds to a .NET class that support
+    text/value conversion through the TypeConverter architecture.
+    Classes that don't support this are serialized and stored with the
+    mimetype set.
+    The mimetype is used for serialized objects, and tells the
+    ResXResourceReader how to depersist the object. This is currently not
+    extensible. For a given mimetype the value must be set accordingly:
+    Note - application/x-microsoft.net.object.binary.base64 is the format
+    that the ResXResourceWriter will generate, however the reader can
+    read any of the formats listed below.
+    mimetype: application/x-microsoft.net.object.binary.base64
+    value   : The object must be serialized with
+            : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+            : and then encoded with base64 encoding.
+    mimetype: application/x-microsoft.net.object.soap.base64
+            : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+    mimetype: application/x-microsoft.net.object.bytearray.base64
+    value   : The object must be serialized into a byte array
+            : using a System.ComponentModel.TypeConverter
+  <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+    <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+    <xsd:element name="root" msdata:IsDataSet="true">
+      <xsd:complexType>
+        <xsd:choice maxOccurs="unbounded">
+          <xsd:element name="metadata">
+            <xsd:complexType>
+              <xsd:sequence>
+                <xsd:element name="value" type="xsd:string" minOccurs="0" />
+              </xsd:sequence>
+              <xsd:attribute name="name" use="required" type="xsd:string" />
+              <xsd:attribute name="type" type="xsd:string" />
+              <xsd:attribute name="mimetype" type="xsd:string" />
+              <xsd:attribute ref="xml:space" />
+            </xsd:complexType>
+          </xsd:element>
+          <xsd:element name="assembly">
+            <xsd:complexType>
+              <xsd:attribute name="alias" type="xsd:string" />
+              <xsd:attribute name="name" type="xsd:string" />
+          </xsd:element>
+          <xsd:element name="data">
+            <xsd:complexType>
+              <xsd:sequence>
+                <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+                <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+              <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+              <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+          </xsd:element>
+          <xsd:element name="resheader">
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" use="required" />
+          </xsd:element>
+        </xsd:choice>
+    </xsd:element>
+  </xsd:schema>
+    <value>text/microsoft-resx</value>
+  </resheader>
+    <value>2.0</value>
+  </resheader>
+    <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </resheader>
+    <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </resheader>
+  <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>17, 17</value>
+  </metadata>
+  <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+  <data name="toolStripButton1.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
+        YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAIISURBVDhPpZP7S1NxGMbPPxKaXVUkMEq8IpKUCoY/hGgI
+        ymqkDYYXcCjDZOANURSjCNGFQUTsl4GXVMxKk62YU4fXQpaIlygHQxBRH8/zwvyaIAYe+HLgnPN8nue9
+        HA3nvDTq63oW/jm13XOwvPTB3DYFY5MH+bXfcN8ygfTSMSSXfESicQDxBqdYHwH29g9w2tnZ3UcguIvN
+        rR3417exuBJE5N1n/wfwLgXEOc38Bc6xNRHb+/y4nm49G0Bnit2zf9H6bkliE/jKuYxrd6oVgDWfjB+K
+        TWeKMyrGEVfowITvD9re/9ABVQrAhh0HHK+ZselMMaN/mvwtDb+aVqkA7HYIwIj3ysfluPTorJnP6Ezx
+        oHsD1s5ZXEktUwCOioB5f1CEPR9+wTG6iuiserTo8dkwng7HT/R+XUPF8xlcTjErAOdMcW6NW8STiwG8
+        7vej8oUPN/PsEv3t8Ao0TZP3T1u8uJRkUgAuSYHtO97oLxmXd5t9Ho8aPTK+GzntqNfrLm2fFoihwYOI
+        xGIF4KjoGBLzY1OrF9k6OOFxnwDC4wxIMX1G0pMhgVyMNyoA13PAtS7OrJk1PrC69LUdQWxuF6IybHrX
+        LRI7JrtZdoDAo1XmbjMyD+tjSXxGcXRmnYg5ttD9QuxDhN0uUgDOmbvNTpPOJaGAo2K36cyaGZvOFIfd
+        KlSA8/zRh9ABIDUG+1JpAAAAAElFTkSuQmCC
+</value>
+  </data>
+</root>
Added: trunk/Tools/Maestro/SDK/Samples/DrawMap/Program.cs
--- trunk/Tools/Maestro/SDK/Samples/DrawMap/Program.cs	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/DrawMap/Program.cs	2011-05-04 13:22:57 UTC (rev 5737)
@@ -0,0 +1,39 @@
+#endregion
+using System;
+namespace DrawMap
+    static class Program
+        /// <summary>
+        /// The main entry point for the application.
