[mapguide-commits] r6192 - in trunk/Tools/MgInstantSetup:
InstantSetup InstantSetup.Core InstantSetup.Core/Properties
InstantSetup.Core/Resources
svn_mapguide at osgeo.org
Fri Oct 28 09:15:23 EDT 2011
Author: jng
Date: 2011-10-28 06:15:23 -0700 (Fri, 28 Oct 2011)
New Revision: 6192
Added:
trunk/Tools/MgInstantSetup/InstantSetup.Core/Resources/APACHE_WEB1.txt
trunk/Tools/MgInstantSetup/InstantSetup.Core/Resources/SERVER1.txt
trunk/Tools/MgInstantSetup/InstantSetup.Core/Resources/SERVER_INSTALL1.txt
trunk/Tools/MgInstantSetup/InstantSetup.Core/Resources/SERVER_UNINSTALL1.txt
trunk/Tools/MgInstantSetup/InstantSetup.Core/AbstractSetupConfigurationProcess.cs
trunk/Tools/MgInstantSetup/InstantSetup.Core/ApacheSetupConfigurationProcess.cs
trunk/Tools/MgInstantSetup/InstantSetup.Core/InstantSetup.Core.csproj
trunk/Tools/MgInstantSetup/InstantSetup.Core/Properties/Resources.Designer.cs
trunk/Tools/MgInstantSetup/InstantSetup.Core/Properties/Resources.resx
trunk/Tools/MgInstantSetup/InstantSetup/Form1.Designer.cs
trunk/Tools/MgInstantSetup/InstantSetup/Form1.cs
#1840: Update MgInstantSetup utility to support RFC122
Modified: trunk/Tools/MgInstantSetup/InstantSetup/Form1.Designer.cs
--- trunk/Tools/MgInstantSetup/InstantSetup/Form1.Designer.cs 2011-10-28 11:38:49 UTC (rev 6191)
+++ trunk/Tools/MgInstantSetup/InstantSetup/Form1.Designer.cs 2011-10-28 13:15:23 UTC (rev 6192)
@@ -41,6 +41,7 @@
this.button1 = new System.Windows.Forms.Button();
this.txtBatchOutput = new System.Windows.Forms.TextBox();
this.label3 = new System.Windows.Forms.Label();
+ this.chkWriteMentorDictPath = new System.Windows.Forms.CheckBox();
this.tabControl1.SuspendLayout();
this.SuspendLayout();
@@ -169,11 +170,23 @@
this.label3.TabIndex = 8;
this.label3.Text = "Batch File Output Directory";
+ // chkWriteMentorDictPath
+ this.chkWriteMentorDictPath.AutoSize = true;
+ this.chkWriteMentorDictPath.Location = new System.Drawing.Point(116, 513);
+ this.chkWriteMentorDictPath.Name = "chkWriteMentorDictPath";
+ this.chkWriteMentorDictPath.Size = new System.Drawing.Size(271, 17);
+ this.chkWriteMentorDictPath.TabIndex = 11;
+ this.chkWriteMentorDictPath.Text = "Write MENTOR_DICTIONARY_PATH to batch files";
+ this.chkWriteMentorDictPath.UseVisualStyleBackColor = true;
+ this.chkWriteMentorDictPath.CheckedChanged += new System.EventHandler(this.chkWriteMentorDictPath_CheckedChanged);
// Form1
this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
this.ClientSize = new System.Drawing.Size(552, 544);
+ this.Controls.Add(this.chkWriteMentorDictPath);
this.Controls.Add(this.button1);
this.Controls.Add(this.txtBatchOutput);
this.Controls.Add(this.label3);
@@ -208,6 +221,7 @@
private System.Windows.Forms.Button button1;
private System.Windows.Forms.TextBox txtBatchOutput;
private System.Windows.Forms.Label label3;
+ private System.Windows.Forms.CheckBox chkWriteMentorDictPath;
Modified: trunk/Tools/MgInstantSetup/InstantSetup/Form1.cs
--- trunk/Tools/MgInstantSetup/InstantSetup/Form1.cs 2011-10-28 11:38:49 UTC (rev 6191)
+++ trunk/Tools/MgInstantSetup/InstantSetup/Form1.cs 2011-10-28 13:15:23 UTC (rev 6192)
@@ -72,6 +72,11 @@
