[mapguide-commits] r6580 - trunk/Installer/scripts
svn_mapguide at osgeo.org
Thu Apr 19 12:56:15 EDT 2012
Author: jng
Date: 2012-04-19 09:56:15 -0700 (Thu, 19 Apr 2012)
New Revision: 6580
Added:
trunk/Installer/scripts/build_oem_ubuntu.sh
trunk/Installer/scripts/setvars.sh
trunk/Installer/scripts/build.sh
trunk/Installer/scripts/dpkgmapguide.sh
Update linux build scripts for Ubuntu 11.10 and greater flexibility
Modified: trunk/Installer/scripts/build.sh
--- trunk/Installer/scripts/build.sh 2012-04-19 16:09:38 UTC (rev 6579)
+++ trunk/Installer/scripts/build.sh 2012-04-19 16:56:15 UTC (rev 6580)
@@ -1,22 +1,28 @@
#!/bin/bash
-APIVERSION=2.3
-BUILDNUM=${APIVERSION}.0
-BUILDROOT=`pwd`
-INSTALLROOT=/usr/local/mapguideopensource-${BUILDNUM}
-LOCKFILEDIR=/var/lock/mgserver
-MGSOURCE=${BUILDROOT}/mgdev
-VERFILE=${MGSOURCE}/Common/ProductVersion.h
-SVNROOT="svn://svn.bld.mgproto.net"
-#SVNROOT="http://svn.osgeo.org"
-rm -rf ${MGSOURCE}
-rm -rf ${INSTALLROOT}
+# Make sure setvars.sh is called first before running this script
+if [ ! -d ${JAVA_HOME} ];
+then
+echo "ERROR: Environment variable JAVA_HOME not set. Please set this enviroment variable first"
+exit
+fi
+sudo rm -rf ${MGSOURCE}
+sudo rm -rf ${INSTALLROOT}
REVISION=`svn info ${SVNROOT}/mapguide/trunk/MgDev | perl revnum.pl`
echo ${REVISION} > revnum.txt
+echo "Exporting svn revision ${REVISION}"
+if [ ${LOCALSVN} = 1 ]
+then
+ echo "Making local SVN copy to ${MGSOURCE}"
+ cp -R ${SVNROOT}/mapguide/trunk/MgDev ${MGSOURCE}
+else
+ echo "Performing fresh SVN export to ${MGSOURCE}"
+ svn export -q -r ${REVISION} ${SVNROOT}/mapguide/trunk/MgDev ${MGSOURCE}
+fi
echo "Building Revision ${BUILDNUM}.${REVISION}"
-svn export -q -r ${REVISION} ${SVNROOT}/mapguide/trunk/MgDev ${MGSOURCE}
cd ${MGSOURCE}
echo "#ifndef PRODUCTVERSION_H_" > ${VERFILE}
@@ -25,48 +31,71 @@
echo 'const STRING ApiVersion = L"'${APIVERSION}'";' >> ${VERFILE}
echo '#endif' >> ${VERFILE}
+echo "Building LinuxApt"
pushd ${MGSOURCE}/Oem/LinuxApt
-./build_apt.sh --prefix ${INSTALLROOT} --with-tomcat
+sudo ./build_apt.sh --prefix ${INSTALLROOT} --with-tomcat
popd
-./build_oem.sh --prefix=${INSTALLROOT}
+echo "Building Oem"
+# Need an ubuntu-flavoured build_oem.sh if we're doing ubuntu
+if [ ${UBUNTU} = 1 ]
+then
+ cp ${BUILDROOT}/build_oem_ubuntu.sh .
