[mapguide-commits] r6160 -
sandbox/rfc90.2/MgDev/Server/src/Services/Tile
svn_mapguide at osgeo.org
Fri Sep 30 06:55:36 EDT 2011
Author: uvlite
Date: 2011-09-30 03:55:36 -0700 (Fri, 30 Sep 2011)
New Revision: 6160
sandbox/rfc90.2/MgDev/Server/src/Services/Tile/ServerTileService.cpp
sandbox/rfc90.2/MgDev/Server/src/Services/Tile/ServerTileService.h
sandbox/rfc90.2/MgDev/Server/src/Services/Tile/ServerTileService.vcproj
sandbox/rfc90.2/MgDev/Server/src/Services/Tile/TileCache.cpp
sandbox/rfc90.2/MgDev/Server/src/Services/Tile/TileCache.h
stable version with only minor leaks if any
Modified: sandbox/rfc90.2/MgDev/Server/src/Services/Tile/ServerTileService.cpp
--- sandbox/rfc90.2/MgDev/Server/src/Services/Tile/ServerTileService.cpp 2011-09-30 07:00:47 UTC (rev 6159)
+++ sandbox/rfc90.2/MgDev/Server/src/Services/Tile/ServerTileService.cpp 2011-09-30 10:55:36 UTC (rev 6160)
@@ -19,6 +19,7 @@
#include "ServerTileService.h"
#include "ServerRenderingService.h"
//#include <sstream>
+//#include <iostream>
IMPLEMENT_CREATE_SERVICE(MgServerTileService)
@@ -83,8 +84,18 @@
sm_initialized = true;
m_tileCache = new MgTileCache(this);
+#ifdef _DEBUG
+ if (sm_useMetaTiles > 0) // the tilecache is instantiated for each request so this is debug only
+ std::wstringstream text;
+ text << L"Server is using MetaTiling Factor: " << sm_useMetaTiles << L" & Locking Method: " << sm_lockMethod;
+ ACE_DEBUG ((LM_INFO, text.str().c_str()));
+#endif
// bail out if metatile factor to large (allocation problem)
if (sm_useMetaTiles > 7)
@@ -117,32 +128,13 @@
/// \brief
-/// Detect if the tile file has been locked by another thread or process.
+/// Detect if the tile file has been locked by another thread or process and wait up to sm_creationCutoffTime
bool MgServerTileService::DetectTileLockFile(CREFSTRING lockPathname, CREFSTRING tilePathname)
bool found = false;
struct _stat lockFileInfo;
- if (sm_lockMethod == 2) // simple collection of paths
- int sec = sm_pollingInterval/1000;
- ACE_Time_Value polInt (sec, (sm_pollingInterval - (sec*1000))*1000);
- time_t startTime;
- ACE_OS::time(&startTime);
- time_t diffTime = 0;
- time_t currTime;
- // sm_creationCutoffTime times or found
- // TODO think about multithreaded lockmap access
- //(found = m_tileCache->GetLockMap().count(tilePathname))
- for (INT32 diffTime=0;diffTime < sm_creationCutoffTime;
- ACE_OS::time(&currTime),diffTime = (INT32)(currTime - startTime))
- // sm_pollingInterval om milliseconds
- ACE_OS::sleep(polInt);
// Check the lock file to see if another thread/process is writing the tile file.
