[mapguide-commits] r5840 - trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue May 24 07:10:02 EDT 2011
Author: jng
Date: 2011-05-24 04:10:02 -0700 (Tue, 24 May 2011)
New Revision: 5840
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/ConfigurationDocument.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/GdalConfigurationDocument.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/GdalRasterItem.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/GenericConfigurationDocument.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/OdbcConfigurationDocument.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/OdbcTableItem.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/WmsConfigurationDocument.cs
#1319: API docs for classes in SchemaOverrides namespace
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/ConfigurationDocument.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/ConfigurationDocument.cs	2011-05-24 10:49:54 UTC (rev 5839)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/ConfigurationDocument.cs	2011-05-24 11:10:02 UTC (rev 5840)
@@ -26,6 +26,9 @@
 namespace OSGeo.MapGuide.MaestroAPI.SchemaOverrides
+    /// <summary>
+    /// The base class of all configuration documents
+    /// </summary>
     public abstract class ConfigurationDocument : IFdoSerializable
         protected List<IFdoSpatialContext> _spatialContexts;
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/GdalConfigurationDocument.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/GdalConfigurationDocument.cs	2011-05-24 10:49:54 UTC (rev 5839)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/GdalConfigurationDocument.cs	2011-05-24 11:10:02 UTC (rev 5840)
@@ -25,10 +25,19 @@
+    /// <summary>
+    /// A configuration document for the GDAL raster provider. A GDAL configuration document serves as a raster image catalog. Allowing
+    /// the GDAL provider to optimally select the correct raster images to return for the given queried extents.
+    /// </summary>
     public class GdalConfigurationDocument : ConfigurationDocument
         private Dictionary<string, GdalRasterLocationItem> _items = new Dictionary<string, GdalRasterLocationItem>();
+        /// <summary>
+        /// Adds the specified raster location to this document
+        /// </summary>
+        /// <param name="item"></param>
+        /// <returns></returns>
         public GdalRasterLocationItem AddLocation(GdalRasterLocationItem item)
             if (!_items.ContainsKey(item.Location))
@@ -38,6 +47,11 @@
             return _items[item.Location];
+        /// <summary>
+        /// Removes the specified raster location from this document
+        /// </summary>
         public bool RemoveLocation(GdalRasterLocationItem item)
             return _items.Remove(item.Location);
@@ -60,6 +74,11 @@
             return env;
+        /// <summary>
+        /// Adds the specified directory to this document
+        /// </summary>
+        /// <param name="directory"></param>
         public GdalRasterLocationItem AddLocation(string directory)
             if (_items.ContainsKey(directory))
@@ -68,6 +87,9 @@
             return AddLocation(new GdalRasterLocationItem() { Location = directory });
+        /// <summary>
+        /// Gets an array of all the raster locations for this document
+        /// </summary>
         public GdalRasterLocationItem[] RasterLocations { get { return new List<GdalRasterLocationItem>(_items.Values).ToArray(); } }
         protected override void WriteSchemaMappings(System.Xml.XmlDocument doc, System.Xml.XmlNode currentNode)
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/GdalRasterItem.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/GdalRasterItem.cs	2011-05-24 10:49:54 UTC (rev 5839)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/GdalRasterItem.cs	2011-05-24 11:10:02 UTC (rev 5840)
@@ -28,14 +28,24 @@
+    /// <summary>
+    /// Represents a directory of raster images in a GDAL configuration document
+    /// </summary>
     public class GdalRasterLocationItem : IFdoSerializable
         private Dictionary<string, GdalRasterItem> _items = new Dictionary<string, GdalRasterItem>();
         private IEnvelope _extents;
+        /// <summary>
+        /// Gets or sets the directory
+        /// </summary>
         public string Location { get; set; }
+        /// <summary>
+        /// Adds the specified raster image reference
+        /// </summary>
         public void AddItem(GdalRasterItem item)
             if (!_items.ContainsKey(item.FileName))
@@ -61,11 +71,18 @@
             return env;
+        /// <summary>
+        /// Removes the specified raster image reference
+        /// </summary>
         public void RemoveItem(GdalRasterItem item)
             _items.Remove(item.FileName);
+        /// <summary>
+        /// Gets all the raster image references in this location
+        /// </summary>
         public GdalRasterItem[] Items { get { return new List<GdalRasterItem>(_items.Values).ToArray(); } }
         public void WriteXml(System.Xml.XmlDocument doc, System.Xml.XmlNode currentNode)
@@ -100,22 +117,44 @@
+        /// <summary>
+        /// </summary>
+        /// <param name="fileName"></param>
         public void RemoveItem(string fileName)
             _items.Remove(fileName);
+    /// <summary>
+    /// Represents a raster image location and its extents.