+        /// </summary>
+        [STAThread]
+        static void Main()
+            Application.EnableVisualStyles();
+            Application.SetCompatibleTextRenderingDefault(false);
+            Application.Run(new Form1());
Added: trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/AssemblyInfo.cs	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/AssemblyInfo.cs	2011-05-04 13:22:57 UTC (rev 5737)
@@ -0,0 +1,36 @@
+using System.Reflection;
+using System.Runtime.CompilerServices;
+using System.Runtime.InteropServices;
+// General Information about an assembly is controlled through the following
+// set of attributes. Change these attribute values to modify the information
+// associated with an assembly.
+[assembly: AssemblyTitle("DrawMap")]
+[assembly: AssemblyDescription("")]
+[assembly: AssemblyConfiguration("")]
+[assembly: AssemblyCompany("")]
+[assembly: AssemblyProduct("DrawMap")]
+[assembly: AssemblyCopyright("Copyright ©  2011")]
+[assembly: AssemblyTrademark("")]
+[assembly: AssemblyCulture("")]
+// Setting ComVisible to false makes the types in this assembly not visible
+// to COM components.  If you need to access a type in this assembly from
+// COM, set the ComVisible attribute to true on that type.
+[assembly: ComVisible(false)]
+// The following GUID is for the ID of the typelib if this project is exposed to COM
+[assembly: Guid("09d59ee9-d441-4abf-b001-f5e26654528f")]
+// Version information for an assembly consists of the following four values:
+//      Major Version
+//      Minor Version
+//      Build Number
+//      Revision
+// You can specify all the values or you can default the Build and Revision Numbers
+// by using the '*' as shown below:
+// [assembly: AssemblyVersion("1.0.*")]
+[assembly: AssemblyVersion("1.0.0.0")]
+[assembly: AssemblyFileVersion("1.0.0.0")]
Added: trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Resources.Designer.cs	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Resources.Designer.cs	2011-05-04 13:22:57 UTC (rev 5737)
@@ -0,0 +1,71 @@
+// <auto-generated>
+//     This code was generated by a tool.
+//     Runtime Version:2.0.50727.4952
+//     Changes to this file may cause incorrect behavior and will be lost if
+//     the code is regenerated.
+// </auto-generated>
+namespace DrawMap.Properties
+    /// <summary>
+    ///   A strongly-typed resource class, for looking up localized strings, etc.
+    /// </summary>
+    // This class was auto-generated by the StronglyTypedResourceBuilder
+    // class via a tool like ResGen or Visual Studio.
+    // To add or remove a member, edit your .ResX file then rerun ResGen
+    // with the /str option, or rebuild your VS project.
+    [global::System.CodeDom.Compiler.GeneratedCodeAttribute("System.Resources.Tools.StronglyTypedResourceBuilder", "2.0.0.0")]
+    [global::System.Diagnostics.DebuggerNonUserCodeAttribute()]
+    [global::System.Runtime.CompilerServices.CompilerGeneratedAttribute()]
+    internal class Resources
+        private static global::System.Resources.ResourceManager resourceMan;
+        private static global::System.Globalization.CultureInfo resourceCulture;
+        [global::System.Diagnostics.CodeAnalysis.SuppressMessageAttribute("Microsoft.Performance", "CA1811:AvoidUncalledPrivateCode")]
+        internal Resources()
+        /// <summary>
+        ///   Returns the cached ResourceManager instance used by this class.