while (MgFileUtil::GetFileStatus(lockPathname, lockFileInfo))
@@ -152,10 +144,12 @@
if (diffTime < sm_creationCutoffTime)
+ ACE_OS::sleep(sm_pollingInterval);
+#ifdef _DEBUG
+ text << L"(" << ACE_OS::thr_self() << L") METATILE: WaitForLockfile(" << lockPathname << L")\n" ;
+ ACE_DEBUG ((LM_DEBUG, text.str().c_str()));
+#endif
else
@@ -182,7 +176,7 @@
if (NULL == mapDefinition || baseMapLayerGroupName.empty())
throw new MgNullArgumentException(L"MgServerTileService.GetTile",
- __LINE__, __WFILE__, NULL, L"", NULL);
+ __LINE__, __WFILE__, NULL, L"MgGetTileWithOutMapSpecified", NULL);
if (scaleIndex < 0)
@@ -222,7 +216,7 @@
if (scaleIndex < 0)
@@ -355,15 +349,15 @@
-// Create tilename from mapDefinition, scaleIndex, row, and column USING METATILES
-/// APIVERSION 1.2 use locking method specified in sm_lockMethod
+// Get tile using mapDefinition, scaleIndex, row, and column USING METATILES
+/// APIVERSION 1.2 and using the locking method specified in sm_lockMethod
MgByteReader* MgServerTileService::GetMetaTile(MgResourceIdentifier* mapDefinition,
CREFSTRING baseMapLayerGroupName,
INT32 tileColumn,
INT32 tileRow,
INT32 scaleIndex)
- Ptr<MgByteReader> ret;
+ Ptr<MgByteReader> returnedSubtile;
FILE* lockFile = NULL;
STRING tilePathname, lockPathname;
// metatiling vars
@@ -376,11 +370,13 @@
MG_TRY()
// Generate tile and lock pathnames for later use
- m_tileCache->GeneratePathnames(mapDefinition, scaleIndex, baseMapLayerGroupName,
- tileColumn, tileRow, tilePathname, lockPathname, false);
+ //m_tileCache->GeneratePathnames(mapDefinition, scaleIndex, baseMapLayerGroupName,
+ // tileColumn, tileRow, tilePathname, lockPathname, false);
- // additional names and control variables for meta tiles
- // which subTile from sm_useMetaTiles^2 larger tile
+ ////// compute additional names and control variables to deal with meta tiles:
+ // a meta tile is sm_useMetaTiles^2 larger than the requested subtile so there are less tiles computed per map
+ // the metatile coords are computed from original coords modulo metatilesize
+ // e.g. with metatile=2 4 tiles (0,0)(0,1)(1,0)(1,1) get mapped to metatile(0,0)
subTileX = abs(tileColumn % sm_useMetaTiles);
subTileY = abs(tileRow % sm_useMetaTiles);
// determine left top corner of metaTile having sm_useMetaTiles**2 subtiles
@@ -388,7 +384,7 @@
metaTileRow = tileRow - subTileY;
maxX = maxY = sm_useMetaTiles; // init control vars
- // iterate subtiles
+ //// iterate subtiles and create all pathnames of the created tiles
for (int y=0; y < maxY; y++) // subtile rows
for (int x=0; x < maxX; x++) // subtile columns
{ // Generate tile and lock pathnames.
@@ -397,55 +393,48 @@
metaTileColumn + x, metaTileRow + y, subTilePathname[x][y], subTileLockPathname[x][y], false);
- // Generate tile and lock pathnames for meta tile in the mod xx grid
+ // Generate tile and lock pathnames for meta tile in the larger grid mod xx
metaTileColumn, metaTileRow, metaTilePathname, metaTileLockPathname, false);
- // sm_lockMethod == 1 using 1 remapped metalockfile for all subtiles
- // sm_lockMethod == 2 using 1 lockfile for each subtiles
- // sm_lockMethod == 3 using 1 ace condition per metatile
- switch (sm_lockMethod)
+ // sm_lockMethod == 0 is using 1 remapped metalockfile for all subtiles
+ // sm_lockMethod > 0 is using 1 an ace condition mapped by metatilename
+ if (sm_lockMethod)
- case 3: // use ace conditions no files
- m_tileCache->WaitForLock(metaTilePathname);
- break;
- case 2:
- if (DetectTileLockFile(lockPathname, tilePathname))
#ifdef _DEBUG
- text << L"(" << ACE_OS::thr_self() << L") METATILE: DeletedDanglingLockfile(" << tileRow
- << L", " << tileColumn << L") " << lockPathname << L")\n" ;
+ text << L"(" << ACE_OS::thr_self() << L") METATILE: " << "WaitForLock("
+ << tileRow << L", " << tileColumn << L") (" << metaTilePathname << L")\n" ;
#endif
- // TODO: Handle the exception by displaying a tile with an error message?
