[mapguide-commits] r5821 - in trunk/MgDev: Common/Foundation/System
	Common/Geometry Common/Renderers
	Oem/dbxml/xerces-c-src/projects/Win32/VC10/xerces-all/XercesLib
	Server Server/src/Common/Base Server/src/Services/Drawing
	Server/src/Services/Feature Server/src/Services/Kml
	Server/src/Services/Mapping Server/src/Services/Rendering
	Server/src/Services/Resource Server/src/Services/ServerAdmin
	Server/src/Services/Site Server/src/Services/Tile
	Server/src/UnitTesting
    svn_mapguide at osgeo.org
    Thu May 19 03:59:46 EDT 2011
Author: hubu
Date: 2011-05-19 00:59:46 -0700 (Thu, 19 May 2011)
New Revision: 5821
   trunk/MgDev/Common/Foundation/System/ConfigurationHeap.cpp
   trunk/MgDev/Common/Geometry/Geometry.vcxproj
   trunk/MgDev/Common/Renderers/Renderers.vcxproj
   trunk/MgDev/Oem/dbxml/xerces-c-src/projects/Win32/VC10/xerces-all/XercesLib/XercesLib.vcxproj
   trunk/MgDev/Server/Server_VS2010.sln
   trunk/MgDev/Server/src/Common/Base/ServerBase.vcxproj
   trunk/MgDev/Server/src/Services/Drawing/ServerDrawingService.vcxproj
   trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.vcxproj
   trunk/MgDev/Server/src/Services/Kml/ServerKmlService.vcxproj
   trunk/MgDev/Server/src/Services/Mapping/ServerMappingService.vcxproj
   trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.vcxproj
   trunk/MgDev/Server/src/Services/Resource/ServerResourceService.vcxproj
   trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.vcxproj
   trunk/MgDev/Server/src/Services/Site/ServerSiteService.vcxproj
   trunk/MgDev/Server/src/Services/Tile/ServerTileService.vcxproj
   trunk/MgDev/Server/src/UnitTesting/UnitTesting.vcxproj
RFC107 - porting mapguide server to VS2010.
Modified: trunk/MgDev/Common/Foundation/System/ConfigurationHeap.cpp
--- trunk/MgDev/Common/Foundation/System/ConfigurationHeap.cpp	2011-05-18 17:02:18 UTC (rev 5820)
+++ trunk/MgDev/Common/Foundation/System/ConfigurationHeap.cpp	2011-05-19 07:59:46 UTC (rev 5821)
@@ -64,7 +64,7 @@
         wstring mbLine = Trim(MG_TCHAR_TO_WCHAR(buffer)); // remove extra spaces at beginning and end of line
         // Blank line
-        if (mbLine[0] == L'\0')
+        if (mbLine.size() <= 0 || mbLine[0] == L'\0')
             continue;
@@ -113,7 +113,7 @@
         wstring propertyName = Trim(mbLine.substr(0, pos).c_str());
         wstring value = Trim(mbLine.substr(pos+1, (mbLine.size()-pos-1)).c_str());
         // Remove any quotes that may be present at ends of value
-        if (value[0] == L'\"' && value[value.length()-1] == L'\"')
+        if (value.size() > 0 && value[0] == L'\"' && value[value.length()-1] == L'\"')
             value = value.substr(1,value.length()-2);
Modified: trunk/MgDev/Common/Geometry/Geometry.vcxproj
--- trunk/MgDev/Common/Geometry/Geometry.vcxproj	2011-05-18 17:02:18 UTC (rev 5820)
+++ trunk/MgDev/Common/Geometry/Geometry.vcxproj	2011-05-19 07:59:46 UTC (rev 5821)
@@ -1085,9 +1085,6 @@
     <ProjectReference Include="..\Foundation\Foundation.vcxproj">
       <Project>{a82adc7d-4da4-42f2-9bf6-df5dcfb44425}</Project>
     </ProjectReference>
-    <ProjectReference Include="..\MdfModel\MdfModel.vcxproj">
-      <Project>{c50254f2-654a-48de-af5b-20605aef8d10}</Project>
-    </ProjectReference>
   </ItemGroup>
   <Import Project="$(VCTargetsPath)\Microsoft.Cpp.targets" />
   <ImportGroup Label="ExtensionTargets">
Modified: trunk/MgDev/Common/Renderers/Renderers.vcxproj