+        /// </summary>
+        [global::System.ComponentModel.EditorBrowsableAttribute(global::System.ComponentModel.EditorBrowsableState.Advanced)]
+        internal static global::System.Resources.ResourceManager ResourceManager
+            get
+                if ((resourceMan == null))
+                    global::System.Resources.ResourceManager temp = new global::System.Resources.ResourceManager("DrawMap.Properties.Resources", typeof(Resources).Assembly);
+                    resourceMan = temp;
+                return resourceMan;
+        /// <summary>
+        ///   Overrides the current thread's CurrentUICulture property for all
+        ///   resource lookups using this strongly typed resource class.
+        /// </summary>
+        internal static global::System.Globalization.CultureInfo Culture
+            get
+                return resourceCulture;
+            set
+                resourceCulture = value;
Added: trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Resources.resx
--- trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Resources.resx	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Resources.resx	2011-05-04 13:22:57 UTC (rev 5737)
@@ -0,0 +1,117 @@
+<root>
+    Version 2.0
+    Example:
+    </data>
+    </data>
+    name/value pairs.
+    mimetype set.
+            : System.Serialization.Formatters.Binary.BinaryFormatter
+      <xsd:complexType>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+            <xsd:complexType>
+          </xsd:element>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" msdata:Ordinal="1" />
+          </xsd:element>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+        </xsd:choice>
+    </xsd:element>
+  </xsd:schema>
+  </resheader>
+  </resheader>
+  </resheader>
+  </resheader>
+</root>
Added: trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Settings.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Settings.Designer.cs	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Settings.Designer.cs	2011-05-04 13:22:57 UTC (rev 5737)
@@ -0,0 +1,30 @@
+    [global::System.CodeDom.Compiler.GeneratedCodeAttribute("Microsoft.VisualStudio.Editors.SettingsDesigner.SettingsSingleFileGenerator", "9.0.0.0")]
+    internal sealed partial class Settings : global::System.Configuration.ApplicationSettingsBase
+        private static Settings defaultInstance = ((Settings)(global::System.Configuration.ApplicationSettingsBase.Synchronized(new Settings())));
+        public static Settings Default
+            get
+                return defaultInstance;
Added: trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Settings.settings
--- trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Settings.settings	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Settings.settings	2011-05-04 13:22:57 UTC (rev 5737)
@@ -0,0 +1,7 @@
+<?xml version='1.0' encoding='utf-8'?>
+<SettingsFile xmlns="http://schemas.microsoft.com/VisualStudio/2004/01/settings" CurrentProfile="(Default)">
+  <Profiles>
+    <Profile Name="(Default)" />
+  </Profiles>
+  <Settings />
+</SettingsFile>
Added: trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Form1.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Form1.Designer.cs	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Form1.Designer.cs	2011-05-04 13:22:57 UTC (rev 5737)
@@ -0,0 +1,202 @@
+namespace QueryFeatureSource
+        /// <summary>
+        /// </summary>
+        /// <summary>
+        /// </summary>
+        /// <summary>
+        /// </summary>
+            this.groupBox1 = new System.Windows.Forms.GroupBox();
+            this.groupBox2 = new System.Windows.Forms.GroupBox();
+            this.label1 = new System.Windows.Forms.Label();
+            this.txtResourceId = new System.Windows.Forms.TextBox();
+            this.button1 = new System.Windows.Forms.Button();
+            this.label2 = new System.Windows.Forms.Label();
+            this.cmbFeatureClasses = new System.Windows.Forms.ComboBox();
+            this.label3 = new System.Windows.Forms.Label();
+            this.txtFilter = new System.Windows.Forms.TextBox();
+            this.btnQuery = new System.Windows.Forms.Button();
