[mapguide-commits] r6202 - in trunk/Tools/Maestro:
	Maestro.Editors/FeatureSource/Preview
	Maestro.Editors/LayerDefinition/Vector/Thematics
	Maestro.Editors/Properties OSGeo.MapGuide.MaestroAPI
	OSGeo.MapGuide.MaestroAPI.Local
    svn_mapguide at osgeo.org
    Mon Nov  7 10:57:46 EST 2011
Author: jng
Date: 2011-11-07 07:57:45 -0800 (Mon, 07 Nov 2011)
New Revision: 6202
   trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/PreviewPane.Designer.cs
   trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/PreviewPane.cs
   trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/PreviewPane.resx
   trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.cs
   trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
   trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs
This submission includes the following changes:
 - Measure the elapsed query time for queries in Feature Source Preview
 - Update the Theme Creator Dialog to use the UNIQUE() aggregate function for fetching distinct values. The traditional way exists as a fallback should the UNIQUE() approach throw any exceptions
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/PreviewPane.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/PreviewPane.Designer.cs	2011-11-07 12:13:28 UTC (rev 6201)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/PreviewPane.Designer.cs	2011-11-07 15:57:45 UTC (rev 6202)
@@ -35,9 +35,12 @@
             this.btnClear = new System.Windows.Forms.ToolStripButton();
             this.queryPane = new System.Windows.Forms.Panel();
             this.statusBar = new System.Windows.Forms.StatusStrip();
+            this.lblCount = new System.Windows.Forms.ToolStripStatusLabel();
+            this.lblElapsed = new System.Windows.Forms.ToolStripStatusLabel();
             this.grdResults = new System.Windows.Forms.DataGridView();
             this.queryWorker = new System.ComponentModel.BackgroundWorker();
             this.toolStrip1.SuspendLayout();
+            this.statusBar.SuspendLayout();
             ((System.ComponentModel.ISupportInitialize)(this.grdResults)).BeginInit();
             this.SuspendLayout();
@@ -78,9 +81,23 @@
             // statusBar
+            this.statusBar.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+            this.lblCount,
+            this.lblElapsed});
             resources.ApplyResources(this.statusBar, "statusBar");
             this.statusBar.Name = "statusBar";
+            // lblCount
+            this.lblCount.Name = "lblCount";
+            resources.ApplyResources(this.lblCount, "lblCount");
+            // lblElapsed
+            this.lblElapsed.Name = "lblElapsed";
+            resources.ApplyResources(this.lblElapsed, "lblElapsed");
+            this.lblElapsed.Spring = true;
             // grdResults
             this.grdResults.AllowUserToAddRows = false;
@@ -108,6 +125,8 @@
             resources.ApplyResources(this, "$this");
             this.toolStrip1.ResumeLayout(false);
             this.toolStrip1.PerformLayout();
+            this.statusBar.ResumeLayout(false);
+            this.statusBar.PerformLayout();
             ((System.ComponentModel.ISupportInitialize)(this.grdResults)).EndInit();
             this.ResumeLayout(false);
             this.PerformLayout();
@@ -124,5 +143,7 @@
         private System.Windows.Forms.ToolStripButton btnStop;
         private System.Windows.Forms.ToolStripButton btnClear;
         private System.ComponentModel.BackgroundWorker queryWorker;
+        private System.Windows.Forms.ToolStripStatusLabel lblCount;
+        private System.Windows.Forms.ToolStripStatusLabel lblElapsed;
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/PreviewPane.cs
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/PreviewPane.cs	2011-11-07 12:13:28 UTC (rev 6201)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/PreviewPane.cs	2011-11-07 15:57:45 UTC (rev 6202)
@@ -100,6 +100,7 @@
             btnClear.Enabled = false;
             btnStop.Enabled = true;
             btnRunQuery.Enabled = false;
+            lblCount.Text = lblElapsed.Text = string.Empty;
             queryWorker.RunWorkerAsync();
@@ -122,8 +123,10 @@
                 InitTable(reader, res.Result);
                 while (reader.ReadNext())
-                    if (e.Cancel)
+                    if (queryWorker.CancellationPending)
