[mapguide-commits] r5785 - trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/SubEditors
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu May 12 07:33:26 EDT 2011
Author: jng
Date: 2011-05-12 04:33:26 -0700 (Thu, 12 May 2011)
New Revision: 5785
   trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/SubEditors/UnmanagedCtrl.Designer.cs
   trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/SubEditors/UnmanagedCtrl.cs
   trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/SubEditors/UnmanagedCtrl.resx
#1688: Enable file and alias browsing for Unmanaged file sub-editor
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/SubEditors/UnmanagedCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/SubEditors/UnmanagedCtrl.Designer.cs	2011-05-12 10:58:09 UTC (rev 5784)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/SubEditors/UnmanagedCtrl.Designer.cs	2011-05-12 11:33:26 UTC (rev 5785)
@@ -32,6 +32,7 @@
             this.label1 = new System.Windows.Forms.Label();
             this.txtFilePath = new System.Windows.Forms.TextBox();
             this.btnBrowse = new System.Windows.Forms.Button();
+            this.btnBrowseAlias = new System.Windows.Forms.Button();
             this.SuspendLayout();
             // label1
@@ -43,17 +44,28 @@
             resources.ApplyResources(this.txtFilePath, "txtFilePath");
             this.txtFilePath.Name = "txtFilePath";
+            this.txtFilePath.TextChanged += new System.EventHandler(this.txtFilePath_TextChanged);
             // btnBrowse
             resources.ApplyResources(this.btnBrowse, "btnBrowse");
             this.btnBrowse.Name = "btnBrowse";
             this.btnBrowse.UseVisualStyleBackColor = true;
+            this.btnBrowse.Click += new System.EventHandler(this.btnBrowse_Click);
+            // btnBrowseAlias
+            resources.ApplyResources(this.btnBrowseAlias, "btnBrowseAlias");
+            this.btnBrowseAlias.Image = global::Maestro.Editors.Properties.Resources.document;
+            this.btnBrowseAlias.Name = "btnBrowseAlias";
+            this.btnBrowseAlias.UseVisualStyleBackColor = true;
+            this.btnBrowseAlias.Click += new System.EventHandler(this.btnBrowseAlias_Click);
             // UnmanagedCtrl
             resources.ApplyResources(this, "$this");
             this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+            this.Controls.Add(this.btnBrowseAlias);
             this.Controls.Add(this.btnBrowse);
             this.Controls.Add(this.txtFilePath);
             this.Controls.Add(this.label1);
@@ -68,5 +80,6 @@
         private System.Windows.Forms.Label label1;
         private System.Windows.Forms.TextBox txtFilePath;
         private System.Windows.Forms.Button btnBrowse;
+        private System.Windows.Forms.Button btnBrowseAlias;
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/SubEditors/UnmanagedCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/SubEditors/UnmanagedCtrl.cs	2011-05-12 10:58:09 UTC (rev 5784)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/SubEditors/UnmanagedCtrl.cs	2011-05-12 11:33:26 UTC (rev 5785)
@@ -25,6 +25,8 @@
 using System.Text;
 using System.Windows.Forms;
 using System.Collections.Specialized;
+using Maestro.Editors.Common;
+using OSGeo.MapGuide.MaestroAPI.Services;
 namespace Maestro.Editors.FeatureSource.Providers.Odbc.SubEditors
@@ -36,9 +38,12 @@
             InitializeComponent();
+        private IResourceService _resSvc;
         public override void Bind(IEditorService service)
             service.RegisterCustomNotifier(this);
+            _resSvc = service.ResourceService;
         public Control Content
@@ -105,5 +110,37 @@
         public event EventHandler ConnectionChanged;
+        private void btnBrowse_Click(object sender, EventArgs e)
+            using (var open = new OpenFileDialog())
+                open.Filter = Properties.Resources.OdbcDriverAccess + "|*.mdb|" +