- MgFileUtil::DeleteFile(lockPathname, true);
- break;
- default:
- case 1: // default
- if (DetectTileLockFile(metaTileLockPathname, metaTilePathname))
+ m_tileCache->WaitForLock(metaTilePathname);
+ else // this is the same locking strategie as with single tiles but using one mapped metatile locking all subtile requests
+ bool fileExist = DetectTileLockFile(metaTileLockPathname, metaTilePathname);
+ if (fileExist)
+ { // TODO: Handle the exception by displaying a tile with an error message?
+ MgFileUtil::DeleteFile(metaTileLockPathname, true);
#ifdef _DEBUG
- text << L"(" << ACE_OS::thr_self() << L") METATILE: DeletedDanglingLockfile(" << metaTileRow
- << L", " << metaTileColumn << L") " << metaTileLockPathname << L")\n" ;
+ text << L"(" << ACE_OS::thr_self() << L") METATILE: " << (fileExist?L"DeletedDanglingLockfile(":L"NoLockfile(")
+ << metaTileRow << L", " << metaTileColumn << L") " << metaTileLockPathname << L")\n" ;
#endif
- MgFileUtil::DeleteFile(metaTileLockPathname, true);
- } /// end switch
// try getting the tile from the cache first time
- cacheHit = ret = m_tileCache->Get(tilePathname);
+ cacheHit = returnedSubtile = m_tileCache->Get(tilePathname);
#ifdef _DEBUG
- std::wstringstream text;
- text << L"(" << ACE_OS::thr_self() << (cacheHit?L") CACHEHIT":L") CACHEMISS") << L": GetTile("
- << tileRow << L", " << tileColumn << L") " << tilePathname << L"\n";
- ACE_DEBUG ((LM_DEBUG, text.str().c_str()));
+ text << L"(" << ACE_OS::thr_self() << (cacheHit?L") CACHEHIT":L") CACHEMISS") << L": GetTile("
+ << tileRow << L", " << tileColumn << L") " << tilePathname << L"\n";
#endif
// if the reader is NULL then the tile wasn't in the cache and we need to generate it
- while (NULL == ret) // while is needed to use break; =========================================
+ while (NULL == returnedSubtile) // while for if to be able to use break to skip to end;
Ptr<MgMap> map;
@@ -453,125 +442,78 @@
// thread safe so we need to deserialize the map within the mutex to ensure
// that a Rewind() is not called in the middle of a Deserialize().
// Lockfile test and creation is in same protected scope.
- { // ------------------------ LLLLOOOOOOCCCCCKKKKKIIIIINNNGGGG
+ { // ------------------------ Locking Context
// Attempt to get the mapcache mutex .
ACE_MT(ACE_GUARD_RETURN(ACE_Recursive_Thread_Mutex, ace_mon, sm_mutex, NULL));
- switch(sm_lockMethod)
- case 3:// TODO do we need the second lock test here in a signal/wait algorithm?
- m_tileCache->LockTile(metaTilePathname);
- break;
- case 2: // Bail out if the tile file has been locked for so long.
+ // we DONT need the second lock test here in a signal/wait algorithm
+// m_tileCache->WaitForLock(metaTilePathname);
+ else
+ if (DetectTileLockFile(metaTileLockPathname, metaTilePathname)) //
MgStringCollection arguments;
- arguments.Add(lockPathname);
- throw new MgFileIoException(L"MgServerTileService.GetTile",
- __LINE__, __WFILE__, &arguments, L"MgUnableToLockMetaTileFile", NULL);
- break;
- default:
- case 1:
- MgStringCollection arguments;
arguments.Add(metaTileLockPathname);
- } // end switch ------------------------ LLLLOOOOOOCCCCCKKKKKIIIIINNNGGGG
// try getting the tile from the cache second time ???????????????????????????????????????????
