[mapguide-commits] r6125 - in trunk/Tools/Maestro:
Maestro.AddIn.Local Maestro.Base/Commands Maestro.Base/UI
OSGeo.MapGuide.MaestroAPI/CrossConnection
svn_mapguide at osgeo.org
Wed Sep 7 06:22:36 EDT 2011
Author: jng
Date: 2011-09-07 03:22:36 -0700 (Wed, 07 Sep 2011)
New Revision: 6125
trunk/Tools/Maestro/Maestro.AddIn.Local/OSGeo.MapGuide.Viewer.dll
trunk/Tools/Maestro/Maestro.Base/Commands/PasteCommand.cs
trunk/Tools/Maestro/Maestro.Base/UI/ISiteExplorer.cs
trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/CrossConnection/ResourceMigrator.cs
- Update mg-desktop viewer component (plugs connection leaks on selections)
- #1800: Update paste command to be multi-site aware
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/OSGeo.MapGuide.Viewer.dll
(Binary files differ)
Modified: trunk/Tools/Maestro/Maestro.Base/Commands/PasteCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/PasteCommand.cs 2011-09-07 09:19:29 UTC (rev 6124)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/PasteCommand.cs 2011-09-07 10:22:36 UTC (rev 6125)
@@ -20,11 +20,14 @@
using System;
using System.Collections.Generic;
using System.Text;
+using System.Linq;
using ICSharpCode.Core;
+using Maestro.Editors;
using Maestro.Base.Services;
using Maestro.Base.UI;
using OSGeo.MapGuide.MaestroAPI.Resource;
using Maestro.Shared.UI;
+using Wintellect.PowerCollections;
namespace Maestro.Base.Commands
@@ -60,9 +63,10 @@
Dictionary<string, string> folders = new Dictionary<string, string>();
var notPasted = new List<RepositoryItem>();
- foreach (var item in itemsToPaste)
+ //From same connection
+ if (itemsToPaste.First().ConnectionName == targetConnName)
- if (item.ConnectionName == targetConnName) //From same connection
+ foreach (var item in itemsToPaste)
LoggingService.InfoFormatted(Properties.Resources.ClipboardAction, item.ClipboardState, item.ResourceId, folder.ResourceId);
@@ -121,11 +125,25 @@
folders[item.Parent.ResourceId] = item.Parent.ResourceId;
- else
+ else
+ var copied = ((UI.SiteExplorer)exp).CopyResourcesToFolder(
+ itemsToPaste.Select(x => new RepositoryHandle(new ResourceIdentifier(x.ResourceId), connMgr.GetConnection(x.ConnectionName))).ToArray(),
+ targetConnName,
+ folder.ResourceId);
+ //Delete any originating items that were successfully cut/pasted
- //TODO: Revisit later
- MessageService.ShowError("Copy/Pasting between connections is currently not implemented");
- return;
+ if (item.ClipboardState == RepositoryItem.ClipboardAction.Cut)
+ var origConn = connMgr.GetConnection(item.ConnectionName);
+ if (origConn.ResourceService.ResourceExists(item.ResourceId))
+ origConn.ResourceService.DeleteResource(item.ResourceId);
if (sourceItemsNotMoved.Count > 0)
Modified: trunk/Tools/Maestro/Maestro.Base/UI/ISiteExplorer.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/ISiteExplorer.cs 2011-09-07 09:19:29 UTC (rev 6124)
+++ trunk/Tools/Maestro/Maestro.Base/UI/ISiteExplorer.cs 2011-09-07 10:22:36 UTC (rev 6125)
@@ -21,6 +21,7 @@
using System.Text;
using OSGeo.MapGuide.MaestroAPI;
namespace Maestro.Base.UI
Modified: trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.cs 2011-09-07 09:19:29 UTC (rev 6124)
+++ trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.cs 2011-09-07 10:22:36 UTC (rev 6125)
@@ -420,79 +420,85 @@
else
- string rootSourceParent = GetCommonParent(data);
+ CopyResourcesToFolder(data, connectionName, folderId);
- //There is an implicit assumption here that all items dropped come from the same connection
