[mapguide-commits] r6122 - in trunk/Tools/Maestro:
Maestro.Base/Properties Maestro.Base/UI Maestro.Shared.UI
OSGeo.MapGuide.MaestroAPI OSGeo.MapGuide.MaestroAPI/CrossConnection
OSGeo.MapGuide.MaestroAPI/Properties
OSGeo.MapGuide.MaestroAPI/Resource/Conversion
svn_mapguide at osgeo.org
Tue Sep 6 12:08:40 EDT 2011
Author: jng
Date: 2011-09-06 09:08:40 -0700 (Tue, 06 Sep 2011)
New Revision: 6122
Added:
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/CrossConnection/ResourceRebaser.cs
trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.cs
trunk/Tools/Maestro/Maestro.Shared.UI/ProgressDialog.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/CrossConnection/ResourceMigrator.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Conversion/IResourceConverter.cs
#1800: Add support for drag/drop of resources between different connections. To support preservation of folder structures, a new API was added to the ResourceMigrator class with a new ResourceRebaser class to help update internal resource id references for resources as they are copied across
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs 2011-09-06 08:25:08 UTC (rev 6121)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs 2011-09-06 16:08:40 UTC (rev 6122)
@@ -1588,6 +1588,15 @@
/// <summary>
+ /// Looks up a localized string similar to There are {0} already existing resources that have the same name. Do you want to overwrite these resources?.
+ /// </summary>
+ internal static string PromptOverwriteOnTargetConnection {
+ get {
+ return ResourceManager.GetString("PromptOverwriteOnTargetConnection", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Rename to.
/// </summary>
internal static string RenameTo {
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx 2011-09-06 08:25:08 UTC (rev 6121)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx 2011-09-06 16:08:40 UTC (rev 6122)
@@ -1067,4 +1067,7 @@
<data name="DwfHandlerAction" xml:space="preserve">
<value>Create a Drawing Source</value>
</data>
+ <data name="PromptOverwriteOnTargetConnection" xml:space="preserve">
+ <value>There are {0} already existing resources that have the same name. Do you want to overwrite these resources?</value>
+ </data>
</root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.cs 2011-09-06 08:25:08 UTC (rev 6121)
+++ trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.cs 2011-09-06 16:08:40 UTC (rev 6122)
@@ -36,6 +36,7 @@
using Maestro.Base.Commands;
using System.Linq;
using Maestro.Editors;
+using OSGeo.MapGuide.MaestroAPI.CrossConnection;
namespace Maestro.Base.UI
@@ -376,7 +377,7 @@
private void trvResources_DragDrop(object sender, DragEventArgs e)
- var data = e.Data.GetData(typeof(RepositoryItem[])) as RepositoryItem[];
+ var data = e.Data.GetData(typeof(RepositoryHandle[])) as RepositoryHandle[];
if (data == null)
//See if the mouse is currently over a node
@@ -397,17 +398,20 @@
string connectionName = RepositoryTreeModel.GetParentConnectionName(item);
string folderId = item.ResourceId;
- //I think it's nice to ask for confirmation
- if (data.Length > 0)
- if (!MessageService.AskQuestion(Properties.Resources.ConfirmMove))
- return;
+ if (data.Length < 0)
+ return;
- if (data.First().ConnectionName == connectionName)
+ if (data.First().Connection.DisplayName == connectionName)
- string[] folders = MoveResourcesWithinConnection(connectionName, data.Select(x => x.ResourceId).ToArray(), folderId);
+ //I think it's nice to ask for confirmation
+ if (data.Length > 0)
+ if (!MessageService.AskQuestion(Properties.Resources.ConfirmMove))
+ return;
+ string[] folders = MoveResourcesWithinConnection(connectionName, data.Select(x => x.ResourceId.ToString()).ToArray(), folderId);
foreach (var fid in folders)
LoggingService.Info("Refreshing: " + fid + " on " + connectionName); //LOCALIZEME
@@ -416,17 +420,135 @@
else
- //TODO: Revisit later
- MessageService.ShowError("Moving resources between connections is currently not implemented");
- return;
+ string rootSourceParent = GetCommonParent(data);
+ //There is an implicit assumption here that all items dropped come from the same connection
+ var sourceConn = data.First().Connection;
+ var targetConn = _connManager.GetConnection(connectionName);
+ var migrator = new ResourceMigrator(sourceConn, targetConn);