_apacheConf.Config.InstallServices = chkInstallServices.Checked;
+ private void chkWriteMentorDictPath_CheckedChanged(object sender, EventArgs e)
+ _apacheConf.Config.WriteMentorDictionaryPath = chkWriteMentorDictPath.Checked;
private void btnConfigure_Click(object sender, EventArgs e)
try
Modified: trunk/Tools/MgInstantSetup/InstantSetup.Core/AbstractSetupConfigurationProcess.cs
--- trunk/Tools/MgInstantSetup/InstantSetup.Core/AbstractSetupConfigurationProcess.cs 2011-10-28 11:38:49 UTC (rev 6191)
+++ trunk/Tools/MgInstantSetup/InstantSetup.Core/AbstractSetupConfigurationProcess.cs 2011-10-28 13:15:23 UTC (rev 6192)
@@ -39,6 +39,7 @@
protected AbstractSetupConfigurationProcess()
this.EnablePhp = true;
+ this.WriteMentorDictionaryPath = false;
this.DefaultViewer = ApiType.Php;
//Port numbers specified not to intentionally clash with an existing
@@ -48,6 +49,8 @@
this.ServerSitePort = 2822;
+ public bool WriteMentorDictionaryPath { get; set; }
public string BatchFileOutputDirectory { get; set; }
public string MapGuideServiceName { get; set; }
@@ -207,18 +210,34 @@
else
- //Write server batch file
- string serverText = string.Format(Properties.Resources.SERVER, this.CsMapDictionaryDir, this.ServerBinDir);
- File.WriteAllText(Path.Combine(this.BatchFileOutputDirectory, "mgserver.bat"), serverText);
+ if (this.WriteMentorDictionaryPath)
+ //Write server batch file
+ string serverText = string.Format(Properties.Resources.SERVER, this.CsMapDictionaryDir, this.ServerBinDir);
+ File.WriteAllText(Path.Combine(this.BatchFileOutputDirectory, "mgserver.bat"), serverText);
- //Write service install batch file
- serverText = string.Format(Properties.Resources.SERVER_INSTALL, this.CsMapDictionaryDir, this.ServerBinDir, this.MapGuideServiceName);
- File.WriteAllText(Path.Combine(this.BatchFileOutputDirectory, "mgserverinstall.bat"), serverText);
+ //Write service install batch file
+ serverText = string.Format(Properties.Resources.SERVER_INSTALL, this.CsMapDictionaryDir, this.ServerBinDir, this.MapGuideServiceName);
+ File.WriteAllText(Path.Combine(this.BatchFileOutputDirectory, "mgserverinstall.bat"), serverText);
- //Write service uninstall batch file
- serverText = string.Format(Properties.Resources.SERVER_UNINSTALL, this.CsMapDictionaryDir, this.ServerBinDir, this.MapGuideServiceName);
- File.WriteAllText(Path.Combine(this.BatchFileOutputDirectory, "mgserveruninstall.bat"), serverText);
+ //Write service uninstall batch file
+ serverText = string.Format(Properties.Resources.SERVER_UNINSTALL, this.CsMapDictionaryDir, this.ServerBinDir, this.MapGuideServiceName);
+ File.WriteAllText(Path.Combine(this.BatchFileOutputDirectory, "mgserveruninstall.bat"), serverText);
+ else //Post RFC 122
+ string serverText = string.Format(Properties.Resources.SERVER_NO_MENTOR, this.ServerBinDir);
+ serverText = string.Format(Properties.Resources.SERVER_INSTALL_NO_MENTOR, this.ServerBinDir, this.MapGuideServiceName);
+ serverText = string.Format(Properties.Resources.SERVER_UNINSTALL_NO_MENTOR, this.ServerBinDir, this.MapGuideServiceName);
WriteAdditionalBatchFiles();
@@ -245,6 +264,10 @@
_webConfig.IniWriteValue("GeneralProperties","ResourcesPath",Path.Combine(this.WebTierMapAgentDir, "Resources"));