- if (NULL != ret)
+ if (NULL != returnedSubtile)
#ifdef _DEBUG
text << L"(" << ACE_OS::thr_self() << L") CACHEHIT2: GetTile(" << tileRow << L", " << tileColumn << L") " << tilePathname << L"\n";
-#endif
- /////////////////////////////////// tile was in tileCache .. done.
- break;
+#endif
+ break; /////////////////////////////////// tile was in tileCache .. done.
} else {
#ifdef _DEBUG
text << L"(" << ACE_OS::thr_self() << L") CACHEMISS2: GetTile(" << tileRow << L", " << tileColumn << L") " << tilePathname << L"\n";
#endif
+ // Create the directory structure all subtiles!
+ for (int y=0; y < maxY; y++) // rows
+ for (int x=0; x < maxX; x++) // columns
+ m_tileCache->CreateFullPath(mapDefinition, scaleIndex, baseMapLayerGroupName,
+ metaTileColumn + x, metaTileRow + y);
- // ============================================================================ LOCKING
+ // ================================================== LOCKING
- case 3:
- // Create the directory structure for each subtile!
- for (int y=0; y < maxY; y++) // rows
- for (int x=0; x < maxX; x++) // columns
- m_tileCache->CreateFullPath(mapDefinition, scaleIndex, baseMapLayerGroupName,
- metaTileColumn + x, metaTileRow + y);
- break;
- case 2:
- { // Create the directory structure for each subtile
- // Create a lock file per sub tile and close it right away.
- subTileLockFile[x][y] = ACE_OS::fopen(MG_WCHAR_TO_TCHAR(subTileLockPathname[x][y]), ACE_TEXT("wb"));
+ m_tileCache->LockTile(metaTilePathname); // ace lock once per metatile
+ else
+ // Create the lock file
+ lockFile = ACE_OS::fopen(MG_WCHAR_TO_TCHAR(metaTileLockPathname), ACE_TEXT("wb"));
- if (NULL == subTileLockFile[x][y])
- arguments.Add(subTilePathname[x][y]);
- __LINE__, __WFILE__, &arguments, L"MgUnableToCreateLockFile", NULL);
- else
- ACE_OS::fclose(subTileLockFile[x][y]);
+ if (NULL == lockFile)
+ MgStringCollection arguments;
+ arguments.Add(metaTileLockPathname);
+ throw new MgFileIoException(L"MgServerTileService.GetTile",
+ __LINE__, __WFILE__, &arguments, L"MgUnableToCreateLockFile", NULL);
+ else
+ ACE_OS::fclose(lockFile); // and close it right away.
#ifdef _DEBUG
- text << L"(" << ACE_OS::thr_self() << L") METATILE: CreatedLockfile(" << metaTileRow + y << L", " << metaTileColumn + x << L") "
- << L" S(" << x << L", " << y << L") " << subTileLockPathname[x][y] << L")\n";
+ text << L"(" << ACE_OS::thr_self() << L") METATILE: CreatedLockfile(" << metaTileRow << L", " << metaTileColumn<< L") "
+ << metaTileLockPathname << L")\n";
#endif
- } // end meta tiling loop for lockfiles
- break;
- default:
- case 1:
- metaTileColumn, metaTileRow);
- // per array element Create the lock file and close it right away.