+ //Collect all source ids
+ var sourceIds = new List<string>();
+ foreach (var resId in data.Select(x => x.ResourceId.ToString()))
+ if (ResourceIdentifier.IsFolderResource(resId))
+ sourceIds.AddRange(GetFullResourceList(sourceConn, resId));
+ else
+ sourceIds.Add(resId);
+ //If we're dropping to the root, the common parent becomes our
+ //target root
+ if (folderId == "Library://")
+ folderId = rootSourceParent;
+ //If common parent is not root, we want the name of the folder to append
+ //to our target
+ if (rootSourceParent != "Library://")
+ ResourceIdentifier resId = new ResourceIdentifier(rootSourceParent);
+ folderId = folderId + resId.Name + "/";
+ var targets = new List<string>();
+ foreach (var resId in sourceIds)
+ var dstId = resId.Replace(rootSourceParent, folderId);
+ System.Diagnostics.Trace.TraceInformation("{0} => {1}", resId, dstId);
+ targets.Add(dstId);
+ bool overwrite = true;
+ var existing = new List<string>();
+ foreach (var resId in targets)
+ if (targetConn.ResourceService.ResourceExists(resId))
+ existing.Add(resId);
+ if (existing.Count > 0)
+ overwrite = MessageService.AskQuestion(string.Format(Properties.Resources.PromptOverwriteOnTargetConnection, existing.Count));
+ var wb = Workbench.Instance;
+ var dlg = new ProgressDialog();
+ var worker = new ProgressDialog.DoBackgroundWork((w, evt, args) =>
+ LengthyOperationProgressCallBack cb = (s, cbe) =>
+ w.ReportProgress(cbe.Progress, cbe.StatusMessage);
+ return migrator.CopyResources(sourceIds.ToArray(), targets.ToArray(), overwrite, new RebaseOptions(rootSourceParent, folderId), cb);
+ dlg.RunOperationAsync(wb, worker);
+ RefreshModel(targetConn.DisplayName, folderId);
+ ExpandNode(targetConn.DisplayName, folderId);
+ private string GetCommonParent(RepositoryHandle[] data)
+ if (data.Length == 1)
+ if (data[0].ResourceId.IsFolder)
+ return data[0].ResourceId.ToString();
+ else
+ return data[0].ResourceId.ParentFolder;
+ else
+ int matches = 0;
+ string[] parts = data.First().ResourceId.ToString()
+ .Substring("Library://".Length)
+ .Split('/');
+ string test = "Library://";
+ string parent = test;
+ int partIndex = 0;
+ //Use first one as a sample to see how far we can go. Keep going until we have
+ //a parent that doesn't match all of them. The one we recorded before then will
+ //be the common parent
+ while (matches == data.Length)
+ parent = test;
+ partIndex++;
+ if (partIndex < parts.Length) //Shouldn't happen, but just in case
+ break;
+ test = test + parts[partIndex];
+ matches = data.Where(x => x.ResourceId.ResourceId.StartsWith(test)).Count();
+ return parent;
+ else
+ return "Library://";
+ private static IEnumerable<string> GetFullResourceList(IServerConnection sourceConn, string resId)
+ var list = sourceConn.ResourceService.GetRepositoryResources(resId, -1);
+ foreach (var res in list.Children)
+ if (res.IsFolder)
+ continue;
+ yield return res.ResourceId;
private void trvResources_DragOver(object sender, DragEventArgs e)
if (data == null)
SiteExplorerDragDropHandler.OnDragEnter(this, e);
Modified: trunk/Tools/Maestro/Maestro.Shared.UI/ProgressDialog.cs
--- trunk/Tools/Maestro/Maestro.Shared.UI/ProgressDialog.cs 2011-09-06 08:25:08 UTC (rev 6121)
+++ trunk/Tools/Maestro/Maestro.Shared.UI/ProgressDialog.cs 2011-09-06 16:08:40 UTC (rev 6122)
@@ -128,7 +128,9 @@
else if (e.Error != null)
- throw e.Error;
+ ErrorDialog.Show(e.Error);
+ this.DialogResult = DialogResult.Abort;
+ this.Close();
else
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/CrossConnection/ResourceMigrator.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/CrossConnection/ResourceMigrator.cs 2011-09-06 08:25:08 UTC (rev 6121)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/CrossConnection/ResourceMigrator.cs 2011-09-06 16:08:40 UTC (rev 6122)
@@ -21,6 +21,8 @@
using System.Collections.Generic;
using System.Text;
using OSGeo.MapGuide.MaestroAPI.Resource;
+using OSGeo.MapGuide.MaestroAPI.Resource.Conversion;
+using System.IO;
namespace OSGeo.MapGuide.MaestroAPI.CrossConnection
@@ -33,6 +35,8 @@
private IServerConnection _source;
private IServerConnection _target;
+ private IResourceConverter _converter;
/// <summary>
/// Initializes a new instance of the <see cref="ResourceMigrator"/> class.
