[mapguide-commits] r5859 - in trunk/Tools/Maestro: . Maestro
OSGeo.MapGuide.MaestroAPI/ObjectModels Properties
svn_mapguide at osgeo.org
Wed May 25 09:08:20 EDT 2011
Author: jng
Date: 2011-05-25 06:08:20 -0700 (Wed, 25 May 2011)
New Revision: 5859
trunk/Tools/Maestro/Maestro/changelog.txt
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/WebLayoutInterfaces.cs
trunk/Tools/Maestro/Properties/GlobalAssemblyInfo.cs
trunk/Tools/Maestro/build.bat
Final preps for 3.1 release.
Modified: trunk/Tools/Maestro/Maestro/changelog.txt
--- trunk/Tools/Maestro/Maestro/changelog.txt 2011-05-25 12:57:59 UTC (rev 5858)
+++ trunk/Tools/Maestro/Maestro/changelog.txt 2011-05-25 13:08:20 UTC (rev 5859)
@@ -7,6 +7,8 @@
- Generated Web Layout previews now have a KML export command
- Add a command to view all spatial contexts of a feature source
- Implement layer editor support for KML extrusion (RFC16). Thanks to James Murphy for test data needed in implementing this.
+ - API: Add missing Visible property to ITaskPane
+ - API: Small adjustment to selection APIs
- API: Re-worked the RuntimeMap API so that draw order of layers can be manipulated like a collection.
- API: Add APIs to GdalConfigurationDocument to allow calculation of combined extents.
- API: Extend the IMappingService API to support rendering map legend images.
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/WebLayoutInterfaces.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/WebLayoutInterfaces.cs 2011-05-25 12:57:59 UTC (rev 5858)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/WebLayoutInterfaces.cs 2011-05-25 13:08:20 UTC (rev 5859)
@@ -772,6 +772,11 @@
public interface ITaskPane : IWebLayoutResizableControl, INotifyPropertyChanged
/// <summary>
+ /// Gets or sets whether this control is visible
+ /// </summary>
+ bool Visible { get; set; }
+ /// <summary>
/// Gets or sets the url of the initial task.
/// </summary>
/// <value>The url of the initial task.</value>
Modified: trunk/Tools/Maestro/Properties/GlobalAssemblyInfo.cs
--- trunk/Tools/Maestro/Properties/GlobalAssemblyInfo.cs 2011-05-25 12:57:59 UTC (rev 5858)
+++ trunk/Tools/Maestro/Properties/GlobalAssemblyInfo.cs 2011-05-25 13:08:20 UTC (rev 5859)
@@ -35,5 +35,5 @@
// You can specify all the values or you can default the Build and Revision Numbers
// by using the '*' as shown below:
// [assembly: AssemblyVersion("1.0.*")]
-[assembly: AssemblyVersion("3.0.0.5728")]
-[assembly: AssemblyFileVersion("3.0.0.5728")]
+[assembly: AssemblyVersion("3.1.0.5859")]
+[assembly: AssemblyFileVersion("3.1.0.5859")]
Modified: trunk/Tools/Maestro/build.bat
--- trunk/Tools/Maestro/build.bat 2011-05-25 12:57:59 UTC (rev 5858)
+++ trunk/Tools/Maestro/build.bat 2011-05-25 13:08:20 UTC (rev 5859)
@@ -2,7 +2,7 @@
SET TYPEACTION=build
SET TYPEBUILD=Release
SET PLATFORM=Any CPU
-SET RELEASE_VERSION=3.0.0
+SET RELEASE_VERSION=3.1.0
SET OLDPATH=%PATH%
SET PATH=%PATH%;%CD%\Thirdparty\NSIS;C:\Windows\Microsoft.NET\Framework\v3.5
SET SLNDIR=%CD%
More information about the mapguide-commits