- lockFile = ACE_OS::fopen(MG_WCHAR_TO_TCHAR(metaTileLockPathname), ACE_TEXT("wb"));
- if (NULL == lockFile)
- arguments.Add(metaTileLockPathname);
- __LINE__, __WFILE__, &arguments, L"MgUnableToOpenLockFile", NULL);
- else
- ACE_OS::fclose(lockFile);
-#ifdef _DEBUG
- text << L"(" << ACE_OS::thr_self() << L") METATILE: CreatedLockfile(" << metaTileRow << L", " << metaTileColumn<< L") "
- << metaTileLockPathname << L")\n";
-#endif
- } // end switch
GetMapFromDefinition(mapDefinition, scaleIndex, map);
} // end of mutex scope
@@ -580,10 +522,10 @@
STRING metaTileName = L"META" + metaTilePathname;
#ifdef _DEBUG
- text << L"(" << ACE_OS::thr_self() << L") METATILE: RenderMetaTile(" << metaTileRow << L", " << metaTileColumn << L") " << metaTileName << L"\n";
+ text << L"(" << ACE_OS::thr_self() << L") METATILE: RenderMetaTile(" << metaTileRow << L", " << metaTileColumn << L") " << metaTileName << " using map 0x" << map << L"\n";
#endif
- Ptr<MgByteReader> metaTile = GetTile(metaTileName, map, scaleIndex, baseMapLayerGroupName, metaTileColumn, metaTileRow);
+ Ptr<MgByteReader> metaTileBitMap = GetTile(metaTileName, map, scaleIndex, baseMapLayerGroupName, metaTileColumn, metaTileRow);
// Get a ServerSide rendering Service only...
MgServiceManager* serviceMan = MgServiceManager::GetInstance();
@@ -596,57 +538,48 @@
- // generate the tile
- Ptr<MgByteReader> img = svcRendering->RenderTileFromMetaTile(map, metaTile, x,y);
+ // callback to the rendering service to collect the subtile from the metatile bitmap
+ Ptr<MgByteReader> img = svcRendering->RenderTileFromMetaTile(map, metaTileBitMap, x,y);
if ((subTileX == x) && (subTileY == y))
- ret = img; // keep pointer for requested subtile
+ returnedSubtile = img; // keep pointer for subtile which has triggered the metatile in the current thread
assert (x < maxX && y < maxY);
+#ifdef _DEBUG
+ std::wstringstream text; // streams for more compact debug statements
+ text << L"(" << ACE_OS::thr_self();
+ text << L") RenderTileFromMetaTile dim:" << MgTileParameters::tileWidth << L"x" << MgTileParameters::tileHeight;
+ text << L" format:" << MgTileParameters::tileFormat.c_str() << L" subTile(" << x << L"," << y;
+ text << L") metaTile(" << metaTileRow << L"," << metaTileColumn << L") " << metaTilePathname.c_str() << L"\n";
+#endif
m_tileCache->Set(img, subTilePathname[x][y]); // store all subtiles in tile cache
+ // rewind the reader since setting the tile advances it to the end
if (img)
+ img->Rewind();
#ifdef _DEBUG
- text << L"(" << ACE_OS::thr_self() << L") METATILE: SetTileFromMetaTile(" << tileRow << L", " << tileColumn << L") " << subTilePathname[x][y]
- << L" S(" << x << L", " << y << L")\n";
+ text << L"(" << ACE_OS::thr_self() << L") METATILE: " << (img?L"SetTile":L"NoTileReturned");
+ text << "FromMetaTile(" << tileRow << L", " << tileColumn << L") ";
+ text << subTilePathname[x][y] << L" S(" << x << L", " << y << L")\n";
-#endif
- // rewind the reader since setting the tile advances it to the end
- if (img)
- img->Rewind();
+#endif
break;