/// </summary>
@@ -44,9 +48,106 @@
Check.NotNull(target, "target");
_source = source;
_target = target;
+ _converter = new ResourceObjectConverter();
/// <summary>
+ /// Copies resource from the source connection to another connection.
+ /// </summary>
+ /// <param name="sourceResourceIds">The array of source resource ids</param>
+ /// <param name="targetResourceIds">The array of target resource ids to copy to. Each resource id in the source array will be copied to the corresponding resource id in the target array</param>
+ /// <param name="overwrite">Indicates whether to overwrite </param>
+ /// <param name="options">Re-base options</param>
+ /// <param name="callback"></param>
+ /// <returns></returns>
+ public int CopyResources(string[] sourceResourceIds, string[] targetResourceIds, bool overwrite, RebaseOptions options, LengthyOperationProgressCallBack callback)
+ Check.NotNull(sourceResourceIds, "sourceResourceIds");
+ Check.NotNull(targetResourceIds, "targetResourceIds");
+ Check.Precondition(sourceResourceIds.Length == targetResourceIds.Length, "resourceIds.Length == targetResourceIds.Length");
+ var cb = callback;
+ if (cb == null)
+ cb = new LengthyOperationProgressCallBack((s, e) =>
+ //Do nothing
+ var targetCaps = _target.Capabilities;
+ int copied = 0;
+ int unit = 100 / sourceResourceIds.Length;
+ int progress = 0;
+ string message = "";
+ for (int i = 0; i < sourceResourceIds.Length; i++)
+ var srcResId = sourceResourceIds[i];
+ var dstResId = targetResourceIds[i];
+ //Get the source resource object
+ IResource res = _source.ResourceService.GetResource(srcResId);
+ //Skip if target exists and overwrite is not specified
+ if (!overwrite && _target.ResourceService.ResourceExists(dstResId))
+ progress += unit;
+ continue;
+ else
+ //Check if downgrading is required
+ var maxVer = targetCaps.GetMaxSupportedResourceVersion(res.ResourceType);
+ if (res.ResourceVersion > maxVer)
+ res = _converter.Convert(res, maxVer);
+ cb(this, new LengthyOperationProgressArgs(string.Format(Properties.Resources.DowngradedResource, srcResId, maxVer), progress));
+ //Now rebase if rebase options supplied
+ if (options != null)
+ var rebaser = new ResourceRebaser(res);
+ res = rebaser.Rebase(options.SourceFolder, options.TargetFolder);
+ //Save resource
+ _target.ResourceService.SaveResourceAs(res, dstResId);
+ //Copy resource data
+ foreach (var data in res.EnumerateResourceData())
+ using (var stream = res.GetResourceData(data.Name))
+ if (!stream.CanSeek)
+ using (var ms = new MemoryStream())
+ Utility.CopyStream(stream, ms, false);
+ ms.Position = 0L;
+ _target.ResourceService.SetResourceData(dstResId, data.Name, data.Type, ms);
+ else
+ stream.Position = 0L;
+ _target.ResourceService.SetResourceData(dstResId, data.Name, data.Type, stream);
+ copied++;
+ message = string.Format(Properties.Resources.CopiedResourceToTarget, srcResId, dstResId);
+ progress += unit;
+ cb(this, new LengthyOperationProgressArgs(message, progress));
+ return copied;
+ /// <summary>
/// Copies resources from the source connection to another connection. The resources in question will
/// be copied to the specified folder. Folder structure of the source is discarded
/// </summary>
@@ -69,6 +170,8 @@
int copied = 0;
int unit = 100 / resourceIds.Length;
int progress = 0;
@@ -81,10 +184,19 @@
if (!overwrite && _target.ResourceService.ResourceExists(targetId))
+ progress += unit;
continue;
else
+ cb(this, new LengthyOperationProgressArgs(string.Format(Properties.Resources.DowngradedResource, resId, maxVer), progress));
//Save resource
_target.ResourceService.SaveResourceAs(res, targetId);
