[mapguide-commits] r6174 - sandbox/rfc90.2/MgDev/Server/src/Core
svn_mapguide at osgeo.org
Fri Oct 14 05:39:55 EDT 2011
Author: uvlite
Date: 2011-10-14 02:39:55 -0700 (Fri, 14 Oct 2011)
New Revision: 6174
sandbox/rfc90.2/MgDev/Server/src/Core/serverconfig.ini
rfc90 use standard paths in config file
Modified: sandbox/rfc90.2/MgDev/Server/src/Core/serverconfig.ini
--- sandbox/rfc90.2/MgDev/Server/src/Core/serverconfig.ini 2011-10-14 08:59:15 UTC (rev 6173)
+++ sandbox/rfc90.2/MgDev/Server/src/Core/serverconfig.ini 2011-10-14 09:39:55 UTC (rev 6174)
@@ -86,21 +86,21 @@
ConnectionTimerInterval = 60
DefaultMessageLocale = en
DisplayName =
-#FdoPath = FDO/
-FdoPath =C:\Program Files\OSGeo\MapGuide\Server\Fdo\
+FdoPath = FDO/
+#FdoPath =C:\Program Files\OSGeo\MapGuide\Server\Fdo\
LicenseServerPath = @localhost
Locale =
LogsDelimiter = \t
LogsDetail =
-#LogsPath = Logs/
-LogsPath =C:\Program Files\OSGeo\MapGuide\Server\Logs\
+LogsPath = Logs/
+#LogsPath =C:\Program Files\OSGeo\MapGuide\Server\Logs\
MachineIp = 127.0.0.1
MaxLogFileSize = 1024
MaxLogFileSizeEnabled = 0
PreCacheMaps =
Renderer = AGG
-#ResourcesPath = Resources/
-ResourcesPath =C:\Program Files\OSGeo\MapGuide\Server\Resources\
+ResourcesPath = Resources/
+#ResourcesPath =C:\Program Files\OSGeo\MapGuide\Server\Resources\
SerialNumber =
TcpIpMtu = 1460
#TempPath = Temp/
@@ -443,16 +443,15 @@
# 50 < value <= 10000
# ImageFormat Image format for generated tiles
# PNG, PNG8, GIF or JPG
-# UseMetaTiles set the meta tile factor used for rendering the tiles
-# 0 is off, 1 is not changing the tilesize
-# LockMethod set the strategie used for locking files in the tilecache
-# default= 1 using 1 remapped metalockfile for all subtiles
-# 2 using 1 lockfile for each subtiles
-# 3 using 1 ace condition per metatile
+# UseMetaTiles set the meta tile factor used for rendering the tiles
+# 0 is off, 1 is not changing the metatile size, higher does
+# LockMethod set the strategie used for locking files in the tilecache
+# default = 0 a shared lockfile per metatile for all subtiles
+# 1 using an ace condition per metatile (experimental)
RenderOnly = 0
-#TileCachePath = Repositories/TileCache/
-TileCachePath =C:\Program Files\OSGeo\MapGuide\Server\Repositories\TileCache\
+TileCachePath = Repositories/TileCache/
+#TileCachePath =C:\Program Files\OSGeo\MapGuide\Server\Repositories\TileCache\
TileColumnsPerFolder = 30
TileRowsPerFolder = 30
DefaultTileSizeX = 300
More information about the mapguide-commits