--- trunk/MgDev/Common/Renderers/Renderers.vcxproj	2011-05-18 17:02:18 UTC (rev 5820)
+++ trunk/MgDev/Common/Renderers/Renderers.vcxproj	2011-05-19 07:59:46 UTC (rev 5821)
@@ -103,7 +103,7 @@
     <Link>
       <AdditionalDependencies>dwfcore_wt.1.1.1.lib;dwftk_wt.7.1.1.lib;whiptk_wt.7.7.601.lib;emaptk_wt.1.0.0.lib;gd.lib;freetype235_D.lib;libpngd.lib;%(AdditionalDependencies)</AdditionalDependencies>
       <OutputFile>$(OutDir)MgRenderersd.dll</OutputFile>
-      <AdditionalLibraryDirectories>..\..\Oem\DWFTK7.1\develop\global\lib\static\debug\vc8.0;..\..\Oem\gd\build\win32\gd\Debug;..\..\Oem\gd\freetype\objs;..\..\Oem\gd\lpng\projects\visualc8\Win32_LIB_ASM_Debug;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
+      <AdditionalLibraryDirectories>..\..\Oem\DWFTK7.1\develop\global\lib\static\debug\vc8.0;..\..\Oem\gd\build\win32\gd\Debug;..\..\Oem\gd\freetype\objs\debug;..\..\Oem\gd\lpng\projects\visualc8\Win32_LIB_ASM_Debug;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
       <GenerateDebugInformation>true</GenerateDebugInformation>
       <ProgramDatabaseFile>$(OutDir)MgRenderersd.pdb</ProgramDatabaseFile>
       <SubSystem>Windows</SubSystem>
@@ -159,7 +159,7 @@
     <Link>
       <AdditionalDependencies>dwfcore_wt.1.1.1.lib;dwftk_wt.7.1.1.lib;whiptk_wt.7.7.601.lib;emaptk_wt.1.0.0.lib;gd.lib;freetype235.lib;libpng.lib;%(AdditionalDependencies)</AdditionalDependencies>
       <OutputFile>$(OutDir)MgRenderers.dll</OutputFile>
-      <AdditionalLibraryDirectories>..\..\Oem\DWFTK7.1\develop\global\lib\static\release\vc8.0;..\..\Oem\gd\build\win32\gd\Release;..\..\Oem\gd\freetype\objs;..\..\Oem\gd\lpng\projects\visualc8\Win32_LIB_ASM_Release;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
+      <AdditionalLibraryDirectories>..\..\Oem\DWFTK7.1\develop\global\lib\static\release\vc8.0;..\..\Oem\gd\build\win32\gd\Release;..\..\Oem\gd\freetype\objs\release;..\..\Oem\gd\lpng\projects\visualc8\Win32_LIB_ASM_Release;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
       <ProgramDatabaseFile>$(OutDir)MgRenderers.pdb</ProgramDatabaseFile>
@@ -192,7 +192,7 @@
     <Link>
-      <AdditionalLibraryDirectories>..\..\Oem\DWFTK7.1\develop\global\lib\static\release64\vc8.0;..\..\Oem\gd\build\win32\gd\Release64;..\..\Oem\gd\freetype\objs64;..\..\Oem\gd\lpng\projects\visualc8\Win64_LIB_Release;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
+      <AdditionalLibraryDirectories>..\..\Oem\DWFTK7.1\develop\global\lib\static\release64\vc8.0;..\..\Oem\gd\build\win32\gd\Release64;..\..\Oem\gd\freetype\objs64\release64;..\..\Oem\gd\lpng\projects\visualc8\Win64_LIB_Release;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
Modified: trunk/MgDev/Oem/dbxml/xerces-c-src/projects/Win32/VC10/xerces-all/XercesLib/XercesLib.vcxproj
--- trunk/MgDev/Oem/dbxml/xerces-c-src/projects/Win32/VC10/xerces-all/XercesLib/XercesLib.vcxproj	2011-05-18 17:02:18 UTC (rev 5820)
+++ trunk/MgDev/Oem/dbxml/xerces-c-src/projects/Win32/VC10/xerces-all/XercesLib/XercesLib.vcxproj	2011-05-19 07:59:46 UTC (rev 5821)
@@ -228,10 +228,10 @@
       <OutputFile>$(OutDir)\xerces-c_3_1mg.dll</OutputFile>
       <AdditionalLibraryDirectories>%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
-      <ProgramDatabaseFile>$(OutDir)xerces-c_3_1.fullpdb</ProgramDatabaseFile>
-      <StripPrivateSymbols>$(OutDir)xerces-c_3_1.pdb</StripPrivateSymbols>
+      <ProgramDatabaseFile>$(OutDir)xerces-c_3_1mg.fullpdb</ProgramDatabaseFile>