_webConfig.IniWriteValue("GeneralProperties","TempPath",Path.Combine(this.WebTierRootDir, "Temp"));
+ //Post RFC 122
+ if (!this.WriteMentorDictionaryPath)
+ _webConfig.IniWriteValue("GeneralProperties", "MentorDictionaryPath", this.CsMapDictionaryDir);
_webConfig.IniWriteValue("SiteConnectionProperties","IpAddress","127.0.0.1");
_webConfig.IniWriteValue("WebApplicationProperties","TemplateRootFolder",Path.Combine(this.WebTierPublicDir, "fusion\\templates\\mapguide"));
@@ -266,6 +289,10 @@
_serverConfig.IniWriteValue("GeneralProperties","WfsDocumentPath",Path.Combine(ServerRootDir, "Wfs"));
_serverConfig.IniWriteValue("GeneralProperties","WmsDocumentPath",Path.Combine(ServerRootDir, "Wms"));
_serverConfig.IniWriteValue("GeneralProperties","FdoPath",Path.Combine(ServerRootDir, "Fdo"));
+ //Post RFC 122
+ _serverConfig.IniWriteValue("GeneralProperties", "MentorDictionaryPath", this.CsMapDictionaryDir);
_serverConfig.IniWriteValue("ResourceServiceProperties","PackagesPath",Path.Combine(ServerRootDir, "Packages"));
Modified: trunk/Tools/MgInstantSetup/InstantSetup.Core/ApacheSetupConfigurationProcess.cs
--- trunk/Tools/MgInstantSetup/InstantSetup.Core/ApacheSetupConfigurationProcess.cs 2011-10-28 11:38:49 UTC (rev 6191)
+++ trunk/Tools/MgInstantSetup/InstantSetup.Core/ApacheSetupConfigurationProcess.cs 2011-10-28 13:15:23 UTC (rev 6192)
@@ -139,9 +139,19 @@
protected override void WriteAdditionalBatchFiles()
- //Write httpd batch file
- string httpdText = string.Format(Properties.Resources.APACHE_WEB, this.CsMapDictionaryDir, Path.Combine(this.WebTierApacheDir, "bin"));
- File.WriteAllText(Path.Combine(this.BatchFileOutputDirectory, "mgwebtier.bat"), httpdText);
+ string httpdText = "";
+ //Write httpd batch file
+ httpdText = string.Format(Properties.Resources.APACHE_WEB, this.CsMapDictionaryDir, Path.Combine(this.WebTierApacheDir, "bin"));
+ File.WriteAllText(Path.Combine(this.BatchFileOutputDirectory, "mgwebtier.bat"), httpdText);
+ httpdText = string.Format(Properties.Resources.APACHE_WEB_NO_MENTOR, Path.Combine(this.WebTierApacheDir, "bin"));
//Write service installer batch file
httpdText = string.Format(Properties.Resources.APACHE_WEB_INSTALL, Path.Combine(this.WebTierApacheDir, "bin"), this.HttpdServiceName);
Modified: trunk/Tools/MgInstantSetup/InstantSetup.Core/InstantSetup.Core.csproj
--- trunk/Tools/MgInstantSetup/InstantSetup.Core/InstantSetup.Core.csproj 2011-10-28 11:38:49 UTC (rev 6191)
+++ trunk/Tools/MgInstantSetup/InstantSetup.Core/InstantSetup.Core.csproj 2011-10-28 13:15:23 UTC (rev 6192)
@@ -74,6 +74,18 @@
<ItemGroup>
<None Include="Resources\APACHE_WEB_UNINSTALL.txt" />
</ItemGroup>
+ <ItemGroup>
+ <None Include="Resources\APACHE_WEB1.txt" />
+ </ItemGroup>
+ <ItemGroup>
+ <None Include="Resources\SERVER1.txt" />
+ </ItemGroup>
+ <ItemGroup>
+ <None Include="Resources\SERVER_INSTALL1.txt" />
+ </ItemGroup>
+ <ItemGroup>
+ <None Include="Resources\SERVER_UNINSTALL1.txt" />
+ </ItemGroup>
<Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
<!-- To modify your build process, add your task inside one of the targets below and uncomment it.