+                        e.Cancel = true;
+                        _cancelResult = res.Result;
                         break;
@@ -142,6 +145,10 @@
                 reader.Close();
                 sw.Stop();
+                    _cancelDuration = sw.Elapsed;
             e.Result = res;
@@ -158,6 +165,9 @@
+        DataTable _cancelResult;
+        TimeSpan? _cancelDuration;
         private void queryWorker_RunWorkerCompleted(object sender, RunWorkerCompletedEventArgs e)
             if (e.Error != null)
@@ -166,11 +176,22 @@
             else
-                var res = e.Result as QueryResult;
-                if (res != null)
+                if (e.Cancelled)
-                    grdResults.DataSource = res.Result;
+                    grdResults.DataSource = _cancelResult;
+                    lblElapsed.Text = string.Format(Properties.Resources.PreviewQueryElapsed, _cancelDuration.Value.TotalMilliseconds);
+                    lblCount.Text = string.Format(Properties.Resources.PreviewRecordCount, _cancelResult.Rows.Count);
+                else
+                    var res = e.Result as QueryResult;
+                    if (res != null)
+                        grdResults.DataSource = res.Result;
+                        lblElapsed.Text = string.Format(Properties.Resources.PreviewQueryElapsed, res.Duration.TotalMilliseconds);
+                        lblCount.Text = string.Format(Properties.Resources.PreviewRecordCount, res.Result.Rows.Count);
             btnRunQuery.Enabled = true;
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/PreviewPane.resx
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/PreviewPane.resx	2011-11-07 12:13:28 UTC (rev 6201)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/PreviewPane.resx	2011-11-07 15:57:45 UTC (rev 6202)
@@ -207,6 +207,15 @@
   <metadata name="statusBar.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
     <value>116, 17</value>
   </metadata>
+  <data name="lblCount.Size" type="System.Drawing.Size, System.Drawing">
+    <value>0, 17</value>
+  </data>
+  <data name="lblElapsed.Size" type="System.Drawing.Size, System.Drawing">
+    <value>655, 17</value>
+  </data>
+  <data name="lblElapsed.TextAlign" type="System.Drawing.ContentAlignment, System.Drawing">
+    <value>MiddleRight</value>
+  </data>
   <data name="statusBar.Location" type="System.Drawing.Point, System.Drawing">
     <value>0, 453</value>
   </data>
@@ -282,6 +291,18 @@
   <data name=">>btnClear.Type" xml:space="preserve">
     <value>System.Windows.Forms.ToolStripButton, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
+  <data name=">>lblCount.Name" xml:space="preserve">
+    <value>lblCount</value>
+  </data>
+  <data name=">>lblCount.Type" xml:space="preserve">
+    <value>System.Windows.Forms.ToolStripStatusLabel, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name=">>lblElapsed.Name" xml:space="preserve">
+    <value>lblElapsed</value>
+  </data>
+  <data name=">>lblElapsed.Type" xml:space="preserve">
+  </data>
   <data name=">>queryWorker.Name" xml:space="preserve">
     <value>queryWorker</value>
   </data>
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.cs	2011-11-07 12:13:28 UTC (rev 6201)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.cs	2011-11-07 15:57:45 UTC (rev 6202)
@@ -34,6 +34,7 @@
 using OSGeo.MapGuide.ObjectModels.LayerDefinition;
 using Ldf = OSGeo.MapGuide.ObjectModels.LayerDefinition;
 using OSGeo.MapGuide.MaestroAPI.Schema;
+using System.Collections.Specialized;
 namespace Maestro.Editors.LayerDefinition.Vector.Thematics
@@ -228,22 +229,53 @@
                     try
                         IVectorLayerDefinition vl = (IVectorLayerDefinition)m_layer.SubLayer;
-                        using (var rd = m_editor.FeatureService.QueryFeatureSource(vl.ResourceId, m_schema.QualifiedName, filter, new string[] { col.Name }))
+                        try
-                            while (rd.ReadNext() && m_values.Count < 100000) //No more than 100.000 records in memory
+                            //Either UNIQUE() is an undocumented FDO expression function (!!!)
+                            //Or it is FDO expression sugar to work around the fact there is no distinct
+                            //flag in the SELECTAGGREGATES operation that's exposed over HTTP. Either
+                            //case, try this method first.