+            this.btnClear = new System.Windows.Forms.Button();
+            this.grdResults = new System.Windows.Forms.DataGridView();
+            this.groupBox1.SuspendLayout();
+            this.groupBox2.SuspendLayout();
+            ((System.ComponentModel.ISupportInitialize)(this.grdResults)).BeginInit();
+            // groupBox1
+            this.groupBox1.Controls.Add(this.btnClear);
+            this.groupBox1.Controls.Add(this.btnQuery);
+            this.groupBox1.Controls.Add(this.txtFilter);
+            this.groupBox1.Controls.Add(this.label3);
+            this.groupBox1.Controls.Add(this.cmbFeatureClasses);
+            this.groupBox1.Controls.Add(this.label2);
+            this.groupBox1.Controls.Add(this.button1);
+            this.groupBox1.Controls.Add(this.txtResourceId);
+            this.groupBox1.Controls.Add(this.label1);
+            this.groupBox1.Location = new System.Drawing.Point(13, 13);
+            this.groupBox1.Name = "groupBox1";
+            this.groupBox1.Size = new System.Drawing.Size(660, 174);
+            this.groupBox1.TabIndex = 0;
+            this.groupBox1.TabStop = false;
+            this.groupBox1.Text = "Query Parameters";
+            // groupBox2
+            this.groupBox2.Controls.Add(this.grdResults);
+            this.groupBox2.Location = new System.Drawing.Point(13, 193);
+            this.groupBox2.Name = "groupBox2";
+            this.groupBox2.Size = new System.Drawing.Size(660, 271);
+            this.groupBox2.TabIndex = 1;
+            this.groupBox2.TabStop = false;
+            this.groupBox2.Text = "Results";
+            // label1
+            this.label1.AutoSize = true;
+            this.label1.Location = new System.Drawing.Point(16, 29);
+            this.label1.Name = "label1";
+            this.label1.Size = new System.Drawing.Size(80, 13);
+            this.label1.TabIndex = 0;
+            this.label1.Text = "Feature Source";
+            // txtResourceId
+            this.txtResourceId.Location = new System.Drawing.Point(115, 26);
+            this.txtResourceId.Name = "txtResourceId";
+            this.txtResourceId.ReadOnly = true;
+            this.txtResourceId.Size = new System.Drawing.Size(419, 20);
+            this.txtResourceId.TabIndex = 1;
+            // button1
+            this.button1.Location = new System.Drawing.Point(549, 24);
+            this.button1.Name = "button1";
+            this.button1.Size = new System.Drawing.Size(75, 23);
+            this.button1.TabIndex = 2;
+            this.button1.Text = "Browse";
+            this.button1.UseVisualStyleBackColor = true;
+            this.button1.Click += new System.EventHandler(this.button1_Click);
+            // label2
+            this.label2.AutoSize = true;
+            this.label2.Location = new System.Drawing.Point(16, 55);
+            this.label2.Name = "label2";
+            this.label2.Size = new System.Drawing.Size(71, 13);
+            this.label2.TabIndex = 3;
+            this.label2.Text = "Feature Class";
+            // cmbFeatureClasses
+            this.cmbFeatureClasses.DropDownStyle = System.Windows.Forms.ComboBoxStyle.DropDownList;
+            this.cmbFeatureClasses.FormattingEnabled = true;
+            this.cmbFeatureClasses.Location = new System.Drawing.Point(115, 52);
+            this.cmbFeatureClasses.Name = "cmbFeatureClasses";
+            this.cmbFeatureClasses.Size = new System.Drawing.Size(419, 21);
+            this.cmbFeatureClasses.TabIndex = 4;
+            // label3
+            this.label3.AutoSize = true;
+            this.label3.Location = new System.Drawing.Point(16, 95);
+            this.label3.Name = "label3";
+            this.label3.Size = new System.Drawing.Size(29, 13);
+            this.label3.TabIndex = 5;
+            this.label3.Text = "Filter";
+            // txtFilter
+            this.txtFilter.Location = new System.Drawing.Point(115, 92);
+            this.txtFilter.Name = "txtFilter";
+            this.txtFilter.Size = new System.Drawing.Size(419, 20);
+            this.txtFilter.TabIndex = 6;
+            // btnQuery
