[mapguide-commits] r5886 - trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue May 31 09:05:25 EDT 2011
Author: jng
Date: 2011-05-31 06:05:25 -0700 (Tue, 31 May 2011)
New Revision: 5886
   trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/FileBasedCtrl.Designer.cs
   trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/FileBasedCtrl.cs
   trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/FileBasedCtrl.resx
#1706: Offer alias browsing by file and folder. Reuse the CanSelectFolders() logic to enable/disable the folder browse button
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/FileBasedCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/FileBasedCtrl.Designer.cs	2011-05-31 12:38:36 UTC (rev 5885)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/FileBasedCtrl.Designer.cs	2011-05-31 13:05:25 UTC (rev 5886)
@@ -34,10 +34,11 @@
             this.rdUnmanaged = new System.Windows.Forms.RadioButton();
             this.label1 = new System.Windows.Forms.Label();
             this.txtAlias = new System.Windows.Forms.TextBox();
-            this.btnBrowseAlias = new System.Windows.Forms.Button();
+            this.btnBrowseAliasFile = new System.Windows.Forms.Button();
             this.tt = new System.Windows.Forms.ToolTip(this.components);
             this.unmanagedPanel = new System.Windows.Forms.Panel();
             this.resDataCtrl = new Maestro.Editors.Common.ResourceDataCtrl();
+            this.btnBrowseAliasFolder = new System.Windows.Forms.Button();
             this.contentPanel.SuspendLayout();
             this.unmanagedPanel.SuspendLayout();
             this.SuspendLayout();
@@ -78,18 +79,20 @@
             this.txtAlias.Name = "txtAlias";
             this.txtAlias.TextChanged += new System.EventHandler(this.txtAlias_TextChanged);
-            // btnBrowseAlias
+            // btnBrowseAliasFile
-            resources.ApplyResources(this.btnBrowseAlias, "btnBrowseAlias");
-            this.btnBrowseAlias.Name = "btnBrowseAlias";
-            this.btnBrowseAlias.UseVisualStyleBackColor = true;
-            this.btnBrowseAlias.Click += new System.EventHandler(this.btnBrowseAlias_Click);
+            resources.ApplyResources(this.btnBrowseAliasFile, "btnBrowseAliasFile");
+            this.btnBrowseAliasFile.Image = global::Maestro.Editors.Properties.Resources.document;
+            this.btnBrowseAliasFile.Name = "btnBrowseAliasFile";
+            this.btnBrowseAliasFile.UseVisualStyleBackColor = true;
+            this.btnBrowseAliasFile.Click += new System.EventHandler(this.btnBrowseAlias_Click);
             // unmanagedPanel
             resources.ApplyResources(this.unmanagedPanel, "unmanagedPanel");
+            this.unmanagedPanel.Controls.Add(this.btnBrowseAliasFolder);
             this.unmanagedPanel.Controls.Add(this.label1);
-            this.unmanagedPanel.Controls.Add(this.btnBrowseAlias);
+            this.unmanagedPanel.Controls.Add(this.btnBrowseAliasFile);
             this.unmanagedPanel.Controls.Add(this.txtAlias);
             this.unmanagedPanel.Name = "unmanagedPanel";
@@ -100,6 +103,14 @@
             this.resDataCtrl.MarkEnabled = true;
             this.resDataCtrl.Name = "resDataCtrl";
+            // btnBrowseAliasFolder
+            resources.ApplyResources(this.btnBrowseAliasFolder, "btnBrowseAliasFolder");
+            this.btnBrowseAliasFolder.Image = global::Maestro.Editors.Properties.Resources.folder_horizontal;
+            this.btnBrowseAliasFolder.Name = "btnBrowseAliasFolder";
+            this.btnBrowseAliasFolder.UseVisualStyleBackColor = true;
+            this.btnBrowseAliasFolder.Click += new System.EventHandler(this.btnBrowseAliasFolder_Click);
             // FileBasedCtrl