+                              Properties.Resources.OdbcDriverAccess64 + "|*.accdb|" +
+                              Properties.Resources.OdbcDriverExcel + "|*.xls|" +
+                              Properties.Resources.OdbcDriverExcel64 + "|*.xlsx, *.xlsm, *.xlsb";
+                if (open.ShowDialog() == DialogResult.OK)
+                    txtFilePath.Text = open.FileName;
+        private void btnBrowseAlias_Click(object sender, EventArgs e)
+            using (var picker = new UnmanagedFileBrowser(_resSvc))
+                if (picker.ShowDialog() == DialogResult.OK)
+                    txtFilePath.Text = picker.SelectedItem;
+        private void txtFilePath_TextChanged(object sender, EventArgs e)
+            OnConnectionChanged();
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/SubEditors/UnmanagedCtrl.resx
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/SubEditors/UnmanagedCtrl.resx	2011-05-12 10:58:09 UTC (rev 5784)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/SubEditors/UnmanagedCtrl.resx	2011-05-12 11:33:26 UTC (rev 5785)
@@ -144,7 +144,7 @@
     <value>$this</value>
   </data>
   <data name="&gt;&gt;label1.ZOrder" xml:space="preserve">
-    <value>2</value>
+    <value>3</value>
   </data>
   <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
   <data name="txtFilePath.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
@@ -154,7 +154,7 @@
     <value>3, 28</value>
   </data>
   <data name="txtFilePath.Size" type="System.Drawing.Size, System.Drawing">
-    <value>451, 20</value>
+    <value>421, 20</value>
   </data>
   <data name="txtFilePath.TabIndex" type="System.Int32, mscorlib">
     <value>1</value>
@@ -169,13 +169,13 @@
   </data>
   <data name="&gt;&gt;txtFilePath.ZOrder" xml:space="preserve">
-    <value>1</value>
+    <value>2</value>
   </data>
   <data name="btnBrowse.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
     <value>Top, Right</value>
   </data>
   <data name="btnBrowse.Location" type="System.Drawing.Point, System.Drawing">
-    <value>460, 26</value>
+    <value>430, 26</value>
   </data>
   <data name="btnBrowse.Size" type="System.Drawing.Size, System.Drawing">
     <value>27, 23</value>
@@ -196,6 +196,33 @@
   </data>
   <data name="&gt;&gt;btnBrowse.ZOrder" xml:space="preserve">
+    <value>1</value>
+  </data>
+  <data name="btnBrowseAlias.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+    <value>Top, Right</value>
+  </data>
+  <data name="btnBrowseAlias.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+    <value>NoControl</value>
+  </data>
+  <data name="btnBrowseAlias.Location" type="System.Drawing.Point, System.Drawing">
+    <value>460, 26</value>
+  </data>
+  <data name="btnBrowseAlias.Size" type="System.Drawing.Size, System.Drawing">
+    <value>27, 23</value>
+  </data>
+  <data name="btnBrowseAlias.TabIndex" type="System.Int32, mscorlib">
+    <value>3</value>
+  </data>
+  <data name="&gt;&gt;btnBrowseAlias.Name" xml:space="preserve">
+    <value>btnBrowseAlias</value>
+  </data>
+  <data name="&gt;&gt;btnBrowseAlias.Type" xml:space="preserve">
+    <value>System.Windows.Forms.Button, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name="&gt;&gt;btnBrowseAlias.Parent" xml:space="preserve">
+    <value>$this</value>
+  </data>
+  <data name="&gt;&gt;btnBrowseAlias.ZOrder" xml:space="preserve">
     <value>0</value>
   </data>
   <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
@@ -211,6 +238,6 @@
     <value>UnmanagedCtrl</value>
   </data>
   <data name="&gt;&gt;$this.Type" xml:space="preserve">
-    <value>Maestro.Editors.EditorBase, Maestro.Editors, Version=3.0.0.5475, Culture=neutral, PublicKeyToken=null</value>
+    <value>Maestro.Editors.EditorBase, Maestro.Editors, Version=3.0.0.5728, Culture=neutral, PublicKeyToken=null</value>
   </data>
 </root>
\ No newline at end of file
More information about the mapguide-commits mailing list