} // end of gettile loop end MgMap scope
MG_CATCH(L"MgServerTileService.GetTile")
- // remove all lockfiles
- switch(sm_lockMethod) // do the locking now
+ // remove all lockfiles or conditions
- case 3:
m_tileCache->ClearLock(metaTilePathname);
- break;
- case 2:
- if (NULL != subTileLockFile[x][y])
- MgFileUtil::DeleteFile(subTileLockPathname[x][y], false);
-#ifdef _DEBUG
- text << L"(" << ACE_OS::thr_self() << L") METATILE: DeletedLockfile(" << metaTileRow + y << L", " << metaTileColumn + x
- << L") S(" << x << L", " << y << subTileLockPathname[x][y] << L")\n";
-#endif
- break;
- case 1:
- default:
+ else
if (NULL != lockFile)
MgFileUtil::DeleteFile(metaTileLockPathname, false);
@@ -659,7 +592,7 @@
#endif
- } // end switch
MG_THROW()
@@ -668,15 +601,14 @@
#ifdef _DEBUG
text << L"(" << ACE_OS::thr_self() << L") Rendered: GetTILE(" << tileRow << L", " << tileColumn << L") "
- << L" S(" << subTileX << L", " << subTileY << tilePathname << L")\n";
+ << L" S(" << subTileX << L", " << subTileY << L") (" << tilePathname << L")\n";
#endif
- return ret.Detach();
+ return returnedSubtile.Detach();
// look for the tile in the tilecache first
MgByteReader* MgServerTileService::GetTile(MgMap* map,
@@ -757,7 +689,7 @@
else
@@ -802,8 +734,9 @@
img = svcRendering->RenderTile(map, baseMapLayerGroupName, tileColumn, tileRow);
- // cache the tile
- if (!sm_renderOnly && !sm_useMetaTiles)
+ // cache the tile here ONLY IF WE ARE NOT METATILING !!!!
+ // if we do metatiling this is the large metatile here and we cache the subtiles in GetMetaTile ~line600
+ if (!sm_renderOnly && (sm_useMetaTiles == 0))
m_tileCache->Set(img, tilePathname);
@@ -875,7 +808,7 @@
throw new MgFileIoException(L"MgServerTileService.SetTile",
else
@@ -919,7 +852,7 @@
arguments.Add(mapDefinition->ToString());
throw new MgPermissionDeniedException(
- funcName, __LINE__, __WFILE__, &arguments, L"", NULL);
+ funcName, __LINE__, __WFILE__, &arguments, L"MgPermissionDeniedForResource", NULL);
return resourceService.Detach();
@@ -931,7 +864,7 @@
MG_TRY()
if (NULL == map)
- throw new MgNullArgumentException(L"MgServerTileService.ClearCache", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgNullArgumentException(L"MgServerTileService.ClearCache", __LINE__, __WFILE__, NULL, L"MgNoMapSpecified", NULL);
Ptr<MgResourceIdentifier> resourceId = map->GetMapDefinition();
ClearMapCache(resourceId->ToString());
Modified: sandbox/rfc90.2/MgDev/Server/src/Services/Tile/ServerTileService.h
--- sandbox/rfc90.2/MgDev/Server/src/Services/Tile/ServerTileService.h 2011-09-30 07:00:47 UTC (rev 6159)
+++ sandbox/rfc90.2/MgDev/Server/src/Services/Tile/ServerTileService.h 2011-09-30 10:55:36 UTC (rev 6160)
@@ -69,6 +69,7 @@
static INT32 sm_lockMethod;
static INT32 sm_useMetaTiles;
+ static ACE_Recursive_Thread_Mutex sm_mutex;
private:
@@ -104,7 +105,6 @@
static bool sm_initialized;
static MapCache sm_mapCache;
- static ACE_Recursive_Thread_Mutex sm_mutex;
static bool sm_renderOnly;
static INT32 sm_creationCutoffTime;
static INT32 sm_pollingInterval;