+            this.btnQuery.Location = new System.Drawing.Point(459, 136);
+            this.btnQuery.Name = "btnQuery";
+            this.btnQuery.Size = new System.Drawing.Size(75, 23);
+            this.btnQuery.TabIndex = 7;
+            this.btnQuery.Text = "Run Query";
+            this.btnQuery.UseVisualStyleBackColor = true;
+            this.btnQuery.Click += new System.EventHandler(this.btnQuery_Click);
+            // btnClear
+            this.btnClear.Location = new System.Drawing.Point(549, 136);
+            this.btnClear.Name = "btnClear";
+            this.btnClear.Size = new System.Drawing.Size(75, 23);
+            this.btnClear.TabIndex = 8;
+            this.btnClear.Text = "Clear";
+            this.btnClear.UseVisualStyleBackColor = true;
+            this.btnClear.Click += new System.EventHandler(this.btnClear_Click);
+            // grdResults
+            this.grdResults.AllowUserToAddRows = false;
+            this.grdResults.AllowUserToDeleteRows = false;
+            this.grdResults.ColumnHeadersHeightSizeMode = System.Windows.Forms.DataGridViewColumnHeadersHeightSizeMode.AutoSize;
+            this.grdResults.Dock = System.Windows.Forms.DockStyle.Fill;
+            this.grdResults.Location = new System.Drawing.Point(3, 16);
+            this.grdResults.Name = "grdResults";
+            this.grdResults.ReadOnly = true;
+            this.grdResults.Size = new System.Drawing.Size(654, 252);
+            this.grdResults.TabIndex = 0;
+            // Form1
+            this.ClientSize = new System.Drawing.Size(685, 476);
+            this.Controls.Add(this.groupBox2);
+            this.Controls.Add(this.groupBox1);
+            this.Text = "QueryFeatureSource Example";
+            this.groupBox1.ResumeLayout(false);
+            this.groupBox1.PerformLayout();
+            this.groupBox2.ResumeLayout(false);
+            ((System.ComponentModel.ISupportInitialize)(this.grdResults)).EndInit();
+        #endregion
+        private System.Windows.Forms.GroupBox groupBox1;
+        private System.Windows.Forms.ComboBox cmbFeatureClasses;
+        private System.Windows.Forms.Label label2;
+        private System.Windows.Forms.Button button1;
+        private System.Windows.Forms.TextBox txtResourceId;
+        private System.Windows.Forms.Label label1;
+        private System.Windows.Forms.GroupBox groupBox2;
+        private System.Windows.Forms.TextBox txtFilter;
+        private System.Windows.Forms.Label label3;
+        private System.Windows.Forms.Button btnClear;
+        private System.Windows.Forms.Button btnQuery;
+        private System.Windows.Forms.DataGridView grdResults;
Added: trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Form1.cs
--- trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Form1.cs	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Form1.cs	2011-05-04 13:22:57 UTC (rev 5737)
@@ -0,0 +1,147 @@
+#endregion
+using System;
+using System.Data;
+using System.Text;
+using OSGeo.MapGuide.MaestroAPI.Feature;
+using OSGeo.MapGuide.MaestroAPI.Schema;
+        public Form1()
+            //reference.
+        private void btnClear_Click(object sender, EventArgs e)
+            grdResults.Rows.Clear();
+            grdResults.Columns.Clear();
+        private void btnQuery_Click(object sender, EventArgs e)
+            //This method does the actual query
+            IFeatureReader reader = null;
+            try
+                //QueryFeatureSource gives us an IFeatureReader which contains the reader results
+                reader = _conn.FeatureService.QueryFeatureSource(
+                    txtResourceId.Text,
+                    cmbFeatureClasses.Text,
+                    txtFilter.Text);
+                //Set up the data grid with all the known fields in this reader
+                for (int i = 0; i < reader.FieldCount; i++)
+                    grdResults.Columns.Add(reader.GetName(i), reader.GetName(i));
+                //Now loop the reader to process each result
+                while (reader.ReadNext())
+                    object[] values = new object[reader.FieldCount];
+                        // Property values can be fetched by index or by name.