+                            using (var rd = m_editor.FeatureService.AggregateQueryFeatureSource(
+                                                    vl.ResourceId,
+                                                    m_schema.QualifiedName,
+                                                    filter,
+                                                    new NameValueCollection() {
+                                                        { "value", "UNIQUE(\"" + col.Name + "\")" }
-                                if (!rd.IsNull(col.Name))
+                                while (rd.ReadNext() && m_values.Count < 100000) //No more than 100.000 records in memory
-                                    object value = rd[col.Name];
-                                    if (!m_values.ContainsKey(value))
-                                        m_values.Add(value, 0);
+                                    if (!rd.IsNull("value"))
+                                        object value = rd["value"];
+                                        if (!m_values.ContainsKey(value))
+                                            m_values.Add(value, 0);
-                                    m_values[value]++;
+                                        m_values[value]++;
+                                rd.Close();
-                            rd.Close();
+                        catch
+                            using (var rd = m_editor.FeatureService.QueryFeatureSource(vl.ResourceId, m_schema.QualifiedName, filter, new string[] { col.Name }))
+                                    if (!rd.IsNull(col.Name))
+                                        object value = rd[col.Name];
+                                rd.Close();
                         rawEx = null; //Clear error
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs	2011-11-07 12:13:28 UTC (rev 6201)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs	2011-11-07 15:57:45 UTC (rev 6202)
@@ -1,7 +1,7 @@
 // <auto-generated>
 //     This code was generated by a tool.
-//     Runtime Version:2.0.50727.4959
+//     Runtime Version:2.0.50727.4961
 //     Changes to this file may cause incorrect behavior and will be lost if
 //     the code is regenerated.
@@ -2270,6 +2270,24 @@
         /// <summary>
+        ///   Looks up a localized string similar to Preview Completed in {0}ms.
+        /// </summary>
+        internal static string PreviewQueryElapsed {
+            get {
+                return ResourceManager.GetString("PreviewQueryElapsed", resourceCulture);
+        /// <summary>
+        ///   Looks up a localized string similar to {0} results found.
+        /// </summary>
+        internal static string PreviewRecordCount {
+            get {
+                return ResourceManager.GetString("PreviewRecordCount", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to The Preview URL is not currently available.
         /// </summary>
         internal static string PreviewUrlNotAvailable {
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx	2011-11-07 12:13:28 UTC (rev 6201)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx	2011-11-07 15:57:45 UTC (rev 6202)
@@ -1268,4 +1268,10 @@
   <data name="PromptRepairBrokenFeatureSource" xml:space="preserve">
     <value>The resource id {0} could not be found. You will now be prompted to select the correct feature source</value>
   </data>
+  <data name="PreviewQueryElapsed" xml:space="preserve">
+    <value>Preview Completed in {0}ms</value>
+  </data>
+  <data name="PreviewRecordCount" xml:space="preserve">
+    <value>{0} results found</value>
+  </data>
 </root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs	2011-11-07 12:13:28 UTC (rev 6201)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs	2011-11-07 15:57:45 UTC (rev 6202)
@@ -1565,27 +1565,32 @@
                 fun.Add("extent", "SpatialExtents(\"" + geometry + "\")");
                 using (IReader fsr = AggregateQueryFeatureSource(resourceID, schema, filter, fun))
-                    if (fsr.ReadNext())
+                    try
-                        IGeometry geom = fsr["extent"] as IGeometry;
-                        if (geom == null)
+                        if (fsr.ReadNext())
-                            throw new Exception("No data found in resource: " + resourceID);
+                            IGeometry geom = fsr["extent"] as IGeometry;
+                            if (geom == null)
+                                throw new Exception("No data found in resource: " + resourceID);
+                            else
+                                var env = geom.EnvelopeInternal;
+                                return OSGeo.MapGuide.ObjectModels.ObjectFactory.CreateEnvelope(
+                                    env.MinX,
+                                    env.MinY,
+                                    env.MaxX,
+                                    env.MaxY);
                         else
-                            var env = geom.EnvelopeInternal;
-                            return OSGeo.MapGuide.ObjectModels.ObjectFactory.CreateEnvelope(
-                                env.MinX,
-                                env.MinY,
-                                env.MaxX,
-                                env.MaxY);
-                    else
-                    fsr.Close();
+                    finally
+                        fsr.Close();
             catch
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs	2011-11-07 12:13:28 UTC (rev 6201)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs	2011-11-07 15:57:45 UTC (rev 6202)
@@ -652,7 +652,8 @@
                 foreach (string s in computedProperties.Keys)
                     mgf.AddComputedProperty(s, computedProperties[s]);
-            MgFeatureReader mr = fes.SelectFeatures(new MgResourceIdentifier(resourceID), schema, mgf);
+            var fsId = new MgResourceIdentifier(resourceID);
+            MgFeatureReader mr = fes.SelectFeatures(fsId, schema, mgf);
             LogMethodCall("MgFeatureService::SelectFeatures", true, resourceID, schema, "MgFeatureQueryOptions");
More information about the mapguide-commits