- var sourceConn = data.First().Connection;
- var targetConn = _connManager.GetConnection(connectionName);
- var migrator = new ResourceMigrator(sourceConn, targetConn);
+ internal string[] CopyResourcesToFolder(RepositoryHandle[] data, string targetConnectionName, string folderId)
+ string rootSourceParent = GetCommonParent(data);
- //Collect all source ids
- var sourceIds = new List<string>();
- foreach (var resId in data.Select(x => x.ResourceId.ToString()))
- if (ResourceIdentifier.IsFolderResource(resId))
- sourceIds.AddRange(GetFullResourceList(sourceConn, resId));
- else
- sourceIds.Add(resId);
+ //There is an implicit assumption here that all items dropped come from the same connection
+ var sourceConn = data.First().Connection;
+ var targetConn = _connManager.GetConnection(targetConnectionName);
+ var migrator = new ResourceMigrator(sourceConn, targetConn);
- //If we're dropping to the root, the common parent becomes our
- //target root
- if (folderId == "Library://")
- folderId = rootSourceParent;
- //If common parent is not root, we want the name of the folder to append
- //to our target
- if (rootSourceParent != "Library://")
- ResourceIdentifier resId = new ResourceIdentifier(rootSourceParent);
- folderId = folderId + resId.Name + "/";
+ //Collect all source ids
+ var sourceIds = new List<string>();
+ foreach (var resId in data.Select(x => x.ResourceId.ToString()))
+ if (ResourceIdentifier.IsFolderResource(resId))
+ sourceIds.AddRange(GetFullResourceList(sourceConn, resId));
+ else
+ sourceIds.Add(resId);
- var targets = new List<string>();
- foreach (var resId in sourceIds)
- var dstId = resId.Replace(rootSourceParent, folderId);
- System.Diagnostics.Trace.TraceInformation("{0} => {1}", resId, dstId);
- targets.Add(dstId);
- bool overwrite = true;
- var existing = new List<string>();
- foreach (var resId in targets)
- if (targetConn.ResourceService.ResourceExists(resId))
- existing.Add(resId);
- if (existing.Count > 0)
- overwrite = MessageService.AskQuestion(string.Format(Properties.Resources.PromptOverwriteOnTargetConnection, existing.Count));
+ //If we're dropping to the root, the common parent becomes our
+ //target root
+ if (folderId == "Library://")
+ folderId = rootSourceParent;
+ //If common parent is not root, we want the name of the folder to append
+ //to our target
+ if (rootSourceParent != "Library://")
+ ResourceIdentifier resId = new ResourceIdentifier(rootSourceParent);
+ folderId = folderId + resId.Name + "/";
- var wb = Workbench.Instance;
- var dlg = new ProgressDialog();
- var worker = new ProgressDialog.DoBackgroundWork((w, evt, args) =>
- LengthyOperationProgressCallBack cb = (s, cbe) =>
- w.ReportProgress(cbe.Progress, cbe.StatusMessage);
+ var targets = new List<string>();
+ foreach (var resId in sourceIds)
+ var dstId = resId.Replace(rootSourceParent, folderId);
+ System.Diagnostics.Trace.TraceInformation("{0} => {1}", resId, dstId);
+ targets.Add(dstId);
- return migrator.CopyResources(sourceIds.ToArray(), targets.ToArray(), overwrite, new RebaseOptions(rootSourceParent, folderId), cb);
- dlg.RunOperationAsync(wb, worker);
- RefreshModel(targetConn.DisplayName, folderId);
- ExpandNode(targetConn.DisplayName, folderId);
+ bool overwrite = true;
+ var existing = new List<string>();
+ foreach (var resId in targets)
+ if (targetConn.ResourceService.ResourceExists(resId))
+ existing.Add(resId);
+ if (existing.Count > 0)
