[mapguide-commits] r6141 - in trunk/Tools/Maestro/Maestro.Editors:
LayerDefinition LayerDefinition/Vector Properties
svn_mapguide at osgeo.org
Wed Sep 21 10:27:26 EDT 2011
Author: jng
Date: 2011-09-21 07:27:26 -0700 (Wed, 21 Sep 2011)
New Revision: 6141
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/LayerPropertiesSectionCtrl.cs
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/FeaturePreviewRender.cs
trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
#1811: Fix an exception rendering a null Brush. Also implement a graceful way to recover when opening a broken Layer Definition
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/LayerPropertiesSectionCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/LayerPropertiesSectionCtrl.cs 2011-09-21 09:56:04 UTC (rev 6140)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/LayerPropertiesSectionCtrl.cs 2011-09-21 14:27:26 UTC (rev 6141)
@@ -9,6 +9,8 @@
using System.Diagnostics;
using OSGeo.MapGuide.ObjectModels.LayerDefinition;
using Maestro.Editors.Common;
+using Maestro.Editors.Generic;
+using OSGeo.MapGuide.MaestroAPI;
namespace Maestro.Editors.LayerDefinition
@@ -77,30 +79,44 @@
if (_vl == null || string.IsNullOrEmpty(_vl.FeatureName))
return;
- //TODO: Should just fetch the class definition
- var desc = _edsvc.FeatureService.DescribeFeatureSource(_vl.ResourceId);
- var cls = desc.GetClass(_vl.FeatureName);
- if (cls != null)
+ if (_edsvc.ResourceService.ResourceExists(_vl.ResourceId))
- grdProperties.Rows.Clear();
- foreach (var col in cls.Properties)
+ //TODO: Should just fetch the class definition
+ var desc = _edsvc.FeatureService.DescribeFeatureSource(_vl.ResourceId);
+ var cls = desc.GetClass(_vl.FeatureName);
+ if (cls != null)
- if (col.Type == OSGeo.MapGuide.MaestroAPI.Schema.PropertyDefinitionType.Data)
+ grdProperties.Rows.Clear();
+ foreach (var col in cls.Properties)
- bool visible = false;
- string disp = col.Name;
- foreach (var item in _vl.PropertyMapping)
+ if (col.Type == OSGeo.MapGuide.MaestroAPI.Schema.PropertyDefinitionType.Data)
- if (item.Name == col.Name)
+ bool visible = false;
+ string disp = col.Name;
+ foreach (var item in _vl.PropertyMapping)
- visible = true;
- disp = item.Value;
+ if (item.Name == col.Name)
+ visible = true;
+ disp = item.Value;
+ grdProperties.Rows.Add(visible, col.Name, disp);
- grdProperties.Rows.Add(visible, col.Name, disp);
+ else
+ MessageBox.Show(string.Format(Properties.Resources.PromptRepairBrokenFeatureSource, _vl.ResourceId));
+ using (var picker = new ResourcePicker(_edsvc.ResourceService, ResourceTypes.FeatureSource, ResourcePickerMode.OpenResource))
+ if (picker.ShowDialog() == DialogResult.OK)
+ _vl.ResourceId = picker.ResourceID;
private void btnCheckAll_Click(object sender, EventArgs e)
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/FeaturePreviewRender.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/FeaturePreviewRender.cs 2011-09-21 09:56:04 UTC (rev 6140)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/FeaturePreviewRender.cs 2011-09-21 14:27:26 UTC (rev 6141)
@@ -58,7 +58,7 @@
if (item.Fill != null)
- Brush b;
+ Brush b = null;
Image texture = null;
foreach (ImageStylePicker.NamedImage img in FillImages)
@@ -112,7 +112,7 @@
catch { }
if (texture == null && bgColor.HasValue)
b = new SolidBrush(bgColor.Value);
- else
+ else if (texture != null)
b = new TextureBrush(texture);
if (b != null)
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs 2011-09-21 09:56:04 UTC (rev 6140)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs 2011-09-21 14:27:26 UTC (rev 6141)
@@ -2315,6 +2315,15 @@
/// <summary>
+ /// Looks up a localized string similar to The resource id {0} could not be found. You will now be prompted to select the correct feature source.
+ /// </summary>
+ internal static string PromptRepairBrokenFeatureSource {
+ get {
+ return ResourceManager.GetString("PromptRepairBrokenFeatureSource", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Use Office 2010 Drivers? (these are 64-bit compatible).
/// </summary>
internal static string PromptUseOffice2010Drivers {
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx 2011-09-21 09:56:04 UTC (rev 6140)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx 2011-09-21 14:27:26 UTC (rev 6141)
@@ -1265,4 +1265,7 @@
<data name="color" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\color.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="PromptRepairBrokenFeatureSource" xml:space="preserve">
+ <value>The resource id {0} could not be found. You will now be prompted to select the correct feature source</value>
+ </data>
</root>
\ No newline at end of file
More information about the mapguide-commits
