[mapguide-commits] r5842 - trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue May 24 07:57:41 EDT 2011
Author: jng
Date: 2011-05-24 04:57:41 -0700 (Tue, 24 May 2011)
New Revision: 5842
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/ClassDefinition.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/DataPropertyDefinition.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/FeatureSchema.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/FeatureSourceDescription.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/GeometricPropertyDefinition.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/PropertyDefinition.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/RasterPropertyDefinition.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/XmlNamespaces.cs
#1319: API documentation for classes in the Schema namespace
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/ClassDefinition.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/ClassDefinition.cs	2011-05-24 11:38:54 UTC (rev 5841)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/ClassDefinition.cs	2011-05-24 11:57:41 UTC (rev 5842)
@@ -52,6 +52,9 @@
             this.Description = description;
+        /// <summary>
+        /// Gets or sets the base class
+        /// </summary>
         public ClassDefinition BaseClass { get; set; }
         /// <summary>
@@ -314,6 +317,11 @@
         public FeatureSchema Parent { get; internal set; }
+        /// <summary>
+        /// Gets a Property Definition by its name
+        /// </summary>
+        /// <param name="name"></param>
+        /// <returns>The matching property definition. null if none found</returns>
         public PropertyDefinition FindProperty(string name)
             foreach (var prop in _properties)
@@ -324,6 +332,9 @@
             return null;
+        /// <summary>
+        /// Gets the qualified name of this class. The qualified name takes the form [Schema Name]:[Class Name]
+        /// </summary>
         public string QualifiedName { get { return this.Parent != null ? this.Parent.Name + ":" + this.Name : this.Name; } }
         public void WriteXml(XmlDocument doc, XmlNode currentNode)
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/DataPropertyDefinition.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/DataPropertyDefinition.cs	2011-05-24 11:38:54 UTC (rev 5841)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/DataPropertyDefinition.cs	2011-05-24 11:57:41 UTC (rev 5842)
@@ -25,6 +25,11 @@
 namespace OSGeo.MapGuide.MaestroAPI.Schema
+    /// <summary>
+    /// Derives from <see cref="T:OSGeo.MapGuide.MaestroAPI.Schema.PropertyDefinition"/> and represents simple values or
+    /// collections of simple values. This can take on any of the data types listed in the
+    /// <see cref="T:OSGeo.MapGuide.MaestroAPI.Schema.DataPropertyType"/> enumeration.
+    /// </summary>
     public class DataPropertyDefinition : PropertyDefinition
         private DataPropertyDefinition() { this.DataType = DataPropertyType.String; }
@@ -36,22 +41,49 @@
+        /// <summary>
+        /// Gets the data type of this property
+        /// </summary>
         public DataPropertyType DataType { get; set; }
+        /// <summary>
+        /// Gets or sets the default value. Applies only to string data types
+        /// </summary>
         public string DefaultValue { get; set; }
+        /// <summary>
+        /// Gets or sets the length of this property. Applies only to string and blob/clob data types
+        /// </summary>
         public int Length { get; set; }
+        /// <summary>
+        /// Gets or sets whether this property accepts null values
+        /// </summary>
         public bool IsNullable { get; set; }
+        /// <summary>
+        /// Gets or sets the precision of this property. Applies only to decimal data types
+        /// </summary>
         public int Precision { get; set; }
+        /// <summary>
+        /// Gets or sets whether this property is read-only
+        /// </summary>
         public bool IsReadOnly { get; set; }
+        /// <summary>
+        /// Gets or sets the scale of this property. Applies only to decimal data types.
+        /// </summary>
         public int Scale { get; set; }
+        /// <summary>
+        /// Gets or sets whether this property automatically generates a value on insert.
