[mapguide-commits] r5823 - in trunk/Tools/Maestro: Maestro.Editors/MapDefinition Maestro.Editors/Properties OSGeo.MapGuide.MaestroAPI/ObjectModels
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri May 20 07:31:31 EDT 2011
Author: jng
Date: 2011-05-20 04:31:31 -0700 (Fri, 20 May 2011)
New Revision: 5823
   trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.cs
   trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
   trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerInterfaceExtensions.cs
#1698: Notify the user if some or all extents failed transformation to Map's Coordinate System
Modified: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.cs	2011-05-20 06:00:49 UTC (rev 5822)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.cs	2011-05-20 11:31:31 UTC (rev 5823)
@@ -32,6 +32,7 @@
 using OSGeo.MapGuide.ObjectModels.MapDefinition;
 using System.Globalization;
 using OSGeo.MapGuide.MaestroAPI.CoordinateSystem;
+using OSGeo.MapGuide.ObjectModels;
 namespace Maestro.Editors.MapDefinition
@@ -239,39 +240,84 @@
-                var env = Util.GetCombinedExtents(layers);
-                _map.SetExtents(env.MinX, env.MinY, env.MaxX, env.MaxY);
+                var env = Util.GetCombinedExtents(_map, layers);
+                if (env != null)
+                    _map.SetExtents(env.MinX, env.MinY, env.MaxX, env.MaxY);
+                    MessageBox.Show(Properties.Resources.WarningMapExtentCalculation, Properties.Resources.TitleWarning, MessageBoxButtons.OK, MessageBoxIcon.Warning);
+                else
+                    MessageBox.Show(Properties.Resources.ErrorMapExtentCalculationFailed, Properties.Resources.TitleError, MessageBoxButtons.OK, MessageBoxIcon.Error);
         internal class Util
-            public static IEnvelope GetCombinedExtents(IEnumerable<ILayerDefinition> layers)
+            public static IEnvelope GetCombinedExtents(IMapDefinition mapDef, IEnumerable<ILayerDefinition> layers)
                 Check.NotNull(layers, "layers");
                 IEnvelope env = null;
                 foreach (var layer in layers)
                     var e1 = layer.GetSpatialExtent(true);
-                    if (env == null)
+                    var wkt = layer.GetCoordinateSystemWkt();
+                    if (wkt != mapDef.CoordinateSystem)
-                        env = e1;
+                        e1 = TransformEnvelope(e1, wkt, mapDef.CoordinateSystem);
+                    if (e1 != null)
+                        if (env == null)
+                            env = e1;
+                        else
+                            if (e1.MinX < env.MinX)
+                                env.MinX = e1.MinX;
+                            if (e1.MinY < env.MinY)
+                                env.MinY = e1.MinY;
+                            if (e1.MaxX > env.MaxX)
+                                env.MaxX = e1.MaxX;
+                            if (e1.MaxY > env.MaxY)
+                                env.MaxY = e1.MaxY;
                     else
-                        if (e1.MinX < env.MinX)
-                            env.MinX = e1.MinX;
-                        if (e1.MinY < env.MinY)
-                            env.MinY = e1.MinY;
-                        if (e1.MaxX > env.MaxX)
-                            env.MaxX = e1.MaxX;
-                        if (e1.MaxY > env.MaxY)
-                            env.MaxY = e1.MaxY;
+                        System.Diagnostics.Trace.TraceWarning("Could not transform extent of layer " + layer.ResourceID + " to the map definition's coordinate system. Extents ignored");
                 return env;
+            private static IEnvelope TransformEnvelope(IEnvelope env, string srcCsWkt, string dstCsWkt)
+                try
+                    var trans = new DefaultSimpleTransform(srcCsWkt, dstCsWkt);
+                    var oldExt = env;
+                    double llx;
+                    double lly;
+                    double urx;
+                    double ury;
+                    trans.Transform(oldExt.MinX, oldExt.MinY, out llx, out lly);
+                    trans.Transform(oldExt.MaxX, oldExt.MaxY, out urx, out ury);
+                    return ObjectFactory.CreateEnvelope(llx, lly, urx, ury);
+                catch
+                    return null;
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs	2011-05-20 06:00:49 UTC (rev 5822)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs	2011-05-20 11:31:31 UTC (rev 5823)
@@ -1,7 +1,7 @@
 // <auto-generated>
 //     This code was generated by a tool.
-//     Runtime Version:2.0.50727.4952
+//     Runtime Version:2.0.50727.4959
 //     Changes to this file may cause incorrect behavior and will be lost if
 //     the code is regenerated.
@@ -547,6 +547,15 @@
+        /// <summary>
+        ///   Looks up a localized string similar to Could not transform extents of any layer in this Map Definition. You will have to specify the extents manually..