Other similar extension points exist, see Microsoft.Common.targets.
Modified: trunk/Tools/MgInstantSetup/InstantSetup.Core/Properties/Resources.Designer.cs
--- trunk/Tools/MgInstantSetup/InstantSetup.Core/Properties/Resources.Designer.cs 2011-10-28 11:38:49 UTC (rev 6191)
+++ trunk/Tools/MgInstantSetup/InstantSetup.Core/Properties/Resources.Designer.cs 2011-10-28 13:15:23 UTC (rev 6192)
@@ -1,7 +1,7 @@
// <auto-generated>
// This code was generated by a tool.
-// Runtime Version:2.0.50727.4961
+// Runtime Version:2.0.50727.5420
// Changes to this file may cause incorrect behavior and will be lost if
// the code is regenerated.
@@ -74,7 +74,7 @@
/// <summary>
/// Looks up a localized string similar to pushd {0}
- ///httpd.exe -k install "{1}"
+ ///httpd.exe -k install -n "{1}"
///popd.
/// </summary>
internal static string APACHE_WEB_INSTALL {
@@ -85,9 +85,20 @@
/// <summary>
- ///httpd.exe -k uninstall "{1}"
+ ///httpd.exe
///popd.
/// </summary>
+ internal static string APACHE_WEB_NO_MENTOR {
+ get {
+ return ResourceManager.GetString("APACHE_WEB_NO_MENTOR", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to pushd {0}
+ ///httpd.exe -k uninstall -n "{1}"
+ ///popd.
+ /// </summary>
internal static string APACHE_WEB_UNINSTALL {
get {
return ResourceManager.GetString("APACHE_WEB_UNINSTALL", resourceCulture);
@@ -119,6 +130,28 @@
/// <summary>
+ ///mgserver install "{1}"
+ ///popd.
+ /// </summary>
+ internal static string SERVER_INSTALL_NO_MENTOR {
+ get {
+ return ResourceManager.GetString("SERVER_INSTALL_NO_MENTOR", resourceCulture);
+ /// <summary>
+ ///mgserver.exe run
+ ///popd.
+ /// </summary>
+ internal static string SERVER_NO_MENTOR {
+ get {
+ return ResourceManager.GetString("SERVER_NO_MENTOR", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to SET MENTOR_DICTIONARY_PATH={0}
///pushd {1}
///mgserver uninstall "{2}"
@@ -129,5 +162,16 @@
return ResourceManager.GetString("SERVER_UNINSTALL", resourceCulture);
+ /// <summary>
+ ///mgserver uninstall "{1}"
+ ///popd.
