[mapguide-commits] r6190 - in trunk/Installer/Support/Web: x64
x64/Apache2 x64/Apache2/conf x64/Php x64/Tomcat
x64/Tomcat/conf x64/Tomcat/conf/Catalina
x64/Tomcat/conf/Catalina/localhost x86 x86/Apache2
x86/Apache2/conf x86/Php x86/Tomcat x86/Tomcat/conf
x86/Tomcat/conf/Catalina x86/Tomcat/conf/Catalina/localhost
svn_mapguide at osgeo.org
Fri Oct 28 06:46:48 EDT 2011
Author: jng
Date: 2011-10-28 03:46:47 -0700 (Fri, 28 Oct 2011)
New Revision: 6190
Added:
trunk/Installer/Support/Web/x64/Apache2/
trunk/Installer/Support/Web/x64/Apache2/conf/
trunk/Installer/Support/Web/x64/Apache2/conf/httpd.conf
trunk/Installer/Support/Web/x64/Php/
trunk/Installer/Support/Web/x64/Php/php.ini
trunk/Installer/Support/Web/x64/Tomcat/
trunk/Installer/Support/Web/x64/Tomcat/conf/
trunk/Installer/Support/Web/x64/Tomcat/conf/Catalina/
trunk/Installer/Support/Web/x64/Tomcat/conf/Catalina/localhost/
trunk/Installer/Support/Web/x64/Tomcat/conf/Catalina/localhost/mapguide.xml
trunk/Installer/Support/Web/x86/Apache2/
trunk/Installer/Support/Web/x86/Apache2/conf/
trunk/Installer/Support/Web/x86/Apache2/conf/httpd.conf
trunk/Installer/Support/Web/x86/Apache2/conf/tomcat.conf
trunk/Installer/Support/Web/x86/Php/
trunk/Installer/Support/Web/x86/Php/php.ini
trunk/Installer/Support/Web/x86/Tomcat/
trunk/Installer/Support/Web/x86/Tomcat/conf/
trunk/Installer/Support/Web/x86/Tomcat/conf/Catalina/
trunk/Installer/Support/Web/x86/Tomcat/conf/Catalina/localhost/
trunk/Installer/Support/Web/x86/Tomcat/conf/Catalina/localhost/mapguide.xml
#1805: Restore the templated config files
Added: trunk/Installer/Support/Web/x64/Apache2/conf/httpd.conf
--- trunk/Installer/Support/Web/x64/Apache2/conf/httpd.conf (rev 0)
+++ trunk/Installer/Support/Web/x64/Apache2/conf/httpd.conf 2011-10-28 10:46:47 UTC (rev 6190)
@@ -0,0 +1,1032 @@
+# Based upon the NCSA server configuration files originally by Rob McCool.
+# This is the main Apache server configuration file. It contains the
+# configuration directives that give the server its instructions.
+# See <URL:http://httpd.apache.org/docs-2.2/> for detailed information about
+# the directives.
+# Do NOT simply read the instructions in here without understanding
+# what they do. They're here only as hints or reminders. If you are unsure
+# consult the online docs. You have been warned.
+# The configuration directives are grouped into three basic sections:
+# 1. Directives that control the operation of the Apache server process as a
+# whole (the 'global environment').
+# 2. Directives that define the parameters of the 'main' or 'default' server,
+# which responds to requests that aren't handled by a virtual host.
+# These directives also provide default values for the settings
+# of all virtual hosts.
+# 3. Settings for virtual hosts, which allow Web requests to be sent to
+# different IP addresses or hostnames and have them handled by the
+# same Apache server process.
+# Configuration and logfile names: If the filenames you specify for many
+# of the server's control files begin with "/" (or "drive:/" for Win32), the
+# server will use that explicit path. If the filenames do *not* begin
+# with "/", the value of ServerRoot is prepended -- so "logs/foo.log"
+# with ServerRoot set to "C:/Program Files/Apache Group/Apache2" will be interpreted by the
+# server as "C:/Program Files/Apache Group/Apache2/logs/foo.log".
+# NOTE: Where filenames are specified, you must use forward slashes
+# instead of backslashes (e.g., "c:/apache" instead of "c:\apache").
+# If a drive letter is omitted, the drive on which Apache.exe is located
+# will be used by default. It is recommended that you always supply
+# an explicit drive letter in absolute paths, however, to avoid
+# confusion.
+### Section 1: Global Environment
+# The directives in this section affect the overall operation of Apache,
+# such as the number of concurrent requests it can handle or where it
+# can find its configuration files.
+# ServerRoot: The top of the directory tree under which the server's
+# configuration, error, and log files are kept.
+# NOTE! If you intend to place this on an NFS (or otherwise network)
+# mounted filesystem then please read the LockFile documentation (available
+# at <URL:http://httpd.apache.org/docs-2.0/mod/mpm_common.html#lockfile>);
+# you will save yourself a lot of trouble.
+# Do NOT add a slash at the end of the directory path.
+ServerRoot "%MG_WEB_APACHE%"
+# ScoreBoardFile: File used to store internal server process information.
+# If unspecified (the default), the scoreboard will be stored in an
+# anonymous shared memory segment, and will be unavailable to third-party
+# applications.
+# If specified, ensure that no two invocations of Apache share the same
+# scoreboard file. The scoreboard file MUST BE STORED ON A LOCAL DISK.
+#ScoreBoardFile logs/apache_runtime_status
+# PidFile: The file in which the server should record its process
+# identification number when it starts.
+PidFile logs/httpd.pid
+# Timeout: The number of seconds before receives and sends time out.
+Timeout 300
+# KeepAlive: Whether or not to allow persistent connections (more than
+# one request per connection). Set to "Off" to deactivate.
+KeepAlive On
+# MaxKeepAliveRequests: The maximum number of requests to allow
+# during a persistent connection. Set to 0 to allow an unlimited amount.
+# We recommend you leave this number high, for maximum performance.
+MaxKeepAliveRequests 100
+# KeepAliveTimeout: Number of seconds to wait for the next request from the
+# same client on the same connection.
+KeepAliveTimeout 15
+## Server-Pool Size Regulation (MPM specific)
+# WinNT MPM
+# ThreadsPerChild: constant number of worker threads in the server process
+# MaxRequestsPerChild: maximum number of requests a server process serves
+<IfModule mpm_winnt.c>
+ThreadsPerChild 50
+MaxRequestsPerChild 10000
+MaxMemFree 1000
+</IfModule>
+# Listen: Allows you to bind Apache to specific IP addresses and/or
+# ports, instead of the default. See also the <VirtualHost>
+# directive.
+# Change this to Listen on specific IP addresses as shown below to
+# prevent Apache from glomming onto all bound IP addresses (0.0.0.0)
+#Listen 12.34.56.78:80
+Listen %MG_WEB_PORT%
+LoadFile "%MG_WEB_PHP%/php5ts.dll"
+LoadFile "%MG_WEB_PHP%/ACE.dll"
+LoadFile "%MG_WEB_PHP%/MgHttpHandler.dll"
+LoadFile "%MG_WEB_PHP%/MgFoundation.dll"
+LoadFile "%MG_WEB_PHP%/MgGeometry.dll"
+LoadFile "%MG_WEB_PHP%/MgMapGuideCommon.dll"
+LoadFile "%MG_WEB_PHP%/MgMdfModel.dll"
+LoadFile "%MG_WEB_PHP%/MgMdfParser.dll"
+LoadFile "%MG_WEB_PHP%/MgPlatformBase.dll"
+LoadFile "%MG_WEB_PHP%/MgWebApp.dll"
+LoadFile "%MG_WEB_PHP%/MgWebSupport.dll"
+# Dynamic Shared Object (DSO) Support
+# To be able to use the functionality of a module which was built as a DSO you
+# have to place corresponding `LoadModule' lines at this location so the
+# directives contained in it are actually available _before_ they are used.
+# Statically compiled modules (those listed by `httpd -l') do not need
+# to be loaded here.
+# Example:
+# LoadModule foo_module modules/mod_foo.so
+LoadModule actions_module modules/mod_actions.so
+LoadModule alias_module modules/mod_alias.so
+LoadModule asis_module modules/mod_asis.so
+LoadModule auth_basic_module modules/mod_auth_basic.so
+#LoadModule auth_digest_module modules/mod_auth_digest.so
+#LoadModule authn_anon_module modules/mod_authn_anon.so
+#LoadModule authn_dbm_module modules/mod_authn_dbm.so
+LoadModule authn_default_module modules/mod_authn_default.so
+LoadModule authn_file_module modules/mod_authn_file.so
+#LoadModule authz_dbm_module modules/mod_authz_dbm.so
+LoadModule authz_default_module modules/mod_authz_default.so
+LoadModule authz_groupfile_module modules/mod_authz_groupfile.so
+LoadModule authz_host_module modules/mod_authz_host.so
+LoadModule authz_user_module modules/mod_authz_user.so
+LoadModule autoindex_module modules/mod_autoindex.so
+#LoadModule cern_meta_module modules/mod_cern_meta.so
+LoadModule cgi_module modules/mod_cgi.so
+#LoadModule dav_module modules/mod_dav.so
+#LoadModule dav_fs_module modules/mod_dav_fs.so
+LoadModule deflate_module modules/mod_deflate.so
+LoadModule dir_module modules/mod_dir.so
+LoadModule env_module modules/mod_env.so
+#LoadModule expires_module modules/mod_expires.so
+#LoadModule file_cache_module modules/mod_file_cache.so
+#LoadModule headers_module modules/mod_headers.so
+LoadModule imagemap_module modules/mod_imagemap.so
+LoadModule include_module modules/mod_include.so
+#LoadModule info_module modules/mod_info.so
+LoadModule isapi_module modules/mod_isapi.so
+LoadModule log_config_module modules/mod_log_config.so
+LoadModule mime_module modules/mod_mime.so
+#LoadModule mime_magic_module modules/mod_mime_magic.so
+#LoadModule proxy_module modules/mod_proxy.so
+#LoadModule proxy_ajp_module modules/mod_proxy_ajp.so
+#LoadModule proxy_balancer_module modules/mod_proxy_balancer.so
+#LoadModule proxy_connect_module modules/mod_proxy_connect.so
+#LoadModule proxy_http_module modules/mod_proxy_http.so
+#LoadModule proxy_ftp_module modules/mod_proxy_ftp.so
+LoadModule negotiation_module modules/mod_negotiation.so
+LoadModule rewrite_module modules/mod_rewrite.so
+LoadModule setenvif_module modules/mod_setenvif.so
+#LoadModule speling_module modules/mod_speling.so
+#LoadModule status_module modules/mod_status.so
+#LoadModule unique_id_module modules/mod_unique_id.so
+LoadModule userdir_module modules/mod_userdir.so
+#LoadModule usertrack_module modules/mod_usertrack.so
+#LoadModule vhost_alias_module modules/mod_vhost_alias.so
+#LoadModule ssl_module modules/mod_ssl.so
+LoadModule php5_module modules/php5apache2_2.dll
+LoadModule mgmapagent_module modules/mod_mgmapagent.so
+# ExtendedStatus controls whether Apache will generate "full" status
+# information (ExtendedStatus On) or just basic information (ExtendedStatus
+# Off) when the "server-status" handler is called. The default is Off.
+#ExtendedStatus On
+### Section 2: 'Main' server configuration
+# The directives in this section set up the values used by the 'main'
+# server, which responds to any requests that aren't handled by a
+# <VirtualHost> definition. These values also provide defaults for
+# any <VirtualHost> containers you may define later in the file.
+# All of these directives may appear inside <VirtualHost> containers,
+# in which case these default settings will be overridden for the
+# virtual host being defined.
+# ServerAdmin: Your address, where problems with the server should be
+# e-mailed. This address appears on some server-generated pages, such
+# as error documents. e.g. admin at your-domain.com
+ServerAdmin admin at your-domain.com
+# ServerName gives the name and port that the server uses to identify itself.
+# This can often be determined automatically, but we recommend you specify
+# it explicitly to prevent problems during startup.
+# If this is not set to valid DNS name for your host, server-generated
+# redirections will not work. See also the UseCanonicalName directive.
+# If your host doesn't have a registered DNS name, enter its IP address here.
+# You will have to access it by its address anyway, and this will make
+# redirections work in a sensible way.
+ServerName localhost:%MG_WEB_PORT%
+# UseCanonicalName: Determines how Apache constructs self-referencing
+# URLs and the SERVER_NAME and SERVER_PORT variables.
+# When set "Off", Apache will use the Hostname and Port supplied
+# by the client. When set "On", Apache will use the value of the
+# ServerName directive.
+UseCanonicalName Off
+# DocumentRoot: The directory out of which you will serve your
+# documents. By default, all requests are taken from this directory, but
+# symbolic links and aliases may be used to point to other locations.
+DocumentRoot "%MG_WEB_APACHE%/htdocs"
+# Each directory to which Apache has access can be configured with respect
+# to which services and features are allowed and/or disabled in that
+# directory (and its subdirectories).
+# First, we configure the "default" to be a very restrictive set of
+# features.
+<Directory />
+ Options FollowSymLinks
+ AllowOverride None
+</Directory>
+# Note that from this point forward you must specifically allow
+# particular features to be enabled - so if something's not working as
+# you might expect, make sure that you have specifically enabled it
+# below.
+# This should be changed to whatever you set DocumentRoot to.
+<Directory "%MG_WEB_APACHE%/htdocs">
+# Possible values for the Options directive are "None", "All",
+# or any combination of:
+# Indexes Includes FollowSymLinks SymLinksifOwnerMatch ExecCGI MultiViews
+# Note that "MultiViews" must be named *explicitly* --- "Options All"
+# doesn't give it to you.
+# The Options directive is both complicated and important. Please see
+# http://httpd.apache.org/docs-2.0/mod/core.html#options
+# for more information.
+ Options Indexes FollowSymLinks
+# AllowOverride controls what directives may be placed in .htaccess files.
+# It can be "All", "None", or any combination of the keywords:
+# Options FileInfo AuthConfig Limit
+# Controls who can get stuff from this server.
+ Order allow,deny
+ Allow from all
+</Directory>
+# UserDir: The name of the directory that is appended onto a user's home
+# directory if a ~user request is received. Be especially careful to use
+# proper, forward slashes here. On Windows NT, "Personal/My Website"
+# is a more appropriate choice.
+UserDir "My Documents/My Website"
+# Control access to UserDir directories. The following is an example
+# for a site where these directories are restricted to read-only.
+# You must correct the path for the root to match your system's configured
+# user directory location, e.g. "C:/WinNT/profiles/*/My Documents/My Website"
+# or whichever, as appropriate.
+#<Directory "C:/Documents and Settings/*/My Documents/My Website">
+# AllowOverride FileInfo AuthConfig Limit
+# Options MultiViews Indexes SymLinksIfOwnerMatch IncludesNoExec
+# <Limit GET POST OPTIONS PROPFIND>
+# Order allow,deny
+# Allow from all
+# </Limit>
+# <LimitExcept GET POST OPTIONS PROPFIND>
+# Order deny,allow
+# Deny from all
+# </LimitExcept>
+#</Directory>
+# DirectoryIndex: sets the file that Apache will serve if a directory
+# is requested.
+# The index.html.var file (a type-map) is used to deliver content-
+# negotiated documents. The MultiViews Option can be used for the
+# same purpose, but it is much slower.
+DirectoryIndex index.html index.html.var
+# AccessFileName: The name of the file to look for in each directory
+# for additional configuration directives. See also the AllowOverride
+# directive.
+AccessFileName .htaccess
+# The following lines prevent .htaccess and .htpasswd files from being
+# viewed by Web clients.
+<Files ~ "^\.ht">
+ Order allow,deny
+ Deny from all
+</Files>
+# TypesConfig describes where the mime.types file (or equivalent) is
+# to be found.
+TypesConfig conf/mime.types
+# DefaultType is the default MIME type the server will use for a document
+# if it cannot otherwise determine one, such as from filename extensions.
+# If your server contains mostly text or HTML documents, "text/plain" is
+# a good value. If most of your content is binary, such as applications
+# or images, you may want to use "application/octet-stream" instead to
+# keep browsers from trying to display binary files as though they are
+# text.
+DefaultType text/plain
+# The mod_mime_magic module allows the server to use various hints from the
+# contents of the file itself to determine its type. The MIMEMagicFile
+# directive tells the module where the hint definitions are located.
+<IfModule mod_mime_magic.c>
+ MIMEMagicFile conf/magic
+</IfModule>
+# HostnameLookups: Log the names of clients or just their IP addresses
+# e.g., www.apache.org (on) or 204.62.129.132 (off).
+# The default is off because it'd be overall better for the net if people
+# had to knowingly turn this feature on, since enabling it means that
+# each client request will result in AT LEAST one lookup request to the
+# nameserver.
+HostnameLookups Off
+# EnableMMAP: Control whether memory-mapping is used to deliver
+# files (assuming that the underlying OS supports it).
+# The default is on; turn this off if you serve from NFS-mounted
+# filesystems. On some systems, turning it off (regardless of
+# filesystem) can improve performance; for details, please see
+# http://httpd.apache.org/docs-2.0/mod/core.html#enablemmap
+#EnableMMAP off
+# EnableSendfile: Control whether the sendfile kernel support is
+# used to deliver files (assuming that the OS supports it).
+# filesystems. Please see
+# http://httpd.apache.org/docs-2.0/mod/core.html#enablesendfile
+#EnableSendfile off
+# ErrorLog: The location of the error log file.
+# If you do not specify an ErrorLog directive within a <VirtualHost>
+# container, error messages relating to that virtual host will be
+# logged here. If you *do* define an error logfile for a <VirtualHost>
+# container, that host's errors will be logged there and not here.
+ErrorLog logs/error.log
+# LogLevel: Control the number of messages logged to the error.log.
+# Possible values include: debug, info, notice, warn, error, crit,
+# alert, emerg.
+LogLevel warn
+# The following directives define some format nicknames for use with
+# a CustomLog directive (see below).
+LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
+LogFormat "%h %l %u %t \"%r\" %>s %b" common
+LogFormat "%{Referer}i -> %U" referer
+LogFormat "%{User-agent}i" agent
+# You need to enable mod_logio.c to use %I and %O
+#LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\" %I %O" combinedio
+# The location and format of the access logfile (Common Logfile Format).
+# If you do not define any access logfiles within a <VirtualHost>
+# container, they will be logged here. Contrariwise, if you *do*
+# define per-<VirtualHost> access logfiles, transactions will be
+# logged therein and *not* in this file.
+CustomLog logs/access.log common
+# If you would like to have agent and referer logfiles, uncomment the
+# following directives.
+#CustomLog logs/referer.log referer
+#CustomLog logs/agent.log agent
+# If you prefer a single logfile with access, agent, and referer information
+# (Combined Logfile Format) you can use the following directive.
+#CustomLog logs/access.log combined
+# ServerTokens
+# This directive configures what you return as the Server HTTP response
+# Header. The default is 'Full' which sends information about the OS-Type
+# and compiled in modules.
+# Set to one of: Full | OS | Minor | Minimal | Major | Prod
+# where Full conveys the most information, and Prod the least.
+ServerTokens Prod
+# Optionally add a line containing the server version and virtual host
+# name to server-generated pages (internal error documents, FTP directory
+# listings, mod_status and mod_info output etc., but not CGI generated
+# documents or custom error documents).
+# Set to "EMail" to also include a mailto: link to the ServerAdmin.
+# Set to one of: On | Off | EMail
+ServerSignature On
+# Aliases: Add here as many aliases as you need (with no limit). The format is
+# Alias fakename realname
+# Note that if you include a trailing / on fakename then the server will
+# require it to be present in the URL. So "/icons" isn't aliased in this
+# example, only "/icons/". If the fakename is slash-terminated, then the
+# realname must also be slash terminated, and if the fakename omits the
+# trailing slash, the realname must also omit it.
+# We include the /icons/ alias for FancyIndexed directory listings. If you
+# do not use FancyIndexing, you may comment this out.
+Alias /icons/ "%MG_WEB_APACHE%/icons/"
+<Directory "%MG_WEB_APACHE%/icons">
+ Options Indexes MultiViews
+ Order allow,deny
+ Allow from all
+</Directory>
+# This should be changed to the ServerRoot/manual/. The alias provides
+# the manual, even if you choose to move your DocumentRoot. You may comment
+# this out if you do not care for the documentation.
