[mapguide-commits] r5880 - trunk/MgDev
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue May 31 02:16:44 EDT 2011
Author: jng
Date: 2011-05-30 23:16:44 -0700 (Mon, 30 May 2011)
New Revision: 5880
   trunk/MgDev/build.bat
   trunk/MgDev/build64.bat
trunk: Fix build.bat not considering CS-Map directory when using the -a=install with a custom -o flag
Modified: trunk/MgDev/build.bat
--- trunk/MgDev/build.bat	2011-05-31 06:14:13 UTC (rev 5879)
+++ trunk/MgDev/build.bat	2011-05-31 06:16:44 UTC (rev 5880)
@@ -157,6 +157,7 @@
 if "%2" == "def" SET MG_OUTPUT=%MG_DEFAULT_INSTALLDIR%
 SET MG_OUTPUT_SERVER=%MG_OUTPUT%\Server
 SET MG_OUTPUT_WEB=%MG_OUTPUT%\Web
+SET MG_OUTPUT_CSMAP=%MG_OUTPUT%\CS-Map
 goto next_param
 :get_conf
Modified: trunk/MgDev/build64.bat
--- trunk/MgDev/build64.bat	2011-05-31 06:14:13 UTC (rev 5879)
+++ trunk/MgDev/build64.bat	2011-05-31 06:16:44 UTC (rev 5880)
@@ -161,6 +161,7 @@
 goto next_param
 :get_conf
More information about the mapguide-commits mailing list
