[mapguide-commits] r5813 - trunk/Tools/Maestro/Maestro.Base/Editor
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue May 17 12:37:24 EDT 2011
Author: jng
Date: 2011-05-17 09:37:23 -0700 (Tue, 17 May 2011)
New Revision: 5813
   trunk/Tools/Maestro/Maestro.Base/Editor/ResourcePreviewEngine.cs
#1694: Add a KML output command to the generated preview web layout. These extra commands are now under a "Tools" flyout menu
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/ResourcePreviewEngine.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/ResourcePreviewEngine.cs	2011-05-17 16:03:11 UTC (rev 5812)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/ResourcePreviewEngine.cs	2011-05-17 16:37:23 UTC (rev 5813)
@@ -90,7 +90,7 @@
                 var wl = ObjectFactory.CreateWebLayout(_edSvc.GetEditedResource().CurrentConnection, new Version(1, 0, 0), mdfId);
                 //Add a custom zoom command (to assist previews of layers that aren't [0, infinity] scale)
-                AttachZoomToScaleCommand(wl);
+                AttachPreviewCommands(wl);
                 var resId = "Session:" + sessionId + "//" + Guid.NewGuid() + ".WebLayout";
@@ -112,7 +112,7 @@
             return url;
-        private static void AttachZoomToScaleCommand(IWebLayout wl)
+        private static void AttachPreviewCommands(IWebLayout wl)
             var cmd = wl.CreateInvokeScriptCommand();
             cmd.Name = "ZoomScale";
@@ -130,8 +130,29 @@
             wl.CommandSet.AddCommand(cmd);
-            var item = wl.CreateCommandItem(cmd.Name);
-            wl.ToolBar.AddItem(item);
+            var cmd2 = wl.CreateInvokeScriptCommand();
+            cmd2.Name = "GetMapKml";
+            cmd2.Label = "Get KML";
+            cmd2.Description = "Gets the current map as a KML document";
+            cmd2.Tooltip = "Gets the current map as a KML document";
+            cmd2.Script = @"
+                var map = parent.parent.GetMapFrame();
+                var url = ""../mapagent/mapagent.fcgi?OPERATION=GETMAPKML&VERSION=1.0.0&FORMAT=KML&DISPLAYDPI=96&MAPDEFINITION=" + wl.Map.ResourceId + @""";
+                url += ""&SESSION="" + map.GetSessionId();
+                window.open(url);";
+            cmd2.TargetViewer = TargetViewerType.Ajax;
+            cmd2.ImageURL = "../stdicons/icon_invokescript.gif";
+            wl.CommandSet.AddCommand(cmd2);
+            var zoomScale = wl.CreateCommandItem(cmd.Name);
+            var menu = wl.CreateFlyout("Tools", "Tools", "Extra tools", "", "",
+                wl.CreateCommandItem("ZoomScale"),
+                wl.CreateCommandItem("GetMapKml")
+            wl.ToolBar.AddItem(menu);
         private string GenerateMapPreviewUrl(IResource res)
@@ -153,7 +174,7 @@
More information about the mapguide-commits mailing list