+AliasMatch ^/manual(?:/(?:de|en|es|fr|ja|ko|ru))?(/.*)?$ "%MG_WEB_APACHE%/manual$1"
+<Directory "%MG_WEB_APACHE%/manual">
+ Options Indexes
+ Order allow,deny
+ Allow from all
+ <Files *.html>
+ SetHandler type-map
+ </Files>
+ SetEnvIf Request_URI ^/manual/(de|en|es|fr|ja|ko|ru)/ prefer-language=$1
+ RedirectMatch 301 ^/manual(?:/(de|en|es|fr|ja|ko|ru)){2,}(/.*)?$ /manual/$1$2
+</Directory>
+# ScriptAlias: This controls which directories contain server scripts.
+# ScriptAliases are essentially the same as Aliases, except that
+# documents in the realname directory are treated as applications and
+# run by the server when requested rather than as documents sent to the client.
+# The same rules about trailing "/" apply to ScriptAlias directives as to
+# Alias.
+ScriptAlias /cgi-bin/ "%MG_WEB_APACHE%/cgi-bin/"
+# "%MG_WEB_APACHE%/cgi-bin" should be changed to whatever your ScriptAliased
+# CGI directory exists, if you have that configured.
+<Directory "%MG_WEB_APACHE%/cgi-bin">
+ Options None
+ Order allow,deny
+ Allow from all
+</Directory>
+# Redirect allows you to tell clients about documents which used to exist in
+# your server's namespace, but do not anymore. This allows you to tell the
+# clients where to look for the relocated document.
+# Example:
+# Redirect permanent /foo http://www.example.com/bar
+# Directives controlling the display of server-generated directory listings.
+# IndexOptions: Controls the appearance of server-generated directory
+# listings.
+IndexOptions FancyIndexing VersionSort
+# AddIcon* directives tell the server which icon to show for different
+# files or filename extensions. These are only displayed for
+# FancyIndexed directories.
+AddIconByEncoding (CMP,/icons/compressed.gif) x-compress x-gzip
+AddIconByType (TXT,/icons/text.gif) text/*
+AddIconByType (IMG,/icons/image2.gif) image/*
+AddIconByType (SND,/icons/sound2.gif) audio/*
+AddIconByType (VID,/icons/movie.gif) video/*
+AddIcon /icons/binary.gif .bin .exe
+AddIcon /icons/binhex.gif .hqx
+AddIcon /icons/tar.gif .tar
+AddIcon /icons/world2.gif .wrl .wrl.gz .vrml .vrm .iv
+AddIcon /icons/compressed.gif .Z .z .tgz .gz .zip
+AddIcon /icons/a.gif .ps .ai .eps
+AddIcon /icons/layout.gif .html .shtml .htm .pdf
+AddIcon /icons/text.gif .txt
+AddIcon /icons/c.gif .c
+AddIcon /icons/p.gif .pl .py
+AddIcon /icons/f.gif .for
+AddIcon /icons/dvi.gif .dvi
+AddIcon /icons/uuencoded.gif .uu
+AddIcon /icons/script.gif .conf .sh .shar .csh .ksh .tcl
+AddIcon /icons/tex.gif .tex
+AddIcon /icons/bomb.gif core
+AddIcon /icons/back.gif ..
+AddIcon /icons/hand.right.gif README
+AddIcon /icons/folder.gif ^^DIRECTORY^^
+AddIcon /icons/blank.gif ^^BLANKICON^^
+# DefaultIcon is which icon to show for files which do not have an icon
+# explicitly set.
+DefaultIcon /icons/unknown.gif
+# AddDescription allows you to place a short description after a file in
+# server-generated indexes. These are only displayed for FancyIndexed
+# directories.
+# Format: AddDescription "description" filename
+#AddDescription "GZIP compressed document" .gz
+#AddDescription "tar archive" .tar
+#AddDescription "GZIP compressed tar archive" .tgz
+# ReadmeName is the name of the README file the server will look for by
+# default, and append to directory listings.
+# HeaderName is the name of a file which should be prepended to
+# directory indexes.
+ReadmeName README.html
+HeaderName HEADER.html
+# IndexIgnore is a set of filenames which directory indexing should ignore
+# and not include in the listing. Shell-style wildcarding is permitted.
+IndexIgnore .??* *~ *# HEADER* README* RCS CVS *,v *,t
+# DefaultLanguage and AddLanguage allows you to specify the language of
+# a document. You can then use content negotiation to give a browser a
+# file in a language the user can understand.
+# Specify a default language. This means that all data
+# going out without a specific language tag (see below) will
+# be marked with this one. You probably do NOT want to set
+# this unless you are sure it is correct for all cases.
+# * It is generally better to not mark a page as
+# * being a certain language than marking it with the wrong
+# * language!
+# DefaultLanguage nl
+# Note 1: The suffix does not have to be the same as the language
+# keyword --- those with documents in Polish (whose net-standard
+# language code is pl) may wish to use "AddLanguage pl .po" to
+# avoid the ambiguity with the common suffix for perl scripts.
+# Note 2: The example entries below illustrate that in some cases
+# the two character 'Language' abbreviation is not identical to
+# the two character 'Country' code for its country,
+# E.g. 'Danmark/dk' versus 'Danish/da'.
+# Note 3: In the case of 'ltz' we violate the RFC by using a three char
+# specifier. There is 'work in progress' to fix this and get
+# the reference data for rfc1766 cleaned up.
+# Catalan (ca) - Croatian (hr) - Czech (cs) - Danish (da) - Dutch (nl)
+# English (en) - Esperanto (eo) - Estonian (et) - French (fr) - German (de)
+# Greek-Modern (el) - Hebrew (he) - Italian (it) - Japanese (ja)
+# Korean (ko) - Luxembourgeois* (ltz) - Norwegian Nynorsk (nn)
+# Norwegian (no) - Polish (pl) - Portugese (pt)
+# Brazilian Portuguese (pt-BR) - Russian (ru) - Swedish (sv)
+# Simplified Chinese (zh-CN) - Spanish (es) - Traditional Chinese (zh-TW)
+AddLanguage ca .ca
+AddLanguage cs .cz .cs
+AddLanguage da .dk
+AddLanguage de .de
+AddLanguage el .el
+AddLanguage en .en
+AddLanguage eo .eo
+AddLanguage es .es
+AddLanguage et .et
+AddLanguage fr .fr
+AddLanguage he .he
+AddLanguage hr .hr
+AddLanguage it .it
+AddLanguage ja .ja
+AddLanguage ko .ko
+AddLanguage ltz .ltz
+AddLanguage nl .nl
+AddLanguage nn .nn
+AddLanguage no .no
+AddLanguage pl .po
+AddLanguage pt .pt
+AddLanguage pt-BR .pt-br
+AddLanguage ru .ru
+AddLanguage sv .sv
+AddLanguage zh-CN .zh-cn
+AddLanguage zh-TW .zh-tw
+# LanguagePriority allows you to give precedence to some languages
+# in case of a tie during content negotiation.
+# Just list the languages in decreasing order of preference. We have
+# more or less alphabetized them here. You probably want to change this.
+LanguagePriority en ca cs da de el eo es et fr he hr it ja ko ltz nl nn no pl pt pt-BR ru sv zh-CN zh-TW
+# ForceLanguagePriority allows you to serve a result page rather than
+# MULTIPLE CHOICES (Prefer) [in case of a tie] or NOT ACCEPTABLE (Fallback)
+# [in case no accepted languages matched the available variants]
+ForceLanguagePriority Prefer Fallback
+# Commonly used filename extensions to character sets. You probably
+# want to avoid clashes with the language extensions, unless you
+# are good at carefully testing your setup after each change.
+# See http://www.iana.org/assignments/character-sets for the
+# official list of charset names and their respective RFCs.
+AddCharset ISO-8859-1 .iso8859-1 .latin1
+AddCharset ISO-8859-2 .iso8859-2 .latin2 .cen
+AddCharset ISO-8859-3 .iso8859-3 .latin3
+AddCharset ISO-8859-4 .iso8859-4 .latin4
+AddCharset ISO-8859-5 .iso8859-5 .latin5 .cyr .iso-ru
+AddCharset ISO-8859-6 .iso8859-6 .latin6 .arb
+AddCharset ISO-8859-7 .iso8859-7 .latin7 .grk
+AddCharset ISO-8859-8 .iso8859-8 .latin8 .heb
+AddCharset ISO-8859-9 .iso8859-9 .latin9 .trk
+AddCharset ISO-2022-JP .iso2022-jp .jis
+AddCharset ISO-2022-KR .iso2022-kr .kis
+AddCharset ISO-2022-CN .iso2022-cn .cis
+AddCharset Big5 .Big5 .big5
+# For russian, more than one charset is used (depends on client, mostly):
+AddCharset WINDOWS-1251 .cp-1251 .win-1251
+AddCharset CP866 .cp866
+AddCharset KOI8-r .koi8-r .koi8-ru
+AddCharset KOI8-ru .koi8-uk .ua
+AddCharset ISO-10646-UCS-2 .ucs2
+AddCharset ISO-10646-UCS-4 .ucs4
+AddCharset UTF-8 .utf8
+# The set below does not map to a specific (iso) standard
+# but works on a fairly wide range of browsers. Note that
+# capitalization actually matters (it should not, but it
+# does for some browsers).
+# for a list of sorts. But browsers support few.
+AddCharset GB2312 .gb2312 .gb
+AddCharset utf-7 .utf7
+AddCharset utf-8 .utf8
+AddCharset big5 .big5 .b5
+AddCharset EUC-TW .euc-tw
+AddCharset EUC-JP .euc-jp
+AddCharset EUC-KR .euc-kr
+AddCharset shift_jis .sjis
+# AddType allows you to add to or override the MIME configuration
+# file mime.types for specific file types.
+#AddType application/x-tar .tgz
+# AddEncoding allows you to have certain browsers (Mosaic/X 2.1+) uncompress
+# information on the fly. Note: Not all browsers support this.
+# Despite the name similarity, the following Add* directives have nothing
+# to do with the FancyIndexing customization directives above.
+#AddEncoding x-compress .Z
+#AddEncoding x-gzip .gz .tgz
+# If the AddEncoding directives above are commented-out, then you
+# probably should define those extensions to indicate media types:
+AddType application/x-compress .Z
+AddType application/x-gzip .gz .tgz
+# AddHandler allows you to map certain file extensions to "handlers":
+# actions unrelated to filetype. These can be either built into the server
+# or added with the Action directive (see below)
+# To use CGI scripts outside of ScriptAliased directories:
+# (You will also need to add "ExecCGI" to the "Options" directive.)
+#AddHandler cgi-script .cgi
+# For files that include their own HTTP headers:
+#AddHandler send-as-is asis
+# For server-parsed imagemap files:
+#AddHandler imap-file map
+# For type maps (negotiated resources):
+# (This is enabled by default to allow the Apache "It Worked" page
+# to be distributed in multiple languages.)
+AddHandler type-map var
+# Filters allow you to process content before it is sent to the client.
+# To parse .shtml files for server-side includes (SSI):
+# (You will also need to add "Includes" to the "Options" directive.)
+#AddType text/html .shtml
+#AddOutputFilter INCLUDES .shtml
+# Action lets you define media types that will execute a script whenever
+# a matching file is called. This eliminates the need for repeated URL
+# pathnames for oft-used CGI file processors.
+# Format: Action media/type /cgi-script/location
+# Format: Action handler-name /cgi-script/location
+# Customizable error responses come in three flavors:
+# 1) plain text 2) local redirects 3) external redirects
+# Some examples:
+#ErrorDocument 500 "The server made a boo boo."
+#ErrorDocument 404 /missing.html
+#ErrorDocument 404 "/cgi-bin/missing_handler.pl"
+#ErrorDocument 402 http://www.example.com/subscription_info.html
+# Putting this all together, we can internationalize error responses.
+# We use Alias to redirect any /error/HTTP_<error>.html.var response to
+# our collection of by-error message multi-language collections. We use
+# includes to substitute the appropriate text.
+# You can modify the messages' appearance without changing any of the
+# default HTTP_<error>.html.var files by adding the line:
+# Alias /error/include/ "/your/include/path/"
+# which allows you to create your own set of files by starting with the
+# @exp_errordir@/include/ files and copying them to /your/include/path/,
+# even on a per-VirtualHost basis. The default include files will display
+# your Apache version number and your ServerAdmin email address regardless
+# of the setting of ServerSignature.
+# The internationalized error documents require mod_alias, mod_include
+# and mod_negotiation. To activate them, uncomment the following 30 lines.
+# Alias /error/ "@exp_errordir@/"
+# <Directory "@exp_errordir@">
+# AllowOverride None
+# Options IncludesNoExec
+# AddOutputFilter Includes html
+# AddHandler type-map var
+# Order allow,deny
+# Allow from all
+# LanguagePriority en cs de es fr it ja ko nl pl pt-br ro sv tr
+# ForceLanguagePriority Prefer Fallback
+# </Directory>
+# ErrorDocument 400 /error/HTTP_BAD_REQUEST.html.var
+# ErrorDocument 401 /error/HTTP_UNAUTHORIZED.html.var
+# ErrorDocument 403 /error/HTTP_FORBIDDEN.html.var
+# ErrorDocument 404 /error/HTTP_NOT_FOUND.html.var
+# ErrorDocument 405 /error/HTTP_METHOD_NOT_ALLOWED.html.var
+# ErrorDocument 408 /error/HTTP_REQUEST_TIME_OUT.html.var
+# ErrorDocument 410 /error/HTTP_GONE.html.var
+# ErrorDocument 411 /error/HTTP_LENGTH_REQUIRED.html.var
+# ErrorDocument 412 /error/HTTP_PRECONDITION_FAILED.html.var
+# ErrorDocument 413 /error/HTTP_REQUEST_ENTITY_TOO_LARGE.html.var
+# ErrorDocument 414 /error/HTTP_REQUEST_URI_TOO_LARGE.html.var
+# ErrorDocument 415 /error/HTTP_UNSUPPORTED_MEDIA_TYPE.html.var
+# ErrorDocument 500 /error/HTTP_INTERNAL_SERVER_ERROR.html.var
+# ErrorDocument 501 /error/HTTP_NOT_IMPLEMENTED.html.var
+# ErrorDocument 502 /error/HTTP_BAD_GATEWAY.html.var
+# ErrorDocument 503 /error/HTTP_SERVICE_UNAVAILABLE.html.var
+# ErrorDocument 506 /error/HTTP_VARIANT_ALSO_VARIES.html.var
+# The following directives modify normal HTTP response behavior to
+# handle known problems with browser implementations.
+BrowserMatch "Mozilla/2" nokeepalive
+BrowserMatch "MSIE 4\.0b2;" nokeepalive downgrade-1.0 force-response-1.0
+BrowserMatch "RealPlayer 4\.0" force-response-1.0
+BrowserMatch "Java/1\.0" force-response-1.0
+BrowserMatch "JDK/1\.0" force-response-1.0
+# The following directive disables redirects on non-GET requests for
+# a directory that does not include the trailing slash. This fixes a
+# problem with Microsoft WebFolders which does not appropriately handle
+# redirects for folders with DAV methods.
+# Same deal with Apple's DAV filesystem and Gnome VFS support for DAV.
+BrowserMatch "Microsoft Data Access Internet Publishing Provider" redirect-carefully
+BrowserMatch "^WebDrive" redirect-carefully
+BrowserMatch "^WebDAVFS/1.[012]" redirect-carefully
+BrowserMatch "^gnome-vfs" redirect-carefully
+# Allow server status reports generated by mod_status,
+# with the URL of http://servername/server-status
+# Change the ".ads.autodesk.com" to match your domain to enable.
+#<Location /server-status>
+# SetHandler server-status
+# Order deny,allow
+# Deny from all
+# Allow from .ads.autodesk.com
+#</Location>
+# Allow remote server configuration reports, with the URL of
+# http://servername/server-info (requires that mod_info.c be loaded).
+#<Location /server-info>
+# SetHandler server-info
+# Order deny,allow
+# Deny from all
+#</Location>
+# Bring in additional module-specific configurations
+<IfModule mod_ssl.c>
+ Include conf/ssl.conf
+</IfModule>
+### Section 3: Virtual Hosts
+# VirtualHost: If you want to maintain multiple domains/hostnames on your
+# machine you can setup VirtualHost containers for them. Most configurations
+# use only name-based virtual hosts so the server doesn't need to worry about
+# IP addresses. This is indicated by the asterisks in the directives below.
+# Please see the documentation at
+# <URL:http://httpd.apache.org/docs-2.0/vhosts/>
+# for further details before you try to setup virtual hosts.
+# You may use the command line option '-S' to verify your virtual host
+# configuration.
+# Use name-based virtual hosting.
+#NameVirtualHost *:80
+# VirtualHost example:
+# Almost any Apache directive may go into a VirtualHost container.
+# The first VirtualHost section is used for requests without a known
+# server name.
+#<VirtualHost *:80>
+# ServerAdmin webmaster at dummy-host.example.com
+# DocumentRoot /www/docs/dummy-host.example.com
+# ServerName dummy-host.example.com
+# ErrorLog logs/dummy-host.example.com-error_log
+# CustomLog logs/dummy-host.example.com-access_log common
+#</VirtualHost>
+#Start PHP Config
+AddType application/x-httpd-php .php
+PHPIniDir "%MG_WEB_PHP%"
+#End PHP Config
+# MapViewer to MapViewerPhp aliases. Comment out Alias and AliasMatch for Java API.
+ScriptAlias /%MG_VIRTUAL_DIR%/mapagent/mapagent.fcgi "%MG_WEB_ROOT%mapagent/mapagent.fcgi"
+%MG_PHP_API%AliasMatch ^/%MG_VIRTUAL_DIR%/mapviewerajax/([^\?])(.*)$ "%MG_WEB_ROOT%mapviewerphp/$1$2"
+%MG_PHP_API%AliasMatch ^/%MG_VIRTUAL_DIR%/mapviewerajax/(.*)$ "%MG_WEB_ROOT%mapviewerphp/ajaxviewer.php$1"
+%MG_PHP_API%AliasMatch ^/%MG_VIRTUAL_DIR%/mapviewerdwf/([^\?])(.*)$ "%MG_WEB_ROOT%mapviewerphp/$1$2"
+%MG_PHP_API%AliasMatch ^/%MG_VIRTUAL_DIR%/mapviewerdwf/(.*)$ "%MG_WEB_ROOT%mapviewerphp/dwfviewer.php$1"
+# MapViewer to MapViewerJava Redirect. Uncomment Redirect for Java API.
+%MG_JAVA_API%Redirect /%MG_VIRTUAL_DIR%/mapviewerajax/ http://localhost:%MG_WEB_PORT%/%MG_VIRTUAL_DIR%/mapviewerjava/ajaxviewer.jsp
+%MG_JAVA_API%Redirect /%MG_VIRTUAL_DIR%/mapviewerdwf/ http://localhost:%MG_WEB_PORT%/%MG_VIRTUAL_DIR%/mapviewerjava/dwfviewer.jsp
+Alias /%MG_VIRTUAL_DIR% "%MG_WEB_ROOT%"
+<Directory "%MG_WEB_ROOT%">
+ AllowOverride All
+ Options All -Indexes
+ Order allow,deny
+ Allow from all
+# Restrict access via HTTP to webconfig.ini
+<Files webconfig.ini>
+ Order allow,deny
+ Deny from all
+</Files>
+# Apache MapAgent Module
+AddHandler mgmapagent_handler fcgi
+# Regular CGI MapAgent
+ AddHandler cgi-script exe
+ # Content compression
+ SetOutputFilter DEFLATE
+ AddType text/javascript js jgz
+ AddOutputFilterByType DEFLATE text/css
+ AddOutputFilterByType DEFLATE text/javascript
+ AddOutputFilterByType DEFLATE text/html
+ AddOutputFilterByType DEFLATE text/plain
+ AddOutputFilterByType DEFLATE text/xml
+ AddOutputFilterByType DEFLATE application/json
+ RewriteEngine on
+ RewriteRule .* - [E=REMOTE_USER:%{HTTP:Authorization},L]
+</Directory>
+#Disable the AcceptEx call
+Win32DisableAcceptEx
+%MG_INCLUDE_TOMCAT%
Added: trunk/Installer/Support/Web/x64/Php/php.ini
--- trunk/Installer/Support/Web/x64/Php/php.ini (rev 0)
+++ trunk/Installer/Support/Web/x64/Php/php.ini 2011-10-28 10:46:47 UTC (rev 6190)
@@ -0,0 +1,1263 @@
+[PHP]
+; About php.ini ;
+; This file controls many aspects of PHP's behavior. In order for PHP to
+; read it, it must be named 'php.ini'. PHP looks for it in the current
+; working directory, in the path designated by the environment variable
+; PHPRC, and in the path that was defined in compile time (in that order).
