[mapguide-commits] r6567 - in trunk/Installer: Installers/MapGuide
Libraries/MapGuide Web Extensions
svn_mapguide at osgeo.org
Wed Apr 11 08:34:13 EDT 2012
Author: jng
Date: 2012-04-11 05:34:12 -0700 (Wed, 11 Apr 2012)
New Revision: 6567
trunk/Installer/Installers/MapGuide/MapGuide.wxs
trunk/Installer/Libraries/MapGuide Web Extensions/IIS7.wxs
#1805: Fix broken IIS/PHP configuration for 64-bit. Turns out I wasn't even calling the FastCGI setup actions I created!
Modified: trunk/Installer/Installers/MapGuide/MapGuide.wxs
--- trunk/Installer/Installers/MapGuide/MapGuide.wxs 2012-04-05 06:20:20 UTC (rev 6566)
+++ trunk/Installer/Installers/MapGuide/MapGuide.wxs 2012-04-11 12:34:12 UTC (rev 6567)
@@ -660,9 +660,9 @@
<InstallExecuteSequence>
<!-- IIS7 Base properties for deferred actions -->
- <Custom Action="MapGuideIIS7_I_CreateFastCgi_Cmd" After="CostFinalize">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_AppCmd_Cmd" After="MapGuideIIS7_I_CreateFastCgi_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_CreateAppPool_Cmd" After="MapGuideIIS7_I_AppCmd_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR="#7" AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_AppCmd_Cmd" After="CostFinalize">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR="#7" AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_CreateFastCgi_Cmd" After="MapGuideIIS7_I_AppCmd_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR="#7" AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_CreateAppPool_Cmd" After="MapGuideIIS7_I_CreateFastCgi_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR="#7" AND &WebExtensionsFeature>2</Custom>
<Custom Action="MapGuideIIS7_I_SetAppPoolProp_Cmd" After="MapGuideIIS7_I_CreateAppPool_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR="#7" AND &WebExtensionsFeature>2</Custom>
<Custom Action="MapGuideIIS7_I_UnlockSrvHandlers_Cmd" After="MapGuideIIS7_I_SetAppPoolProp_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR="#7" AND &WebExtensionsFeature>2</Custom>
<Custom Action="MapGuideIIS7_I_UnlockSiteHandlers_Cmd" After="MapGuideIIS7_I_UnlockSrvHandlers_Cmd">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR="#7" AND &WebExtensionsFeature>2</Custom>
@@ -692,7 +692,8 @@
<!-- IIS7 Base deferred CAs -->
<Custom Action="MapGuideIIS7_I_CreateAppPool" After="InstallFiles">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR="#7" AND &WebExtensionsFeature>2</Custom>
- <Custom Action="MapGuideIIS7_I_SetAppPoolProp" After="MapGuideIIS7_I_CreateAppPool">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR="#7" AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_CreateFastCgi" After="MapGuideIIS7_I_CreateAppPool">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR="#7" AND &WebExtensionsFeature>2</Custom>
+ <Custom Action="MapGuideIIS7_I_SetAppPoolProp" After="MapGuideIIS7_I_CreateFastCgi">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR="#7" AND &WebExtensionsFeature>2</Custom>
<?if "$(var.MgPlatform)" = "x64" ?>
<Custom Action="MapGuideIIS7_I_UnlockSrvHandlers" After="MapGuideIIS7_I_SetAppPoolProp">MGWEB_CONFIG="IIS" AND IISVERSIONMAJOR="#7" AND &WebExtensionsFeature>2</Custom>
Modified: trunk/Installer/Libraries/MapGuide Web Extensions/IIS7.wxs
--- trunk/Installer/Libraries/MapGuide Web Extensions/IIS7.wxs 2012-04-05 06:20:20 UTC (rev 6566)
+++ trunk/Installer/Libraries/MapGuide Web Extensions/IIS7.wxs 2012-04-11 12:34:12 UTC (rev 6567)
@@ -17,8 +17,8 @@
<!-- Set up FastCGI -->
<CustomAction Id="MapGuideIIS7_I_CreateFastCgi_Cmd" Property="MapGuideIIS7_I_CreateFastCgi" Execute="immediate"
- Value="[AppCmd] set config /section:system.webServer/fastCGI /+[\[]fullPath="[PHPLOCATION]php-cgi.exe"[\]]" />
- <CustomAction Id="MapGuideIIS7_I_CreateFastCgi" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="ignore" Impersonate="no"/>
+ Value="[AppCmd] set config /section:system.webServer/fastCGI "/+[\[]fullPath='[PHPLOCATION]php-cgi.exe'[\]]"" />
+ <CustomAction Id="MapGuideIIS7_I_CreateFastCgi" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="check" Impersonate="no"/>
<!-- Set the application pool's properties -->
<CustomAction Id="MapGuideIIS7_I_SetAppPoolProp_Cmd" Property="MapGuideIIS7_I_SetAppPoolProp" Execute="immediate"
More information about the mapguide-commits