+                        // Regardless of which way you fetch these values, do not blindly
+                        // fetch the reader value
+                        // Need to check for null for each value we want to fetch.
+                        if (!reader.IsNull(i))
+                            values[i] = reader[i];
+                        else
+                            values[i] = DBNull.Value;
+                    //Add the result to the data grid
+                    grdResults.Rows.Add(values);
+            catch (Exception ex) //Could happen due to bad query parameters, or the connection went out while query is being executed and processed.
+                MessageBox.Show(ex.ToString());
+            finally
+                //Always close the reader when done
+                if (reader != null)
+                    reader.Close();
+        private void button1_Click(object sender, EventArgs e)
+                                                   ResourceTypes.FeatureSource,
+                    LoadFeatureSource(picker.ResourceID);
+        private void LoadFeatureSource(string featureSourceId)
+            FeatureSourceDescription desc = _conn.FeatureService.DescribeFeatureSource(featureSourceId);
+            List<ClassDefinition> classes = new List<ClassDefinition>(desc.AllClasses);
+            cmbFeatureClasses.DisplayMember = "QualifiedName";
+            cmbFeatureClasses.DataSource = classes;
+            txtResourceId.Text = featureSourceId;
Added: trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Form1.resx
--- trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Form1.resx	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Form1.resx	2011-05-04 13:22:57 UTC (rev 5737)
@@ -0,0 +1,120 @@
+<root>
+    Version 2.0
+    Example:
+    </data>
+    </data>
+    name/value pairs.
+    mimetype set.
+      <xsd:complexType>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+            <xsd:complexType>
+          </xsd:element>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+        </xsd:choice>
+    </xsd:element>
+  </xsd:schema>
+  </resheader>
+  </resheader>
+  </resheader>
+  </resheader>
+</root>
Added: trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Program.cs
--- trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Program.cs	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Program.cs	2011-05-04 13:22:57 UTC (rev 5737)
@@ -0,0 +1,39 @@
+#endregion
+using System;
+        /// <summary>
+        /// </summary>
+        [STAThread]
Added: trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/AssemblyInfo.cs	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/AssemblyInfo.cs	2011-05-04 13:22:57 UTC (rev 5737)
@@ -0,0 +1,36 @@
+[assembly: AssemblyTitle("QueryFeatureSource")]
+[assembly: AssemblyProduct("QueryFeatureSource")]
+[assembly: Guid("9c115511-e4d7-4554-a22e-377ced9f3f71")]
+//      Major Version
+//      Minor Version
+//      Build Number
+//      Revision
Added: trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Resources.Designer.cs	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Resources.Designer.cs	2011-05-04 13:22:57 UTC (rev 5737)
@@ -0,0 +1,71 @@
+namespace QueryFeatureSource.Properties
+    /// <summary>
+    /// </summary>
+        /// <summary>
+        /// </summary>
+            get
+                    global::System.Resources.ResourceManager temp = new global::System.Resources.ResourceManager("QueryFeatureSource.Properties.Resources", typeof(Resources).Assembly);
+        /// <summary>
+        /// </summary>
+            get
+            set
Added: trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Resources.resx
--- trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Resources.resx	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Resources.resx	2011-05-04 13:22:57 UTC (rev 5737)
@@ -0,0 +1,117 @@
+<root>
+    Version 2.0
+    Example:
+    </data>
+    </data>
+    name/value pairs.
+    mimetype set.