+; Under Windows, the compile-time path is the Windows directory. The
+; path in which the php.ini file is looked for can be overridden using
+; the -c argument in command line mode.
+; The syntax of the file is extremely simple. Whitespace and Lines
+; beginning with a semicolon are silently ignored (as you probably guessed).
+; Section headers (e.g. [Foo]) are also silently ignored, even though
+; they might mean something in the future.
+; Directives are specified using the following syntax:
+; directive = value
+; Directive names are *case sensitive* - foo=bar is different from FOO=bar.
+; The value can be a string, a number, a PHP constant (e.g. E_ALL or M_PI), one
+; of the INI constants (On, Off, True, False, Yes, No and None) or an expression
+; (e.g. E_ALL & ~E_NOTICE), or a quoted string ("foo").
+; Expressions in the INI file are limited to bitwise operators and parentheses:
+; | bitwise OR
+; & bitwise AND
+; ~ bitwise NOT
+; ! boolean NOT
+; Boolean flags can be turned on using the values 1, On, True or Yes.
+; They can be turned off using the values 0, Off, False or No.
+; An empty string can be denoted by simply not writing anything after the equal
+; sign, or by using the None keyword:
+; foo = ; sets foo to an empty string
+; foo = none ; sets foo to an empty string
+; foo = "none" ; sets foo to the string 'none'
+; If you use constants in your value, and these constants belong to a
+; dynamically loaded extension (either a PHP extension or a Zend extension),
+; you may only use these constants *after* the line that loads the extension.
+; About this file ;
+; This is the recommended, PHP 5-style version of the php.ini-dist file. It
+; sets some non standard settings, that make PHP more efficient, more secure,
+; and encourage cleaner coding.
+; The price is that with these settings, PHP may be incompatible with some
+; applications, and sometimes, more difficult to develop with. Using this
+; file is warmly recommended for production sites. As all of the changes from
+; the standard settings are thoroughly documented, you can go over each one,
+; and decide whether you want to use it or not.
+; For general information about the php.ini file, please consult the php.ini-dist
+; file, included in your PHP distribution.
+; This file is different from the php.ini-dist file in the fact that it features
+; different values for several directives, in order to improve performance, while
+; possibly breaking compatibility with the standard out-of-the-box behavior of
+; PHP. Please make sure you read what's different, and modify your scripts
+; accordingly, if you decide to use this file instead.
+; - register_globals = Off [Security, Performance]
+; Global variables are no longer registered for input data (POST, GET, cookies,
+; environment and other server variables). Instead of using $foo, you must use
+; you can use $_REQUEST["foo"] (includes any variable that arrives through the
+; request, namely, POST, GET and cookie variables), or use one of the specific
+; $_GET["foo"], $_POST["foo"], $_COOKIE["foo"] or $_FILES["foo"], depending
+; on where the input originates. Also, you can look at the
+; import_request_variables() function.
+; Note that register_globals is going to be depracated (i.e., turned off by
+; default) in the next version of PHP, because it often leads to security bugs.
+; Read http://php.net/manual/en/security.registerglobals.php for further
+; information.
+; - register_long_arrays = Off [Performance]
+; Disables registration of the older (and deprecated) long predefined array
+; variables ($HTTP_*_VARS). Instead, use the superglobals that were
+; introduced in PHP 4.1.0
+; - display_errors = Off [Security]
+; With this directive set to off, errors that occur during the execution of
+; scripts will no longer be displayed as a part of the script output, and thus,
+; will no longer be exposed to remote users. With some errors, the error message
+; content may expose information about your script, web server, or database
+; server that may be exploitable for hacking. Production sites should have this
+; directive set to off.
+; - log_errors = On [Security]
+; This directive complements the above one. Any errors that occur during the
+; execution of your script will be logged (typically, to your server's error log,
+; but can be configured in several ways). Along with setting display_errors to off,
+; this setup gives you the ability to fully understand what may have gone wrong,
+; without exposing any sensitive information to remote users.
+; - output_buffering = 4096 [Performance]
+; Set a 4KB output buffer. Enabling output buffering typically results in less
+; writes, and sometimes less packets sent on the wire, which can often lead to
+; better performance. The gain this directive actually yields greatly depends
+; on which Web server you're working with, and what kind of scripts you're using.
+; - register_argc_argv = Off [Performance]
+; Disables registration of the somewhat redundant $argv and $argc global
+; variables.
+; - magic_quotes_gpc = Off [Performance]
+; Input data is no longer escaped with slashes so that it can be sent into
+; SQL databases without further manipulation. Instead, you should use the
+; function addslashes() on each input element you wish to send to a database.
+; - variables_order = "GPCS" [Performance]
+; The environment variables are not hashed into the $_ENV. To access
+; environment variables, you can use getenv() instead.
+; - error_reporting = E_ALL [Code Cleanliness, Security(?)]
+; By default, PHP surpresses errors of type E_NOTICE. These error messages
+; are emitted for non-critical errors, but that could be a symptom of a bigger
+; problem. Most notably, this will cause error messages about the use
+; of uninitialized variables to be displayed.
+; - allow_call_time_pass_reference = Off [Code cleanliness]
+; It's not possible to decide to force a variable to be passed by reference
+; when calling a function. The PHP 4 style to do this is by making the
+; function require the relevant argument by reference.
+; Language Options ;
+; Enable the PHP scripting language engine under Apache.
+engine = On
+; Enable compatibility mode with Zend Engine 1 (PHP 4.x)
+zend.ze1_compatibility_mode = Off
+; Allow the <? tag. Otherwise, only <?php and <script> tags are recognized.
+; NOTE: Using short tags should be avoided when developing applications or
+; libraries that are meant for redistribution, or deployment on PHP
+; servers which are not under your control, because short tags may not
+; be supported on the target server. For portable, redistributable code,
+; be sure not to use short tags.
+short_open_tag = On
+; Allow ASP-style <% %> tags.
+asp_tags = Off
+; The number of significant digits displayed in floating point numbers.
+precision = 14
+; Enforce year 2000 compliance (will cause problems with non-compliant browsers)
+y2k_compliance = On
+; Output buffering allows you to send header lines (including cookies) even
+; after you send body content, at the price of slowing PHP's output layer a
+; bit. You can enable output buffering during runtime by calling the output
+; buffering functions. You can also enable output buffering for all files by
+; setting this directive to On. If you wish to limit the size of the buffer
+; to a certain size - you can use a maximum number of bytes instead of 'On', as
+; a value for this directive (e.g., output_buffering=4096).
+output_buffering = 4096
+; You can redirect all of the output of your scripts to a function. For
+; example, if you set output_handler to "mb_output_handler", character
+; encoding will be transparently converted to the specified encoding.
+; Setting any output handler automatically turns on output buffering.
+; Note: People who wrote portable scripts should not depend on this ini
+; directive. Instead, explicitly set the output handler using ob_start().
+; Using this ini directive may cause problems unless you know what script
+; is doing.
+; Note: You cannot use both "mb_output_handler" with "ob_iconv_handler"
+; and you cannot use both "ob_gzhandler" and "zlib.output_compression".
+; Note: output_handler must be empty if this is set 'On' !!!!
+; Instead you must use zlib.output_handler.
+;output_handler =
+; Transparent output compression using the zlib library
+; Valid values for this option are 'off', 'on', or a specific buffer size
+; to be used for compression (default is 4KB)
+; Note: Resulting chunk size may vary due to nature of compression. PHP
+; outputs chunks that are few hundreds bytes each as a result of
+; compression. If you prefer a larger chunk size for better
+; performance, enable output_buffering in addition.
+; Note: You need to use zlib.output_handler instead of the standard
+; output_handler, or otherwise the output will be corrupted.
+zlib.output_compression = Off
+; You cannot specify additional output handlers if zlib.output_compression
+; is activated here. This setting does the same as output_handler but in
+; a different order.
+;zlib.output_handler =
+; Implicit flush tells PHP to tell the output layer to flush itself
+; automatically after every output block. This is equivalent to calling the
+; PHP function flush() after each and every call to print() or echo() and each
+; and every HTML block. Turning this option on has serious performance
+; implications and is generally recommended for debugging purposes only.
+implicit_flush = Off
+; The unserialize callback function will be called (with the undefined class'
+; name as parameter), if the unserializer finds an undefined class
+; which should be instanciated.
+; A warning appears if the specified function is not defined, or if the
+; function doesn't include/implement the missing class.
+; So only set this entry, if you really want to implement such a
+; callback-function.
+unserialize_callback_func=
+; When floats & doubles are serialized store serialize_precision significant
+; digits after the floating point. The default value ensures that when floats
+; are decoded with unserialize, the data will remain the same.
+serialize_precision = 100
+; Whether to enable the ability to force arguments to be passed by reference
+; at function call time. This method is deprecated and is likely to be
+; unsupported in future versions of PHP/Zend. The encouraged method of
+; specifying which arguments should be passed by reference is in the function
+; declaration. You're encouraged to try and turn this option Off and make
+; sure your scripts work properly with it in order to ensure they will work
+; with future versions of the language (you will receive a warning each time
+; you use this feature, and the argument will be passed by value instead of by
+; reference).
+allow_call_time_pass_reference = Off
+; Safe Mode
+safe_mode = Off
+; By default, Safe Mode does a UID compare check when
+; opening files. If you want to relax this to a GID compare,
+; then turn on safe_mode_gid.
+safe_mode_gid = Off
+; When safe_mode is on, UID/GID checks are bypassed when
+; including files from this directory and its subdirectories.
+; (directory must also be in include_path or full path must
+; be used when including)
+safe_mode_include_dir =
+; When safe_mode is on, only executables located in the safe_mode_exec_dir
+; will be allowed to be executed via the exec family of functions.
+safe_mode_exec_dir =
+; Setting certain environment variables may be a potential security breach.
+; This directive contains a comma-delimited list of prefixes. In Safe Mode,
+; the user may only alter environment variables whose names begin with the
+; prefixes supplied here. By default, users will only be able to set
+; environment variables that begin with PHP_ (e.g. PHP_FOO=BAR).
+; Note: If this directive is empty, PHP will let the user modify ANY
+; environment variable!
+safe_mode_allowed_env_vars = PHP_
+; This directive contains a comma-delimited list of environment variables that
+; the end user won't be able to change using putenv(). These variables will be
+; protected even if safe_mode_allowed_env_vars is set to allow to change them.
+safe_mode_protected_env_vars = LD_LIBRARY_PATH
+; open_basedir, if set, limits all file operations to the defined directory
+; and below. This directive makes most sense if used in a per-directory
+; or per-virtualhost web server configuration file. This directive is
+; *NOT* affected by whether Safe Mode is turned On or Off.
+;open_basedir =
+; This directive allows you to disable certain functions for security reasons.
+; It receives a comma-delimited list of function names. This directive is
+disable_functions =
+; This directive allows you to disable certain classes for security reasons.
+; It receives a comma-delimited list of class names. This directive is
+disable_classes =
+; Colors for Syntax Highlighting mode. Anything that's acceptable in
+; <span style="color: ???????"> would work.
+;highlight.string = #DD0000
+;highlight.comment = #FF9900
+;highlight.keyword = #007700
+;highlight.bg = #FFFFFF
+;highlight.default = #0000BB
+;highlight.html = #000000
+; Misc
+; Decides whether PHP may expose the fact that it is installed on the server
+; (e.g. by adding its signature to the Web server header). It is no security
+; threat in any way, but it makes it possible to determine whether you use PHP
+; on your server or not.
+expose_php = Off
+; Resource Limits ;
+max_execution_time = 180 ; Maximum execution time of each script, in seconds
+max_input_time = 60 ; Maximum amount of time each script may spend parsing request data
+memory_limit = 256M ; Maximum amount of memory a script may consume
+; Error handling and logging ;
+; error_reporting is a bit-field. Or each number up to get desired error
+; reporting level
+; E_ALL - All errors and warnings (doesn't include E_STRICT)
+; E_ERROR - fatal run-time errors
+; E_WARNING - run-time warnings (non-fatal errors)
+; E_PARSE - compile-time parse errors
+; E_NOTICE - run-time notices (these are warnings which often result
+; from a bug in your code, but it's possible that it was
+; intentional (e.g., using an uninitialized variable and
+; relying on the fact it's automatically initialized to an
+; empty string)
+; E_STRICT - run-time notices, enable to have PHP suggest changes
+; to your code which will ensure the best interoperability
+; and forward compatibility of your code
+; E_CORE_ERROR - fatal errors that occur during PHP's initial startup
+; E_CORE_WARNING - warnings (non-fatal errors) that occur during PHP's
+; initial startup
+; E_COMPILE_ERROR - fatal compile-time errors
+; E_COMPILE_WARNING - compile-time warnings (non-fatal errors)
+; E_USER_ERROR - user-generated error message
+; E_USER_WARNING - user-generated warning message
+; E_USER_NOTICE - user-generated notice message
+; Examples:
+; - Show all errors, except for notices and coding standards warnings
+;error_reporting = E_ALL & ~E_NOTICE & ~E_STRICT
+; - Show only errors
+;error_reporting = E_COMPILE_ERROR|E_ERROR|E_CORE_ERROR
+error_reporting = E_ALL
+; Print out errors (as a part of the output). For production web sites,
+; you're strongly encouraged to turn this feature off, and use error logging
+; instead (see below). Keeping display_errors enabled on a production web site
+; may reveal security information to end users, such as file paths on your Web
+; server, your database schema or other information.
+display_errors = Off
+; Even when display_errors is on, errors that occur during PHP's startup
+; sequence are not displayed. It's strongly recommended to keep
+; display_startup_errors off, except for when debugging.
+display_startup_errors = Off
+; Log errors into a log file (server-specific log, stderr, or error_log (below))
+; As stated above, you're strongly advised to use error logging in place of
+; error displaying on production web sites.
+log_errors = On
+; Set maximum length of log_errors. In error_log information about the source is
+; added. The default is 1024 and 0 allows to not apply any maximum length at all.
+log_errors_max_len = 1024
+; Do not log repeated messages. Repeated errors must occur in same file on same
+; line until ignore_repeated_source is set true.
+ignore_repeated_errors = Off
+; Ignore source of message when ignoring repeated messages. When this setting
+; is On you will not log errors with repeated messages from different files or
+; sourcelines.
+ignore_repeated_source = Off
+; If this parameter is set to Off, then memory leaks will not be shown (on
+; stdout or in the log). This has only effect in a debug compile, and if
+; error reporting includes E_WARNING in the allowed list
+report_memleaks = On
+; Store the last error/warning message in $php_errormsg (boolean).
+track_errors = Off
+; Disable the inclusion of HTML tags in error messages.
+; Note: Never use this feature for production boxes.
+;html_errors = Off
+; If html_errors is set On PHP produces clickable error messages that direct
+; to a page describing the error or function causing the error in detail.
+; You can download a copy of the PHP manual from http://www.php.net/docs.php
+; and change docref_root to the base URL of your local copy including the
+; leading '/'. You must also specify the file extension being used including
+; the dot.
+;docref_root = "/phpmanual/"
+;docref_ext = .html
+; String to output before an error message.
+;error_prepend_string = "<font color=ff0000>"
+; String to output after an error message.
+;error_append_string = "</font>"
+; Log errors to specified file.
+;error_log = filename
+; Log errors to syslog (Event Log on NT, not valid in Windows 95).
+;error_log = syslog
+; Data Handling ;
+; Note - track_vars is ALWAYS enabled as of PHP 4.0.3
+; The separator used in PHP generated URLs to separate arguments.
+; Default is "&".
+;arg_separator.output = "&"
+; List of separator(s) used by PHP to parse input URLs into variables.
+; Default is "&".
+; NOTE: Every character in this directive is considered as separator!
+;arg_separator.input = ";&"
+; This directive describes the order in which PHP registers GET, POST, Cookie,
+; Environment and Built-in variables (G, P, C, E & S respectively, often
+; referred to as EGPCS or GPC). Registration is done from left to right, newer
+; values override older values.
+variables_order = "GPCS"
+; Whether or not to register the EGPCS variables as global variables. You may
+; want to turn this off if you don't want to clutter your scripts' global scope
+; with user data. This makes most sense when coupled with track_vars - in which
+; case you can access all of the GPC variables through the $HTTP_*_VARS[],
+; variables.
+; You should do your best to write your scripts so that they do not require
+; register_globals to be on; Using form variables as globals can easily lead
+; to possible security problems, if the code is not very well thought of.
+register_globals = Off
+; Whether or not to register the old-style input arrays, HTTP_GET_VARS
+; and friends. If you're not using them, it's recommended to turn them off,
+; for performance reasons.
+register_long_arrays = Off
+; This directive tells PHP whether to declare the argv&argc variables (that
+; would contain the GET information). If you don't use these variables, you
+; should turn it off for increased performance.
+register_argc_argv = Off
+; When enabled, the SERVER and ENV variables are created when they're first
+; used (Just In Time) instead of when the script starts. If these variables
+; are not used within a script, having this directive on will result in a
+; performance gain. The PHP directives register_globals, register_long_arrays,
+; and register_argc_argv must be disabled for this directive to have any affect.
+auto_globals_jit = On
+; Maximum size of POST data that PHP will accept.
+post_max_size = 64M
+; Magic quotes
+; Magic quotes for incoming GET/POST/Cookie data.
+magic_quotes_gpc = Off
+; Magic quotes for runtime-generated data, e.g. data from SQL, from exec(), etc.
+magic_quotes_runtime = Off
+; Use Sybase-style magic quotes (escape ' with '' instead of \').
+magic_quotes_sybase = Off
+; Automatically add files before or after any PHP document.
+auto_prepend_file =
+auto_append_file =
+; As of 4.0b4, PHP always outputs a character encoding by default in
+; the Content-type: header. To disable sending of the charset, simply
+; set it to be empty.
+; PHP's built-in default is text/html
+default_mimetype = "text/html"
+;default_charset = "iso-8859-1"
+; Always populate the $HTTP_RAW_POST_DATA variable.
+;always_populate_raw_post_data = On
+; Paths and Directories ;
+; UNIX: "/path1:/path2"
+;include_path = ".:/php/includes"
+; Windows: "\path1;\path2"
+;include_path = ".;c:\php\includes"
+; The root of the PHP pages, used only if nonempty.
+; if PHP was not compiled with FORCE_REDIRECT, you SHOULD set doc_root
+; if you are running php as a CGI under any web server (other than IIS)
+; see documentation for security issues. The alternate is to use the
+; cgi.force_redirect configuration below
+doc_root =
+; The directory under which PHP opens the script using /~username used only
+; if nonempty.
+user_dir =
+; Directory in which the loadable extensions (modules) reside.
+extension_dir = "%MG_WEB_PHP%ext"
+; Whether or not to enable the dl() function. The dl() function does NOT work
+; properly in multithreaded servers, such as IIS or Zeus, and is automatically
+; disabled on them.
+enable_dl = On
+; cgi.force_redirect is necessary to provide security running PHP as a CGI under
+; most web servers. Left undefined, PHP turns this on by default. You can
+; turn it off here AT YOUR OWN RISK
+; **You CAN safely turn this off for IIS, in fact, you MUST.**
+; cgi.force_redirect = 1
+; if cgi.nph is enabled it will force cgi to always sent Status: 200 with
+; every request.
+; cgi.nph = 1
+; if cgi.force_redirect is turned on, and you are not running under Apache or Netscape
+; (iPlanet) web servers, you MAY need to set an environment variable name that PHP
+; will look for to know it is OK to continue execution. Setting this variable MAY
+; cause security issues, KNOW WHAT YOU ARE DOING FIRST.
+; cgi.redirect_status_env = ;
+; FastCGI under IIS (on WINNT based OS) supports the ability to impersonate
+; security tokens of the calling client. This allows IIS to define the
+; security context that the request runs under. mod_fastcgi under Apache
+; does not currently support this feature (03/17/2002)
+; Set to 1 if running under IIS. Default is zero.
+; fastcgi.impersonate = 1;
+; Disable logging through FastCGI connection
+; fastcgi.log = 0
+; cgi.rfc2616_headers configuration option tells PHP what type of headers to
+; use when sending HTTP response code. If it's set 0 PHP sends Status: header that
+; is supported by Apache. When this option is set to 1 PHP will send
+; RFC2616 compliant header.
+; Default is zero.
+;cgi.rfc2616_headers = 0
+; File Uploads ;
+; Whether to allow HTTP file uploads.