             this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
@@ -118,9 +129,10 @@
         private System.Windows.Forms.ToolTip tt;
         private System.Windows.Forms.Panel unmanagedPanel;
         protected Maestro.Editors.Common.ResourceDataCtrl resDataCtrl;
-        protected System.Windows.Forms.Button btnBrowseAlias;
+        protected System.Windows.Forms.Button btnBrowseAliasFile;
         protected System.Windows.Forms.TextBox txtAlias;
         protected System.Windows.Forms.RadioButton rdUnmanaged;
         protected System.Windows.Forms.RadioButton rdManaged;
+        protected System.Windows.Forms.Button btnBrowseAliasFolder;
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/FileBasedCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/FileBasedCtrl.cs	2011-05-31 12:38:36 UTC (rev 5885)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/FileBasedCtrl.cs	2011-05-31 13:05:25 UTC (rev 5886)
@@ -56,6 +56,8 @@
             _service = service;
             _service.RegisterCustomNotifier(this);
+            btnBrowseAliasFile.Enabled = true;
+            btnBrowseAliasFolder.Enabled = CanSelectFolders();
             resDataCtrl.Init(service);
             resDataCtrl.DataListChanged += (sender, e) => { OnResourceChanged(); };
             resDataCtrl.ResourceDataMarked += (sender, e) => { OnResourceMarked(e); };
@@ -70,7 +72,7 @@
             using (var picker = new UnmanagedFileBrowser(_service.ResourceService))
-                picker.SelectFoldersOnly = CanSelectFolders();
+                picker.SelectFoldersOnly = false;
                 if (picker.ShowDialog() == DialogResult.OK)
                     txtAlias.Text = picker.SelectedItem;
@@ -78,6 +80,18 @@
+        private void btnBrowseAliasFolder_Click(object sender, EventArgs e)
+            using (var picker = new UnmanagedFileBrowser(_service.ResourceService))
+                picker.SelectFoldersOnly = true;
+                if (picker.ShowDialog() == DialogResult.OK)
+                    txtAlias.Text = picker.SelectedItem;
         protected virtual string FileFdoProperty { get { return "File"; } }
         protected virtual bool CanSelectFolders()
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/FileBasedCtrl.resx
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/FileBasedCtrl.resx	2011-05-31 12:38:36 UTC (rev 5885)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/FileBasedCtrl.resx	2011-05-31 13:05:25 UTC (rev 5886)
@@ -121,11 +121,38 @@
   <data name="unmanagedPanel.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
     <value>Top, Left, Right</value>
   </data>
+  <data name="btnBrowseAliasFolder.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+    <value>Top, Right</value>
+  </data>
+  <data name="btnBrowseAliasFolder.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+    <value>NoControl</value>
+  </data>
+  <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+  <data name="btnBrowseAliasFolder.Location" type="System.Drawing.Point, System.Drawing">
+    <value>375, 2</value>
+  </data>
+  <data name="btnBrowseAliasFolder.Size" type="System.Drawing.Size, System.Drawing">
+    <value>25, 25</value>
+  </data>
   <assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+  <data name="btnBrowseAliasFolder.TabIndex" type="System.Int32, mscorlib">
+    <value>8</value>
+  </data>
+  <data name="&gt;&gt;btnBrowseAliasFolder.Name" xml:space="preserve">
+    <value>btnBrowseAliasFolder</value>
+  </data>
+  <data name="&gt;&gt;btnBrowseAliasFolder.Type" xml:space="preserve">
+    <value>System.Windows.Forms.Button, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name="&gt;&gt;btnBrowseAliasFolder.Parent" xml:space="preserve">
+    <value>unmanagedPanel</value>
+  </data>