+ chmod +x build_oem_ubuntu.sh
+ sudo ./build_oem_ubuntu.sh --prefix=${INSTALLROOT}
+else
+ sudo ./build_oem.sh --prefix=${INSTALLROOT}
+fi
+echo "Building Fusion"
pushd ${MGSOURCE}/Oem/fusion
ant prepare
ant compress
popd
+echo "Building MapGuide"
aclocal
libtoolize --force
automake --add-missing --copy
autoconf
./configure --enable-optimized --prefix=${INSTALLROOT}
-make
-make install
+make $MY_MAKE_OPTS
+sudo make install
+echo "Preparing binaries for packaging"
# Prepare binaries for packaging by removing unnecessary
# .la and .a files and stripping unneeded symbols from the binaries
pushd ${INSTALLROOT}
LIBDIRS="lib server/lib webserverextensions/lib"
+echo "Stripping symbols from binaries"
for libdir in ${LIBDIRS}
do
- # Remove any .la and .a files in lib directories
- rm -f ${libdir}/*.la
- rm -f ${libdir}/*.a
+ # Remove any .la and .a files in lib directories
+ sudo rm -f ${libdir}/*.la
+ sudo rm -f ${libdir}/*.a
- # Remove unneeded symbols from files in the lib directories
- for file in `find ${libdir}/lib*.so* -type f -print`
- do
- strip --strip-unneeded ${file}
- chmod a-x ${file}
- done
+ # Remove unneeded symbols from files in the lib directories
+ for file in `find ${libdir}/lib*.so* -type f -print`
+ do
+ sudo strip --strip-unneeded ${file}
+ sudo chmod a-x ${file}
+ done
done
+then
+ echo "Stripping out .svn directories"
+ # Empty out all .svn directories
+ find -name "\.svn" -exec sudo rm -rf {} \;
+fi
popd
+echo "Creating MapGuide Open Source binary tarball"
# Tarball the whole works and put it in a bin directory
pushd ${BUILDROOT}
if [ ! -d bin ]; then
- mkdir -p bin
+ mkdir -p bin
fi
-tar -zcf bin/mapguideopensource-${BUILDNUM}.${REVISION}.tar.gz ${INSTALLROOT} ${LOCKFILEDIR}
-popd
+sudo tar -zcf bin/mapguideopensource-${BUILDNUM}.${REVISION}.tar.gz ${INSTALLROOT} ${LOCKFILEDIR}
+echo "Build complete!"
Added: trunk/Installer/scripts/build_oem_ubuntu.sh
--- trunk/Installer/scripts/build_oem_ubuntu.sh (rev 0)
+++ trunk/Installer/scripts/build_oem_ubuntu.sh 2012-04-19 16:56:15 UTC (rev 6580)
@@ -0,0 +1,612 @@
+#! /bin/bash
+# MapGuide Open Source build script (tweaked for Ubuntu)
+# Initialization
+echo "MapGuide Open Source build script for OEM components"
+INSTALLDIR=/usr/local/mapguideopensource-2.4.0
+MY_MAKE_OPTS="-j 4"
+CLEAN_FLAG=0
+while [ $# -gt 0 ]; do # Until you run out of parameters...
+ case "$1" in
+ -prefix|--prefix)
+ INSTALLDIR="$2"
+ shift
+ -clean|--clean)
+ CLEAN_FLAG=1
+ shift
+ -help|--help)
+ echo "Usage: $0 (options)"
+ echo "Options:"
+ echo " --prefix [installation directory]"
+ echo " --clean [clean all objects and binaries in Oem]"
+ echo " --help [Display usage]"
+ exit
+ esac
+ shift # Check next set of parameters.
+done
+echo "OEM Build Initialization ............................"
+echo "Oem Libraries will be installed at: ${INSTALLDIR}"
+LIB_NAME=""
+# Generic Functions
+check_build()
+ error=$?
+ if [ $error -ne 0 ]; then
+ echo "$LIB_NAME: Error build failed ($error)................."
+ exit $error
+ fi
+check_clean()
+ error=$?
+ echo "$LIB_NAME: Error clean failed ($error)................."