+file_uploads = On
+; Temporary directory for HTTP uploaded files (will use system default if not
+; specified).
+;upload_tmp_dir =
+; Maximum allowed size for uploaded files.
+upload_max_filesize = 2M
+; Fopen wrappers ;
+; Whether to allow the treatment of URLs (like http:// or ftp://) as files.
+allow_url_fopen = On
+; Define the anonymous ftp password (your email address)
+;from="john at doe.com"
+; Define the User-Agent string
+; user_agent="PHP"
+; Default timeout for socket based streams (seconds)
+default_socket_timeout = 60
+; If your scripts have to deal with files from Macintosh systems,
+; or you are running on a Mac and need to deal with files from
+; unix or win32 systems, setting this flag will cause PHP to
+; automatically detect the EOL character in those files so that
+; fgets() and file() will work regardless of the source of the file.
+; auto_detect_line_endings = Off
+; Dynamic Extensions ;
+; If you wish to have an extension loaded automatically, use the following
+; syntax:
+; extension=modulename.extension
+; For example, on Windows:
+; extension=msql.dll
+; ... or under UNIX:
+; extension=msql.so
+; Note that it should be the name of the module only; no directory information
+; needs to go here. Specify the location of the extension with the
+; extension_dir directive above.
+;Windows Extensions
+;Note that ODBC support is built in, so no dll is needed for it.
+extension=php_mbstring.dll
+;extension=php_bz2.dll
+;extension=php_cpdf.dll
+;extension=php_curl.dll
+;extension=php_dba.dll
+;extension=php_dbase.dll
+;extension=php_dbx.dll
+;extension=php_exif.dll
+;extension=php_fdf.dll
+;extension=php_filepro.dll
+extension=php_gd2.dll
+;extension=php_gettext.dll
+;extension=php_ifx.dll
+;extension=php_iisfunc.dll
+;extension=php_imap.dll
+;extension=php_interbase.dll
+;extension=php_java.dll
+;extension=php_ldap.dll
+;extension=php_mcrypt.dll
+;extension=php_mhash.dll
+;extension=php_mime_magic.dll
+;extension=php_ming.dll
+;extension=php_mssql.dll
+;extension=php_msql.dll
+;extension=php_mysql.dll
+;extension=php_oci8.dll
+;extension=php_openssl.dll
+;extension=php_oracle.dll
+;extension=php_pdf.dll
+;extension=php_pgsql.dll
+;extension=php_shmop.dll
+;extension=php_snmp.dll
+;extension=php_sockets.dll
+;extension=php_sybase_ct.dll
+;extension=php_tidy.dll
+;extension=php_w32api.dll
+;extension=php_xmlrpc.dll
+extension=php_xsl.dll
+;extension=php_yaz.dll
+;extension=php_zip.dll
+extension=php_MapGuideApiEnvConfig.dll
+extension=php_MapGuideApi.dll
+; Module Settings ;
+[Syslog]
+; Whether or not to define the various syslog variables (e.g. $LOG_PID,
+; $LOG_CRON, etc.). Turning it off is a good idea performance-wise. In
+; runtime, you can define these variables by calling define_syslog_variables().
+define_syslog_variables = Off
+[mail function]
+; For Win32 only.
+SMTP = localhost
+smtp_port = 25
+; For Win32 only.
+;sendmail_from = me at example.com
+; For Unix only. You may supply arguments as well (default: "sendmail -t -i").
+;sendmail_path =
+; Force the addition of the specified parameters to be passed as extra parameters
+; to the sendmail binary. These parameters will always replace the value of
+; the 5th parameter to mail(), even in safe mode.
+;mail.force_extra_parameters =
+[SQL]
+sql.safe_mode = Off
+[ODBC]
+;odbc.default_db = Not yet implemented
+;odbc.default_user = Not yet implemented
+;odbc.default_pw = Not yet implemented
+; Allow or prevent persistent links.
+odbc.allow_persistent = On
+; Check that a connection is still valid before reuse.
+odbc.check_persistent = On
+; Maximum number of persistent links. -1 means no limit.
+odbc.max_persistent = -1
+; Maximum number of links (persistent + non-persistent). -1 means no limit.
+odbc.max_links = -1
+; Handling of LONG fields. Returns number of bytes to variables. 0 means
+; passthru.
+odbc.defaultlrl = 4096
+; Handling of binary data. 0 means passthru, 1 return as is, 2 convert to char.
+; See the documentation on odbc_binmode and odbc_longreadlen for an explanation
+; of uodbc.defaultlrl and uodbc.defaultbinmode
+odbc.defaultbinmode = 1
+[MySQL]
+mysql.allow_persistent = On
+mysql.max_persistent = -1
+mysql.max_links = -1
+; Default port number for mysql_connect(). If unset, mysql_connect() will use
+; the $MYSQL_TCP_PORT or the mysql-tcp entry in /etc/services or the
+; compile-time value defined MYSQL_PORT (in that order). Win32 will only look
+; at MYSQL_PORT.
+mysql.default_port =
+; Default socket name for local MySQL connects. If empty, uses the built-in
+; MySQL defaults.
+mysql.default_socket =
+; Default host for mysql_connect() (doesn't apply in safe mode).
+mysql.default_host =
+; Default user for mysql_connect() (doesn't apply in safe mode).
+mysql.default_user =
+; Default password for mysql_connect() (doesn't apply in safe mode).
+; Note that this is generally a *bad* idea to store passwords in this file.
+; *Any* user with PHP access can run 'echo get_cfg_var("mysql.default_password")
+; and reveal this password! And of course, any users with read access to this
+; file will be able to reveal the password as well.
+mysql.default_password =
+; Maximum time (in secondes) for connect timeout. -1 means no limit
+mysql.connect_timeout = 60
+; Trace mode. When trace_mode is active (=On), warnings for table/index scans and
+; SQL-Errors will be displayed.
+mysql.trace_mode = Off
+[MySQLI]
+; Maximum number of links. -1 means no limit.
+mysqli.max_links = -1
+; Default port number for mysqli_connect(). If unset, mysqli_connect() will use
+; at MYSQL_PORT.
+mysqli.default_port = 3306
+; MySQL defaults.
+mysqli.default_socket =
+mysqli.default_host =
+mysqli.default_user =
+; Default password for mysqli_connect() (doesn't apply in safe mode).
+; *Any* user with PHP access can run 'echo get_cfg_var("mysqli.default_pw")
+mysqli.default_pw =
+; Allow or prevent reconnect
+mysqli.reconnect = Off
+[mSQL]
+msql.allow_persistent = On
+msql.max_persistent = -1
+; Maximum number of links (persistent+non persistent). -1 means no limit.
+msql.max_links = -1
+[PostgresSQL]
+pgsql.allow_persistent = On
+; Detect broken persistent links always with pg_pconnect().
+; Auto reset feature requires a little overheads.
+pgsql.auto_reset_persistent = Off
+pgsql.max_persistent = -1
+pgsql.max_links = -1
+; Ignore PostgreSQL backends Notice message or not.
+; Notice message logging require a little overheads.
+pgsql.ignore_notice = 0
+; Log PostgreSQL backends Noitce message or not.
+; Unless pgsql.ignore_notice=0, module cannot log notice message.
+pgsql.log_notice = 0
+[Sybase]
+sybase.allow_persistent = On
+sybase.max_persistent = -1
+sybase.max_links = -1
+;sybase.interface_file = "/usr/sybase/interfaces"
+; Minimum error severity to display.
+sybase.min_error_severity = 10
+; Minimum message severity to display.
+sybase.min_message_severity = 10
+; Compatability mode with old versions of PHP 3.0.
+; If on, this will cause PHP to automatically assign types to results according
+; to their Sybase type, instead of treating them all as strings. This
+; compatability mode will probably not stay around forever, so try applying
+; whatever necessary changes to your code, and turn it off.
+sybase.compatability_mode = Off
+[Sybase-CT]
+sybct.allow_persistent = On
+sybct.max_persistent = -1
+sybct.max_links = -1
+; Minimum server message severity to display.
+sybct.min_server_severity = 10
+; Minimum client message severity to display.
+sybct.min_client_severity = 10
+[dbx]
+; returned column names can be converted for compatibility reasons
+; possible values for dbx.colnames_case are
+; "unchanged" (default, if not set)
+; "lowercase"
+; "uppercase"
+; the recommended default is either upper- or lowercase, but
+; unchanged is currently set for backwards compatibility
+dbx.colnames_case = "lowercase"
+[bcmath]
+; Number of decimal digits for all bcmath functions.
+bcmath.scale = 0
+[browscap]
+;browscap = extra/browscap.ini
+[Informix]
+; Default host for ifx_connect() (doesn't apply in safe mode).
+ifx.default_host =
+; Default user for ifx_connect() (doesn't apply in safe mode).
+ifx.default_user =
+; Default password for ifx_connect() (doesn't apply in safe mode).
+ifx.default_password =
+ifx.allow_persistent = On
+ifx.max_persistent = -1
+ifx.max_links = -1
+; If on, select statements return the contents of a text blob instead of its id.
+ifx.textasvarchar = 0
+; If on, select statements return the contents of a byte blob instead of its id.
+ifx.byteasvarchar = 0
+; Trailing blanks are stripped from fixed-length char columns. May help the
+; life of Informix SE users.
+ifx.charasvarchar = 0
+; If on, the contents of text and byte blobs are dumped to a file instead of
+; keeping them in memory.
+ifx.blobinfile = 0
+; NULL's are returned as empty strings, unless this is set to 1. In that case,
+; NULL's are returned as string 'NULL'.
+ifx.nullformat = 0
+[Session]
+; Handler used to store/retrieve data.
+session.save_handler = files
+; Argument passed to save_handler. In the case of files, this is the path
+; where data files are stored. Note: Windows users have to change this
+; variable in order to use PHP's session functions.
+; As of PHP 4.0.1, you can define the path as:
+; session.save_path = "N;/path"
+; where N is an integer. Instead of storing all the session files in
+; /path, what this will do is use subdirectories N-levels deep, and
+; store the session data in those directories. This is useful if you
+; or your OS have problems with lots of files in one directory, and is
+; a more efficient layout for servers that handle lots of sessions.
+; NOTE 1: PHP will not create this directory structure automatically.
+; You can use the script in the ext/session dir for that purpose.
+; NOTE 2: See the section on garbage collection below if you choose to
+; use subdirectories for session storage
+; The file storage module creates files using mode 600 by default.
+; You can change that by using
+; session.save_path = "N;MODE;/path"
+; where MODE is the octal representation of the mode. Note that this
+; does not overwrite the process's umask.
+;session.save_path = "/tmp"
+session.save_path = "%MG_WEB_TEMP%"
+; Whether to use cookies.
+session.use_cookies = 1
+; This option enables administrators to make their users invulnerable to
+; attacks which involve passing session ids in URLs; defaults to 0.
+; session.use_only_cookies = 1
+; Name of the session (used as cookie name).
+session.name = PHPSESSID
+; Initialize session on request startup.
+session.auto_start = 0
+; Lifetime in seconds of cookie or, if 0, until browser is restarted.
+session.cookie_lifetime = 0
+; The path for which the cookie is valid.
+session.cookie_path = /
+; The domain for which the cookie is valid.
+session.cookie_domain =
+; Handler used to serialize data. php is the standard serializer of PHP.
+session.serialize_handler = php
+; Define the probability that the 'garbage collection' process is started
+; on every session initialization.
+; The probability is calculated by using gc_probability/gc_divisor,
+; e.g. 1/100 means there is a 1% chance that the GC process starts
+; on each request.
+session.gc_probability = 1
+session.gc_divisor = 1000
+; After this number of seconds, stored data will be seen as 'garbage' and
+; cleaned up by the garbage collection process.
+session.gc_maxlifetime = 1440
+; NOTE: If you are using the subdirectory option for storing session files
+; (see session.save_path above), then garbage collection does *not*
+; happen automatically. You will need to do your own garbage
+; collection through a shell script, cron entry, or some other method.
+; For example, the following script would is the equivalent of
+; setting session.gc_maxlifetime to 1440 (1440 seconds = 24 minutes):
+; cd /path/to/sessions; find -cmin +24 | xargs rm
+; PHP 4.2 and less have an undocumented feature/bug that allows you to
+; to initialize a session variable in the global scope, albeit register_globals
+; is disabled. PHP 4.3 and later will warn you, if this feature is used.
+; You can disable the feature and the warning separately. At this time,
+; the warning is only displayed, if bug_compat_42 is enabled.
+session.bug_compat_42 = 0
+session.bug_compat_warn = 1
+; Check HTTP Referer to invalidate externally stored URLs containing ids.
+; HTTP_REFERER has to contain this substring for the session to be
+; considered as valid.
+session.referer_check =
+; How many bytes to read from the file.
+session.entropy_length = 0
+; Specified here to create the session id.
+session.entropy_file =
+;session.entropy_length = 16
+;session.entropy_file = /dev/urandom
+; Set to {nocache,private,public,} to determine HTTP caching aspects
+; or leave this empty to avoid sending anti-caching headers.
+session.cache_limiter = nocache
+; Document expires after n minutes.
+session.cache_expire = 180
+; trans sid support is disabled by default.
+; Use of trans sid may risk your users security.
+; Use this option with caution.
+; - User may send URL contains active session ID
+; to other person via. email/irc/etc.
+; - URL that contains active session ID may be stored
+; in publically accessible computer.
+; - User may access your site with the same session ID
+; always using URL stored in browser's history or bookmarks.
+session.use_trans_sid = 0
+; Select a hash function
+; 0: MD5 (128 bits)
+; 1: SHA-1 (160 bits)
+session.hash_function = 0
+; Define how many bits are stored in each character when converting
+; the binary hash data to something readable.
+; 4 bits: 0-9, a-f
+; 5 bits: 0-9, a-v
+; 6 bits: 0-9, a-z, A-Z, "-", ","
+session.hash_bits_per_character = 5
+; The URL rewriter will look for URLs in a defined set of HTML tags.
+; form/fieldset are special; if you include them here, the rewriter will
+; add a hidden <input> field with the info which is otherwise appended
+; to URLs. If you want XHTML conformity, remove the form entry.
+; Note that all valid entries require a "=", even if no value follows.
+url_rewriter.tags = "a=href,area=href,frame=src,input=src,form=fakeentry"
+[MSSQL]
+mssql.allow_persistent = On
+mssql.max_persistent = -1
+mssql.max_links = -1
+mssql.min_error_severity = 10
+mssql.min_message_severity = 10
+mssql.compatability_mode = Off
+; Connect timeout
+;mssql.connect_timeout = 5
+; Query timeout
+;mssql.timeout = 60
+; Valid range 0 - 2147483647. Default = 4096.
+;mssql.textlimit = 4096
+;mssql.textsize = 4096
+; Limits the number of records in each batch. 0 = all records in one batch.
+;mssql.batchsize = 0
+; Specify how datetime and datetim4 columns are returned
+; On => Returns data converted to SQL server settings
+; Off => Returns values as YYYY-MM-DD hh:mm:ss
+;mssql.datetimeconvert = On
+; Use NT authentication when connecting to the server
+mssql.secure_connection = Off
+; Specify max number of processes. Default = 25
+;mssql.max_procs = 25
+[Assertion]
+; Assert(expr); active by default.
+;assert.active = On
+; Issue a PHP warning for each failed assertion.
+;assert.warning = On
+; Don't bail out by default.
+;assert.bail = Off
+; User-function to be called if an assertion fails.
+;assert.callback = 0
+; Eval the expression with current error_reporting(). Set to true if you want
+; error_reporting(0) around the eval().
+;assert.quiet_eval = 0
+[Ingres II]
+ingres.allow_persistent = On
+ingres.max_persistent = -1
+; Maximum number of links, including persistents. -1 means no limit.
+ingres.max_links = -1
+; Default database (format: [node_id::]dbname[/srv_class]).
+ingres.default_database =
+; Default user.
+ingres.default_user =
+; Default password.
+ingres.default_password =
+[Verisign Payflow Pro]
+; Default Payflow Pro server.
+pfpro.defaulthost = "test-payflow.verisign.com"
+; Default port to connect to.
+pfpro.defaultport = 443
+; Default timeout in seconds.
+pfpro.defaulttimeout = 30
+; Default proxy IP address (if required).
+;pfpro.proxyaddress =
+; Default proxy port.
+;pfpro.proxyport =
+; Default proxy logon.
+;pfpro.proxylogon =
+; Default proxy password.
+;pfpro.proxypassword =
+[com]
+; path to a file containing GUIDs, IIDs or filenames of files with TypeLibs
+;com.typelib_file =
+; allow Distributed-COM calls
+;com.allow_dcom = true
+; autoregister constants of a components typlib on com_load()
+;com.autoregister_typelib = true
+; register constants casesensitive
+;com.autoregister_casesensitive = false
+; show warnings on duplicate constat registrations
+;com.autoregister_verbose = true
+[mbstring]
+; language for internal character representation.
+mbstring.language = UTF-8
+; internal/script encoding.
+; Some encoding cannot work as internal encoding.
+; (e.g. SJIS, BIG5, ISO-2022-*)
+mbstring.internal_encoding = UTF-8
+; http input encoding.
+mbstring.http_input = UTF-8
+; http output encoding. mb_output_handler must be
+; registered as output buffer to function
+mbstring.http_output = pass
+; enable automatic encoding translation accoding to
+; mbstring.internal_encoding setting. Input chars are
+; converted to internal encoding by setting this to On.
+; Note: Do _not_ use automatic encoding translation for
+; portable libs/applications.
+mbstring.encoding_translation = Off
+; automatic encoding detection order.
+; auto means
+mbstring.detect_order = auto
+; substitute_character used when character cannot be converted
+; one from another
+;mbstring.substitute_character = none;
+; overload(replace) single byte functions by mbstring functions.
+; mail(), ereg(), etc are overloaded by mb_send_mail(), mb_ereg(),
+; etc. Possible values are 0,1,2,4 or combination of them.
+; For example, 7 for overload everything.
+; 0: No overload
+; 1: Overload mail() function
+; 2: Overload str*() functions
+; 4: Overload ereg*() functions
+mbstring.func_overload = 0
+[FrontBase]
+;fbsql.allow_persistent = On
+;fbsql.autocommit = On
+;fbsql.default_database =
+;fbsql.default_database_password =
+;fbsql.default_host =
+;fbsql.default_password =
+;fbsql.default_user = "_SYSTEM"
+;fbsql.generate_warnings = Off
+;fbsql.max_connections = 128
+;fbsql.max_links = 128
+;fbsql.max_persistent = -1
+;fbsql.max_results = 128
+;fbsql.batchSize = 1000
+[exif]
+; Exif UNICODE user comments are handled as UCS-2BE/UCS-2LE and JIS as JIS.
+; With mbstring support this will automatically be converted into the encoding
+; given by corresponding encode setting. When empty mbstring.internal_encoding
+; is used. For the decode settings you can distinguish between motorola and
+; intel byte order. A decode setting cannot be empty.
+;exif.encode_unicode = ISO-8859-15
+;exif.decode_unicode_motorola = UCS-2BE
+;exif.decode_unicode_intel = UCS-2LE
+;exif.encode_jis =
+;exif.decode_jis_motorola = JIS
+;exif.decode_jis_intel = JIS
+[Tidy]
+; The path to a default tidy configuration file to use when using tidy
+;tidy.default_config = /usr/local/lib/php/default.tcfg
+; Should tidy clean and repair output automatically?
+; WARNING: Do not use this option if you are generating non-html content
+; such as dynamic images
+tidy.clean_output = Off
+[soap]
+; Enables or disables WSDL caching feature.
+soap.wsdl_cache_enabled=1
+; Sets the directory name where SOAP extension will put cache files.
+soap.wsdl_cache_dir="/tmp"
+; (time to live) Sets the number of second while cached file will be used
+; instead of original one.
