[mapguide-commits] r5865 - in trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI: . Properties Resource
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu May 26 08:53:50 EDT 2011
Author: jng
Date: 2011-05-26 05:53:49 -0700 (Thu, 26 May 2011)
New Revision: 5865
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/ResourceContentVersionChecker.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ResourceTypeRegistry.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/XmlValidator.cs
#1702: Fix NRE on validation of XML content via generic editor.
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs	2011-05-26 06:28:07 UTC (rev 5864)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs	2011-05-26 12:53:49 UTC (rev 5865)
@@ -386,6 +386,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to XML content does not match any known resource.
+        /// </summary>
+        internal static string ERR_NOT_RESOURCE_CONTENT_XML {
+            get {
+                return ResourceManager.GetString("ERR_NOT_RESOURCE_CONTENT_XML", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to No connection attached to this resource.
         /// </summary>
         internal static string ERR_RESOURCE_NOT_ATTACHED {
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx	2011-05-26 06:28:07 UTC (rev 5864)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx	2011-05-26 12:53:49 UTC (rev 5865)
@@ -506,4 +506,7 @@
   <data name="MDF_LayerWithNonExistentGroup" xml:space="preserve">
     <value>Layer ({0}) belongs to a non-existent Layer Group ({1})</value>
   </data>
+  <data name="ERR_NOT_RESOURCE_CONTENT_XML" xml:space="preserve">
+    <value>XML content does not match any known resource</value>
+  </data>
 </root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/ResourceContentVersionChecker.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/ResourceContentVersionChecker.cs	2011-05-26 06:28:07 UTC (rev 5864)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/ResourceContentVersionChecker.cs	2011-05-26 12:53:49 UTC (rev 5865)
@@ -91,6 +91,9 @@
                     //Parse version number from ResourceType-x.y.z.xsd
                     string xsd = xr.GetAttribute("xsi:noNamespaceSchemaLocation");
+                    if (xsd == null)
+                        return null;
                     int start = (xsd.LastIndexOf("-"));
                     int end = xsd.IndexOf(".xsd") - 1;
                     version = xsd.Substring(start + 1, xsd.Length - end);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ResourceTypeRegistry.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ResourceTypeRegistry.cs	2011-05-26 06:28:07 UTC (rev 5864)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ResourceTypeRegistry.cs	2011-05-26 12:53:49 UTC (rev 5865)
@@ -275,6 +275,9 @@
             var checker = new ResourceContentVersionChecker(xml);
             var rd = checker.GetVersion();
+            if (rd != null)
+                throw new SerializationException(Properties.Resources.ERR_NOT_RESOURCE_CONTENT_XML);
             if (!_serializers.ContainsKey(rd))
                 throw new SerializationException(Properties.Resources.ERR_NO_SERIALIZER + rd.ToString());
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/XmlValidator.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/XmlValidator.cs	2011-05-26 06:28:07 UTC (rev 5864)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/XmlValidator.cs	2011-05-26 12:53:49 UTC (rev 5865)
@@ -31,6 +31,7 @@
     using System.Collections.Generic;
     using System.Collections.ObjectModel;
     using OSGeo.MapGuide.MaestroAPI.Resource;
+    using OSGeo.MapGuide.MaestroAPI.Exceptions;
 	///<summary>
 	/// Class that makes XSD validation
@@ -135,7 +136,10 @@
             catch (Exception ex)
-                err.Add(ex.Message);
+                if (!(ex is SerializationException))
+                    err.Add(ex.Message);
+                else
+                    res = null;
             if (res != null)
More information about the mapguide-commits mailing list