+      <StripPrivateSymbols>$(OutDir)xerces-c_3_1mg.pdb</StripPrivateSymbols>
       <GenerateMapFile>true</GenerateMapFile>
-      <MapFileName>$(IntDir)xerces-c_3_1.map</MapFileName>
+      <MapFileName>$(IntDir)xerces-c_3_1mg.map</MapFileName>
       <OptimizeReferences>true</OptimizeReferences>
       <SetChecksum>true</SetChecksum>
@@ -274,10 +274,10 @@
@@ -321,7 +321,7 @@
       <OutputFile>$(OutDir)\xerces-c_3_1mgD.dll</OutputFile>
-      <ProgramDatabaseFile>$(OutDir)xerces-c_3_1D.pdb</ProgramDatabaseFile>
+      <ProgramDatabaseFile>$(OutDir)xerces-c_3_1mgD.pdb</ProgramDatabaseFile>
       <SetChecksum>false</SetChecksum>
       <BaseAddress>0x12000000</BaseAddress>
@@ -361,7 +361,7 @@
Modified: trunk/MgDev/Server/Server_VS2010.sln
--- trunk/MgDev/Server/Server_VS2010.sln	2011-05-18 17:02:18 UTC (rev 5820)
+++ trunk/MgDev/Server/Server_VS2010.sln	2011-05-19 07:59:46 UTC (rev 5821)
@@ -276,11 +276,9 @@
 		{42491401-B624-440D-91D7-1F2633EFB4E3}.Release|x64.Build.0 = Release|x64
 		{DD0284A0-1ECE-4387-AED3-E9BF5EE74FF8}.Debug|Win32.ActiveCfg = Debug|Win32
 		{DD0284A0-1ECE-4387-AED3-E9BF5EE74FF8}.Debug|x64.ActiveCfg = Debug|x64
-		{DD0284A0-1ECE-4387-AED3-E9BF5EE74FF8}.Debug|x64.Build.0 = Debug|x64
 		{DD0284A0-1ECE-4387-AED3-E9BF5EE74FF8}.Release|Win32.ActiveCfg = Release|Win32
 		{DD0284A0-1ECE-4387-AED3-E9BF5EE74FF8}.Release|Win32.Build.0 = Release|Win32
 		{DD0284A0-1ECE-4387-AED3-E9BF5EE74FF8}.Release|x64.ActiveCfg = Release|x64
-		{DD0284A0-1ECE-4387-AED3-E9BF5EE74FF8}.Release|x64.Build.0 = Release|x64
 		{F486B768-640A-445D-8C09-437C896EFFAD}.Debug|Win32.ActiveCfg = Debug|Win32
 		{F486B768-640A-445D-8C09-437C896EFFAD}.Debug|Win32.Build.0 = Debug|Win32
 		{F486B768-640A-445D-8C09-437C896EFFAD}.Debug|x64.ActiveCfg = Debug|x64
Modified: trunk/MgDev/Server/src/Common/Base/ServerBase.vcxproj
--- trunk/MgDev/Server/src/Common/Base/ServerBase.vcxproj	2011-05-18 17:02:18 UTC (rev 5820)
+++ trunk/MgDev/Server/src/Common/Base/ServerBase.vcxproj	2011-05-19 07:59:46 UTC (rev 5821)
@@ -229,10 +229,6 @@
     <ResourceCompile Include="ServerBase.rc" />
   </ItemGroup>
   <ItemGroup>
-    <ProjectReference Include="..\..\..\..\..\Server\src\Common\Manager\ServerManager.vcxproj">
-      <Project>{adbf25e2-c629-4832-b315-f12abde05632}</Project>
-      <ReferenceOutputAssembly>false</ReferenceOutputAssembly>
     <ProjectReference Include="..\..\..\..\Common\Foundation\Foundation.vcxproj">
Modified: trunk/MgDev/Server/src/Services/Drawing/ServerDrawingService.vcxproj
--- trunk/MgDev/Server/src/Services/Drawing/ServerDrawingService.vcxproj	2011-05-18 17:02:18 UTC (rev 5820)
+++ trunk/MgDev/Server/src/Services/Drawing/ServerDrawingService.vcxproj	2011-05-19 07:59:46 UTC (rev 5821)
@@ -311,10 +311,6 @@
     <ResourceCompile Include="ServerDrawingService.rc" />
   </ItemGroup>
   <ItemGroup>
Modified: trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.vcxproj
--- trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.vcxproj	2011-05-18 17:02:18 UTC (rev 5820)
+++ trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.vcxproj	2011-05-19 07:59:46 UTC (rev 5821)
@@ -874,14 +874,6 @@
     <ResourceCompile Include="ServerFeatureService.rc" />
   </ItemGroup>
   <ItemGroup>
-    <ProjectReference Include="..\..\..\..\..\Common\Security\Security.vcxproj">
-      <Project>{7c1c5695-c51c-4017-abef-bc3032cbaf3b}</Project>
Modified: trunk/MgDev/Server/src/Services/Kml/ServerKmlService.vcxproj