+soap.wsdl_cache_ttl=86400
+; Local Variables:
+; tab-width: 4
+; End:
Added: trunk/Installer/Support/Web/x64/Tomcat/conf/Catalina/localhost/mapguide.xml
--- trunk/Installer/Support/Web/x64/Tomcat/conf/Catalina/localhost/mapguide.xml (rev 0)
+++ trunk/Installer/Support/Web/x64/Tomcat/conf/Catalina/localhost/mapguide.xml 2011-10-28 10:46:47 UTC (rev 6190)
@@ -0,0 +1,17 @@
+ Context configuration file for the Tomcat Manager Web App
+ $Id: manager.xml,v 1.3 2004/08/26 17:03:34 remm Exp $
+<Context docBase="%MG_WEB_ROOT%"
+ privileged="true" antiResourceLocking="false" antiJARLocking="false">
+ <!-- Link to the user database we will get roles from -->
+ <ResourceLink name="users" global="UserDatabase"
+ type="org.apache.catalina.UserDatabase"/>
+</Context>
Added: trunk/Installer/Support/Web/x86/Apache2/conf/httpd.conf
--- trunk/Installer/Support/Web/x86/Apache2/conf/httpd.conf (rev 0)
+++ trunk/Installer/Support/Web/x86/Apache2/conf/httpd.conf 2011-10-28 10:46:47 UTC (rev 6190)
@@ -0,0 +1,1032 @@
+# Based upon the NCSA server configuration files originally by Rob McCool.
+# This is the main Apache server configuration file. It contains the
+# configuration directives that give the server its instructions.
+# See <URL:http://httpd.apache.org/docs-2.2/> for detailed information about
+# the directives.
+# Do NOT simply read the instructions in here without understanding
+# what they do. They're here only as hints or reminders. If you are unsure
+# consult the online docs. You have been warned.
+# The configuration directives are grouped into three basic sections:
+# 1. Directives that control the operation of the Apache server process as a
+# whole (the 'global environment').
+# 2. Directives that define the parameters of the 'main' or 'default' server,
+# which responds to requests that aren't handled by a virtual host.
+# These directives also provide default values for the settings
+# of all virtual hosts.
+# 3. Settings for virtual hosts, which allow Web requests to be sent to
+# different IP addresses or hostnames and have them handled by the
+# same Apache server process.
+# Configuration and logfile names: If the filenames you specify for many
+# of the server's control files begin with "/" (or "drive:/" for Win32), the
+# server will use that explicit path. If the filenames do *not* begin
+# with "/", the value of ServerRoot is prepended -- so "logs/foo.log"
+# with ServerRoot set to "C:/Program Files/Apache Group/Apache2" will be interpreted by the
+# server as "C:/Program Files/Apache Group/Apache2/logs/foo.log".
+# NOTE: Where filenames are specified, you must use forward slashes
+# instead of backslashes (e.g., "c:/apache" instead of "c:\apache").
+# If a drive letter is omitted, the drive on which Apache.exe is located
+# will be used by default. It is recommended that you always supply
+# an explicit drive letter in absolute paths, however, to avoid
+# confusion.
+### Section 1: Global Environment
+# The directives in this section affect the overall operation of Apache,
+# such as the number of concurrent requests it can handle or where it
+# can find its configuration files.
+# ServerRoot: The top of the directory tree under which the server's
+# configuration, error, and log files are kept.
+# NOTE! If you intend to place this on an NFS (or otherwise network)
+# mounted filesystem then please read the LockFile documentation (available
+# at <URL:http://httpd.apache.org/docs-2.0/mod/mpm_common.html#lockfile>);
+# you will save yourself a lot of trouble.
+# Do NOT add a slash at the end of the directory path.
+ServerRoot "%MG_WEB_APACHE%"
+# ScoreBoardFile: File used to store internal server process information.
+# If unspecified (the default), the scoreboard will be stored in an
+# anonymous shared memory segment, and will be unavailable to third-party
+# applications.
+# If specified, ensure that no two invocations of Apache share the same
+# scoreboard file. The scoreboard file MUST BE STORED ON A LOCAL DISK.
+#ScoreBoardFile logs/apache_runtime_status
+# PidFile: The file in which the server should record its process
+# identification number when it starts.
+PidFile logs/httpd.pid
+# Timeout: The number of seconds before receives and sends time out.
+Timeout 300
+# KeepAlive: Whether or not to allow persistent connections (more than
+# one request per connection). Set to "Off" to deactivate.
+KeepAlive On
+# MaxKeepAliveRequests: The maximum number of requests to allow
+# during a persistent connection. Set to 0 to allow an unlimited amount.
+# We recommend you leave this number high, for maximum performance.
+MaxKeepAliveRequests 100
+# KeepAliveTimeout: Number of seconds to wait for the next request from the
+# same client on the same connection.
+KeepAliveTimeout 15
+## Server-Pool Size Regulation (MPM specific)
+# WinNT MPM
+# ThreadsPerChild: constant number of worker threads in the server process
+# MaxRequestsPerChild: maximum number of requests a server process serves
+<IfModule mpm_winnt.c>
+ThreadsPerChild 50
+MaxRequestsPerChild 10000
+MaxMemFree 1000
+</IfModule>
+# Listen: Allows you to bind Apache to specific IP addresses and/or
+# ports, instead of the default. See also the <VirtualHost>
+# directive.
+# Change this to Listen on specific IP addresses as shown below to
+# prevent Apache from glomming onto all bound IP addresses (0.0.0.0)
+#Listen 12.34.56.78:80
+Listen %MG_WEB_PORT%
+LoadFile "%MG_WEB_PHP%/php5ts.dll"
+LoadFile "%MG_WEB_PHP%/ACE.dll"
+LoadFile "%MG_WEB_PHP%/MgHttpHandler.dll"
+LoadFile "%MG_WEB_PHP%/MgFoundation.dll"
+LoadFile "%MG_WEB_PHP%/MgGeometry.dll"
+LoadFile "%MG_WEB_PHP%/MgMapGuideCommon.dll"
+LoadFile "%MG_WEB_PHP%/MgMdfModel.dll"
+LoadFile "%MG_WEB_PHP%/MgMdfParser.dll"
+LoadFile "%MG_WEB_PHP%/MgPlatformBase.dll"
+LoadFile "%MG_WEB_PHP%/MgWebApp.dll"
+LoadFile "%MG_WEB_PHP%/MgWebSupport.dll"
+# Dynamic Shared Object (DSO) Support
+# To be able to use the functionality of a module which was built as a DSO you
+# have to place corresponding `LoadModule' lines at this location so the
+# directives contained in it are actually available _before_ they are used.
+# Statically compiled modules (those listed by `httpd -l') do not need
+# to be loaded here.
+# Example:
+# LoadModule foo_module modules/mod_foo.so
+LoadModule actions_module modules/mod_actions.so
+LoadModule alias_module modules/mod_alias.so
+LoadModule asis_module modules/mod_asis.so
+LoadModule auth_basic_module modules/mod_auth_basic.so
+#LoadModule auth_digest_module modules/mod_auth_digest.so
+#LoadModule authn_anon_module modules/mod_authn_anon.so
+#LoadModule authn_dbm_module modules/mod_authn_dbm.so
+LoadModule authn_default_module modules/mod_authn_default.so
+LoadModule authn_file_module modules/mod_authn_file.so
+#LoadModule authz_dbm_module modules/mod_authz_dbm.so
+LoadModule authz_default_module modules/mod_authz_default.so
+LoadModule authz_groupfile_module modules/mod_authz_groupfile.so
+LoadModule authz_host_module modules/mod_authz_host.so
+LoadModule authz_user_module modules/mod_authz_user.so
+LoadModule autoindex_module modules/mod_autoindex.so
+#LoadModule cern_meta_module modules/mod_cern_meta.so
+LoadModule cgi_module modules/mod_cgi.so
+#LoadModule dav_module modules/mod_dav.so
+#LoadModule dav_fs_module modules/mod_dav_fs.so
+LoadModule deflate_module modules/mod_deflate.so
+LoadModule dir_module modules/mod_dir.so
+LoadModule env_module modules/mod_env.so
+#LoadModule expires_module modules/mod_expires.so
+#LoadModule file_cache_module modules/mod_file_cache.so
+#LoadModule headers_module modules/mod_headers.so
+LoadModule imagemap_module modules/mod_imagemap.so
+LoadModule include_module modules/mod_include.so
+#LoadModule info_module modules/mod_info.so
+LoadModule isapi_module modules/mod_isapi.so
+LoadModule log_config_module modules/mod_log_config.so
+LoadModule mime_module modules/mod_mime.so
+#LoadModule mime_magic_module modules/mod_mime_magic.so
+#LoadModule proxy_module modules/mod_proxy.so
+#LoadModule proxy_ajp_module modules/mod_proxy_ajp.so
+#LoadModule proxy_balancer_module modules/mod_proxy_balancer.so
+#LoadModule proxy_connect_module modules/mod_proxy_connect.so
+#LoadModule proxy_http_module modules/mod_proxy_http.so
+#LoadModule proxy_ftp_module modules/mod_proxy_ftp.so
+LoadModule negotiation_module modules/mod_negotiation.so
+LoadModule rewrite_module modules/mod_rewrite.so
+LoadModule setenvif_module modules/mod_setenvif.so
+#LoadModule speling_module modules/mod_speling.so
+#LoadModule status_module modules/mod_status.so
+#LoadModule unique_id_module modules/mod_unique_id.so
+LoadModule userdir_module modules/mod_userdir.so
+#LoadModule usertrack_module modules/mod_usertrack.so
+#LoadModule vhost_alias_module modules/mod_vhost_alias.so
+#LoadModule ssl_module modules/mod_ssl.so
+LoadModule php5_module modules/php5apache2_2.dll
+LoadModule mgmapagent_module modules/mod_mgmapagent.so
+# ExtendedStatus controls whether Apache will generate "full" status
+# information (ExtendedStatus On) or just basic information (ExtendedStatus
+# Off) when the "server-status" handler is called. The default is Off.
+#ExtendedStatus On
+### Section 2: 'Main' server configuration
+# The directives in this section set up the values used by the 'main'
+# server, which responds to any requests that aren't handled by a
+# <VirtualHost> definition. These values also provide defaults for
+# any <VirtualHost> containers you may define later in the file.
+# All of these directives may appear inside <VirtualHost> containers,
+# in which case these default settings will be overridden for the
+# virtual host being defined.
+# ServerAdmin: Your address, where problems with the server should be
+# e-mailed. This address appears on some server-generated pages, such
+# as error documents. e.g. admin at your-domain.com
+ServerAdmin admin at your-domain.com
+# ServerName gives the name and port that the server uses to identify itself.
+# This can often be determined automatically, but we recommend you specify
+# it explicitly to prevent problems during startup.
+# If this is not set to valid DNS name for your host, server-generated
+# redirections will not work. See also the UseCanonicalName directive.
+# If your host doesn't have a registered DNS name, enter its IP address here.
+# You will have to access it by its address anyway, and this will make
+# redirections work in a sensible way.
+ServerName localhost:%MG_WEB_PORT%
+# UseCanonicalName: Determines how Apache constructs self-referencing
+# URLs and the SERVER_NAME and SERVER_PORT variables.
+# When set "Off", Apache will use the Hostname and Port supplied
+# by the client. When set "On", Apache will use the value of the
+# ServerName directive.
+UseCanonicalName Off
+# DocumentRoot: The directory out of which you will serve your
+# documents. By default, all requests are taken from this directory, but
+# symbolic links and aliases may be used to point to other locations.
+DocumentRoot "%MG_WEB_APACHE%/htdocs"
+# Each directory to which Apache has access can be configured with respect
+# to which services and features are allowed and/or disabled in that
+# directory (and its subdirectories).
+# First, we configure the "default" to be a very restrictive set of
+# features.
+<Directory />
+ Options FollowSymLinks
+ AllowOverride None
+</Directory>
+# Note that from this point forward you must specifically allow
+# particular features to be enabled - so if something's not working as
+# you might expect, make sure that you have specifically enabled it
+# below.
+# This should be changed to whatever you set DocumentRoot to.
+<Directory "%MG_WEB_APACHE%/htdocs">
+# Possible values for the Options directive are "None", "All",
+# or any combination of:
+# Indexes Includes FollowSymLinks SymLinksifOwnerMatch ExecCGI MultiViews
+# Note that "MultiViews" must be named *explicitly* --- "Options All"
+# doesn't give it to you.
+# The Options directive is both complicated and important. Please see
+# http://httpd.apache.org/docs-2.0/mod/core.html#options
+# for more information.
+ Options Indexes FollowSymLinks
+# AllowOverride controls what directives may be placed in .htaccess files.
+# It can be "All", "None", or any combination of the keywords:
+# Options FileInfo AuthConfig Limit
+# Controls who can get stuff from this server.
+ Order allow,deny
+ Allow from all
+</Directory>
+# UserDir: The name of the directory that is appended onto a user's home
+# directory if a ~user request is received. Be especially careful to use
+# proper, forward slashes here. On Windows NT, "Personal/My Website"
+# is a more appropriate choice.
+UserDir "My Documents/My Website"
+# Control access to UserDir directories. The following is an example
+# for a site where these directories are restricted to read-only.
+# You must correct the path for the root to match your system's configured
+# user directory location, e.g. "C:/WinNT/profiles/*/My Documents/My Website"
+# or whichever, as appropriate.
+#<Directory "C:/Documents and Settings/*/My Documents/My Website">
+# AllowOverride FileInfo AuthConfig Limit
+# Options MultiViews Indexes SymLinksIfOwnerMatch IncludesNoExec
+# <Limit GET POST OPTIONS PROPFIND>
+# Order allow,deny
+# Allow from all
+# </Limit>
+# <LimitExcept GET POST OPTIONS PROPFIND>
+# Order deny,allow
+# Deny from all
+# </LimitExcept>
+#</Directory>
+# DirectoryIndex: sets the file that Apache will serve if a directory
+# is requested.
+# The index.html.var file (a type-map) is used to deliver content-
+# negotiated documents. The MultiViews Option can be used for the
+# same purpose, but it is much slower.
+DirectoryIndex index.html index.html.var
+# AccessFileName: The name of the file to look for in each directory
+# for additional configuration directives. See also the AllowOverride
+# directive.
+AccessFileName .htaccess
+# The following lines prevent .htaccess and .htpasswd files from being
+# viewed by Web clients.
+<Files ~ "^\.ht">
+ Order allow,deny
+ Deny from all
+</Files>
+# TypesConfig describes where the mime.types file (or equivalent) is
+# to be found.
+TypesConfig conf/mime.types
+# DefaultType is the default MIME type the server will use for a document
+# if it cannot otherwise determine one, such as from filename extensions.
+# If your server contains mostly text or HTML documents, "text/plain" is
+# a good value. If most of your content is binary, such as applications
+# or images, you may want to use "application/octet-stream" instead to
+# keep browsers from trying to display binary files as though they are
+# text.
+DefaultType text/plain
+# The mod_mime_magic module allows the server to use various hints from the
+# contents of the file itself to determine its type. The MIMEMagicFile
+# directive tells the module where the hint definitions are located.
+<IfModule mod_mime_magic.c>
+ MIMEMagicFile conf/magic
+</IfModule>
+# HostnameLookups: Log the names of clients or just their IP addresses
+# e.g., www.apache.org (on) or 204.62.129.132 (off).
+# The default is off because it'd be overall better for the net if people
+# had to knowingly turn this feature on, since enabling it means that
+# each client request will result in AT LEAST one lookup request to the
+# nameserver.
+HostnameLookups Off
+# EnableMMAP: Control whether memory-mapping is used to deliver
+# files (assuming that the underlying OS supports it).
+# The default is on; turn this off if you serve from NFS-mounted
+# filesystems. On some systems, turning it off (regardless of
+# filesystem) can improve performance; for details, please see
+# http://httpd.apache.org/docs-2.0/mod/core.html#enablemmap
+#EnableMMAP off
+# EnableSendfile: Control whether the sendfile kernel support is
+# used to deliver files (assuming that the OS supports it).
+# filesystems. Please see
+# http://httpd.apache.org/docs-2.0/mod/core.html#enablesendfile
+#EnableSendfile off
+# ErrorLog: The location of the error log file.
+# If you do not specify an ErrorLog directive within a <VirtualHost>
+# container, error messages relating to that virtual host will be
+# logged here. If you *do* define an error logfile for a <VirtualHost>
+# container, that host's errors will be logged there and not here.
+ErrorLog logs/error.log
+# LogLevel: Control the number of messages logged to the error.log.
+# Possible values include: debug, info, notice, warn, error, crit,
+# alert, emerg.
+LogLevel warn
+# The following directives define some format nicknames for use with
+# a CustomLog directive (see below).
+LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
+LogFormat "%h %l %u %t \"%r\" %>s %b" common
+LogFormat "%{Referer}i -> %U" referer
+LogFormat "%{User-agent}i" agent
+# You need to enable mod_logio.c to use %I and %O
+#LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\" %I %O" combinedio
+# The location and format of the access logfile (Common Logfile Format).
+# If you do not define any access logfiles within a <VirtualHost>
+# container, they will be logged here. Contrariwise, if you *do*
+# define per-<VirtualHost> access logfiles, transactions will be
+# logged therein and *not* in this file.
+CustomLog logs/access.log common
+# If you would like to have agent and referer logfiles, uncomment the
+# following directives.
+#CustomLog logs/referer.log referer
+#CustomLog logs/agent.log agent
+# If you prefer a single logfile with access, agent, and referer information
+# (Combined Logfile Format) you can use the following directive.
+#CustomLog logs/access.log combined
+# ServerTokens
+# This directive configures what you return as the Server HTTP response
+# Header. The default is 'Full' which sends information about the OS-Type
+# and compiled in modules.
+# Set to one of: Full | OS | Minor | Minimal | Major | Prod
+# where Full conveys the most information, and Prod the least.
+ServerTokens Prod
+# Optionally add a line containing the server version and virtual host
+# name to server-generated pages (internal error documents, FTP directory
+# listings, mod_status and mod_info output etc., but not CGI generated
+# documents or custom error documents).
+# Set to "EMail" to also include a mailto: link to the ServerAdmin.
+# Set to one of: On | Off | EMail
+ServerSignature On
+# Aliases: Add here as many aliases as you need (with no limit). The format is
+# Alias fakename realname
+# Note that if you include a trailing / on fakename then the server will
+# require it to be present in the URL. So "/icons" isn't aliased in this
+# example, only "/icons/". If the fakename is slash-terminated, then the
+# realname must also be slash terminated, and if the fakename omits the
+# trailing slash, the realname must also omit it.
+# We include the /icons/ alias for FancyIndexed directory listings. If you
+# do not use FancyIndexing, you may comment this out.
+Alias /icons/ "%MG_WEB_APACHE%/icons/"
+<Directory "%MG_WEB_APACHE%/icons">
+ Options Indexes MultiViews
+ Order allow,deny
+ Allow from all
+</Directory>
+# This should be changed to the ServerRoot/manual/. The alias provides
+# the manual, even if you choose to move your DocumentRoot. You may comment
+# this out if you do not care for the documentation.
+AliasMatch ^/manual(?:/(?:de|en|es|fr|ja|ko|ru))?(/.*)?$ "%MG_WEB_APACHE%/manual$1"
+<Directory "%MG_WEB_APACHE%/manual">
+ Options Indexes
+ Order allow,deny
+ Allow from all
+ <Files *.html>
+ SetHandler type-map
+ </Files>
+ SetEnvIf Request_URI ^/manual/(de|en|es|fr|ja|ko|ru)/ prefer-language=$1
+ RedirectMatch 301 ^/manual(?:/(de|en|es|fr|ja|ko|ru)){2,}(/.*)?$ /manual/$1$2
+</Directory>
+# ScriptAlias: This controls which directories contain server scripts.
+# ScriptAliases are essentially the same as Aliases, except that
+# documents in the realname directory are treated as applications and
+# run by the server when requested rather than as documents sent to the client.
+# The same rules about trailing "/" apply to ScriptAlias directives as to
+# Alias.
+ScriptAlias /cgi-bin/ "%MG_WEB_APACHE%/cgi-bin/"
+# "%MG_WEB_APACHE%/cgi-bin" should be changed to whatever your ScriptAliased
+# CGI directory exists, if you have that configured.
+<Directory "%MG_WEB_APACHE%/cgi-bin">
+ Options None
+ Order allow,deny
+ Allow from all
+</Directory>
+# Redirect allows you to tell clients about documents which used to exist in
+# your server's namespace, but do not anymore. This allows you to tell the
+# clients where to look for the relocated document.
+# Example:
+# Redirect permanent /foo http://www.example.com/bar
+# Directives controlling the display of server-generated directory listings.
+# IndexOptions: Controls the appearance of server-generated directory
+# listings.
+IndexOptions FancyIndexing VersionSort
+# AddIcon* directives tell the server which icon to show for different
+# files or filename extensions. These are only displayed for
+# FancyIndexed directories.