+ exit $error
+ fi
+# Build ACE 5.7
+# Notes: none
+init_ace()
+ LIB_NAME="ACE 5.7"
+build_ace()
+ pushd ACE/ACE_wrappers
+ ACE_PATH="${PWD}"
+ pushd ace
+ env ACE_ROOT="${ACE_PATH}" make $MY_MAKE_OPTS
+ check_build
+ popd
+ popd
+clean_ace()
+ ACE_PATH="${PWD}"
+ pushd ace
+ env ACE_ROOT="${ACE_PATH}" make clean
+ check_clean
+ popd
+ popd
+# Build DWFCORE 1.0
+# Notes: none
+init_dwfcore()
+ LIB_NAME="DWFCORE 1.0"
+ pushd DWFTK7.1/develop/global/build/gnu/dwfcore
+ sh ./build_setup.sh
+ popd
+build_dwfcore()
+ pushd DWFTK7.1/develop/global/src/dwfcore
+ sh ./configure --enable-optimized --prefix="${INSTALLDIR}"
+ make $MY_MAKE_OPTS
+ check_build
+ popd
+clean_dwfcore()
+ make clean
+ check_clean
+ popd
+# Build DWFTOOLKIT 7.1
+# Notes: none
+init_dwftk()
+ LIB_NAME="DWFTK 7.1"
+ pushd DWFTK7.1/develop/global/build/gnu/dwftoolkit
+ popd
+build_dwftk()
+ check_build
+ popd
+clean_dwftk()
+ make clean
+ check_clean
+ popd
+# Build DWFEMAP 1.0
+# Notes: none
+init_dwfemap()
+ LIB_NAME="DWFEMAP 1.0"
+ pushd DWFTK7.1/develop/global/build/gnu/dwfemap
+ popd
+build_dwfemap()
+ pushd DWFTK7.1/develop/global/src/dwfemap
+ check_build
+ popd
+clean_dwfemap()
+ make clean
+ check_clean
+ popd
+# Build GEOS 2.2.0
+# Notes: none
+init_geos()
+ LIB_NAME="GEOS 2.2.0"
+build_geos()
+ pushd geos-2.2.0
+ # Force regen to take into account our modified configure.in
+ aclocal -I macros
+ libtoolize --copy --force
+ autoconf
+ automake --add-missing --copy --force-missing
+ sh ./configure --prefix="${INSTALLDIR}"
+ # The check build is disabled as the build will fail with automake version < 2.59
+ # check_build
+ popd
+clean_geos()
+ pushd geos-2.2.0
+ make clean
+ check_clean
+ popd
+# Build PHP 5.3.1
+# Notes: Configure PHP source tree for building PHP extension
+init_php()
+ LIB_NAME="PHP 5.3.1"
+build_php()
+ pushd php
+ sh ./configure
+ check_build
+ popd
+clean_php()
+ pushd php
+ make distclean
+ check_clean
+ popd
+# Build SWIGEx 1.0
+# Notes: none
+init_swigex()
+ LIB_NAME="SWIGEx 1.0"
+build_swigex()
+ pushd SWIGEx
+ mkdir -p Linux/obj/release
+ check_build
+ popd
+clean_swigex()
+ pushd SWIGEx
+ # Note: the qmake system is required to regenerate the Makefile.
+ # This is disabled.
+ # make clean
+ # check_clean
+ popd
+# Build BDBXML
+# Notes: none
+init_bdbxml()
+ LIB_NAME="BDBXML"
+build_bdbxml()
+ # Need to force regen of the correct xerces config header before building dbxml proper
+ pushd dbxml/xerces-c-src
+ sh ./configure
+ popd
+ # Also need to check and set executable flag for s_paths
+ pushd dbxml/dbxml/dist
+ chmod +x s_paths
+ popd
+ pushd dbxml
+ sh ./buildall.sh
+ check_build
+ popd
+clean_bdbxml()
+ pushd dbxml
+ sh ./buildall.sh --clean
+ check_clean
+ popd
+# Build CPPUNIT 1.9.14
+# Notes: none
+init_cppunit()
+ LIB_NAME="CPPUNIT 1.9.14"
+build_cppunit()
+ pushd CppUnit-1.9.14
+ # the configure script as-is is incompatible with ubuntu, so regen it
+ aclocal -I config
+ autoconf
+ # -ldl is to prevent undefined reference to dlsym/dlopen/dlclose
+ sh ./configure --prefix="${INSTALLDIR}" LDFLAGS="-ldl"
+ check_build
+ popd
+clean_cppunit()
+ make clean
+ check_clean
+ popd
+# Build IMake 1.0
+# Notes: none
+init_imake()
+ LIB_NAME="IMake 1.0"
+build_imake()
+ pushd ../BuildTools/WebTools/IMake
+ mkdir -p Linux/obj/debug
+ check_build
+ popd
+clean_imake()
+ # Note: does not support clean as qmake is needed to regenerate the Makefile.