+    /// </summary>
     public class GdalRasterItem : IFdoSerializable
+        /// <summary>
+        /// Gets or sets the raster image file name
+        /// </summary>
         public string FileName { get; set; }
+        /// <summary>
+        /// Gets or sets the minimum X value of this raster extent
+        /// </summary>
         public double MinX { get; set; }
+        /// <summary>
+        /// Gets or sets the minimum Y value of this raster extent
+        /// </summary>
         public double MinY { get; set; }
+        /// <summary>
+        /// Gets or sets the maximum X value of this raster extent
+        /// </summary>
         public double MaxX { get; set; }
+        /// <summary>
+        /// Gets or sets the maximum Y value of this raster extent
+        /// </summary>
         public double MaxY { get; set; }
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/GenericConfigurationDocument.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/GenericConfigurationDocument.cs	2011-05-24 10:49:54 UTC (rev 5839)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/GenericConfigurationDocument.cs	2011-05-24 11:10:02 UTC (rev 5840)
@@ -24,6 +24,10 @@
+    /// <summary>
+    /// Represents a generic configuration document. Customisation is done by manipulating the individual
+    /// XML content.
+    /// </summary>
     public class GenericConfigurationDocument : ConfigurationDocument
         private XmlNode[] _mappings;
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/OdbcConfigurationDocument.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/OdbcConfigurationDocument.cs	2011-05-24 10:49:54 UTC (rev 5839)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/OdbcConfigurationDocument.cs	2011-05-24 11:10:02 UTC (rev 5840)
@@ -25,20 +25,36 @@
+    /// <summary>
+    /// Represents a configuration document for the ODBC provider. The ODBC configuration document allows you to declare
+    /// certain tables as point feature classes by specifying the X, Y and optionally Z columns of the table
+    /// </summary>
     public class OdbcConfigurationDocument : ConfigurationDocument
         private List<OdbcTableItem> _tables;
         public OdbcConfigurationDocument() { _tables = new List<OdbcTableItem>(); }
+        /// <summary>
+        /// Adds the specified table override
+        /// </summary>
         public void AddOverride(OdbcTableItem item)
             _tables.Add(item);
             item.Parent = this;
+        /// <summary>
+        /// Removes all table overrides
+        /// </summary>
         public void ClearMappings() { _tables.Clear(); }
+        /// <summary>
+        /// Gets the table overrides for the specified schema
+        /// </summary>
+        /// <param name="schemaName"></param>
         public List<OdbcTableItem> GetMappingsForSchema(string schemaName)
             List<OdbcTableItem> items = new List<OdbcTableItem>();
@@ -103,6 +119,12 @@
+        /// <summary>
+        /// Gets the table override for the specific feature class name.
+        /// </summary>
+        /// <param name="className"></param>
         public OdbcTableItem GetOverride(string schemaName, string className)
             foreach (var item in _tables)
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/OdbcTableItem.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/OdbcTableItem.cs	2011-05-24 10:49:54 UTC (rev 5839)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/OdbcTableItem.cs	2011-05-24 11:10:02 UTC (rev 5840)
@@ -24,20 +24,41 @@
+    /// <summary>
+    /// Represents a table override. A table override allows a table to be configured as a point feature class
+    /// </summary>
     public class OdbcTableItem : IFdoSerializable
         internal OdbcConfigurationDocument Parent { get; set; }
+        /// <summary>
+        /// Gets or sets the name of the feature schema
+        /// </summary>
         public string SchemaName { get; set; }
+        /// <summary>
+        /// Gets or sets the name of the feature class this override is applicable to
+        /// </summary>
         public string ClassName { get; set; }
+        /// <summary>
+        /// Gets or sets the name of the spatial context the point geometries will be applicable to
+        /// </summary>
         public string SpatialContextName { get; set; }
+        /// <summary>
+        /// Gets or sets the name of the column which contains the X coordinates of the point features
+        /// </summary>
         public string XColumn { get; set; }
+        /// <summary>
+        /// Gets or sets the name of the column which contains the Y coordinates of the point features
+        /// </summary>
         public string YColumn { get; set; }
+        /// <summary>
+        /// Gets or sets the name of the column which contains the Z coordinates of the point features
+        /// </summary>
         public string ZColumn { get; set; }
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/WmsConfigurationDocument.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/WmsConfigurationDocument.cs	2011-05-24 10:49:54 UTC (rev 5839)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/SchemaOverrides/WmsConfigurationDocument.cs	2011-05-24 11:10:02 UTC (rev 5840)
@@ -24,14 +24,28 @@
+    /// <summary>
+    /// Represents a configuration document for the WMS provider.
+    /// </summary>
     public class WmsConfigurationDocument : ConfigurationDocument
         private List<RasterWmsItem> _rasterItems = new List<RasterWmsItem>();
+        /// <summary>
+        /// Gets an array of the added override items
+        /// </summary>
         public RasterWmsItem[] RasterOverrides { get { return _rasterItems.ToArray(); } }
+        /// <summary>
+        /// Adds the specified override item
+        /// </summary>
         public void AddRasterItem(RasterWmsItem item) { _rasterItems.Add(item); }
+        /// <summary>
+        /// Removes the specified override item
+        /// </summary>
         public void RemoveRasterItem(RasterWmsItem item) { _rasterItems.Remove(item); }
More information about the mapguide-commits mailing list