--- trunk/MgDev/Server/src/Services/Kml/ServerKmlService.vcxproj	2011-05-18 17:02:18 UTC (rev 5820)
+++ trunk/MgDev/Server/src/Services/Kml/ServerKmlService.vcxproj	2011-05-19 07:59:46 UTC (rev 5821)
@@ -257,10 +257,6 @@
     <ResourceCompile Include="ServerKmlService.rc" />
   </ItemGroup>
   <ItemGroup>
Modified: trunk/MgDev/Server/src/Services/Mapping/ServerMappingService.vcxproj
--- trunk/MgDev/Server/src/Services/Mapping/ServerMappingService.vcxproj	2011-05-18 17:02:18 UTC (rev 5820)
+++ trunk/MgDev/Server/src/Services/Mapping/ServerMappingService.vcxproj	2011-05-19 07:59:46 UTC (rev 5821)
@@ -340,10 +340,6 @@
     <ResourceCompile Include="ServerMappingService.rc" />
   </ItemGroup>
   <ItemGroup>
Modified: trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.vcxproj
--- trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.vcxproj	2011-05-18 17:02:18 UTC (rev 5820)
+++ trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.vcxproj	2011-05-19 07:59:46 UTC (rev 5821)
@@ -292,10 +292,6 @@
     <ResourceCompile Include="ServerRenderingService.rc" />
   </ItemGroup>
   <ItemGroup>
Modified: trunk/MgDev/Server/src/Services/Resource/ServerResourceService.vcxproj
--- trunk/MgDev/Server/src/Services/Resource/ServerResourceService.vcxproj	2011-05-18 17:02:18 UTC (rev 5820)
+++ trunk/MgDev/Server/src/Services/Resource/ServerResourceService.vcxproj	2011-05-19 07:59:46 UTC (rev 5821)
@@ -759,14 +759,6 @@
     <ResourceCompile Include="ServerResourceService.rc" />
   </ItemGroup>
   <ItemGroup>
Modified: trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.vcxproj
--- trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.vcxproj	2011-05-18 17:02:18 UTC (rev 5820)
+++ trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.vcxproj	2011-05-19 07:59:46 UTC (rev 5821)
@@ -456,10 +456,6 @@
     <ResourceCompile Include="ServerAdminService.rc" />
   </ItemGroup>
   <ItemGroup>
Modified: trunk/MgDev/Server/src/Services/Site/ServerSiteService.vcxproj
--- trunk/MgDev/Server/src/Services/Site/ServerSiteService.vcxproj	2011-05-18 17:02:18 UTC (rev 5820)
+++ trunk/MgDev/Server/src/Services/Site/ServerSiteService.vcxproj	2011-05-19 07:59:46 UTC (rev 5821)
@@ -423,14 +423,6 @@
     <ResourceCompile Include="ServerSiteService.rc" />
   </ItemGroup>
   <ItemGroup>
Modified: trunk/MgDev/Server/src/Services/Tile/ServerTileService.vcxproj
--- trunk/MgDev/Server/src/Services/Tile/ServerTileService.vcxproj	2011-05-18 17:02:18 UTC (rev 5820)
+++ trunk/MgDev/Server/src/Services/Tile/ServerTileService.vcxproj	2011-05-19 07:59:46 UTC (rev 5821)
@@ -278,10 +278,6 @@
     <ResourceCompile Include="ServerTileService.rc" />
   </ItemGroup>
   <ItemGroup>
Modified: trunk/MgDev/Server/src/UnitTesting/UnitTesting.vcxproj
--- trunk/MgDev/Server/src/UnitTesting/UnitTesting.vcxproj	2011-05-18 17:02:18 UTC (rev 5820)
+++ trunk/MgDev/Server/src/UnitTesting/UnitTesting.vcxproj	2011-05-19 07:59:46 UTC (rev 5821)
@@ -238,14 +238,6 @@
     <ResourceCompile Include="UnitTesting.rc" />
   </ItemGroup>
   <ItemGroup>
-    <ProjectReference Include="..\..\..\..\Common\Security\Security.vcxproj">
-    <ProjectReference Include="..\..\..\..\Server\src\Common\Manager\ServerManager.vcxproj">
     <ProjectReference Include="..\..\..\..\Server\src\Core\ServerCore_Mentor.vcxproj">
       <Project>{78971a60-bd03-43d5-9adf-403a0098a64a}</Project>
More information about the mapguide-commits