+AddIconByEncoding (CMP,/icons/compressed.gif) x-compress x-gzip
+AddIconByType (TXT,/icons/text.gif) text/*
+AddIconByType (IMG,/icons/image2.gif) image/*
+AddIconByType (SND,/icons/sound2.gif) audio/*
+AddIconByType (VID,/icons/movie.gif) video/*
+AddIcon /icons/binary.gif .bin .exe
+AddIcon /icons/binhex.gif .hqx
+AddIcon /icons/tar.gif .tar
+AddIcon /icons/world2.gif .wrl .wrl.gz .vrml .vrm .iv
+AddIcon /icons/compressed.gif .Z .z .tgz .gz .zip
+AddIcon /icons/a.gif .ps .ai .eps
+AddIcon /icons/layout.gif .html .shtml .htm .pdf
+AddIcon /icons/text.gif .txt
+AddIcon /icons/c.gif .c
+AddIcon /icons/p.gif .pl .py
+AddIcon /icons/f.gif .for
+AddIcon /icons/dvi.gif .dvi
+AddIcon /icons/uuencoded.gif .uu
+AddIcon /icons/script.gif .conf .sh .shar .csh .ksh .tcl
+AddIcon /icons/tex.gif .tex
+AddIcon /icons/bomb.gif core
+AddIcon /icons/back.gif ..
+AddIcon /icons/hand.right.gif README
+AddIcon /icons/folder.gif ^^DIRECTORY^^
+AddIcon /icons/blank.gif ^^BLANKICON^^
+# DefaultIcon is which icon to show for files which do not have an icon
+# explicitly set.
+DefaultIcon /icons/unknown.gif
+# AddDescription allows you to place a short description after a file in
+# server-generated indexes. These are only displayed for FancyIndexed
+# directories.
+# Format: AddDescription "description" filename
+#AddDescription "GZIP compressed document" .gz
+#AddDescription "tar archive" .tar
+#AddDescription "GZIP compressed tar archive" .tgz
+# ReadmeName is the name of the README file the server will look for by
+# default, and append to directory listings.
+# HeaderName is the name of a file which should be prepended to
+# directory indexes.
+ReadmeName README.html
+HeaderName HEADER.html
+# IndexIgnore is a set of filenames which directory indexing should ignore
+# and not include in the listing. Shell-style wildcarding is permitted.
+IndexIgnore .??* *~ *# HEADER* README* RCS CVS *,v *,t
+# DefaultLanguage and AddLanguage allows you to specify the language of
+# a document. You can then use content negotiation to give a browser a
+# file in a language the user can understand.
+# Specify a default language. This means that all data
+# going out without a specific language tag (see below) will
+# be marked with this one. You probably do NOT want to set
+# this unless you are sure it is correct for all cases.
+# * It is generally better to not mark a page as
+# * being a certain language than marking it with the wrong
+# * language!
+# DefaultLanguage nl
+# Note 1: The suffix does not have to be the same as the language
+# keyword --- those with documents in Polish (whose net-standard
+# language code is pl) may wish to use "AddLanguage pl .po" to
+# avoid the ambiguity with the common suffix for perl scripts.
+# Note 2: The example entries below illustrate that in some cases
+# the two character 'Language' abbreviation is not identical to
+# the two character 'Country' code for its country,
+# E.g. 'Danmark/dk' versus 'Danish/da'.
+# Note 3: In the case of 'ltz' we violate the RFC by using a three char
+# specifier. There is 'work in progress' to fix this and get
+# the reference data for rfc1766 cleaned up.
+# Catalan (ca) - Croatian (hr) - Czech (cs) - Danish (da) - Dutch (nl)
+# English (en) - Esperanto (eo) - Estonian (et) - French (fr) - German (de)
+# Greek-Modern (el) - Hebrew (he) - Italian (it) - Japanese (ja)
+# Korean (ko) - Luxembourgeois* (ltz) - Norwegian Nynorsk (nn)
+# Norwegian (no) - Polish (pl) - Portugese (pt)
+# Brazilian Portuguese (pt-BR) - Russian (ru) - Swedish (sv)
+# Simplified Chinese (zh-CN) - Spanish (es) - Traditional Chinese (zh-TW)
+AddLanguage ca .ca
+AddLanguage cs .cz .cs
+AddLanguage da .dk
+AddLanguage de .de
+AddLanguage el .el
+AddLanguage en .en
+AddLanguage eo .eo
+AddLanguage es .es
+AddLanguage et .et
+AddLanguage fr .fr
+AddLanguage he .he
+AddLanguage hr .hr
+AddLanguage it .it
+AddLanguage ja .ja
+AddLanguage ko .ko
+AddLanguage ltz .ltz
+AddLanguage nl .nl
+AddLanguage nn .nn
+AddLanguage no .no
+AddLanguage pl .po
+AddLanguage pt .pt
+AddLanguage pt-BR .pt-br
+AddLanguage ru .ru
+AddLanguage sv .sv
+AddLanguage zh-CN .zh-cn
+AddLanguage zh-TW .zh-tw
+# LanguagePriority allows you to give precedence to some languages
+# in case of a tie during content negotiation.
+# Just list the languages in decreasing order of preference. We have
+# more or less alphabetized them here. You probably want to change this.
+LanguagePriority en ca cs da de el eo es et fr he hr it ja ko ltz nl nn no pl pt pt-BR ru sv zh-CN zh-TW
+# ForceLanguagePriority allows you to serve a result page rather than
+# MULTIPLE CHOICES (Prefer) [in case of a tie] or NOT ACCEPTABLE (Fallback)
+# [in case no accepted languages matched the available variants]
+ForceLanguagePriority Prefer Fallback
+# Commonly used filename extensions to character sets. You probably
+# want to avoid clashes with the language extensions, unless you
+# are good at carefully testing your setup after each change.
+# See http://www.iana.org/assignments/character-sets for the
+# official list of charset names and their respective RFCs.
+AddCharset ISO-8859-1 .iso8859-1 .latin1
+AddCharset ISO-8859-2 .iso8859-2 .latin2 .cen
+AddCharset ISO-8859-3 .iso8859-3 .latin3
+AddCharset ISO-8859-4 .iso8859-4 .latin4
+AddCharset ISO-8859-5 .iso8859-5 .latin5 .cyr .iso-ru
+AddCharset ISO-8859-6 .iso8859-6 .latin6 .arb
+AddCharset ISO-8859-7 .iso8859-7 .latin7 .grk
+AddCharset ISO-8859-8 .iso8859-8 .latin8 .heb
+AddCharset ISO-8859-9 .iso8859-9 .latin9 .trk
+AddCharset ISO-2022-JP .iso2022-jp .jis
+AddCharset ISO-2022-KR .iso2022-kr .kis
+AddCharset ISO-2022-CN .iso2022-cn .cis
+AddCharset Big5 .Big5 .big5
+# For russian, more than one charset is used (depends on client, mostly):
+AddCharset WINDOWS-1251 .cp-1251 .win-1251
+AddCharset CP866 .cp866
+AddCharset KOI8-r .koi8-r .koi8-ru
+AddCharset KOI8-ru .koi8-uk .ua
+AddCharset ISO-10646-UCS-2 .ucs2
+AddCharset ISO-10646-UCS-4 .ucs4
+AddCharset UTF-8 .utf8
+# The set below does not map to a specific (iso) standard
+# but works on a fairly wide range of browsers. Note that
+# capitalization actually matters (it should not, but it
+# does for some browsers).
+# for a list of sorts. But browsers support few.
+AddCharset GB2312 .gb2312 .gb
+AddCharset utf-7 .utf7
+AddCharset utf-8 .utf8
+AddCharset big5 .big5 .b5
+AddCharset EUC-TW .euc-tw
+AddCharset EUC-JP .euc-jp
+AddCharset EUC-KR .euc-kr
+AddCharset shift_jis .sjis
+# AddType allows you to add to or override the MIME configuration
+# file mime.types for specific file types.
+#AddType application/x-tar .tgz
+# AddEncoding allows you to have certain browsers (Mosaic/X 2.1+) uncompress
+# information on the fly. Note: Not all browsers support this.
+# Despite the name similarity, the following Add* directives have nothing
+# to do with the FancyIndexing customization directives above.
+#AddEncoding x-compress .Z
+#AddEncoding x-gzip .gz .tgz
+# If the AddEncoding directives above are commented-out, then you
+# probably should define those extensions to indicate media types:
+AddType application/x-compress .Z
+AddType application/x-gzip .gz .tgz
+# AddHandler allows you to map certain file extensions to "handlers":
+# actions unrelated to filetype. These can be either built into the server
+# or added with the Action directive (see below)
+# To use CGI scripts outside of ScriptAliased directories:
+# (You will also need to add "ExecCGI" to the "Options" directive.)
+#AddHandler cgi-script .cgi
+# For files that include their own HTTP headers:
+#AddHandler send-as-is asis
+# For server-parsed imagemap files:
+#AddHandler imap-file map
+# For type maps (negotiated resources):
+# (This is enabled by default to allow the Apache "It Worked" page
+# to be distributed in multiple languages.)
+AddHandler type-map var
+# Filters allow you to process content before it is sent to the client.
+# To parse .shtml files for server-side includes (SSI):
+# (You will also need to add "Includes" to the "Options" directive.)
+#AddType text/html .shtml
+#AddOutputFilter INCLUDES .shtml
+# Action lets you define media types that will execute a script whenever
+# a matching file is called. This eliminates the need for repeated URL
+# pathnames for oft-used CGI file processors.
+# Format: Action media/type /cgi-script/location
+# Format: Action handler-name /cgi-script/location
+# Customizable error responses come in three flavors:
+# 1) plain text 2) local redirects 3) external redirects
+# Some examples:
+#ErrorDocument 500 "The server made a boo boo."
+#ErrorDocument 404 /missing.html
+#ErrorDocument 404 "/cgi-bin/missing_handler.pl"
+#ErrorDocument 402 http://www.example.com/subscription_info.html
+# Putting this all together, we can internationalize error responses.
+# We use Alias to redirect any /error/HTTP_<error>.html.var response to
+# our collection of by-error message multi-language collections. We use
+# includes to substitute the appropriate text.
+# You can modify the messages' appearance without changing any of the
+# default HTTP_<error>.html.var files by adding the line:
+# Alias /error/include/ "/your/include/path/"
+# which allows you to create your own set of files by starting with the
+# @exp_errordir@/include/ files and copying them to /your/include/path/,
+# even on a per-VirtualHost basis. The default include files will display
+# your Apache version number and your ServerAdmin email address regardless
+# of the setting of ServerSignature.
+# The internationalized error documents require mod_alias, mod_include
+# and mod_negotiation. To activate them, uncomment the following 30 lines.
+# Alias /error/ "@exp_errordir@/"
+# <Directory "@exp_errordir@">
+# AllowOverride None
+# Options IncludesNoExec
+# AddOutputFilter Includes html
+# AddHandler type-map var
+# Order allow,deny
+# Allow from all
+# LanguagePriority en cs de es fr it ja ko nl pl pt-br ro sv tr
+# ForceLanguagePriority Prefer Fallback
+# </Directory>
+# ErrorDocument 400 /error/HTTP_BAD_REQUEST.html.var
+# ErrorDocument 401 /error/HTTP_UNAUTHORIZED.html.var
+# ErrorDocument 403 /error/HTTP_FORBIDDEN.html.var
+# ErrorDocument 404 /error/HTTP_NOT_FOUND.html.var
+# ErrorDocument 405 /error/HTTP_METHOD_NOT_ALLOWED.html.var
+# ErrorDocument 408 /error/HTTP_REQUEST_TIME_OUT.html.var
+# ErrorDocument 410 /error/HTTP_GONE.html.var
+# ErrorDocument 411 /error/HTTP_LENGTH_REQUIRED.html.var
+# ErrorDocument 412 /error/HTTP_PRECONDITION_FAILED.html.var
+# ErrorDocument 413 /error/HTTP_REQUEST_ENTITY_TOO_LARGE.html.var
+# ErrorDocument 414 /error/HTTP_REQUEST_URI_TOO_LARGE.html.var
+# ErrorDocument 415 /error/HTTP_UNSUPPORTED_MEDIA_TYPE.html.var
+# ErrorDocument 500 /error/HTTP_INTERNAL_SERVER_ERROR.html.var
+# ErrorDocument 501 /error/HTTP_NOT_IMPLEMENTED.html.var
+# ErrorDocument 502 /error/HTTP_BAD_GATEWAY.html.var
+# ErrorDocument 503 /error/HTTP_SERVICE_UNAVAILABLE.html.var
+# ErrorDocument 506 /error/HTTP_VARIANT_ALSO_VARIES.html.var
+# The following directives modify normal HTTP response behavior to
+# handle known problems with browser implementations.
+BrowserMatch "Mozilla/2" nokeepalive
+BrowserMatch "MSIE 4\.0b2;" nokeepalive downgrade-1.0 force-response-1.0
+BrowserMatch "RealPlayer 4\.0" force-response-1.0
+BrowserMatch "Java/1\.0" force-response-1.0
+BrowserMatch "JDK/1\.0" force-response-1.0
+# The following directive disables redirects on non-GET requests for
+# a directory that does not include the trailing slash. This fixes a
+# problem with Microsoft WebFolders which does not appropriately handle
+# redirects for folders with DAV methods.
+# Same deal with Apple's DAV filesystem and Gnome VFS support for DAV.
+BrowserMatch "Microsoft Data Access Internet Publishing Provider" redirect-carefully
+BrowserMatch "^WebDrive" redirect-carefully
+BrowserMatch "^WebDAVFS/1.[012]" redirect-carefully
+BrowserMatch "^gnome-vfs" redirect-carefully
+# Allow server status reports generated by mod_status,
+# with the URL of http://servername/server-status
+# Change the ".ads.autodesk.com" to match your domain to enable.
+#<Location /server-status>
+# SetHandler server-status
+# Order deny,allow
+# Deny from all
+# Allow from .ads.autodesk.com
+#</Location>
+# Allow remote server configuration reports, with the URL of
+# http://servername/server-info (requires that mod_info.c be loaded).
+#<Location /server-info>
+# SetHandler server-info
+# Order deny,allow
+# Deny from all
+#</Location>
+# Bring in additional module-specific configurations
+<IfModule mod_ssl.c>
+ Include conf/ssl.conf
+</IfModule>
+### Section 3: Virtual Hosts
+# VirtualHost: If you want to maintain multiple domains/hostnames on your
+# machine you can setup VirtualHost containers for them. Most configurations
+# use only name-based virtual hosts so the server doesn't need to worry about
+# IP addresses. This is indicated by the asterisks in the directives below.
+# Please see the documentation at
+# <URL:http://httpd.apache.org/docs-2.0/vhosts/>
+# for further details before you try to setup virtual hosts.
+# You may use the command line option '-S' to verify your virtual host
+# configuration.
+# Use name-based virtual hosting.
+#NameVirtualHost *:80
+# VirtualHost example:
+# Almost any Apache directive may go into a VirtualHost container.
+# The first VirtualHost section is used for requests without a known
+# server name.
+#<VirtualHost *:80>
+# ServerAdmin webmaster at dummy-host.example.com
+# DocumentRoot /www/docs/dummy-host.example.com
+# ServerName dummy-host.example.com
+# ErrorLog logs/dummy-host.example.com-error_log
+# CustomLog logs/dummy-host.example.com-access_log common
+#</VirtualHost>
+#Start PHP Config
+AddType application/x-httpd-php .php
+PHPIniDir "%MG_WEB_PHP%"
+#End PHP Config
+# MapViewer to MapViewerPhp aliases. Comment out Alias and AliasMatch for Java API.
+ScriptAlias /%MG_VIRTUAL_DIR%/mapagent/mapagent.fcgi "%MG_WEB_ROOT%mapagent/mapagent.fcgi"
+%MG_PHP_API%AliasMatch ^/%MG_VIRTUAL_DIR%/mapviewerajax/([^\?])(.*)$ "%MG_WEB_ROOT%mapviewerphp/$1$2"
+%MG_PHP_API%AliasMatch ^/%MG_VIRTUAL_DIR%/mapviewerajax/(.*)$ "%MG_WEB_ROOT%mapviewerphp/ajaxviewer.php$1"
+%MG_PHP_API%AliasMatch ^/%MG_VIRTUAL_DIR%/mapviewerdwf/([^\?])(.*)$ "%MG_WEB_ROOT%mapviewerphp/$1$2"
+%MG_PHP_API%AliasMatch ^/%MG_VIRTUAL_DIR%/mapviewerdwf/(.*)$ "%MG_WEB_ROOT%mapviewerphp/dwfviewer.php$1"
+# MapViewer to MapViewerJava Redirect. Uncomment Redirect for Java API.
+%MG_JAVA_API%Redirect /%MG_VIRTUAL_DIR%/mapviewerajax/ http://localhost:%MG_WEB_PORT%/%MG_VIRTUAL_DIR%/mapviewerjava/ajaxviewer.jsp
+%MG_JAVA_API%Redirect /%MG_VIRTUAL_DIR%/mapviewerdwf/ http://localhost:%MG_WEB_PORT%/%MG_VIRTUAL_DIR%/mapviewerjava/dwfviewer.jsp
+Alias /%MG_VIRTUAL_DIR% "%MG_WEB_ROOT%"
+<Directory "%MG_WEB_ROOT%">
+ AllowOverride All
+ Options All -Indexes
+ Order allow,deny
+ Allow from all
+# Restrict access via HTTP to webconfig.ini
+<Files webconfig.ini>
+ Order allow,deny
+ Deny from all
+</Files>
+# Apache MapAgent Module
+AddHandler mgmapagent_handler fcgi
+# Regular CGI MapAgent
+ AddHandler cgi-script exe
+ # Content compression
+ SetOutputFilter DEFLATE
+ AddType text/javascript js jgz
+ AddOutputFilterByType DEFLATE text/css
+ AddOutputFilterByType DEFLATE text/javascript
+ AddOutputFilterByType DEFLATE text/html
+ AddOutputFilterByType DEFLATE text/plain
+ AddOutputFilterByType DEFLATE text/xml
+ AddOutputFilterByType DEFLATE application/json
+ RewriteEngine on
+ RewriteRule .* - [E=REMOTE_USER:%{HTTP:Authorization},L]
+</Directory>
+#Disable the AcceptEx call
+Win32DisableAcceptEx
+%MG_INCLUDE_TOMCAT%
Added: trunk/Installer/Support/Web/x86/Apache2/conf/tomcat.conf
--- trunk/Installer/Support/Web/x86/Apache2/conf/tomcat.conf (rev 0)
+++ trunk/Installer/Support/Web/x86/Apache2/conf/tomcat.conf 2011-10-28 10:46:47 UTC (rev 6190)
@@ -0,0 +1,21 @@
+# Load mod_jk module
+# Update this path to match your modules location
+LoadModule jk_module modules/mod_jk.so
+# Declare the module for <IfModule directive> (remove this line on Apache 2.x)
+# AddModule mod_jk.c
+# Where to find workers.properties
+# Update this path to match your conf directory location (put workers.properties next to httpd.conf)
+JkWorkersFile "%MG_WEB_APACHE%/conf/workers.properties"
+# Where to put jk logs
+# Update this path to match your logs directory location (put mod_jk.log next to access_log)
+JkLogFile "%MG_WEB_APACHE%/logs/mod_jk.log"
+# Set the jk log level [debug/error/info]
+JkLogLevel info
+# Select the log format
+JkLogStampFormat "[%a %b %d %H:%M:%S %Y] "
+# JkOptions indicate to send SSL KEY SIZE,
+JkOptions +ForwardKeySize +ForwardURICompat -ForwardDirectories
+# JkRequestLogFormat set the request format
+JkRequestLogFormat "%w %V %T"
+# Send everything for context /examples to worker named worker1 (ajp13)
+JkMount /%MG_VIRTUAL_DIR%/mapviewerjava/* worker1
\ No newline at end of file
Added: trunk/Installer/Support/Web/x86/Php/php.ini
--- trunk/Installer/Support/Web/x86/Php/php.ini (rev 0)
+++ trunk/Installer/Support/Web/x86/Php/php.ini 2011-10-28 10:46:47 UTC (rev 6190)
@@ -0,0 +1,1263 @@
+[PHP]
+; About php.ini ;
+; This file controls many aspects of PHP's behavior. In order for PHP to
+; read it, it must be named 'php.ini'. PHP looks for it in the current
+; working directory, in the path designated by the environment variable
+; PHPRC, and in the path that was defined in compile time (in that order).
+; Under Windows, the compile-time path is the Windows directory. The
+; path in which the php.ini file is looked for can be overridden using
+; the -c argument in command line mode.