+  <data name="&gt;&gt;btnBrowseAliasFolder.ZOrder" xml:space="preserve">
+    <value>0</value>
+  </data>
   <data name="label1.AutoSize" type="System.Boolean, mscorlib">
     <value>True</value>
   </data>
-  <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
   <data name="label1.Location" type="System.Drawing.Point, System.Drawing">
     <value>3, 8</value>
   </data>
@@ -148,34 +175,31 @@
   </data>
   <data name="&gt;&gt;label1.ZOrder" xml:space="preserve">
-    <value>0</value>
+    <value>1</value>
   </data>
-  <data name="btnBrowseAlias.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+  <data name="btnBrowseAliasFile.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
   </data>
-  <data name="btnBrowseAlias.Location" type="System.Drawing.Point, System.Drawing">
-    <value>373, 3</value>
+  <data name="btnBrowseAliasFile.Location" type="System.Drawing.Point, System.Drawing">
+    <value>344, 2</value>
   </data>
-  <data name="btnBrowseAlias.Size" type="System.Drawing.Size, System.Drawing">
-    <value>32, 23</value>
+  <data name="btnBrowseAliasFile.Size" type="System.Drawing.Size, System.Drawing">
   </data>
-  <data name="btnBrowseAlias.TabIndex" type="System.Int32, mscorlib">
+  <data name="btnBrowseAliasFile.TabIndex" type="System.Int32, mscorlib">
     <value>7</value>
   </data>
-  <data name="btnBrowseAlias.Text" xml:space="preserve">
-    <value>...</value>
+  <data name="&gt;&gt;btnBrowseAliasFile.Name" xml:space="preserve">
+    <value>btnBrowseAliasFile</value>
   </data>
-  <data name="&gt;&gt;btnBrowseAlias.Name" xml:space="preserve">
-    <value>btnBrowseAlias</value>
-  </data>
-  <data name="&gt;&gt;btnBrowseAlias.Type" xml:space="preserve">
+  <data name="&gt;&gt;btnBrowseAliasFile.Type" xml:space="preserve">
   </data>
-  <data name="&gt;&gt;btnBrowseAlias.Parent" xml:space="preserve">
+  <data name="&gt;&gt;btnBrowseAliasFile.Parent" xml:space="preserve">
   </data>
-  <data name="&gt;&gt;btnBrowseAlias.ZOrder" xml:space="preserve">
-    <value>1</value>
+  <data name="&gt;&gt;btnBrowseAliasFile.ZOrder" xml:space="preserve">
+    <value>2</value>
   </data>
   <data name="txtAlias.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
@@ -184,7 +208,7 @@
     <value>111, 5</value>
   </data>
   <data name="txtAlias.Size" type="System.Drawing.Size, System.Drawing">
-    <value>256, 20</value>
+    <value>227, 20</value>
   </data>
   <data name="txtAlias.TabIndex" type="System.Int32, mscorlib">
     <value>6</value>
@@ -199,7 +223,7 @@
   </data>
   <data name="&gt;&gt;txtAlias.ZOrder" xml:space="preserve">
-    <value>2</value>
+    <value>3</value>
   </data>
   <data name="unmanagedPanel.Location" type="System.Drawing.Point, System.Drawing">
     <value>19, 189</value>
@@ -301,7 +325,7 @@
     <value>resDataCtrl</value>
   </data>
   <data name="&gt;&gt;resDataCtrl.Type" xml:space="preserve">
-    <value>Maestro.Editors.Common.ResourceDataCtrl, Maestro.Editors, Version=3.0.0.5610, Culture=neutral, PublicKeyToken=null</value>
+    <value>Maestro.Editors.Common.ResourceDataCtrl, Maestro.Editors, Version=3.1.0.5859, Culture=neutral, PublicKeyToken=null</value>
   </data>
   <data name="&gt;&gt;resDataCtrl.Parent" xml:space="preserve">
     <value>contentPanel</value>
@@ -334,6 +358,6 @@
     <value>FileBasedCtrl</value>
   </data>
   <data name="&gt;&gt;$this.Type" xml:space="preserve">
-    <value>Maestro.Editors.Common.EditorBindableCollapsiblePanel, Maestro.Editors, Version=3.0.0.5610, Culture=neutral, PublicKeyToken=null</value>
+    <value>Maestro.Editors.Common.EditorBindableCollapsiblePanel, Maestro.Editors, Version=3.1.0.5859, Culture=neutral, PublicKeyToken=null</value>
   </data>
 </root>
\ No newline at end of file
More information about the mapguide-commits mailing list