Modified: sandbox/rfc90.2/MgDev/Server/src/Services/Tile/ServerTileService.vcproj
--- sandbox/rfc90.2/MgDev/Server/src/Services/Tile/ServerTileService.vcproj 2011-09-30 07:00:47 UTC (rev 6159)
+++ sandbox/rfc90.2/MgDev/Server/src/Services/Tile/ServerTileService.vcproj 2011-09-30 10:55:36 UTC (rev 6160)
@@ -202,7 +202,7 @@
<Tool
Name="VCCLCompilerTool"
Optimization="2"
- AdditionalIncludeDirectories="..\..\..\..\Common\Foundation;..\..\..\..\Common\Geometry;..\..\..\..\Common\PlatformBase;..\..\..\..\Common\MapGuideCommon;..\..\..\..\Common\MdfModel;..\..\Common;..\..\Common\Base;..\..\Common\Manager;..\Mapping;..\..\..\..\Oem\ACE\ACE_wrappers;..\..\..\..\Oem\FDO\inc"
+ AdditionalIncludeDirectories="..\..\..\..\Common\Foundation;..\..\..\..\Common\Geometry;..\..\..\..\Common\PlatformBase;..\..\..\..\Common\MapGuideCommon;..\..\..\..\Common\MdfModel;..\..\Common;..\..\Common\Base;..\..\Common\Manager;..\Mapping;..\Rendering;..\..\..\..\Oem\ACE\ACE_wrappers;..\..\..\..\Oem\FDO\inc"
PreprocessorDefinitions="WIN32;NDEBUG;_WINDOWS;_USRDLL;MG_SERVER_TILE_EXPORTS"
ExceptionHandling="2"
RuntimeLibrary="2"
@@ -227,7 +227,7 @@
GenerateDebugInformation="true"
ProgramDatabaseFile="$(OutDir)\MgServerTileService.pdb"
SubSystem="2"
- OptimizeReferences="2"
+ OptimizeReferences="1"
EnableCOMDATFolding="2"
RandomizedBaseAddress="1"
DataExecutionPrevention="0"
Modified: sandbox/rfc90.2/MgDev/Server/src/Services/Tile/TileCache.cpp
--- sandbox/rfc90.2/MgDev/Server/src/Services/Tile/TileCache.cpp 2011-09-30 07:00:47 UTC (rev 6159)
+++ sandbox/rfc90.2/MgDev/Server/src/Services/Tile/TileCache.cpp 2011-09-30 10:55:36 UTC (rev 6160)
@@ -25,7 +25,6 @@
const STRING COLUMN_PREFIX = L"C";
STRING MgTileCache::sm_path = L"";
-MgServerTileService* MgTileCache::sm_tileService = 0;
INT32 MgTileCache::sm_tileColumnsPerFolder = 30;
INT32 MgTileCache::sm_tileRowsPerFolder = 30;
ACE_Recursive_Thread_Mutex MgTileCache::sm_tileMutex;
@@ -34,7 +33,8 @@
// default constructor
MgTileCache::MgTileCache(MgServerTileService* tileService)
- sm_tileService = tileService; // keep pointer to parent
+ // !!!! DONT USE ADDREF & Ptr<> here since it leaks cos the Ptr<> destructor never gets called
+ m_tileService = tileService; // keep pointer to parent for access to settings
@@ -178,15 +178,15 @@
ret = byteSource->GetReader();
} else
- //if (sm_tileService->sm_lockMethod==3 && sm_tileService->sm_useMetaTiles)
- //{ // protect creation of lockmap entry with a guard
- // ACE_MT(ACE_GUARD_RETURN (ACE_Recursive_Thread_Mutex, ace_mon, sm_tileService->sm_mutex, 0));
- // // create ace condition for this tile as we are going to make it
- // ACE_Condition<ACE_Recursive_Thread_Mutex> *wait =
- // new ACE_Condition<ACE_Recursive_Thread_Mutex>(sm_tileService->sm_mutex);
- // // keep lock (ace condition) in map
- // GetLockMap()[tilePathname] = wait;
+ if (m_tileService->sm_lockMethod==3 && m_tileService->sm_useMetaTiles)
+ { // protect creation of lockmap entry with a guard
+ ACE_MT(ACE_GUARD_RETURN (ACE_Recursive_Thread_Mutex, ace_mon, m_tileService->sm_mutex, 0));
