[mapguide-commits] r6164 - in trunk/Tools/Maestro:
Maestro.AddIn.Local OSGeo.MapGuide.MaestroAPI.Local
svn_mapguide at osgeo.org
Tue Oct 4 03:06:14 EDT 2011
Author: jng
Date: 2011-10-04 00:06:14 -0700 (Tue, 04 Oct 2011)
New Revision: 6164
trunk/Tools/Maestro/Maestro.AddIn.Local/MapGuideDesktopUnmanagedApi.dll
trunk/Tools/Maestro/Maestro.AddIn.Local/MgDesktop.dll
trunk/Tools/Maestro/Maestro.AddIn.Local/MgFoundation.dll
trunk/Tools/Maestro/Maestro.AddIn.Local/MgGeometry.dll
trunk/Tools/Maestro/Maestro.AddIn.Local/MgGwsCommon.dll
trunk/Tools/Maestro/Maestro.AddIn.Local/MgGwsQueryEngine.dll
trunk/Tools/Maestro/Maestro.AddIn.Local/MgGwsResource.dll
trunk/Tools/Maestro/Maestro.AddIn.Local/MgMdfModel.dll
trunk/Tools/Maestro/Maestro.AddIn.Local/MgMdfParser.dll
trunk/Tools/Maestro/Maestro.AddIn.Local/MgPlatformBase.dll
trunk/Tools/Maestro/Maestro.AddIn.Local/MgRenderers.dll
trunk/Tools/Maestro/Maestro.AddIn.Local/MgStylization.dll
trunk/Tools/Maestro/Maestro.AddIn.Local/OSGeo.MapGuide.Desktop.dll
trunk/Tools/Maestro/Maestro.AddIn.Local/OSGeo.MapGuide.Viewer.dll
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs
Update mg-desktop binaries (now supporting empty string coalescing of null references, eliminating the need for use to do this manually in LocalConnection)
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/MapGuideDesktopUnmanagedApi.dll
(Binary files differ)
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/MgDesktop.dll
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/MgFoundation.dll
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/MgGeometry.dll
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/MgGwsCommon.dll
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/MgGwsQueryEngine.dll
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/MgGwsResource.dll
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/MgMdfModel.dll
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/MgMdfParser.dll
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/MgPlatformBase.dll
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/MgRenderers.dll
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/MgStylization.dll
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/OSGeo.MapGuide.Desktop.dll
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/OSGeo.MapGuide.Viewer.dll
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs 2011-10-04 06:04:59 UTC (rev 6163)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs 2011-10-04 07:06:14 UTC (rev 6164)
@@ -392,8 +392,7 @@
public override UnmanagedDataList EnumerateUnmanagedData(string startpath, string filter, bool recursive, UnmanagedDataTypes type)
var resSvc = GetResourceService();
- //HACK: The SWIG wrapper breaks down on null string parameters (apparently). So coalesce them.
- var br = resSvc.EnumerateUnmanagedData(startpath ?? string.Empty, recursive, type.ToString(), filter ?? string.Empty);
+ var br = resSvc.EnumerateUnmanagedData(startpath, recursive, type.ToString(), filter);
var result = (UnmanagedDataList)base.DeserializeObject(typeof(UnmanagedDataList), new MgReadOnlyStream(new GetByteReaderMethod(() => { return br; })));
LogMethodCall("MgResourceService::EnumerateUnmanagedData", true, startpath, recursive.ToString(), type.ToString(), filter);
return result;
More information about the mapguide-commits
