[mapguide-commits] r6187 - trunk/MgDev/Web/src
svn_mapguide at osgeo.org
Fri Oct 28 06:04:28 EDT 2011
Author: jng
Date: 2011-10-28 03:04:28 -0700 (Fri, 28 Oct 2011)
New Revision: 6187
trunk/MgDev/Web/src/webconfig.ini
#1840: Document the new MentorDictionaryPath configuration value for webconfig.ini
Modified: trunk/MgDev/Web/src/webconfig.ini
--- trunk/MgDev/Web/src/webconfig.ini 2011-10-28 09:59:32 UTC (rev 6186)
+++ trunk/MgDev/Web/src/webconfig.ini 2011-10-28 10:04:28 UTC (rev 6187)
@@ -40,6 +40,7 @@
# be upper case.
# LogsPath Path where log files are stored
+# MentorDictionaryPath The path where the CS-Map Coordinate System Dictionaries are installed
# ResourcesPath Path where the localization resource files are stored
# TcpIpMtu The TCP/IP maximum transmission unit
# 0 < Value <= 65535
@@ -57,6 +58,7 @@
DefaultMessageLocale = en
LogsPath = Logs/
+MentorDictionaryPath =
ResourcesPath = Resources/
TcpIpMtu = 1460
TempPath = Temp/
More information about the mapguide-commits