+        /// </summary>
         public bool IsAutoGenerated { get; set; }
+        /// <summary>
+        /// Gets the type of Property Definition
+        /// </summary>
         public override PropertyDefinitionType Type
             get { return PropertyDefinitionType.Data; }
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/FeatureSchema.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/FeatureSchema.cs	2011-05-24 11:38:54 UTC (rev 5841)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/FeatureSchema.cs	2011-05-24 11:57:41 UTC (rev 5842)
@@ -25,8 +25,10 @@
-    //TODO: Expand on documentation as this is an important class
+    /// <summary>
+    /// Contains all of the classes and relationships that make up a particular data model. This class is used to
+    /// represent the internal logical structure of a Feature Source
+    /// </summary>
     public class FeatureSchema : SchemaElement, IFdoSerializable
         private List<ClassDefinition> _classes;
@@ -73,6 +75,11 @@
             return false;
+        /// <summary>
+        /// Returns the Class Definition by its name
+        /// </summary>
+        /// <returns>The matching Class Definition. null if it doesn't exist</returns>
         public ClassDefinition GetClass(string name)
             foreach (var cls in _classes)
@@ -157,6 +164,10 @@
+        /// <summary>
+        /// Removes a class definition by its name
+        /// </summary>
+        /// <param name="className"></param>
         public void RemoveClass(string className)
             var cls = GetClass(className);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/FeatureSourceDescription.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/FeatureSourceDescription.cs	2011-05-24 11:38:54 UTC (rev 5841)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/FeatureSourceDescription.cs	2011-05-24 11:57:41 UTC (rev 5842)
@@ -31,7 +31,7 @@
 	/// <summary>
-	/// Class that represents a the layout of a datasource
+	/// Class that represents a the layout of a feature source
 	/// </summary>
 	public class FeatureSourceDescription
@@ -61,10 +61,21 @@
             this.Schemas = schemas.ToArray();
+        /// <summary>
+        /// Gets whether this description is a partial description (ie. It doesn't represent the full feature source)
+        /// </summary>
         public bool IsPartial { get; internal set; }
+        /// <summary>
+        /// Gets an array of feature schemas in this feature source
+        /// </summary>
         public FeatureSchema[] Schemas { get; private set; }
+        /// <summary>
+        /// Gets a feature schema by its name
+        /// </summary>
+        /// <param name="schemaName"></param>
+        /// <returns>The matching feature schema. null if not found</returns>
         public FeatureSchema GetSchema(string schemaName)
             foreach (var fsc in this.Schemas)
@@ -77,6 +88,9 @@
             return null;
+        /// <summary>
+        /// Gets an array of feature schema names
+        /// </summary>
         public string[] SchemaNames
             get
@@ -90,6 +104,11 @@
+        /// <summary>
+        /// Gets all the Class Definitions in this feature source. In the event of identically named Class Definitions beloning
+        /// in different parent schemas. Use the <see cref="M:OSGeo.MapGuide.MaestroAPI.Schema.ClassDefinition.QualifiedName"/> property
+        /// to distinguish them.
+        /// </summary>
         public IEnumerable<ClassDefinition> AllClasses
             get
@@ -104,6 +123,12 @@
+        /// <summary>
+        /// Gets the specified class definition by its name and parent schema name
+        /// </summary>
+        /// <returns>The matching class definition. null if not found</returns>
         public ClassDefinition GetClass(string schemaName, string className)
             var fsc = GetSchema(schemaName);
@@ -230,6 +255,10 @@
         #endregion
+        /// <summary>
+        /// Gets whether there are any class definitions
+        /// </summary>
+        /// <returns></returns>
         public bool HasClasses()
             if (this.Schemas.Length == 0)
@@ -243,6 +272,11 @@
             return false;
+        /// <summary>
+        /// Gets the specified class definition by its fully qualified name
+        /// </summary>
+        /// <param name="qualifiedName"></param>
         public ClassDefinition GetClass(string qualifiedName)
             Check.NotEmpty(qualifiedName, "qualifiedName");
@@ -253,114 +287,4 @@
             return GetClass(tokens[0], tokens[1]);
-    internal class ClassPropertyColumn : FeatureSetColumn
-        internal ClassPropertyColumn(XmlNode node)
-            : base()
-            if (node.Name == "PropertyDefinition" || node.Name == "Column")
-                m_name = node["Name"].InnerText;
-                m_allowNull = true;
-                switch (node["Type"].InnerText.ToLower().Trim())
-                    case "string":
