[mapguide-commits] r6170 - trunk/MgDev/Oem/LinuxApt
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sun Oct 9 05:05:36 EDT 2011
Author: liuar
Date: 2011-10-09 02:05:36 -0700 (Sun, 09 Oct 2011)
New Revision: 6170
   trunk/MgDev/Oem/LinuxApt/server.xml
Submit on behalf of Mars Wu
Implement RFC 121. Ticket: http://trac.osgeo.org/mapguide/ticket/1818
server.xml need be updated with the Tomcat7 version
Modified: trunk/MgDev/Oem/LinuxApt/server.xml
--- trunk/MgDev/Oem/LinuxApt/server.xml	2011-10-07 15:26:59 UTC (rev 6169)
+++ trunk/MgDev/Oem/LinuxApt/server.xml	2011-10-09 09:05:36 UTC (rev 6170)
@@ -20,16 +20,17 @@
      Documentation at /docs/config/server.html
 <Server port="8005" shutdown="SHUTDOWN">
+  <!-- Security listener. Documentation at /docs/config/listeners.html
+  <Listener className="org.apache.catalina.security.SecurityListener" />
   <!--APR library loader. Documentation at /docs/apr.html -->
   <Listener className="org.apache.catalina.core.AprLifecycleListener" SSLEngine="on" />
   <!--Initialize Jasper prior to webapps are loaded. Documentation at /docs/jasper-howto.html -->
   <Listener className="org.apache.catalina.core.JasperListener" />
   <!-- Prevent memory leaks due to use of particular java/javax APIs-->
   <Listener className="org.apache.catalina.core.JreMemoryLeakPreventionListener" />
-  <!-- JMX Support for the Tomcat server. Documentation at /docs/non-existent.html -->
-  <Listener className="org.apache.catalina.mbeans.ServerLifecycleListener" />
   <Listener className="org.apache.catalina.mbeans.GlobalResourcesLifecycleListener" />
+  <Listener className="org.apache.catalina.core.ThreadLocalLeakPreventionListener" />
   <!-- Global JNDI resources
        Documentation at /docs/jndi-resources-howto.html
@@ -108,26 +109,19 @@
       <Cluster className="org.apache.catalina.ha.tcp.SimpleTcpCluster"/>
-      <!-- The request dumper valve dumps useful debugging information about
-           the request and response data received and sent by Tomcat.
-           Documentation at: /docs/config/valve.html -->
-      <Valve className="org.apache.catalina.valves.RequestDumperValve"/>
+      <!-- Use the LockOutRealm to prevent attempts to guess user passwords
+           via a brute-force attack -->
+      <Realm className="org.apache.catalina.realm.LockOutRealm">
+        <!-- This Realm uses the UserDatabase configured in the global JNDI
+             resources under the key "UserDatabase".  Any edits
+             that are performed against this UserDatabase are immediately
+             available for use by the Realm.  -->
+        <Realm className="org.apache.catalina.realm.UserDatabaseRealm"
+               resourceName="UserDatabase"/>
+      </Realm>
-      <!-- This Realm uses the UserDatabase configured in the global JNDI
-           resources under the key "UserDatabase".  Any edits
-           that are performed against this UserDatabase are immediately
-           available for use by the Realm.  -->
-      <Realm className="org.apache.catalina.realm.UserDatabaseRealm"
-             resourceName="UserDatabase"/>
-      <!-- Define the default virtual host
-           Note: XML Schema validation will not work with Xerces 2.2.
       <Host name="localhost"  appBase="webapps"
-            unpackWARs="true" autoDeploy="true"
-            xmlValidation="false" xmlNamespaceAware="false">
+            unpackWARs="true" autoDeploy="true">
         <!-- SingleSignOn valve, share authentication between web applications
@@ -136,11 +130,11 @@
         <!-- Access log processes all example.
-        <Valve className="org.apache.catalina.valves.AccessLogValve" directory="logs"
-               prefix="localhost_access_log." suffix=".txt" pattern="common" resolveHosts="false"/>
+             Documentation at: /docs/config/valve.html
+             Note: The pattern used is equivalent to using pattern="common" -->
+        <Valve className="org.apache.catalina.valves.AccessLogValve" directory="logs"
+               prefix="localhost_access_log." suffix=".txt"
+               pattern="%h %l %u %t &quot;%r&quot; %s %b" />
       </Host>
     </Engine>
More information about the mapguide-commits mailing list