+ /// </summary>
+ internal static string SERVER_UNINSTALL_NO_MENTOR {
+ get {
+ return ResourceManager.GetString("SERVER_UNINSTALL_NO_MENTOR", resourceCulture);
Modified: trunk/Tools/MgInstantSetup/InstantSetup.Core/Properties/Resources.resx
--- trunk/Tools/MgInstantSetup/InstantSetup.Core/Properties/Resources.resx 2011-10-28 11:38:49 UTC (rev 6191)
+++ trunk/Tools/MgInstantSetup/InstantSetup.Core/Properties/Resources.resx 2011-10-28 13:15:23 UTC (rev 6192)
@@ -119,21 +119,33 @@
</resheader>
<assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
<data name="APACHE_WEB" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\APACHE_WEB.txt;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;Windows-1252</value>
+ <value>..\Resources\APACHE_WEB.txt;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;iso-8859-1</value>
</data>
<data name="APACHE_WEB_INSTALL" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\APACHE_WEB_INSTALL.txt;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;Windows-1252</value>
</data>
+ <data name="APACHE_WEB_NO_MENTOR" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\APACHE_WEB1.txt;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;Windows-1252</value>
+ </data>
<data name="APACHE_WEB_UNINSTALL" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\APACHE_WEB_UNINSTALL.txt;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;Windows-1252</value>
</data>
<data name="SERVER" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\SERVER.txt;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;Windows-1252</value>
+ <value>..\Resources\SERVER.txt;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;iso-8859-1</value>
</data>
<data name="SERVER_INSTALL" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\SERVER_INSTALL.txt;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;Windows-1252</value>
+ <value>..\Resources\SERVER_INSTALL.txt;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;iso-8859-1</value>
</data>
+ <data name="SERVER_INSTALL_NO_MENTOR" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\SERVER_INSTALL1.txt;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;Windows-1252</value>
+ </data>
+ <data name="SERVER_NO_MENTOR" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\SERVER1.txt;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;Windows-1252</value>
+ </data>
<data name="SERVER_UNINSTALL" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\SERVER_UNINSTALL.txt;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;Windows-1252</value>
+ <value>..\Resources\SERVER_UNINSTALL.txt;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;iso-8859-1</value>
</data>
+ <data name="SERVER_UNINSTALL_NO_MENTOR" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\SERVER_UNINSTALL1.txt;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;Windows-1252</value>
+ </data>
</root>
\ No newline at end of file
Added: trunk/Tools/MgInstantSetup/InstantSetup.Core/Resources/APACHE_WEB1.txt
--- trunk/Tools/MgInstantSetup/InstantSetup.Core/Resources/APACHE_WEB1.txt (rev 0)
+++ trunk/Tools/MgInstantSetup/InstantSetup.Core/Resources/APACHE_WEB1.txt 2011-10-28 13:15:23 UTC (rev 6192)
@@ -0,0 +1,3 @@
+pushd {0}
+httpd.exe
+popd
Added: trunk/Tools/MgInstantSetup/InstantSetup.Core/Resources/SERVER1.txt
--- trunk/Tools/MgInstantSetup/InstantSetup.Core/Resources/SERVER1.txt (rev 0)
+++ trunk/Tools/MgInstantSetup/InstantSetup.Core/Resources/SERVER1.txt 2011-10-28 13:15:23 UTC (rev 6192)
@@ -0,0 +1,3 @@
+pushd {0}
+mgserver.exe run
+popd
Added: trunk/Tools/MgInstantSetup/InstantSetup.Core/Resources/SERVER_INSTALL1.txt
--- trunk/Tools/MgInstantSetup/InstantSetup.Core/Resources/SERVER_INSTALL1.txt (rev 0)
+++ trunk/Tools/MgInstantSetup/InstantSetup.Core/Resources/SERVER_INSTALL1.txt 2011-10-28 13:15:23 UTC (rev 6192)
@@ -0,0 +1,3 @@
+pushd {0}
+mgserver install "{1}"
+popd
Added: trunk/Tools/MgInstantSetup/InstantSetup.Core/Resources/SERVER_UNINSTALL1.txt
--- trunk/Tools/MgInstantSetup/InstantSetup.Core/Resources/SERVER_UNINSTALL1.txt (rev 0)
+++ trunk/Tools/MgInstantSetup/InstantSetup.Core/Resources/SERVER_UNINSTALL1.txt 2011-10-28 13:15:23 UTC (rev 6192)
@@ -0,0 +1,3 @@
+pushd {0}
+mgserver uninstall "{1}"
+popd
More information about the mapguide-commits