-                        m_type = typeof(string);
-                        break;
-                    case "byte":
-                        m_type = typeof(Byte);
-                        break;
-                    case "int32":
-                    case "int":
-                    case "integer":
-                        m_type = typeof(int);
-                        break;
-                    case "int16":
-                        m_type = typeof(short);
-                        break;
-                    case "int64":
-                    case "long":
-                        m_type = typeof(long);
-                        break;
-                    case "float":
-                    case "single":
-                        m_type = typeof(float);
-                        break;
-                    case "double":
-                    case "decimal":
-                        m_type = typeof(double);
-                        break;
-                    case "boolean":
-                    case "bool":
-                        m_type = typeof(bool);
-                        return;
-                    case "datetime":
-                    case "date":
-                        m_type = typeof(DateTime);
-                        break;
-                    case "raster":
-                        m_type = Utility.RasterType;
-                        break;
-                    case "geometry":
-                        m_type = Utility.GeometryType;
-                        break;
-                    default:
-                        //throw new Exception("Failed to find appropriate type for: " + node["xs:simpleType"]["xs:restriction"].Attributes["base"].Value);
-                        m_type = Utility.UnmappedType;
-                        break;
-            else
-                m_name = node.Attributes["name"].Value;
-                m_allowNull = node.Attributes["minOccurs"] != null && node.Attributes["minOccurs"].Value == "0";
-                if (node.Attributes["type"] != null && node.Attributes["type"].Value == "gml:AbstractGeometryType")
-                else if (node["xs:simpleType"] == null)
-                else
-                    switch (node["xs:simpleType"]["xs:restriction"].Attributes["base"].Value.ToLower())
-                        case "xs:string":
-                            break;
-                        case "fdo:byte":
-                            break;
-                        case "fdo:int32":
-                            break;
-                        case "fdo:int16":
-                            break;
-                        case "fdo:int64":
-                            break;
-                        case "xs:float":
-                        case "xs:single":
-                        case "fdo:single":
-                            break;
-                        case "xs:double":
-                        case "xs:decimal":
-                            break;
-                        case "xs:boolean":
-                            return;
-                        case "xs:datetime":
-                            break;
-                        default:
-                            break;
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/GeometricPropertyDefinition.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/GeometricPropertyDefinition.cs	2011-05-24 11:38:54 UTC (rev 5841)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/GeometricPropertyDefinition.cs	2011-05-24 11:57:41 UTC (rev 5842)
@@ -27,6 +27,7 @@
     /// <summary>
     /// Defines the valid types of geometric storage in a geometric property
     /// </summary>
+    [Flags]
     public enum FeatureGeometricType
         Point = 1,
@@ -68,16 +69,33 @@
+        /// <summary>
+        /// Gets or sets a Boolean value that indicates if this geometric property is read-only.
+        /// </summary>
+        /// <summary>
+        /// Gets or sets a Boolean value that indicates if the geometry of this property includes measurement values that can be used for dynamic segmentation.
+        /// </summary>
         public bool HasMeasure { get; set; }
+        /// <summary>
+        /// Gets or sets a Boolean value that indicates if the geometry of this property include elevation values.
+        /// </summary>
         public bool HasElevation { get; set; }
+        /// <summary>
+        /// Gets or sets the Spatial Context name associated to this geometric property.
+        /// </summary>
         public string SpatialContextAssociation { get; set; }
         private FeatureGeometricType _geometricTypes;
+        /// <summary>
+        /// Gets or sets the <see cref="T:OSGeo.MapGuide.MaestroAPI.Schema.FeatureGeometricType"/> that can be stored in this geometric
+        /// property. The returned value may be any combination of the values from the <see cref="T:OSGeo.MapGuide.MaestroAPI.Schema.FeatureGeometricType"/>
+        /// enumeration combined via a bit-wise or operation.