+; The syntax of the file is extremely simple. Whitespace and Lines
+; beginning with a semicolon are silently ignored (as you probably guessed).
+; Section headers (e.g. [Foo]) are also silently ignored, even though
+; they might mean something in the future.
+; Directives are specified using the following syntax:
+; directive = value
+; Directive names are *case sensitive* - foo=bar is different from FOO=bar.
+; The value can be a string, a number, a PHP constant (e.g. E_ALL or M_PI), one
+; of the INI constants (On, Off, True, False, Yes, No and None) or an expression
+; (e.g. E_ALL & ~E_NOTICE), or a quoted string ("foo").
+; Expressions in the INI file are limited to bitwise operators and parentheses:
+; | bitwise OR
+; & bitwise AND
+; ~ bitwise NOT
+; ! boolean NOT
+; Boolean flags can be turned on using the values 1, On, True or Yes.
+; They can be turned off using the values 0, Off, False or No.
+; An empty string can be denoted by simply not writing anything after the equal
+; sign, or by using the None keyword:
+; foo = ; sets foo to an empty string
+; foo = none ; sets foo to an empty string
+; foo = "none" ; sets foo to the string 'none'
+; If you use constants in your value, and these constants belong to a
+; dynamically loaded extension (either a PHP extension or a Zend extension),
+; you may only use these constants *after* the line that loads the extension.
+; About this file ;
+; This is the recommended, PHP 5-style version of the php.ini-dist file. It
+; sets some non standard settings, that make PHP more efficient, more secure,
+; and encourage cleaner coding.
+; The price is that with these settings, PHP may be incompatible with some
+; applications, and sometimes, more difficult to develop with. Using this
+; file is warmly recommended for production sites. As all of the changes from
+; the standard settings are thoroughly documented, you can go over each one,
+; and decide whether you want to use it or not.
+; For general information about the php.ini file, please consult the php.ini-dist
+; file, included in your PHP distribution.
+; This file is different from the php.ini-dist file in the fact that it features
+; different values for several directives, in order to improve performance, while
+; possibly breaking compatibility with the standard out-of-the-box behavior of
+; PHP. Please make sure you read what's different, and modify your scripts
+; accordingly, if you decide to use this file instead.
+; - register_globals = Off [Security, Performance]
+; Global variables are no longer registered for input data (POST, GET, cookies,
+; environment and other server variables). Instead of using $foo, you must use
+; you can use $_REQUEST["foo"] (includes any variable that arrives through the
+; request, namely, POST, GET and cookie variables), or use one of the specific
+; $_GET["foo"], $_POST["foo"], $_COOKIE["foo"] or $_FILES["foo"], depending
+; on where the input originates. Also, you can look at the
+; import_request_variables() function.
+; Note that register_globals is going to be depracated (i.e., turned off by
+; default) in the next version of PHP, because it often leads to security bugs.
+; Read http://php.net/manual/en/security.registerglobals.php for further
+; information.
+; - register_long_arrays = Off [Performance]
+; Disables registration of the older (and deprecated) long predefined array
+; variables ($HTTP_*_VARS). Instead, use the superglobals that were
+; introduced in PHP 4.1.0
+; - display_errors = Off [Security]
+; With this directive set to off, errors that occur during the execution of
+; scripts will no longer be displayed as a part of the script output, and thus,
+; will no longer be exposed to remote users. With some errors, the error message
+; content may expose information about your script, web server, or database
+; server that may be exploitable for hacking. Production sites should have this
+; directive set to off.
+; - log_errors = On [Security]
+; This directive complements the above one. Any errors that occur during the
+; execution of your script will be logged (typically, to your server's error log,
+; but can be configured in several ways). Along with setting display_errors to off,
+; this setup gives you the ability to fully understand what may have gone wrong,
+; without exposing any sensitive information to remote users.
+; - output_buffering = 4096 [Performance]
+; Set a 4KB output buffer. Enabling output buffering typically results in less
+; writes, and sometimes less packets sent on the wire, which can often lead to
+; better performance. The gain this directive actually yields greatly depends
+; on which Web server you're working with, and what kind of scripts you're using.
+; - register_argc_argv = Off [Performance]
+; Disables registration of the somewhat redundant $argv and $argc global
+; variables.
+; - magic_quotes_gpc = Off [Performance]
+; Input data is no longer escaped with slashes so that it can be sent into
+; SQL databases without further manipulation. Instead, you should use the
+; function addslashes() on each input element you wish to send to a database.
+; - variables_order = "GPCS" [Performance]
+; The environment variables are not hashed into the $_ENV. To access
+; environment variables, you can use getenv() instead.
+; - error_reporting = E_ALL [Code Cleanliness, Security(?)]
+; By default, PHP surpresses errors of type E_NOTICE. These error messages
+; are emitted for non-critical errors, but that could be a symptom of a bigger
+; problem. Most notably, this will cause error messages about the use
+; of uninitialized variables to be displayed.
+; - allow_call_time_pass_reference = Off [Code cleanliness]
+; It's not possible to decide to force a variable to be passed by reference
+; when calling a function. The PHP 4 style to do this is by making the
+; function require the relevant argument by reference.
+; Language Options ;
+; Enable the PHP scripting language engine under Apache.
+engine = On
+; Enable compatibility mode with Zend Engine 1 (PHP 4.x)
+zend.ze1_compatibility_mode = Off
+; Allow the <? tag. Otherwise, only <?php and <script> tags are recognized.
+; NOTE: Using short tags should be avoided when developing applications or
+; libraries that are meant for redistribution, or deployment on PHP
+; servers which are not under your control, because short tags may not
+; be supported on the target server. For portable, redistributable code,
+; be sure not to use short tags.
+short_open_tag = On
+; Allow ASP-style <% %> tags.
+asp_tags = Off
+; The number of significant digits displayed in floating point numbers.
+precision = 14
+; Enforce year 2000 compliance (will cause problems with non-compliant browsers)
+y2k_compliance = On
+; Output buffering allows you to send header lines (including cookies) even
+; after you send body content, at the price of slowing PHP's output layer a
+; bit. You can enable output buffering during runtime by calling the output
+; buffering functions. You can also enable output buffering for all files by
+; setting this directive to On. If you wish to limit the size of the buffer
+; to a certain size - you can use a maximum number of bytes instead of 'On', as
+; a value for this directive (e.g., output_buffering=4096).
+output_buffering = 4096
+; You can redirect all of the output of your scripts to a function. For
+; example, if you set output_handler to "mb_output_handler", character
+; encoding will be transparently converted to the specified encoding.
+; Setting any output handler automatically turns on output buffering.
+; Note: People who wrote portable scripts should not depend on this ini
+; directive. Instead, explicitly set the output handler using ob_start().
+; Using this ini directive may cause problems unless you know what script
+; is doing.
+; Note: You cannot use both "mb_output_handler" with "ob_iconv_handler"
+; and you cannot use both "ob_gzhandler" and "zlib.output_compression".
+; Note: output_handler must be empty if this is set 'On' !!!!
+; Instead you must use zlib.output_handler.
+;output_handler =
+; Transparent output compression using the zlib library
+; Valid values for this option are 'off', 'on', or a specific buffer size
+; to be used for compression (default is 4KB)
+; Note: Resulting chunk size may vary due to nature of compression. PHP
+; outputs chunks that are few hundreds bytes each as a result of
+; compression. If you prefer a larger chunk size for better
+; performance, enable output_buffering in addition.
+; Note: You need to use zlib.output_handler instead of the standard
+; output_handler, or otherwise the output will be corrupted.
+zlib.output_compression = Off
+; You cannot specify additional output handlers if zlib.output_compression
+; is activated here. This setting does the same as output_handler but in
+; a different order.
+;zlib.output_handler =
+; Implicit flush tells PHP to tell the output layer to flush itself
+; automatically after every output block. This is equivalent to calling the
+; PHP function flush() after each and every call to print() or echo() and each
+; and every HTML block. Turning this option on has serious performance
+; implications and is generally recommended for debugging purposes only.
+implicit_flush = Off
+; The unserialize callback function will be called (with the undefined class'
+; name as parameter), if the unserializer finds an undefined class
+; which should be instanciated.
+; A warning appears if the specified function is not defined, or if the
+; function doesn't include/implement the missing class.
+; So only set this entry, if you really want to implement such a
+; callback-function.
+unserialize_callback_func=
+; When floats & doubles are serialized store serialize_precision significant
+; digits after the floating point. The default value ensures that when floats
+; are decoded with unserialize, the data will remain the same.
+serialize_precision = 100
+; Whether to enable the ability to force arguments to be passed by reference
+; at function call time. This method is deprecated and is likely to be
+; unsupported in future versions of PHP/Zend. The encouraged method of
+; specifying which arguments should be passed by reference is in the function
+; declaration. You're encouraged to try and turn this option Off and make
+; sure your scripts work properly with it in order to ensure they will work
+; with future versions of the language (you will receive a warning each time
+; you use this feature, and the argument will be passed by value instead of by
+; reference).
+allow_call_time_pass_reference = Off
+; Safe Mode
+safe_mode = Off
+; By default, Safe Mode does a UID compare check when
+; opening files. If you want to relax this to a GID compare,
+; then turn on safe_mode_gid.
+safe_mode_gid = Off
+; When safe_mode is on, UID/GID checks are bypassed when
+; including files from this directory and its subdirectories.
+; (directory must also be in include_path or full path must
+; be used when including)
+safe_mode_include_dir =
+; When safe_mode is on, only executables located in the safe_mode_exec_dir
+; will be allowed to be executed via the exec family of functions.
+safe_mode_exec_dir =
+; Setting certain environment variables may be a potential security breach.
+; This directive contains a comma-delimited list of prefixes. In Safe Mode,
+; the user may only alter environment variables whose names begin with the
+; prefixes supplied here. By default, users will only be able to set
+; environment variables that begin with PHP_ (e.g. PHP_FOO=BAR).
+; Note: If this directive is empty, PHP will let the user modify ANY
+; environment variable!
+safe_mode_allowed_env_vars = PHP_
+; This directive contains a comma-delimited list of environment variables that
+; the end user won't be able to change using putenv(). These variables will be
+; protected even if safe_mode_allowed_env_vars is set to allow to change them.
+safe_mode_protected_env_vars = LD_LIBRARY_PATH
+; open_basedir, if set, limits all file operations to the defined directory
+; and below. This directive makes most sense if used in a per-directory
+; or per-virtualhost web server configuration file. This directive is
+; *NOT* affected by whether Safe Mode is turned On or Off.
+;open_basedir =
+; This directive allows you to disable certain functions for security reasons.
+; It receives a comma-delimited list of function names. This directive is
+disable_functions =
+; This directive allows you to disable certain classes for security reasons.
+; It receives a comma-delimited list of class names. This directive is
+disable_classes =
+; Colors for Syntax Highlighting mode. Anything that's acceptable in
+; <span style="color: ???????"> would work.
+;highlight.string = #DD0000
+;highlight.comment = #FF9900
+;highlight.keyword = #007700
+;highlight.bg = #FFFFFF
+;highlight.default = #0000BB
+;highlight.html = #000000
+; Misc
+; Decides whether PHP may expose the fact that it is installed on the server
+; (e.g. by adding its signature to the Web server header). It is no security
+; threat in any way, but it makes it possible to determine whether you use PHP
+; on your server or not.
+expose_php = Off
+; Resource Limits ;
+max_execution_time = 180 ; Maximum execution time of each script, in seconds
+max_input_time = 60 ; Maximum amount of time each script may spend parsing request data
+memory_limit = 256M ; Maximum amount of memory a script may consume
+; Error handling and logging ;
+; error_reporting is a bit-field. Or each number up to get desired error
+; reporting level
+; E_ALL - All errors and warnings (doesn't include E_STRICT)
+; E_ERROR - fatal run-time errors
+; E_WARNING - run-time warnings (non-fatal errors)
+; E_PARSE - compile-time parse errors
+; E_NOTICE - run-time notices (these are warnings which often result
+; from a bug in your code, but it's possible that it was
+; intentional (e.g., using an uninitialized variable and
+; relying on the fact it's automatically initialized to an
+; empty string)
+; E_STRICT - run-time notices, enable to have PHP suggest changes
+; to your code which will ensure the best interoperability
+; and forward compatibility of your code
+; E_CORE_ERROR - fatal errors that occur during PHP's initial startup
+; E_CORE_WARNING - warnings (non-fatal errors) that occur during PHP's
+; initial startup
+; E_COMPILE_ERROR - fatal compile-time errors
+; E_COMPILE_WARNING - compile-time warnings (non-fatal errors)
+; E_USER_ERROR - user-generated error message
+; E_USER_WARNING - user-generated warning message
+; E_USER_NOTICE - user-generated notice message
+; Examples:
+; - Show all errors, except for notices and coding standards warnings
+;error_reporting = E_ALL & ~E_NOTICE & ~E_STRICT
+; - Show only errors
+;error_reporting = E_COMPILE_ERROR|E_ERROR|E_CORE_ERROR
+error_reporting = E_ALL
+; Print out errors (as a part of the output). For production web sites,
+; you're strongly encouraged to turn this feature off, and use error logging
+; instead (see below). Keeping display_errors enabled on a production web site
+; may reveal security information to end users, such as file paths on your Web
+; server, your database schema or other information.
+display_errors = Off
+; Even when display_errors is on, errors that occur during PHP's startup
+; sequence are not displayed. It's strongly recommended to keep
+; display_startup_errors off, except for when debugging.
+display_startup_errors = Off
+; Log errors into a log file (server-specific log, stderr, or error_log (below))
+; As stated above, you're strongly advised to use error logging in place of
+; error displaying on production web sites.
+log_errors = On
+; Set maximum length of log_errors. In error_log information about the source is
+; added. The default is 1024 and 0 allows to not apply any maximum length at all.
+log_errors_max_len = 1024
+; Do not log repeated messages. Repeated errors must occur in same file on same
+; line until ignore_repeated_source is set true.
+ignore_repeated_errors = Off
+; Ignore source of message when ignoring repeated messages. When this setting
+; is On you will not log errors with repeated messages from different files or
+; sourcelines.
+ignore_repeated_source = Off
+; If this parameter is set to Off, then memory leaks will not be shown (on
+; stdout or in the log). This has only effect in a debug compile, and if
+; error reporting includes E_WARNING in the allowed list
+report_memleaks = On
+; Store the last error/warning message in $php_errormsg (boolean).
+track_errors = Off
+; Disable the inclusion of HTML tags in error messages.
+; Note: Never use this feature for production boxes.
+;html_errors = Off
+; If html_errors is set On PHP produces clickable error messages that direct
+; to a page describing the error or function causing the error in detail.
+; You can download a copy of the PHP manual from http://www.php.net/docs.php
+; and change docref_root to the base URL of your local copy including the
+; leading '/'. You must also specify the file extension being used including
+; the dot.
+;docref_root = "/phpmanual/"
+;docref_ext = .html
+; String to output before an error message.
+;error_prepend_string = "<font color=ff0000>"
+; String to output after an error message.
+;error_append_string = "</font>"
+; Log errors to specified file.
+;error_log = filename
+; Log errors to syslog (Event Log on NT, not valid in Windows 95).
+;error_log = syslog
+; Data Handling ;
+; Note - track_vars is ALWAYS enabled as of PHP 4.0.3
+; The separator used in PHP generated URLs to separate arguments.
+; Default is "&".
+;arg_separator.output = "&"
+; List of separator(s) used by PHP to parse input URLs into variables.
+; Default is "&".
+; NOTE: Every character in this directive is considered as separator!
+;arg_separator.input = ";&"
+; This directive describes the order in which PHP registers GET, POST, Cookie,
+; Environment and Built-in variables (G, P, C, E & S respectively, often
+; referred to as EGPCS or GPC). Registration is done from left to right, newer
+; values override older values.
+variables_order = "GPCS"
+; Whether or not to register the EGPCS variables as global variables. You may
+; want to turn this off if you don't want to clutter your scripts' global scope
+; with user data. This makes most sense when coupled with track_vars - in which
+; case you can access all of the GPC variables through the $HTTP_*_VARS[],
+; variables.
+; You should do your best to write your scripts so that they do not require
+; register_globals to be on; Using form variables as globals can easily lead
+; to possible security problems, if the code is not very well thought of.
+register_globals = Off
+; Whether or not to register the old-style input arrays, HTTP_GET_VARS
+; and friends. If you're not using them, it's recommended to turn them off,
+; for performance reasons.
+register_long_arrays = Off
+; This directive tells PHP whether to declare the argv&argc variables (that
+; would contain the GET information). If you don't use these variables, you
+; should turn it off for increased performance.
+register_argc_argv = Off
+; When enabled, the SERVER and ENV variables are created when they're first
+; used (Just In Time) instead of when the script starts. If these variables
+; are not used within a script, having this directive on will result in a
+; performance gain. The PHP directives register_globals, register_long_arrays,
+; and register_argc_argv must be disabled for this directive to have any affect.
+auto_globals_jit = On
+; Maximum size of POST data that PHP will accept.
+post_max_size = 64M
+; Magic quotes
+; Magic quotes for incoming GET/POST/Cookie data.
+magic_quotes_gpc = Off
+; Magic quotes for runtime-generated data, e.g. data from SQL, from exec(), etc.
+magic_quotes_runtime = Off
+; Use Sybase-style magic quotes (escape ' with '' instead of \').
+magic_quotes_sybase = Off
+; Automatically add files before or after any PHP document.
+auto_prepend_file =
+auto_append_file =
+; As of 4.0b4, PHP always outputs a character encoding by default in
+; the Content-type: header. To disable sending of the charset, simply
+; set it to be empty.
+; PHP's built-in default is text/html
+default_mimetype = "text/html"
+;default_charset = "iso-8859-1"
+; Always populate the $HTTP_RAW_POST_DATA variable.
+;always_populate_raw_post_data = On
+; Paths and Directories ;
+; UNIX: "/path1:/path2"
+;include_path = ".:/php/includes"
+; Windows: "\path1;\path2"
+;include_path = ".;c:\php\includes"
+; The root of the PHP pages, used only if nonempty.
+; if PHP was not compiled with FORCE_REDIRECT, you SHOULD set doc_root
+; if you are running php as a CGI under any web server (other than IIS)
+; see documentation for security issues. The alternate is to use the
+; cgi.force_redirect configuration below
+doc_root =
+; The directory under which PHP opens the script using /~username used only
+; if nonempty.
+user_dir =
+; Directory in which the loadable extensions (modules) reside.
+extension_dir = "%MG_WEB_PHP%ext"
+; Whether or not to enable the dl() function. The dl() function does NOT work
+; properly in multithreaded servers, such as IIS or Zeus, and is automatically
+; disabled on them.
+enable_dl = On
+; cgi.force_redirect is necessary to provide security running PHP as a CGI under
+; most web servers. Left undefined, PHP turns this on by default. You can
+; turn it off here AT YOUR OWN RISK
+; **You CAN safely turn this off for IIS, in fact, you MUST.**
+; cgi.force_redirect = 1
+; if cgi.nph is enabled it will force cgi to always sent Status: 200 with
+; every request.
+; cgi.nph = 1
+; if cgi.force_redirect is turned on, and you are not running under Apache or Netscape
+; (iPlanet) web servers, you MAY need to set an environment variable name that PHP
+; will look for to know it is OK to continue execution. Setting this variable MAY
+; cause security issues, KNOW WHAT YOU ARE DOING FIRST.
+; cgi.redirect_status_env = ;
+; FastCGI under IIS (on WINNT based OS) supports the ability to impersonate
+; security tokens of the calling client. This allows IIS to define the
+; security context that the request runs under. mod_fastcgi under Apache
+; does not currently support this feature (03/17/2002)
+; Set to 1 if running under IIS. Default is zero.
+; fastcgi.impersonate = 1;
+; Disable logging through FastCGI connection
+; fastcgi.log = 0
+; cgi.rfc2616_headers configuration option tells PHP what type of headers to
+; use when sending HTTP response code. If it's set 0 PHP sends Status: header that
+; is supported by Apache. When this option is set to 1 PHP will send
+; RFC2616 compliant header.
+; Default is zero.
+;cgi.rfc2616_headers = 0
+; File Uploads ;
+; Whether to allow HTTP file uploads.
+file_uploads = On
+; Temporary directory for HTTP uploaded files (will use system default if not
+; specified).
+;upload_tmp_dir =
+; Maximum allowed size for uploaded files.
+upload_max_filesize = 2M
+; Fopen wrappers ;
+; Whether to allow the treatment of URLs (like http:// or ftp://) as files.