+ # make clean
+ # check_clean
+ popd
+# Build ZLIB 1.2.3
+# Notes: none
+init_zlib()
+ LIB_NAME="ZLIB 1.2.3"
+build_zlib()
+ pushd gd/zlib
+ sh ./configure
+ check_build
+ popd
+clean_zlib()
+ pushd gd/zlib
+ make clean
+ check_clean
+ popd
+# Build LIBPNG 1.2.8
+# Notes: none
+init_libpng()
+ LIB_NAME="LIBPNG 1.2.8"
+build_libpng()
+ pushd gd/lpng
+ cp scripts/makefile.std makefile
+ check_build
+ popd
+clean_libpng()
+ pushd gd/lpng
+ make clean
+ check_clean
+ popd
+# Build JPEG 6b
+# Notes: none
+init_jpeg()
+ LIB_NAME="JPEG 6b"
+build_jpeg()
+ pushd gd/jpeg
+ sh ./configure --enable-static --disable-shared
+ check_build
+ popd
+clean_jpeg()
+ pushd gd/jpeg
+ make clean
+ check_clean
+ popd
+# Build FREETYPE 2.1.10
+# Notes: none
+init_freetype()
+ LIB_NAME="FREETYPE 2.1.10"
+build_freetype()
+ pushd gd/freetype
+ check_build
+ popd
+clean_freetype()
+ pushd gd/freetype
+ make clean
+ check_clean
+ popd
+# Build GD 2.0.33
+# Notes: none
+init_gd()
+ LIB_NAME="GD 2.0.33"
+build_gd()
+ pushd gd/gd
+ sh ./configure --enable-static --disable-shared --without-fontconfig
+ check_build
+ popd
+clean_gd()
+ pushd gd/gd
+ make clean
+ check_clean
+ popd
+# Build AGG 2.4
+# Notes: none
+init_agg()
+ LIB_NAME="AGG 2.4"
+build_agg()
+ pushd agg-2.4
+ check_build
+ popd
+clean_agg()
+ pushd agg-2.4
+ make clean
+ check_clean
+ popd
+# Build JSON
+# Notes: none
+init_json()
+ LIB_NAME="JSON"
+build_json()
+ pushd jsoncpp
+ #Use the scons installed by apt-get
+ scons platform=linux-gcc
+ popd
+clean_json()
+ pushd jsoncpp
+ rm -rf lib buildscons dist
+ popd
+# Build CSMAP
+# Notes: none
+init_csmap()
+ LIB_NAME="CSMAP"
+build_csmap()
+ pushd CsMap
+ mkdir -p .libs
+ pushd Source
+ make -fLibrary.mak $MY_MAKE_OPTS
+ cp CsMap.a ../.libs/libCsmap.a
+ popd
+ pushd Dictionaries
+ make -fCompiler.mak $MY_MAKE_OPTS
+ ./CS_Comp -b . .
+ popd
+ check_build
+ popd
+clean_csmap()
+ pushd CsMap
+ make clean
+ check_clean
+ popd
+# Script loop
+pushd Oem
+for lib in ace dwfcore dwftk dwfemap geos php swigex bdbxml cppunit imake zlib libpng jpeg freetype gd agg json csmap;
+do
+ echo "$lib: Initialization..........................."
