[mapguide-commits] r6570 - in trunk/Installer: Bootstrapper
Installers/MapGuide Libraries/MapGuide Server
svn_mapguide at osgeo.org
Wed Apr 11 12:45:52 EDT 2012
Author: jng
Date: 2012-04-11 09:45:51 -0700 (Wed, 11 Apr 2012)
New Revision: 6570
trunk/Installer/Bootstrapper/Setup.nsi
trunk/Installer/Installers/MapGuide/MapGuide.wxs
trunk/Installer/Libraries/MapGuide Server/InstallService.wxs
#1805:
- Fix broken bundled configuration in the absence of IIS. This was due to a dangling feature reference to the old PostGIS FDO provider which has been removed a long time ago.
- Fix file offsets for 64-bit installer
- Use banner instead of msgbox for the VC redist automatic install
Modified: trunk/Installer/Bootstrapper/Setup.nsi
--- trunk/Installer/Bootstrapper/Setup.nsi 2012-04-11 15:07:57 UTC (rev 6569)
+++ trunk/Installer/Bootstrapper/Setup.nsi 2012-04-11 16:45:51 UTC (rev 6570)
@@ -65,7 +65,8 @@
!endif
InstallVC2008Redist:
- MessageBox MB_OK "Installing Visual C++ 2008 redist"
+ Banner::show /NOUNLOAD "Installing Visual C++ 2008 Redistributable"
+ Banner::getWindow /NOUNLOAD
!if ${CPU} = "x64"
File /r "${INSTALLER_OUTPUT}\vcredist_2008_x64.exe"
ExecWait '"$OUTDIR\vcredist_2008_x64.exe" /q:a"'
@@ -73,6 +74,7 @@
File /r "${INSTALLER_OUTPUT}\vcredist_2008_x86.exe"
ExecWait '"$OUTDIR\vcredist_2008_x86.exe" /q:a'
!endif
+ Banner::destroy
CheckVC2010Install:
@@ -96,7 +98,8 @@
!endif
InstallVC2010Redist:
- MessageBox MB_OK "Installing Visual C++ 2010 redist"
+ Banner::show /NOUNLOAD "Installing Visual C++ 2010 Redistributable"
!if ${CPU} = "x64"
File /r "${INSTALLER_OUTPUT}\vcredist_2010_x64.exe"
ExecWait '"$OUTDIR\vcredist_2010_x64.exe" /passive /norestart'
@@ -104,6 +107,7 @@
File /r "${INSTALLER_OUTPUT}\vcredist_2010_x86.exe"
ExecWait '"$OUTDIR\vcredist_2010_x86.exe" /passive /norestart'
!endif
+ Banner::destroy
BeginInstall:
Banner::show /NOUNLOAD "Extracting files. Please Wait"
Modified: trunk/Installer/Installers/MapGuide/MapGuide.wxs
--- trunk/Installer/Installers/MapGuide/MapGuide.wxs 2012-04-11 15:07:57 UTC (rev 6569)
+++ trunk/Installer/Installers/MapGuide/MapGuide.wxs 2012-04-11 16:45:51 UTC (rev 6570)
@@ -497,6 +497,8 @@
<Publish Dialog="WebServerConfigDlgIIS" Control="Next" Event="Remove" Value="WebExtMapViewerJSPFeature" Order="12">MGWEB_CONFIG="IIS"</Publish>
<Publish Dialog="WebServerConfigDlgIIS" Control="Next" Event="Remove" Value="WebExtJavaDevGuideSamplesFeature" Order="13">MGWEB_CONFIG="IIS"</Publish>
<Publish Dialog="WebServerConfigDlgIIS" Control="Next" Event="Remove" Value="WebExtJavaViewerSampleFeature" Order="14">MGWEB_CONFIG="IIS"</Publish>
+ <Publish Dialog="WebServerConfigDlgIIS" Control="Next" Event="Remove" Value="WebExtPhpDevGuideSamplesFeature">MGWEB_CONFIG="IIS"</Publish>
+ <Publish Dialog="WebServerConfigDlgIIS" Control="Next" Event="Remove" Value="WebExtPhpViewerSampleFeature">MGWEB_CONFIG="IIS"</Publish>
<Publish Dialog="WebServerConfigDlgIIS" Control="Next" Event="NewDialog" Value="IPConfigDlg" Order="13">MGWEB_CONFIG="MANUAL"</Publish>
<Publish Dialog="WebServerConfigDlgIIS" Control="Back" Event="NewDialog" Value="LicenseAgreementDlg">1</Publish>
<Publish Dialog="WebServerConfigDlgIIS" Control="Cancel" Event="SpawnDialog" Value="CancelDlg">1</Publish>
@@ -516,7 +518,7 @@
<Publish Dialog="WebServerConfigDlgNoIIS" Control="Next" Event="Remove" Value="FdoArcSdeProviderFeature" Order="3">1</Publish>
<Publish Dialog="WebServerConfigDlgNoIIS" Control="Next" Event="Remove" Value="FdoKingOracleProviderFeature" Order="4">1</Publish>
<Publish Dialog="WebServerConfigDlgNoIIS" Control="Next" Event="Remove" Value="FdoMySqlProviderFeature" Order="5">1</Publish>
- <Publish Dialog="WebServerConfigDlgNoIIS" Control="Next" Event="Remove" Value="FdoPostGisProviderFeature" Order="6">1</Publish>
+ <Publish Dialog="WebServerConfigDlgNoIIS" Control="Next" Event="Remove" Value="FdoPostgreSqlProviderFeature" Order="6">1</Publish>
<!-- If Apache, set feature default for the ASPX viewer to not install -->
Turn off:
@@ -842,12 +844,15 @@
<Custom
Action="StartApacheServiceCA"
After="InstallApacheServiceCA">MGWEB_CONFIG="APACHE" AND &WebExtApacheFeature>2</Custom>
+ <!-- Something's wrong with the Tomcat actions. So disable them for now -->
<Custom
Action="InstallTomcatServiceCA"
Before="InstallFinalize">MGWEB_CONFIG="APACHE" AND &WebExtTomcatFeature>2</Custom>
<Custom
Action="StartTomcatServiceCA"
Before="InstallTomcatServiceCA">MGWEB_CONFIG="APACHE" AND &WebExtTomcatFeature>2</Custom>
<Custom
Action="MgServerInstallCA"
Before="InstallFinalize">&ServerFeature>2</Custom>
Modified: trunk/Installer/Libraries/MapGuide Server/InstallService.wxs
--- trunk/Installer/Libraries/MapGuide Server/InstallService.wxs 2012-04-11 15:07:57 UTC (rev 6569)
+++ trunk/Installer/Libraries/MapGuide Server/InstallService.wxs 2012-04-11 16:45:51 UTC (rev 6570)
@@ -1,7 +1,11 @@
<?xml version="1.0" encoding="utf-8"?>
<Wix xmlns="http://schemas.microsoft.com/wix/2006/wi">
<!-- mgserver.exe -->
+ <?if "$(var.MgPlatform)" = "x64" ?>
+ <?define MGSERVER_MAP = "file_SRVBINFILES_23" ?>
+ <?else ?>
<?define MGSERVER_MAP = "file_SRVBINFILES_26" ?>
+ <?endif ?>
<Fragment>
<CustomAction
More information about the mapguide-commits