+allow_url_fopen = On
+; Define the anonymous ftp password (your email address)
+;from="john at doe.com"
+; Define the User-Agent string
+; user_agent="PHP"
+; Default timeout for socket based streams (seconds)
+default_socket_timeout = 60
+; If your scripts have to deal with files from Macintosh systems,
+; or you are running on a Mac and need to deal with files from
+; unix or win32 systems, setting this flag will cause PHP to
+; automatically detect the EOL character in those files so that
+; fgets() and file() will work regardless of the source of the file.
+; auto_detect_line_endings = Off
+; Dynamic Extensions ;
+; If you wish to have an extension loaded automatically, use the following
+; syntax:
+; extension=modulename.extension
+; For example, on Windows:
+; extension=msql.dll
+; ... or under UNIX:
+; extension=msql.so
+; Note that it should be the name of the module only; no directory information
+; needs to go here. Specify the location of the extension with the
+; extension_dir directive above.
+;Windows Extensions
+;Note that ODBC support is built in, so no dll is needed for it.
+extension=php_mbstring.dll
+;extension=php_bz2.dll
+;extension=php_cpdf.dll
+;extension=php_curl.dll
+;extension=php_dba.dll
+;extension=php_dbase.dll
+;extension=php_dbx.dll
+;extension=php_exif.dll
+;extension=php_fdf.dll
+;extension=php_filepro.dll
+extension=php_gd2.dll
+;extension=php_gettext.dll
+;extension=php_ifx.dll
+;extension=php_iisfunc.dll
+;extension=php_imap.dll
+;extension=php_interbase.dll
+;extension=php_java.dll
+;extension=php_ldap.dll
+;extension=php_mcrypt.dll
+;extension=php_mhash.dll
+;extension=php_mime_magic.dll
+;extension=php_ming.dll
+;extension=php_mssql.dll
+;extension=php_msql.dll
+;extension=php_mysql.dll
+;extension=php_oci8.dll
+;extension=php_openssl.dll
+;extension=php_oracle.dll
+;extension=php_pdf.dll
+;extension=php_pgsql.dll
+;extension=php_shmop.dll
+;extension=php_snmp.dll
+;extension=php_sockets.dll
+;extension=php_sybase_ct.dll
+;extension=php_tidy.dll
+;extension=php_w32api.dll
+;extension=php_xmlrpc.dll
+extension=php_xsl.dll
+;extension=php_yaz.dll
+;extension=php_zip.dll
+extension=php_MapGuideApiEnvConfig.dll
+extension=php_MapGuideApi.dll
+; Module Settings ;
+[Syslog]
+; Whether or not to define the various syslog variables (e.g. $LOG_PID,
+; $LOG_CRON, etc.). Turning it off is a good idea performance-wise. In
+; runtime, you can define these variables by calling define_syslog_variables().
+define_syslog_variables = Off
+[mail function]
+; For Win32 only.
+SMTP = localhost
+smtp_port = 25
+; For Win32 only.
+;sendmail_from = me at example.com
+; For Unix only. You may supply arguments as well (default: "sendmail -t -i").
+;sendmail_path =
+; Force the addition of the specified parameters to be passed as extra parameters
+; to the sendmail binary. These parameters will always replace the value of
+; the 5th parameter to mail(), even in safe mode.
+;mail.force_extra_parameters =
+[SQL]
+sql.safe_mode = Off
+[ODBC]
+;odbc.default_db = Not yet implemented
+;odbc.default_user = Not yet implemented
+;odbc.default_pw = Not yet implemented
+; Allow or prevent persistent links.
+odbc.allow_persistent = On
+; Check that a connection is still valid before reuse.
+odbc.check_persistent = On
+; Maximum number of persistent links. -1 means no limit.
+odbc.max_persistent = -1
+; Maximum number of links (persistent + non-persistent). -1 means no limit.
+odbc.max_links = -1
+; Handling of LONG fields. Returns number of bytes to variables. 0 means
+; passthru.
+odbc.defaultlrl = 4096
+; Handling of binary data. 0 means passthru, 1 return as is, 2 convert to char.
+; See the documentation on odbc_binmode and odbc_longreadlen for an explanation
+; of uodbc.defaultlrl and uodbc.defaultbinmode
+odbc.defaultbinmode = 1
+[MySQL]
+mysql.allow_persistent = On
+mysql.max_persistent = -1
+mysql.max_links = -1
+; Default port number for mysql_connect(). If unset, mysql_connect() will use
+; the $MYSQL_TCP_PORT or the mysql-tcp entry in /etc/services or the
+; compile-time value defined MYSQL_PORT (in that order). Win32 will only look
+; at MYSQL_PORT.
+mysql.default_port =
+; Default socket name for local MySQL connects. If empty, uses the built-in
+; MySQL defaults.
+mysql.default_socket =
+; Default host for mysql_connect() (doesn't apply in safe mode).
+mysql.default_host =
+; Default user for mysql_connect() (doesn't apply in safe mode).
+mysql.default_user =
+; Default password for mysql_connect() (doesn't apply in safe mode).
+; Note that this is generally a *bad* idea to store passwords in this file.
+; *Any* user with PHP access can run 'echo get_cfg_var("mysql.default_password")
+; and reveal this password! And of course, any users with read access to this
+; file will be able to reveal the password as well.
+mysql.default_password =
+; Maximum time (in secondes) for connect timeout. -1 means no limit
+mysql.connect_timeout = 60
+; Trace mode. When trace_mode is active (=On), warnings for table/index scans and
+; SQL-Errors will be displayed.
+mysql.trace_mode = Off
+[MySQLI]
+; Maximum number of links. -1 means no limit.
+mysqli.max_links = -1
+; Default port number for mysqli_connect(). If unset, mysqli_connect() will use
+; at MYSQL_PORT.
+mysqli.default_port = 3306
+; MySQL defaults.
+mysqli.default_socket =
+mysqli.default_host =
+mysqli.default_user =
+; Default password for mysqli_connect() (doesn't apply in safe mode).
+; *Any* user with PHP access can run 'echo get_cfg_var("mysqli.default_pw")
+mysqli.default_pw =
+; Allow or prevent reconnect
+mysqli.reconnect = Off
+[mSQL]
+msql.allow_persistent = On
+msql.max_persistent = -1
+; Maximum number of links (persistent+non persistent). -1 means no limit.
+msql.max_links = -1
+[PostgresSQL]
+pgsql.allow_persistent = On
+; Detect broken persistent links always with pg_pconnect().
+; Auto reset feature requires a little overheads.
+pgsql.auto_reset_persistent = Off
+pgsql.max_persistent = -1
+pgsql.max_links = -1
+; Ignore PostgreSQL backends Notice message or not.
+; Notice message logging require a little overheads.
+pgsql.ignore_notice = 0
+; Log PostgreSQL backends Noitce message or not.
+; Unless pgsql.ignore_notice=0, module cannot log notice message.
+pgsql.log_notice = 0
+[Sybase]
+sybase.allow_persistent = On
+sybase.max_persistent = -1
+sybase.max_links = -1
+;sybase.interface_file = "/usr/sybase/interfaces"
+; Minimum error severity to display.
+sybase.min_error_severity = 10
+; Minimum message severity to display.
+sybase.min_message_severity = 10
+; Compatability mode with old versions of PHP 3.0.
+; If on, this will cause PHP to automatically assign types to results according
+; to their Sybase type, instead of treating them all as strings. This
+; compatability mode will probably not stay around forever, so try applying
+; whatever necessary changes to your code, and turn it off.
+sybase.compatability_mode = Off
+[Sybase-CT]
+sybct.allow_persistent = On
+sybct.max_persistent = -1
+sybct.max_links = -1
+; Minimum server message severity to display.
+sybct.min_server_severity = 10
+; Minimum client message severity to display.
+sybct.min_client_severity = 10
+[dbx]
+; returned column names can be converted for compatibility reasons
+; possible values for dbx.colnames_case are
+; "unchanged" (default, if not set)
+; "lowercase"
+; "uppercase"
+; the recommended default is either upper- or lowercase, but
+; unchanged is currently set for backwards compatibility
+dbx.colnames_case = "lowercase"
+[bcmath]
+; Number of decimal digits for all bcmath functions.
+bcmath.scale = 0
+[browscap]
+;browscap = extra/browscap.ini
+[Informix]
+; Default host for ifx_connect() (doesn't apply in safe mode).
+ifx.default_host =
+; Default user for ifx_connect() (doesn't apply in safe mode).
+ifx.default_user =
+; Default password for ifx_connect() (doesn't apply in safe mode).
+ifx.default_password =
+ifx.allow_persistent = On
+ifx.max_persistent = -1
+ifx.max_links = -1
+; If on, select statements return the contents of a text blob instead of its id.
+ifx.textasvarchar = 0
+; If on, select statements return the contents of a byte blob instead of its id.
+ifx.byteasvarchar = 0
+; Trailing blanks are stripped from fixed-length char columns. May help the
+; life of Informix SE users.
+ifx.charasvarchar = 0
+; If on, the contents of text and byte blobs are dumped to a file instead of
+; keeping them in memory.
+ifx.blobinfile = 0
+; NULL's are returned as empty strings, unless this is set to 1. In that case,
+; NULL's are returned as string 'NULL'.
+ifx.nullformat = 0
+[Session]
+; Handler used to store/retrieve data.
+session.save_handler = files
+; Argument passed to save_handler. In the case of files, this is the path
+; where data files are stored. Note: Windows users have to change this
+; variable in order to use PHP's session functions.
+; As of PHP 4.0.1, you can define the path as:
+; session.save_path = "N;/path"
+; where N is an integer. Instead of storing all the session files in
+; /path, what this will do is use subdirectories N-levels deep, and
+; store the session data in those directories. This is useful if you
+; or your OS have problems with lots of files in one directory, and is
+; a more efficient layout for servers that handle lots of sessions.
+; NOTE 1: PHP will not create this directory structure automatically.
+; You can use the script in the ext/session dir for that purpose.
+; NOTE 2: See the section on garbage collection below if you choose to
+; use subdirectories for session storage
+; The file storage module creates files using mode 600 by default.
+; You can change that by using
+; session.save_path = "N;MODE;/path"
+; where MODE is the octal representation of the mode. Note that this
+; does not overwrite the process's umask.
+;session.save_path = "/tmp"
+session.save_path = "%MG_WEB_TEMP%"
+; Whether to use cookies.
+session.use_cookies = 1
+; This option enables administrators to make their users invulnerable to
+; attacks which involve passing session ids in URLs; defaults to 0.
+; session.use_only_cookies = 1
+; Name of the session (used as cookie name).
+session.name = PHPSESSID
+; Initialize session on request startup.
+session.auto_start = 0
+; Lifetime in seconds of cookie or, if 0, until browser is restarted.
+session.cookie_lifetime = 0
+; The path for which the cookie is valid.
+session.cookie_path = /
+; The domain for which the cookie is valid.
+session.cookie_domain =
+; Handler used to serialize data. php is the standard serializer of PHP.
+session.serialize_handler = php
+; Define the probability that the 'garbage collection' process is started
+; on every session initialization.
+; The probability is calculated by using gc_probability/gc_divisor,
+; e.g. 1/100 means there is a 1% chance that the GC process starts
+; on each request.
+session.gc_probability = 1
+session.gc_divisor = 1000
+; After this number of seconds, stored data will be seen as 'garbage' and
+; cleaned up by the garbage collection process.
+session.gc_maxlifetime = 1440
+; NOTE: If you are using the subdirectory option for storing session files
+; (see session.save_path above), then garbage collection does *not*
+; happen automatically. You will need to do your own garbage
+; collection through a shell script, cron entry, or some other method.
+; For example, the following script would is the equivalent of
+; setting session.gc_maxlifetime to 1440 (1440 seconds = 24 minutes):
+; cd /path/to/sessions; find -cmin +24 | xargs rm
+; PHP 4.2 and less have an undocumented feature/bug that allows you to
+; to initialize a session variable in the global scope, albeit register_globals
+; is disabled. PHP 4.3 and later will warn you, if this feature is used.
+; You can disable the feature and the warning separately. At this time,
+; the warning is only displayed, if bug_compat_42 is enabled.
+session.bug_compat_42 = 0
+session.bug_compat_warn = 1
+; Check HTTP Referer to invalidate externally stored URLs containing ids.
+; HTTP_REFERER has to contain this substring for the session to be
+; considered as valid.
+session.referer_check =
+; How many bytes to read from the file.
+session.entropy_length = 0
+; Specified here to create the session id.
+session.entropy_file =
+;session.entropy_length = 16
+;session.entropy_file = /dev/urandom
+; Set to {nocache,private,public,} to determine HTTP caching aspects
+; or leave this empty to avoid sending anti-caching headers.
+session.cache_limiter = nocache
+; Document expires after n minutes.
+session.cache_expire = 180
+; trans sid support is disabled by default.
+; Use of trans sid may risk your users security.
+; Use this option with caution.
+; - User may send URL contains active session ID
+; to other person via. email/irc/etc.
+; - URL that contains active session ID may be stored
+; in publically accessible computer.
+; - User may access your site with the same session ID
+; always using URL stored in browser's history or bookmarks.
+session.use_trans_sid = 0
+; Select a hash function
+; 0: MD5 (128 bits)
+; 1: SHA-1 (160 bits)
+session.hash_function = 0
+; Define how many bits are stored in each character when converting
+; the binary hash data to something readable.
+; 4 bits: 0-9, a-f
+; 5 bits: 0-9, a-v
+; 6 bits: 0-9, a-z, A-Z, "-", ","
+session.hash_bits_per_character = 5
+; The URL rewriter will look for URLs in a defined set of HTML tags.
+; form/fieldset are special; if you include them here, the rewriter will
+; add a hidden <input> field with the info which is otherwise appended
+; to URLs. If you want XHTML conformity, remove the form entry.
+; Note that all valid entries require a "=", even if no value follows.
+url_rewriter.tags = "a=href,area=href,frame=src,input=src,form=fakeentry"
+[MSSQL]
+mssql.allow_persistent = On
+mssql.max_persistent = -1
+mssql.max_links = -1
+mssql.min_error_severity = 10
+mssql.min_message_severity = 10
+mssql.compatability_mode = Off
+; Connect timeout
+;mssql.connect_timeout = 5
+; Query timeout
+;mssql.timeout = 60
+; Valid range 0 - 2147483647. Default = 4096.
+;mssql.textlimit = 4096
+;mssql.textsize = 4096
+; Limits the number of records in each batch. 0 = all records in one batch.
+;mssql.batchsize = 0
+; Specify how datetime and datetim4 columns are returned
+; On => Returns data converted to SQL server settings
+; Off => Returns values as YYYY-MM-DD hh:mm:ss
+;mssql.datetimeconvert = On
+; Use NT authentication when connecting to the server
+mssql.secure_connection = Off
+; Specify max number of processes. Default = 25
+;mssql.max_procs = 25
+[Assertion]
+; Assert(expr); active by default.
+;assert.active = On
+; Issue a PHP warning for each failed assertion.
+;assert.warning = On
+; Don't bail out by default.
+;assert.bail = Off
+; User-function to be called if an assertion fails.
+;assert.callback = 0
+; Eval the expression with current error_reporting(). Set to true if you want
+; error_reporting(0) around the eval().
+;assert.quiet_eval = 0
+[Ingres II]
+ingres.allow_persistent = On
+ingres.max_persistent = -1
+; Maximum number of links, including persistents. -1 means no limit.
+ingres.max_links = -1
+; Default database (format: [node_id::]dbname[/srv_class]).
+ingres.default_database =
+; Default user.
+ingres.default_user =
+; Default password.
+ingres.default_password =
+[Verisign Payflow Pro]
+; Default Payflow Pro server.
+pfpro.defaulthost = "test-payflow.verisign.com"
+; Default port to connect to.
+pfpro.defaultport = 443
+; Default timeout in seconds.
+pfpro.defaulttimeout = 30
+; Default proxy IP address (if required).
+;pfpro.proxyaddress =
+; Default proxy port.
+;pfpro.proxyport =
+; Default proxy logon.
+;pfpro.proxylogon =
+; Default proxy password.
+;pfpro.proxypassword =
+[com]
+; path to a file containing GUIDs, IIDs or filenames of files with TypeLibs
+;com.typelib_file =
+; allow Distributed-COM calls
+;com.allow_dcom = true
+; autoregister constants of a components typlib on com_load()
+;com.autoregister_typelib = true
+; register constants casesensitive
+;com.autoregister_casesensitive = false
+; show warnings on duplicate constat registrations
+;com.autoregister_verbose = true
+[mbstring]
+; language for internal character representation.
+mbstring.language = UTF-8
+; internal/script encoding.
+; Some encoding cannot work as internal encoding.
+; (e.g. SJIS, BIG5, ISO-2022-*)
+mbstring.internal_encoding = UTF-8
+; http input encoding.
+mbstring.http_input = UTF-8
+; http output encoding. mb_output_handler must be
+; registered as output buffer to function
+mbstring.http_output = pass
+; enable automatic encoding translation accoding to
+; mbstring.internal_encoding setting. Input chars are
+; converted to internal encoding by setting this to On.
+; Note: Do _not_ use automatic encoding translation for
+; portable libs/applications.
+mbstring.encoding_translation = Off
+; automatic encoding detection order.
+; auto means
+mbstring.detect_order = auto
+; substitute_character used when character cannot be converted
+; one from another
+;mbstring.substitute_character = none;
+; overload(replace) single byte functions by mbstring functions.
+; mail(), ereg(), etc are overloaded by mb_send_mail(), mb_ereg(),
+; etc. Possible values are 0,1,2,4 or combination of them.
+; For example, 7 for overload everything.
+; 0: No overload
+; 1: Overload mail() function
+; 2: Overload str*() functions
+; 4: Overload ereg*() functions
+mbstring.func_overload = 0
+[FrontBase]
+;fbsql.allow_persistent = On
+;fbsql.autocommit = On
+;fbsql.default_database =
+;fbsql.default_database_password =
+;fbsql.default_host =
+;fbsql.default_password =
+;fbsql.default_user = "_SYSTEM"
+;fbsql.generate_warnings = Off
+;fbsql.max_connections = 128
+;fbsql.max_links = 128
+;fbsql.max_persistent = -1
+;fbsql.max_results = 128
+;fbsql.batchSize = 1000
+[exif]
+; Exif UNICODE user comments are handled as UCS-2BE/UCS-2LE and JIS as JIS.
+; With mbstring support this will automatically be converted into the encoding
+; given by corresponding encode setting. When empty mbstring.internal_encoding
+; is used. For the decode settings you can distinguish between motorola and
+; intel byte order. A decode setting cannot be empty.
+;exif.encode_unicode = ISO-8859-15
+;exif.decode_unicode_motorola = UCS-2BE
+;exif.decode_unicode_intel = UCS-2LE
+;exif.encode_jis =
+;exif.decode_jis_motorola = JIS
+;exif.decode_jis_intel = JIS
+[Tidy]
+; The path to a default tidy configuration file to use when using tidy
+;tidy.default_config = /usr/local/lib/php/default.tcfg
+; Should tidy clean and repair output automatically?
+; WARNING: Do not use this option if you are generating non-html content
+; such as dynamic images
+tidy.clean_output = Off
+[soap]
+; Enables or disables WSDL caching feature.
+soap.wsdl_cache_enabled=1
+; Sets the directory name where SOAP extension will put cache files.
+soap.wsdl_cache_dir="/tmp"
+; (time to live) Sets the number of second while cached file will be used
+; instead of original one.
+soap.wsdl_cache_ttl=86400
+; Local Variables:
+; tab-width: 4
+; End:
Added: trunk/Installer/Support/Web/x86/Tomcat/conf/Catalina/localhost/mapguide.xml
--- trunk/Installer/Support/Web/x86/Tomcat/conf/Catalina/localhost/mapguide.xml (rev 0)
+++ trunk/Installer/Support/Web/x86/Tomcat/conf/Catalina/localhost/mapguide.xml 2011-10-28 10:46:47 UTC (rev 6190)
@@ -0,0 +1,17 @@
+ Context configuration file for the Tomcat Manager Web App
+ $Id: manager.xml,v 1.3 2004/08/26 17:03:34 remm Exp $
+<Context docBase="%MG_WEB_ROOT%"
+ privileged="true" antiResourceLocking="false" antiJARLocking="false">
+ <!-- Link to the user database we will get roles from -->
+ <ResourceLink name="users" global="UserDatabase"
+ type="org.apache.catalina.UserDatabase"/>
+</Context>
More information about the mapguide-commits