+ init_"$lib"
+ if test "$CLEAN_FLAG" = "1"; then
+ echo "$lib: Clean ....................................."
+ clean_"$lib"
+ echo "$lib: Clean Successful .........................."
+ else
+ echo "$lib: Configure/Build ..........................."
+ build_"$lib"
+ echo "$lib: Build Successful .........................."
+ fi
+done
+popd
Property changes on: trunk/Installer/scripts/build_oem_ubuntu.sh
___________________________________________________________________
Added: svn:executable
Modified: trunk/Installer/scripts/dpkgmapguide.sh
--- trunk/Installer/scripts/dpkgmapguide.sh 2012-04-19 16:09:38 UTC (rev 6579)
+++ trunk/Installer/scripts/dpkgmapguide.sh 2012-04-19 16:56:15 UTC (rev 6580)
@@ -6,31 +6,33 @@
# changelog - generated changelog file
# substvars - subst params created by dpkg-shlibdeps
# mapguidecommon/ - packaging directory for common MapGuide components
-# usr/local/mapguideopensource-2.2.0/ - copied tree for common components
+# usr/local/mapguideopensource-2.4.0/ - copied tree for common components
# DEBIAN/
# control - control file generated from dpkg-gencontrol
# symbols - symbols file generated from dpkg-gensymbols
# mapguideserver/ - packaging directory for MapGuide Server
-# usr/local/mapguideopensource-2.2.0/ - copied tree for Server
+# usr/local/mapguideopensource-2.4.0/ - copied tree for Server
# DEBIAN/
# mapguidewebextensions/ - packaging directory for Web Extensions
-# usr/local/mapguideopensource-2.2.0/ - copied tree for Web Extensions
+# usr/local/mapguideopensource-2.4.0/ - copied tree for Web Extensions
# DEBIAN/
# mapguidehttpd/ - packaging directory for Apache Bundle
-# usr/local/mapguideopensource-2.2.0/ - copied tree for Apache bundle
+# usr/local/mapguideopensource-2.4.0/ - copied tree for Apache bundle
# DEBIAN/
BUILDROOT=`pwd`
-MGBUILD=2.2.0
+MGBUILD=${BUILDNUM}
MGINST=usr/local/mapguideopensource-${MGBUILD}
ROOT=${BUILDROOT}/debian/mapguidecommon
TREE=${BUILDROOT}/debian
@@ -124,7 +126,7 @@
cat > debian/changelog <<END-OF-CHANGELOG
mapguideopensource-src (${MGBUILD}-${BUILDNUM}) experimental; urgency=low
- * 2.2.0 Release Candidate 1
+ * ${BUILDNUM}
-- MapGuide Internals Mail List <mapguide-internals at lists.osgeo.org> ${CURRTIME}
END-OF-CHANGELOG
Added: trunk/Installer/scripts/setvars.sh
--- trunk/Installer/scripts/setvars.sh (rev 0)
+++ trunk/Installer/scripts/setvars.sh 2012-04-19 16:56:15 UTC (rev 6580)
@@ -0,0 +1,19 @@
+#!/bin/bash
+# Sets the common set of vars used throughout these build scripts
+export APIVERSION=2.4
+export BUILDNUM=${APIVERSION}.0
+export BUILDROOT=`pwd`
+export INSTALLROOT=/usr/local/mapguideopensource-${BUILDNUM}
+export LOCKFILEDIR=/var/lock/mgserver
+export MGSOURCE=${BUILDROOT}/mgdev
+export VERFILE=${MGSOURCE}/Common/ProductVersion.h
+# Use LOCALSVN=1 if you want to build from an existing copy instead of building
+# from an export
+export LOCALSVN=1
+export SVNROOT=/home/user
+#export SVNROOT="svn://svn.bld.mgproto.net"
+#export SVNROOT="http://svn.osgeo.org"
+export MY_MAKE_OPTS="-j 4"
+export UBUNTU=1
Property changes on: trunk/Installer/scripts/setvars.sh
More information about the mapguide-commits
