[mapguide-commits] r5833 - trunk/Tools/Maestro/Maestro.Editors/MapDefinition
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon May 23 08:55:40 EDT 2011
Author: jng
Date: 2011-05-23 05:55:40 -0700 (Mon, 23 May 2011)
New Revision: 5833
   trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs
#1631: Fix drag/drop to allow groups or layers to be moved up to the root level.
Modified: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs	2011-05-23 12:39:07 UTC (rev 5832)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs	2011-05-23 12:55:40 UTC (rev 5833)
@@ -762,34 +762,32 @@
                         parent = _map.GetGroupByName(li.Tag.Group);
-                if (parent != null)
+                int moved = 0;
+                //Add to this group
+                foreach (var n in nodes)
-                    int moved = 0;
-                    //Add to this group
-                    foreach (var n in nodes)
-                        var gi = n.Tag as GroupItem;
-                        var li = n.Tag as LayerItem;
+                    var gi = n.Tag as GroupItem;
+                    var li = n.Tag as LayerItem;
-                        //Re-assign parent
-                        if (gi != null)
-                            gi.Tag.Group = parent.Name;
-                            moved++;
-                        else if (li != null)
-                            li.Tag.Group = parent.Name;
-                            moved++;
+                    //Re-assign parent
+                    if (gi != null)
+                        gi.Tag.Group = parent == null ? string.Empty : parent.Name;
+                        moved++;
-                    if (moved > 0)
+                    else if (li != null)
-                        //TODO: Fine-grain invalidation
-                        RefreshModels();
+                        li.Tag.Group = parent == null ? string.Empty : parent.Name;
+                        moved++;
+                if (moved > 0)
+                    //TODO: Fine-grain invalidation
+                    RefreshModels();
+                    OnResourceChanged();
More information about the mapguide-commits mailing list
