[mapguide-commits] r5838 - in trunk/Tools/Maestro: Maestro.Editors/Common Maestro.Editors/LayerDefinition/Vector/Thematics Maestro.Editors/MapDefinition OSGeo.MapGuide.MaestroAPI OSGeo.MapGuide.MaestroAPI/CoordinateSystem OSGeo.MapGuide.MaestroAPI/Feature OSGeo.MapGuide.MaestroAPI/SchemaOverrides OSGeo.MapGuide.MaestroAPI/Serialization
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue May 24 06:49:22 EDT 2011
Author: jng
Date: 2011-05-24 03:49:22 -0700 (Tue, 24 May 2011)
New Revision: 5838
   trunk/Tools/Maestro/Maestro.Editors/Common/ImageStylePicker.cs
   trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ColorBrewer.cs
   trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapTreeModels.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/CoordinateSystemCategory.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Feature/RecordBase.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/ConfigurationDocument.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Serialization/MgBinaryDeserializer.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Serialization/MgBinarySerializer.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs
Small cleanup as recommended by FxCop
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/ImageStylePicker.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/ImageStylePicker.cs	2011-05-24 02:15:40 UTC (rev 5837)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/ImageStylePicker.cs	2011-05-24 10:49:22 UTC (rev 5838)
@@ -167,11 +167,5 @@
 				set { m_name = value; }
-        internal void Bind(object dataSource, string dataMember)
-            //We're binding to the name of the image
-            this.DataBindings.Add("Text", dataSource, dataMember);
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ColorBrewer.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ColorBrewer.cs	2011-05-24 02:15:40 UTC (rev 5837)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ColorBrewer.cs	2011-05-24 10:49:22 UTC (rev 5838)
@@ -36,10 +36,12 @@
         /// Gets the name of the ColorBrewer set
         /// </summary>
         public string Name { get { return m_name; } }
         /// <summary>
         /// Gets the assigned type for the ColorBrewer set
         /// </summary>
         public string Type { get { return m_type; } }
         /// <summary>
         /// Gets the ordered list of colors to use
         /// </summary>
Modified: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapTreeModels.cs
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapTreeModels.cs	2011-05-24 02:15:40 UTC (rev 5837)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapTreeModels.cs	2011-05-24 10:49:22 UTC (rev 5838)
@@ -151,7 +151,7 @@
         public event EventHandler<TreeModelEventArgs> NodesRemoved;
         protected void OnStructureChanged(TreePathEventArgs e)
             var handler = this.StructureChanged;
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/CoordinateSystemCategory.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/CoordinateSystemCategory.cs	2011-05-24 02:15:40 UTC (rev 5837)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/CoordinateSystemCategory.cs	2011-05-24 10:49:22 UTC (rev 5838)
@@ -37,7 +37,7 @@
         /// </summary>
         /// <param name="parent">The parent.</param>
         /// <param name="name">The name.</param>
-        public CoordinateSystemCategory(ICoordinateSystemCatalog parent, string name)
+        protected CoordinateSystemCategory(ICoordinateSystemCatalog parent, string name)
 			m_name = name;
 			_parent = parent;
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Feature/RecordBase.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Feature/RecordBase.cs	2011-05-24 02:15:40 UTC (rev 5837)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Feature/RecordBase.cs	2011-05-24 10:49:22 UTC (rev 5838)
@@ -33,7 +33,7 @@
         protected Dictionary<string, PropertyValue> _values;
         protected Dictionary<int, string> _ordinalMap;
-        public RecordBase()
+        protected RecordBase()
             _values = new Dictionary<string, PropertyValue>();
             _ordinalMap = new Dictionary<int, string>();
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/ConfigurationDocument.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/ConfigurationDocument.cs	2011-05-24 02:15:40 UTC (rev 5837)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/ConfigurationDocument.cs	2011-05-24 10:49:22 UTC (rev 5838)
@@ -32,7 +32,7 @@
         protected List<FeatureSchema> _schemas;
-        public ConfigurationDocument()
+        protected ConfigurationDocument()
             _spatialContexts = new List<IFdoSpatialContext>();
             _schemas = new List<FeatureSchema>();
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Serialization/MgBinaryDeserializer.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Serialization/MgBinaryDeserializer.cs	2011-05-24 02:15:40 UTC (rev 5837)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Serialization/MgBinaryDeserializer.cs	2011-05-24 10:49:22 UTC (rev 5838)
@@ -47,7 +47,8 @@
 			m_stream = stream;
 			m_siteVersion = siteversion;
 		private MgStreamHeader ReadStreamHeader()
 			MgStreamHeader h = new MgStreamHeader();
@@ -56,7 +57,7 @@
 			h.StreamVersion = BitConverter.ToUInt32(ReadStream(MgBinarySerializer.UInt32Len), 0);
 			h.StreamDataHdr = (MgStreamHeaderValues)BitConverter.ToUInt32(ReadStream(MgBinarySerializer.UInt32Len), 0);
 			return h;
 		private MgArgumentPacket ReadArgumentPacket()
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Serialization/MgBinarySerializer.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Serialization/MgBinarySerializer.cs	2011-05-24 02:15:40 UTC (rev 5837)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Serialization/MgBinarySerializer.cs	2011-05-24 10:49:22 UTC (rev 5838)
@@ -183,11 +183,12 @@
 			m_stream.Write(BitConverter.GetBytes(value), 0, UInt64Len);
 		private void Write(float value)
 			Write(new MgArgumentPacket(MgPacketHeader.ArgumentSimple, MgArgumentType.Float, null, (ulong)FloatLen));
 			m_stream.Write(BitConverter.GetBytes(value), 0, FloatLen);
         /// <summary>
         /// Writes the specified value.
@@ -296,6 +297,7 @@
 				m_stream.Write(BitConverter.GetBytes((UInt32)value.Length), 0, UInt32Len);
         /// <summary>
         /// </summary>
@@ -351,7 +353,7 @@
 			m_stream.Write(BitConverter.GetBytes((UInt32)value.ControlID), 0, UInt32Len);
 			WriteStreamEnd();
         /// <summary>
         /// Writes the raw.
         /// </summary>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs	2011-05-24 02:15:40 UTC (rev 5837)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs	2011-05-24 10:49:22 UTC (rev 5838)
@@ -515,15 +515,6 @@
-        private static void CopyNodeRecursive(System.Xml.XmlNode n1, System.Xml.XmlNode n2)
-            foreach (System.Xml.XmlAttribute attr in n1.Attributes)
-                n2.Attributes.Append(n2.OwnerDocument.CreateAttribute(attr.Name)).Value = attr.Value;
-            foreach (System.Xml.XmlNode n in n1.ChildNodes)
-                CopyNodeRecursive(n, n2.AppendChild(n2.OwnerDocument.CreateElement(n.Name)));
         /// <summary>
         /// Formats a number of bytes to a human readable format, ea.: 2.56 Kb
         /// </summary>
More information about the mapguide-commits mailing list
