[mapguide-commits] r6156 - trunk/MgDev/Web/src/mapadmin
svn_mapguide at osgeo.org
Fri Sep 30 00:58:47 EDT 2011
Author: liuar
Date: 2011-09-29 21:58:47 -0700 (Thu, 29 Sep 2011)
New Revision: 6156
trunk/MgDev/Web/src/mapadmin/performanceReport.php
trunk/MgDev/Web/src/mapadmin/performanceReport_GetResult.php
trunk/MgDev/Web/src/mapadmin/resizablepagecomponents.php
On behalf of Ted Yang.
fix the ticket 1768(part 5): http://trac.osgeo.org/mapguide/ticket/1768
This submission includes:
1. change the time format for the recent setting "h:m:s A"
2. remove the substr for the CoordinateSystem, for the API implementation has changed
3. change the format method for the scale, the valued should be formatted without a comma or decimal
Modified: trunk/MgDev/Web/src/mapadmin/performanceReport.php
--- trunk/MgDev/Web/src/mapadmin/performanceReport.php 2011-09-29 23:25:55 UTC (rev 6155)
+++ trunk/MgDev/Web/src/mapadmin/performanceReport.php 2011-09-30 04:58:47 UTC (rev 6156)
@@ -483,7 +483,7 @@
//if the scale is not match then show the warning message
if(ValidateScale(false))
- currentScaleValue = RemoveSpace( FormatNumber(currentScaleValue,2) );
+ currentScaleValue = RemoveSpace( FormatNumber(currentScaleValue,0) );
if(currentScaleValue != scaleLastRun.value)
@@ -619,13 +619,13 @@
if(!result)
scaleWarnMsg.innerHTML = "Not a valid map scale.";
- scale.className="warnMsgStyle";
+ scale.className = "warnMsgStyle";
else
if(needFormat)
- scale.value = FormatNumber(scaleValue,2);
+ scale.value = FormatNumber(scaleValue,0);
scaleWarnMsg.innerHTML = "";
@@ -1076,21 +1076,35 @@
function FormatNumber(s, n)
- var n = n > 0 && n <= 20 ? n : 2;
+ var n = n >= 0 && n <= 20 ? n : 2;
var s = parseFloat((s + "").replace(/[^\d\.-]/g, "")).toFixed(n) + "";
- var l = s.split(".")[0].split("").reverse() , r = s.split(".")[1];
+ var l = s.split(".")[0].split("").reverse()
- var t = "";
+ if(n > 0)
+ var r = s.split(".")[1];
+ var t = "";
+ var i=0;
+ for(; i < l.length; i ++ )
+ t += l[i] + ((i + 1) % 3 == 0 && (i + 1) != l.length ? " " : "");
- var i=0;
- for(; i < l.length; i ++ )
+ return t.split("").reverse().join("") + "." + r;
+ else
- t += l[i] + ((i + 1) % 3 == 0 && (i + 1) != l.length ? " " : "");
+ var t = "";
+ var i=0;
+ return t.split("").reverse().join("");
- return t.split("").reverse().join("") + "." + r;
function FormatCenterPoint(x,y,fractionDigits)
@@ -1821,7 +1835,7 @@
centerPoint.value = centerPointCookie.value;
var scaleInput = document.getElementById("txtScale");
- scaleInput.value = FormatNumber(scaleCookie.value,2);
+ scaleInput.value = FormatNumber(scaleCookie.value,0);
var mapDefinitonSelector = document.getElementById("mapSelector_DO_NOT_PERSIST");
mapDefinitonSelector.value = Trim(mapIdCookie.value);
@@ -1880,7 +1894,7 @@
centerPoint.value = selectSetting[2];
- scaleInput.value = FormatNumber(selectSetting[3],2);
+ scaleInput.value = FormatNumber(selectSetting[3],0);
var tipDiv = document.getElementById("mapResourceNameTip");
tipDiv.innerHTML = mapDefinitonSelector.value;
Modified: trunk/MgDev/Web/src/mapadmin/performanceReport_GetResult.php
--- trunk/MgDev/Web/src/mapadmin/performanceReport_GetResult.php 2011-09-29 23:25:55 UTC (rev 6155)
+++ trunk/MgDev/Web/src/mapadmin/performanceReport_GetResult.php 2011-09-30 04:58:47 UTC (rev 6156)
@@ -343,9 +343,8 @@
<td style=" font-weight: bold;">Coordinate System:</td>
<td>
<span style="width:50px; overflow:hidden;">
- <?php
- //TODO: Waiting:Test on new build
- echo substr($mapProfileResult->MapProfileData->CoordinateSystem,0,25);
+ <?php
+ echo $mapProfileResult->MapProfileData->CoordinateSystem;
</span>
</td>
Modified: trunk/MgDev/Web/src/mapadmin/resizablepagecomponents.php
--- trunk/MgDev/Web/src/mapadmin/resizablepagecomponents.php 2011-09-29 23:25:55 UTC (rev 6155)
+++ trunk/MgDev/Web/src/mapadmin/resizablepagecomponents.php 2011-09-30 04:58:47 UTC (rev 6156)
@@ -2198,8 +2198,7 @@
number_format($layerProfileData->TotalRenderTime,2)." ms (".
$layerProfileData->GetRenderTimePercentage($sumofRenderTime)."%) </td>","\n";
echo "<td style='width:25%;'>".$layerProfileData->FeatureClass."</td>","\n";
- //TODO: Waiting:Test on new build CoordinateSystem Length
- echo "<td style='width:25%;'>".substr($layerProfileData->CoordinateSystem,0,25)."</td>","\n";
+ echo "<td style='width:25%;'>".$layerProfileData->CoordinateSystem."</td>","\n";
echo "<td style='width:15%;'>".$layerProfileData->LayerType."</td>","\n";
echo "</tr>","\n";
@@ -2358,7 +2357,7 @@
echo $dTime->format("M d,Y");
echo "</td>","\n";
echo "<td style='width:50%;text-align: right;'>","\n";
- echo $dTime->format("H:m:s");
+ echo $dTime->format("h:m:s A");
echo "</td>","\n";
echo "</tr></table></td></tr></table>","\n";
More information about the mapguide-commits
