[mapguide-commits] r6162 - in trunk/Tools/Maestro/MgCooker: .
Properties
svn_mapguide at osgeo.org
Sun Oct 2 22:32:29 EDT 2011
Author: jng
Date: 2011-10-02 19:32:28 -0700 (Sun, 02 Oct 2011)
New Revision: 6162
trunk/Tools/Maestro/MgCooker/Progress.cs
trunk/Tools/Maestro/MgCooker/Properties/Resources.Designer.cs
trunk/Tools/Maestro/MgCooker/Properties/Resources.resx
trunk/Tools/Maestro/MgCooker/SetupRun.cs
Do not close down MgCooker on success for interactive tiling runs. Also show how long the operation took.
Modified: trunk/Tools/Maestro/MgCooker/Progress.cs
--- trunk/Tools/Maestro/MgCooker/Progress.cs 2011-10-03 00:45:29 UTC (rev 6161)
+++ trunk/Tools/Maestro/MgCooker/Progress.cs 2011-10-03 02:32:28 UTC (rev 6162)
@@ -76,10 +76,14 @@
exception = null; //Eat it
+ public TimeSpan TotalTime { get; private set; }
private void DoClose()
m_allowClose = true;
+ this.TotalTime = DateTime.Now - m_grandBegin;
if (m_cancel)
this.DialogResult = DialogResult.Cancel;
else
Modified: trunk/Tools/Maestro/MgCooker/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/MgCooker/Properties/Resources.Designer.cs 2011-10-03 00:45:29 UTC (rev 6161)
+++ trunk/Tools/Maestro/MgCooker/Properties/Resources.Designer.cs 2011-10-03 02:32:28 UTC (rev 6162)
@@ -1,7 +1,7 @@
// <auto-generated>
// This code was generated by a tool.
-// Runtime Version:2.0.50727.4952
+// Runtime Version:2.0.50727.4961
// Changes to this file may cause incorrect behavior and will be lost if
// the code is regenerated.
@@ -313,5 +313,14 @@
return ResourceManager.GetString("TileErrorCount", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Tile Generation Complete. The operation completed in {0}h {1}m {2}s.
+ /// </summary>
+ internal static string TileGenerationCompleted {
+ get {
+ return ResourceManager.GetString("TileGenerationCompleted", resourceCulture);
Modified: trunk/Tools/Maestro/MgCooker/Properties/Resources.resx
--- trunk/Tools/Maestro/MgCooker/Properties/Resources.resx 2011-10-03 00:45:29 UTC (rev 6161)
+++ trunk/Tools/Maestro/MgCooker/Properties/Resources.resx 2011-10-03 02:32:28 UTC (rev 6162)
@@ -231,4 +231,7 @@
<value>({0} failed tiles)</value>
<comment>Text inserted in the CurrentTileCounter if any tiles are failed</comment>
</data>
+ <data name="TileGenerationCompleted" xml:space="preserve">
+ <value>Tile Generation Complete. The operation completed in {0}h {1}m {2}s</value>
+ </data>
</root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/MgCooker/SetupRun.cs
--- trunk/Tools/Maestro/MgCooker/SetupRun.cs 2011-10-03 00:45:29 UTC (rev 6161)
+++ trunk/Tools/Maestro/MgCooker/SetupRun.cs 2011-10-03 02:32:28 UTC (rev 6162)
@@ -256,7 +256,10 @@
Progress p = new Progress(bx);
if (p.ShowDialog(this) != DialogResult.Cancel)
- this.Close();
+ var ts = p.TotalTime;
+ MessageBox.Show(string.Format(Properties.Resources.TileGenerationCompleted, ((ts.Days * 24) + ts.Hours), ts.Minutes, ts.Seconds));
catch (Exception ex)
More information about the mapguide-commits