+        /// </summary>
+        internal static string ErrorMapExtentCalculationFailed {
+            get {
+                return ResourceManager.GetString("ErrorMapExtentCalculationFailed", resourceCulture);
         internal static System.Drawing.Bitmap exclamation {
             get {
                 object obj = ResourceManager.GetObject("exclamation", resourceCulture);
@@ -2540,6 +2549,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to Warning.
+        /// </summary>
+        internal static string TitleWarning {
+            get {
+                return ResourceManager.GetString("TitleWarning", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to The selected column contains more than {0} different values, and thus cannot be used for theming with individual values.
         /// </summary>
         internal static string TooManyIndiviualValuesError {
@@ -2680,6 +2698,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to Could not transform extents of one or more layers in this Map Definition. These extents have not been factored into the computed result..
+        /// </summary>
+        internal static string WarningMapExtentCalculation {
+            get {
+                return ResourceManager.GetString("WarningMapExtentCalculation", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to A widget named {0} already exists.
         /// </summary>
         internal static string WidgetNameExists {
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx	2011-05-20 06:00:49 UTC (rev 5822)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx	2011-05-20 11:31:31 UTC (rev 5823)
@@ -1169,4 +1169,13 @@
   <data name="InvalidConnection" xml:space="preserve">
     <value>This is not a valid connection: {0}</value>
   </data>
+  <data name="ErrorMapExtentCalculationFailed" xml:space="preserve">
+    <value>Could not transform extents of any layer in this Map Definition. You will have to specify the extents manually.</value>
+  </data>
+  <data name="TitleWarning" xml:space="preserve">
+    <value>Warning</value>
+  </data>
+  <data name="WarningMapExtentCalculation" xml:space="preserve">
+    <value>Could not transform extents of one or more layers in this Map Definition. These extents have not been factored into the computed result.</value>
+  </data>
 </root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerInterfaceExtensions.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerInterfaceExtensions.cs	2011-05-20 06:00:49 UTC (rev 5822)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerInterfaceExtensions.cs	2011-05-20 11:31:31 UTC (rev 5823)
@@ -219,6 +219,87 @@
             return string.Empty;
+        public static IEnvelope GetSpatialExtent(this ILayerDefinition layer, bool allowFallbackToContextInformation, out string csWkt)
+            csWkt = null;
+            Check.NotNull(layer, "layer");
+            if (layer.CurrentConnection == null)
+                throw new System.Exception("No server set for object");
+            var conn = layer.CurrentConnection;
+            switch (layer.SubLayer.LayerType)
+                case LayerType.Vector:
+                        IEnvelope env = null;
+                        try
+                            env = conn.FeatureService.GetSpatialExtent(layer.SubLayer.ResourceId, ((IVectorLayerDefinition)layer.SubLayer).FeatureName, ((IVectorLayerDefinition)layer.SubLayer).Geometry);
+                            return env;
+                        catch //Default to extents of active spatial context
+                            var scList = conn.FeatureService.GetSpatialContextInfo(layer.SubLayer.ResourceId, true);
+                            if (scList.SpatialContext.Count > 0)
+                                var sc = scList.SpatialContext[0];
+                                    Convert.ToDouble(sc.Extent.LowerLeftCoordinate.X),
+                                    Convert.ToDouble(sc.Extent.LowerLeftCoordinate.Y),
+                                    Convert.ToDouble(sc.Extent.UpperRightCoordinate.X),
+                                    Convert.ToDouble(sc.Extent.UpperRightCoordinate.Y));
+                            return null;
+                case LayerType.Raster:
+                        try
+                            env = conn.FeatureService.GetSpatialExtent(layer.SubLayer.ResourceId, ((IRasterLayerDefinition)layer.SubLayer).FeatureName, ((IRasterLayerDefinition)layer.SubLayer).Geometry);
+                            return env;
+                            return null;
+                default:
+                        int[] services = conn.Capabilities.SupportedServices;
+                        if (Array.IndexOf(services, (int)ServiceType.Drawing) >= 0)
+                            var sheet = ((IDrawingLayerDefinition)layer.SubLayer).Sheet;
+                            var dws = (IDrawingSource)conn.ResourceService.GetResource(((IDrawingLayerDefinition)layer.SubLayer).ResourceId);
+                            if (dws.Sheet != null)
+                                //find matching sheet
+                                foreach (var sht in dws.Sheet)
+                                    if (sheet.Equals(sht.Name))
+                                        return ObjectFactory.CreateEnvelope(sht.Extent.MinX, sht.Extent.MinY, sht.Extent.MaxX, sht.Extent.MaxY);
+                        return null;
         /// <summary>
         /// Returns the spatial extent of the data.
         /// This is calculated by asking the underlying featuresource for the minimum rectangle that
More information about the mapguide-commits mailing list