+        /// </summary>
         public FeatureGeometricType GeometricTypes
             get { return _geometricTypes; }
@@ -118,6 +136,10 @@
         private SpecificGeometryType[] _sgts;
+        /// <summary>
+        /// Gets or sets the specific set of geometry types that can be stored in this geometric property. The provided value is a
+        /// list of geometry types that are supported. Usually, one specific type is supported, but there can be more than one.
+        /// </summary>
         public SpecificGeometryType[] SpecificGeometryTypes
             get { return _sgts; }
@@ -179,6 +201,9 @@
+        /// <summary>
+        /// Gets the type of property definition
+        /// </summary>
             get { return PropertyDefinitionType.Geometry; }
@@ -229,6 +254,12 @@
             return string.Join(" ", values.ToArray());
+        /// <summary>
+        /// Gets an array of the individual <see cref="T:OSGeo.MapGuide.MaestroAPI.Schema.FeatureGeometricType"/> values that
+        /// compose the final masked value that is returned by the <see cref="M:OSGeo.MapGuide.MaestroAPI.GeometricPropertyDefinition.GeometricTypes"/>
+        /// property
+        /// </summary>
         public FeatureGeometricType[] GetIndividualGeometricTypes()
             List<FeatureGeometricType> gts = new List<FeatureGeometricType>();
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/PropertyDefinition.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/PropertyDefinition.cs	2011-05-24 11:38:54 UTC (rev 5841)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/PropertyDefinition.cs	2011-05-24 11:57:41 UTC (rev 5842)
@@ -95,6 +95,12 @@
         public abstract void ReadXml(System.Xml.XmlNode node, System.Xml.XmlNamespaceManager mgr);
+        /// <summary>
+        /// Parses the specified XML node into a Property Definition
+        /// </summary>
+        /// <param name="node"></param>
+        /// <param name="mgr"></param>
         public static PropertyDefinition Parse(System.Xml.XmlNode node, System.Xml.XmlNamespaceManager mgr)
             PropertyDefinition prop = null;
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/RasterPropertyDefinition.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/RasterPropertyDefinition.cs	2011-05-24 11:38:54 UTC (rev 5841)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/RasterPropertyDefinition.cs	2011-05-24 11:57:41 UTC (rev 5842)
@@ -23,6 +23,10 @@
+    /// <summary>
+    /// Has the information needed to create or completely describe a raster property. This class encapsulates the information
+    /// necessary to insert a 'new' raster, in the absence of any other information, for the properties defined using this schema element.
+    /// </summary>
     public class RasterPropertyDefinition : PropertyDefinition
         public RasterPropertyDefinition(string name, string description)
@@ -31,16 +35,34 @@
+        /// <summary>
+        /// Gets or sets the default size of image file in the horizontal direction in pixels (number of columns).
+        /// </summary>
         public int DefaultImageXSize { get; set; }
+        /// <summary>
+        /// Gets or sets the default size of an image file in the vertical direction in pixels (number of rows).
+        /// </summary>
         public int DefaultImageYSize { get; set; }
+        /// <summary>
+        /// Gets or sets whether this property's value can be null.
+        /// </summary>
+        /// <summary>
+        /// Gets or sets whether this property is read-only.
+        /// </summary>
+        /// <summary>
+        /// Gets or sets the Spatial Context name associated to this raster property.
+        /// </summary>
+        /// <summary>
+        /// </summary>
             get { return PropertyDefinitionType.Raster; }
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/XmlNamespaces.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/XmlNamespaces.cs	2011-05-24 11:38:54 UTC (rev 5841)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/XmlNamespaces.cs	2011-05-24 11:57:41 UTC (rev 5842)
@@ -26,7 +26,7 @@
     /// <summary>
     /// A set of XML namespaces commonly used in FDO XML documents
     /// </summary>
-    public class XmlNamespaces
+    public static class XmlNamespaces
         /// <summary>
         /// XML Schema namespace
More information about the mapguide-commits mailing list