+ overwrite = MessageService.AskQuestion(string.Format(Properties.Resources.PromptOverwriteOnTargetConnection, existing.Count));
+ var wb = Workbench.Instance;
+ var dlg = new ProgressDialog();
+ var worker = new ProgressDialog.DoBackgroundWork((w, evt, args) =>
+ LengthyOperationProgressCallBack cb = (s, cbe) =>
+ w.ReportProgress(cbe.Progress, cbe.StatusMessage);
+ return migrator.CopyResources(sourceIds.ToArray(), targets.ToArray(), overwrite, new RebaseOptions(rootSourceParent, folderId), cb);
+ var result = (string[])dlg.RunOperationAsync(wb, worker);
+ RefreshModel(targetConn.DisplayName, folderId);
+ ExpandNode(targetConn.DisplayName, folderId);
+ return result;
- private string GetCommonParent(RepositoryHandle[] data)
+ internal static string GetCommonParent(RepositoryHandle[] data)
if (data.Length > 0)
@@ -534,8 +540,50 @@
- private static IEnumerable<string> GetFullResourceList(IServerConnection sourceConn, string resId)
+ internal static string GetCommonParent(RepositoryItem[] data)
+ if (data.Length > 0)
+ if (data.Length == 1)
+ if (data[0].IsFolder)
+ return data[0].ToString();
+ else
+ return data[0].Parent.ResourceId;
+ else
+ int matches = 0;
+ string[] parts = data.First().ResourceId.ToString()
+ .Substring("Library://".Length)
+ .Split('/');
+ string test = "Library://";
+ string parent = test;
+ int partIndex = 0;
+ //Use first one as a sample to see how far we can go. Keep going until we have
+ //a parent that doesn't match all of them. The one we recorded before then will
+ //be the common parent
+ while (matches == data.Length)
+ parent = test;
+ partIndex++;
+ if (partIndex < parts.Length) //Shouldn't happen, but just in case
+ break;
+ test = test + parts[partIndex];
+ matches = data.Where(x => x.ResourceId.StartsWith(test)).Count();
+ return parent;
+ else
+ return "Library://";
+ internal static IEnumerable<string> GetFullResourceList(IServerConnection sourceConn, string resId)
var list = sourceConn.ResourceService.GetRepositoryResources(resId, -1);
foreach (var res in list.Children)
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/CrossConnection/ResourceMigrator.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/CrossConnection/ResourceMigrator.cs 2011-09-07 09:19:29 UTC (rev 6124)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/CrossConnection/ResourceMigrator.cs 2011-09-07 10:22:36 UTC (rev 6125)
@@ -60,12 +60,13 @@
/// <param name="options">Re-base options</param>
/// <param name="callback"></param>
/// <returns></returns>
- public int CopyResources(string[] sourceResourceIds, string[] targetResourceIds, bool overwrite, RebaseOptions options, LengthyOperationProgressCallBack callback)
+ public string[] CopyResources(string[] sourceResourceIds, string[] targetResourceIds, bool overwrite, RebaseOptions options, LengthyOperationProgressCallBack callback)
Check.NotNull(sourceResourceIds, "sourceResourceIds");
Check.NotNull(targetResourceIds, "targetResourceIds");
Check.Precondition(sourceResourceIds.Length == targetResourceIds.Length, "resourceIds.Length == targetResourceIds.Length");
+ var copiedItems = new List<string>();
var cb = callback;
if (cb == null)
@@ -140,11 +141,12 @@
copied++;
message = string.Format(Properties.Resources.CopiedResourceToTarget, srcResId, dstResId);
+ copiedItems.Add(srcResId);
progress += unit;
cb(this, new LengthyOperationProgressArgs(message, progress));
- return copied;
+ return copiedItems.ToArray();
/// <summary>
More information about the mapguide-commits