+      <xsd:complexType>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+            <xsd:complexType>
+          </xsd:element>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+        </xsd:choice>
+    </xsd:element>
+  </xsd:schema>
+  </resheader>
+  </resheader>
+  </resheader>
+  </resheader>
+</root>
Added: trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Settings.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Settings.Designer.cs	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Settings.Designer.cs	2011-05-04 13:22:57 UTC (rev 5737)
@@ -0,0 +1,30 @@
+            get
Added: trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Settings.settings
--- trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Settings.settings	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Settings.settings	2011-05-04 13:22:57 UTC (rev 5737)
@@ -0,0 +1,7 @@
+  <Profiles>
+  </Profiles>
+  <Settings />
+</SettingsFile>
Added: trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/QueryFeatureSource.csproj
--- trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/QueryFeatureSource.csproj	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/QueryFeatureSource.csproj	2011-05-04 13:22:57 UTC (rev 5737)
@@ -0,0 +1,102 @@
+  <PropertyGroup>
+    <ProjectGuid>{7C572B2A-5E77-4AB4-B8AD-1172D3E725EC}</ProjectGuid>
+    <RootNamespace>QueryFeatureSource</RootNamespace>
+    <AssemblyName>QueryFeatureSource</AssemblyName>
+  </PropertyGroup>
+  </PropertyGroup>
+  </PropertyGroup>
+  <ItemGroup>
+    </Reference>
+    </Reference>
+    </Reference>
+  </ItemGroup>
+  <ItemGroup>
+    </Compile>
+    </Compile>
+    </Compile>
+    </None>
+    </Compile>
+  </ItemGroup>
+  <ItemGroup>
+    </Content>
+    </Content>
+  </ItemGroup>
+  </Target>
+  </Target>
+</Project>
Added: trunk/Tools/Maestro/SDK/Samples/Samples.sln
--- trunk/Tools/Maestro/SDK/Samples/Samples.sln	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/Samples.sln	2011-05-04 13:22:57 UTC (rev 5737)
@@ -0,0 +1,26 @@
+Microsoft Visual Studio Solution File, Format Version 10.00
+# Visual Studio 2008
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "DrawMap", "DrawMap\DrawMap.csproj", "{30EA9CAC-7DFA-4434-87F4-0AB226F2D305}"
+EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "QueryFeatureSource", "QueryFeatureSource\QueryFeatureSource.csproj", "{7C572B2A-5E77-4AB4-B8AD-1172D3E725EC}"
+EndProject
+Global
+	GlobalSection(SolutionConfigurationPlatforms) = preSolution
+		Debug|Any CPU = Debug|Any CPU
+		Release|Any CPU = Release|Any CPU
+	EndGlobalSection
+	GlobalSection(ProjectConfigurationPlatforms) = postSolution
+		{30EA9CAC-7DFA-4434-87F4-0AB226F2D305}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+		{30EA9CAC-7DFA-4434-87F4-0AB226F2D305}.Debug|Any CPU.Build.0 = Debug|Any CPU
+		{30EA9CAC-7DFA-4434-87F4-0AB226F2D305}.Release|Any CPU.ActiveCfg = Release|Any CPU
+		{30EA9CAC-7DFA-4434-87F4-0AB226F2D305}.Release|Any CPU.Build.0 = Release|Any CPU
+		{7C572B2A-5E77-4AB4-B8AD-1172D3E725EC}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+		{7C572B2A-5E77-4AB4-B8AD-1172D3E725EC}.Debug|Any CPU.Build.0 = Debug|Any CPU
+		{7C572B2A-5E77-4AB4-B8AD-1172D3E725EC}.Release|Any CPU.ActiveCfg = Release|Any CPU
+		{7C572B2A-5E77-4AB4-B8AD-1172D3E725EC}.Release|Any CPU.Build.0 = Release|Any CPU
+	EndGlobalSection
+	GlobalSection(SolutionProperties) = preSolution
+		HideSolutionNode = FALSE
+	EndGlobalSection
+EndGlobal
More information about the mapguide-commits