+ // create ace condition for this tile as we are going to make it
+ ACE_Condition<ACE_Recursive_Thread_Mutex> *tileLock =
+ new ACE_Condition<ACE_Recursive_Thread_Mutex>(m_tileService->sm_mutex);
+ // keep lock (ace condition) in map
+ sm_lockMap[tilePathname] = tileLock;
MG_CATCH_AND_RELEASE()
@@ -446,11 +446,12 @@
// wait for a previous ace condition
void MgTileCache::WaitForLock(CREFSTRING tilePathname)
-{ // protect test of lockmap entry with a guard
- ACE_Condition<ACE_Recursive_Thread_Mutex> *wait = 0;
+ // protect test of lockmap entry with a guard
+ ACE_Condition<ACE_Recursive_Thread_Mutex> *tileLock = 0;
// look for lock and wait if found
ACE_MT(ACE_GUARD (ACE_Recursive_Thread_Mutex, ace_mon, sm_tileMutex));
- if (wait = sm_lockMap[tilePathname])
+ if (tileLock = sm_lockMap[tilePathname])
{ // lock has been found
#ifdef _DEBUG
@@ -459,26 +460,26 @@
#endif
// ACE_Time_Value waitTime(METATILEWAIT);
- if (-1 == wait->wait()) // wait forever
+ int ret = tileLock->wait(); // returns -1 if timed out which is not supposed to happen
+ if (-1 == ret) // so the wait might never come back!!! and the thread gets cleaned out by the service manager
#ifdef _DEBUG
- text << L"(" << ACE_OS::thr_self() << L") METATILE: WaitForLockTimedOut1("
- << tilePathname << L")\n" ;
+ text << L"(" << ACE_OS::thr_self() << L") METATILE: WaitForLockTimedOut1(" << tilePathname << L")\n" ;
#endif
arguments.Add(tilePathname);
__LINE__, __WFILE__, &arguments, L"MgWaitForLockTimedOut", NULL);
- } else {
#ifdef _DEBUG
- text << L"(" << ACE_OS::thr_self() << L") METATILE: WaitForLockCAUGHTSIGNAL1("
+ text << L"(" << ACE_OS::thr_self() << L") METATILE: LockReleased(" << tilePathname << L")\n" ;
#endif
@@ -486,9 +487,9 @@
void MgTileCache::LockTile(CREFSTRING tilePathname)
- ACE_Condition<ACE_Recursive_Thread_Mutex> *wait = new ACE_Condition<ACE_Recursive_Thread_Mutex>(sm_tileMutex);
+ ACE_Condition<ACE_Recursive_Thread_Mutex> *tileLock = new ACE_Condition<ACE_Recursive_Thread_Mutex>(sm_tileMutex);
// keep reference to lock (ace condition) in our map
- sm_lockMap[tilePathname] = wait;
#ifdef _DEBUG
@@ -513,8 +514,15 @@
<< L") returns: " << result << L"\n";
#endif
- sm_lockMap.erase(tilePathname); // erase: this destroys the ace condition
+ sm_lockMap.erase(tilePathname); // erase only existing lock: this destroys the ace condition
+ }else
+#ifdef _DEBUG
+ text << L"(" << ACE_OS::thr_self() << L") METATILE: NoLockFor(" << tilePathname << L")\n";
+#endif
catch (MgException* e)
Modified: sandbox/rfc90.2/MgDev/Server/src/Services/Tile/TileCache.h
--- sandbox/rfc90.2/MgDev/Server/src/Services/Tile/TileCache.h 2011-09-30 07:00:47 UTC (rev 6159)
+++ sandbox/rfc90.2/MgDev/Server/src/Services/Tile/TileCache.h 2011-09-30 10:55:36 UTC (rev 6160)
@@ -85,7 +85,7 @@
// use a memory based locking scheme
static std::map<STRING,ACE_Condition<ACE_Recursive_Thread_Mutex>*> sm_lockMap;
- static MgServerTileService* sm_tileService; // pointer to owner
+ MgServerTileService* m_tileService; // pointer to owner
More information about the mapguide-commits