@@ -92,8 +204,20 @@
- stream.Position = 0L;
- _target.ResourceService.SetResourceData(targetId, data.Name, data.Type, stream);
+ ms.Position = 0L;
+ _target.ResourceService.SetResourceData(targetId, data.Name, data.Type, ms);
+ else
+ _target.ResourceService.SetResourceData(targetId, data.Name, data.Type, stream);
@@ -128,6 +252,8 @@
int moved = 0;
int progress = 0;
@@ -140,10 +266,19 @@
+ progress += unit;
continue;
else
//Save resource
@@ -151,8 +286,20 @@
+ ms.Position = 0L;
+ else
@@ -194,6 +341,7 @@
cb = new LengthyOperationProgressCallBack((o, a) => { });
int total = dependentResourceIds.Length + 1;
int unit = 100 / total;
int progress = 0;
@@ -202,6 +350,14 @@
//Copy the specified resource
IResource res = _source.ResourceService.GetResource(resourceId);
+ cb(this, new LengthyOperationProgressArgs(string.Format(Properties.Resources.DowngradedResource, resourceId, maxVer), progress));
_target.ResourceService.SaveResource(res);
//Copy its resource data
@@ -209,8 +365,20 @@
- _target.ResourceService.SetResourceData(resourceId, data.Name, data.Type, stream);
+ ms.Position = 0L;
+ _target.ResourceService.SetResourceData(resourceId, data.Name, data.Type, ms);
+ else
+ _target.ResourceService.SetResourceData(resourceId, data.Name, data.Type, stream);
@@ -243,8 +411,20 @@
- _target.ResourceService.SetResourceData(resId, data.Name, data.Type, stream);
+ ms.Position = 0L;
+ _target.ResourceService.SetResourceData(resId, data.Name, data.Type, ms);
+ else
+ _target.ResourceService.SetResourceData(resId, data.Name, data.Type, stream);
Added: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/CrossConnection/ResourceRebaser.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/CrossConnection/ResourceRebaser.cs (rev 0)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/CrossConnection/ResourceRebaser.cs 2011-09-06 16:08:40 UTC (rev 6122)
@@ -0,0 +1,107 @@
+#region Disclaimer / License
+// Copyright (C) 2011, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+using OSGeo.MapGuide.MaestroAPI.Resource;
+using System.Xml;
+using System.IO;
+namespace OSGeo.MapGuide.MaestroAPI.CrossConnection
+ /// <summary>
+ /// Resource re-basing options
+ /// </summary>
+ public class RebaseOptions
+ public RebaseOptions(string sourceFolder, string targetFolder)
+ Check.Precondition(ResourceIdentifier.IsFolderResource(sourceFolder), "ResourceIdentifier.IsFolderResource(sourceFolder)");
+ Check.Precondition(ResourceIdentifier.IsFolderResource(targetFolder), "ResourceIdentifier.IsFolderResource(targetFolder)");
+ this.SourceFolder = sourceFolder;
+ this.TargetFolder = targetFolder;
+ /// <summary>
+ /// The source folder to look for in resource ids
+ /// </summary>
+ public string SourceFolder
+ get;
+ private set;
+ /// <summary>
+ /// The target folder to replace with
+ /// </summary>
+ public string TargetFolder
+ get;
+ private set;
+ /// <summary>
+ /// A helper class to re-base referenced resource ids in a resource document
+ /// </summary>
+ public class ResourceRebaser
+ private IResource _res;
+ public ResourceRebaser(IResource res)
+ _res = res;
+ /// <summary>
+ /// Re-bases any resource id references in the resource document
+ /// </summary>
+ /// <param name="sourceRoot"></param>
+ /// <param name="targetRoot"></param>
+ /// <returns>A re-based copy of the original resource</returns>
+ public IResource Rebase(string sourceRoot, string targetRoot)
+ if (sourceRoot == targetRoot)
+ return _res;
+ var xml = ResourceTypeRegistry.SerializeAsString(_res);
+ var doc = new XmlDocument();
+ doc.LoadXml(xml);
+ var elements = doc.GetElementsByTagName("ResourceId");
