[mapguide-commits] r6210 - trunk/Tools/Maestro/Maestro.Packaging
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue Nov 8 10:36:41 EST 2011
Author: jng
Date: 2011-11-08 07:36:41 -0800 (Tue, 08 Nov 2011)
New Revision: 6210
   trunk/Tools/Maestro/Maestro.Packaging/PackageBuilder.cs
   trunk/Tools/Maestro/Maestro.Packaging/PackageUploadResultDialog.cs
   trunk/Tools/Maestro/Maestro.Packaging/UploadPackageResult.cs
#1820: Non-transactional package loading fixes:
 - Skip any SETRESOURCE package operations where there is non-existent content
 - Include exception details in failed package operations
Modified: trunk/Tools/Maestro/Maestro.Packaging/PackageBuilder.cs
--- trunk/Tools/Maestro/Maestro.Packaging/PackageBuilder.cs	2011-11-08 15:08:40 UTC (rev 6209)
+++ trunk/Tools/Maestro/Maestro.Packaging/PackageBuilder.cs	2011-11-08 15:36:41 UTC (rev 6210)
@@ -211,42 +211,49 @@
                     case "SETRESOURCE":
                             SetResourcePackageOperation sop = (SetResourcePackageOperation)op;
-                            ZipEntry contentEntry = package.GetEntry(sop.Content);
-                            ZipEntry headerEntry = null;
+                            if (sop.Content == null)
+                                skipOps[sop] = sop;
+                            else
+                                ZipEntry contentEntry = package.GetEntry(sop.Content);
+                                ZipEntry headerEntry = null;
-                            if (!string.IsNullOrEmpty(sop.Header))
-                                headerEntry = package.GetEntry(sop.Header);
+                                if (!string.IsNullOrEmpty(sop.Header))
+                                    headerEntry = package.GetEntry(sop.Header);
-                            try
-                                using (var s = package.GetInputStream(contentEntry))
+                                try
-                                    m_connection.ResourceService.SetResourceXmlData(op.ResourceId, s);
-                                    progress(ProgressType.SetResource, op.ResourceId, 100, step);
+                                    using (var s = package.GetInputStream(contentEntry))
+                                        m_connection.ResourceService.SetResourceXmlData(op.ResourceId, s);
+                                        progress(ProgressType.SetResource, op.ResourceId, 100, step);
-                                if (headerEntry != null)
-                                    using (var s = package.GetInputStream(headerEntry))
+                                    if (headerEntry != null)
-                                        using (var sr = new StreamReader(s))
+                                        using (var s = package.GetInputStream(headerEntry))
-                                            ResourceDocumentHeaderType header = ResourceDocumentHeaderType.Deserialize(sr.ReadToEnd());
-                                            m_connection.ResourceService.SetResourceHeader(op.ResourceId, header);
+                                            using (var sr = new StreamReader(s))
+                                                ResourceDocumentHeaderType header = ResourceDocumentHeaderType.Deserialize(sr.ReadToEnd());
+                                                m_connection.ResourceService.SetResourceHeader(op.ResourceId, header);
+                                    result.Successful.Add(op);
-                                result.Successful.Add(op);
+                                catch (Exception ex)
+                                    //We don't really care about the header. We consider failure if the
+                                    //content upload did not succeed
+                                    if (!m_connection.ResourceService.ResourceExists(op.ResourceId))
+                                        result.Failed.Add(op, ex);
-                            catch (Exception)
-                                //We don't really care about the header. We consider failure if the
-                                //content upload did not succeed
-                                if (!m_connection.ResourceService.ResourceExists(op.ResourceId))
-                                    result.Failed.Add(op);
                         break;
                     case "SETRESOURCEDATA":
@@ -264,7 +271,7 @@
-                            catch (Exception)
                                 var resData = m_connection.ResourceService.EnumerateResourceData(sop.ResourceId);
                                 bool found = false;
@@ -279,7 +286,7 @@
                                 if (!found)
-                                    result.Failed.Add(sop);
+                                    result.Failed.Add(sop, ex);
                         break;
@@ -1180,7 +1187,7 @@
             unchecked
                 int hash = 17;
-                hash = hash * 23 + this.Content.GetHashCode();
+                hash = hash * 23 + (this.Content ?? "").GetHashCode();
                 if (this.Header != null)
                     hash = hash * 23 + this.Header.GetHashCode();
                 hash = hash * 23 + this.OperationName.GetHashCode();
Modified: trunk/Tools/Maestro/Maestro.Packaging/PackageUploadResultDialog.cs
--- trunk/Tools/Maestro/Maestro.Packaging/PackageUploadResultDialog.cs	2011-11-08 15:08:40 UTC (rev 6209)
+++ trunk/Tools/Maestro/Maestro.Packaging/PackageUploadResultDialog.cs	2011-11-08 15:36:41 UTC (rev 6210)
@@ -43,7 +43,14 @@
             lblFailed.Text = string.Format(Properties.Resources.PackageOperationsFailed, result.Failed.Count);
             lblSkipped.Text = string.Format(Properties.Resources.PackageOperationsSkipped, result.SkipOperations.Count);
             lblSucceeded.Text = string.Format(Properties.Resources.PackageOperationsSucceeded, result.Successful.Count);
-            grdFailed.DataSource = result.Failed;
+            //grdFailed.DataSource = result.Failed;
+            grdFailed.Columns.Add("Resource ID", "Resource ID");
+            grdFailed.Columns.Add("Operation", "Operation");
+            grdFailed.Columns.Add("Error", "Error");
+            foreach (var op in result.Failed.Keys)
+                grdFailed.Rows.Add(op.ResourceId, op.OperationName, result.Failed[op].ToString());
         private void btnClose_Click(object sender, EventArgs e)
Modified: trunk/Tools/Maestro/Maestro.Packaging/UploadPackageResult.cs
--- trunk/Tools/Maestro/Maestro.Packaging/UploadPackageResult.cs	2011-11-08 15:08:40 UTC (rev 6209)
+++ trunk/Tools/Maestro/Maestro.Packaging/UploadPackageResult.cs	2011-11-08 15:36:41 UTC (rev 6210)
@@ -27,7 +27,7 @@
         public ICollection<PackageOperation> Successful { get; private set; }
-        public ICollection<PackageOperation> Failed { get; private set; }
+        public Dictionary<PackageOperation, Exception> Failed { get; private set; }
         public ICollection<PackageOperation> SkipOperations { get; private set; }
@@ -36,7 +36,7 @@
         public UploadPackageResult(IEnumerable<PackageOperation> skip)
             this.Successful = new List<PackageOperation>();
-            this.Failed = new List<PackageOperation>();
+            this.Failed = new Dictionary<PackageOperation, Exception>();
             this.SkipOperations = new List<PackageOperation>(skip);
More information about the mapguide-commits mailing list
