[mapguide-commits] r5846 - trunk/Tools/Maestro/Maestro
svn_mapguide at osgeo.org
Tue May 24 12:06:03 EDT 2011
Author: jng
Date: 2011-05-24 09:06:02 -0700 (Tue, 24 May 2011)
New Revision: 5846
trunk/Tools/Maestro/Maestro/changelog.txt
changelog.txt update
Modified: trunk/Tools/Maestro/Maestro/changelog.txt
--- trunk/Tools/Maestro/Maestro/changelog.txt 2011-05-24 15:56:21 UTC (rev 5845)
+++ trunk/Tools/Maestro/Maestro/changelog.txt 2011-05-24 16:06:02 UTC (rev 5846)
@@ -6,9 +6,11 @@
- This is the first release with a public SDK and samples demonstrating using the Maestro API.
- Generated Web Layout previews now have a KML export command
- Add a command to view all spatial contexts of a feature source
+ - Implement layer editor support for KML extrusion (RFC16). Thanks to James Murphy for test data needed in implementing this.
- API: Re-worked the RuntimeMap API so that draw order of layers can be manipulated like a collection.
- API: Add APIs to GdalConfigurationDocument to allow calculation of combined extents.
- API: Extend the IMappingService API to support rendering map legend images.
+ - Fix: Show In Legend checkbox does nothing in the Layer Editor
- Fix: Map Definition resource id field in a WebLayout 1.1.0 editor does not update when changed.
- Fix: DWF Load Procedure not settings sheet extents.
- Fix: Site Explorer items incorrectly highlighted when an existing resource is saved under a different resource ID.
More information about the mapguide-commits