+ foreach (XmlNode el in elements)
+ el.InnerText = el.InnerText.Replace(sourceRoot, targetRoot);
+ doc.Save(ms);
+ ms.Position = 0L;
+ var modifiedRes = ResourceTypeRegistry.Deserialize(_res.ResourceType, ms);
+ modifiedRes.CurrentConnection = _res.CurrentConnection;
+ modifiedRes.ResourceID = _res.ResourceID;
+ return modifiedRes;
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2011-09-06 08:25:08 UTC (rev 6121)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2011-09-06 16:08:40 UTC (rev 6122)
@@ -191,6 +191,7 @@
<Compile Include="CoordinateSystem\MeterBasedCoordinateSystem.cs" />
<Compile Include="CoordinateSystem\NsDoc.cs" />
<Compile Include="CrossConnection\NsDoc.cs" />
+ <Compile Include="CrossConnection\ResourceRebaser.cs" />
<Compile Include="Exceptions\CustomPropertyNotFoundException.cs" />
<Compile Include="Exceptions\ExpressionException.cs" />
<Compile Include="Exceptions\MaestroException.cs" />
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs 2011-09-06 08:25:08 UTC (rev 6121)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs 2011-09-06 16:08:40 UTC (rev 6122)
@@ -278,6 +278,24 @@
/// <summary>
+ /// Looks up a localized string similar to Copied: {0} => {1}.
+ /// </summary>
+ internal static string CopiedResourceToTarget {
+ get {
+ return ResourceManager.GetString("CopiedResourceToTarget", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Resource {0} downgraded to version {1}.
+ /// </summary>
+ internal static string DowngradedResource {
+ get {
+ return ResourceManager.GetString("DowngradedResource", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to No coordinate system specified. The coordinate system if not specified will default to LL84.
/// </summary>
internal static string DS_NoCoordinateSpace {
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx 2011-09-06 08:25:08 UTC (rev 6121)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx 2011-09-06 16:08:40 UTC (rev 6122)
@@ -530,4 +530,10 @@
<data name="MDF_NoCoordinateSystem" xml:space="preserve">
<value>Map Definition has no coordinate system</value>
</data>
+ <data name="CopiedResourceToTarget" xml:space="preserve">
+ <value>Copied: {0} => {1}</value>
+ </data>
+ <data name="DowngradedResource" xml:space="preserve">
+ <value>Resource {0} downgraded to version {1}</value>
+ </data>
</root>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Conversion/IResourceConverter.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Conversion/IResourceConverter.cs 2011-09-06 08:25:08 UTC (rev 6121)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Conversion/IResourceConverter.cs 2011-09-06 16:08:40 UTC (rev 6122)
@@ -42,6 +42,11 @@
public IResource Convert(IResource resource, Version targetVersion)
+ //How does this work? If source and target versions are known, it means the classes
+ //that represent them are also known and we just serialize from the source type to xml
+ //and deserialize that xml to the target type, with any unsupported bits falling by the
+ //wayside in the process, and any new bits flubbed with default values as part of deserialization
var resVer = resource.GetResourceTypeDescriptor().Version;
var dstVer = string.Format("{0}.{1}.{2}", targetVersion.Major, targetVersion.Minor, targetVersion.Build);
var dstXsd = resource.ValidatingSchema.Replace(resVer, dstVer);
@@ -56,6 +61,7 @@
var convRes = ResourceTypeRegistry.Deserialize(xml.ToString());
convRes.CurrentConnection = resource.CurrentConnection;
+ convRes.ResourceID = resource.ResourceID;
return convRes;
More information about the mapguide-commits
